 Old 12-03-2009, 09:47 AM   #281
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Under closer inspection this morning before coming to work, it looks like there is quite a bit of room between the bottom of the threaded valve, and the bottom of the threaded rail hole. There is a slight discoloration where it looks like the valve threads in only so far.
Now we may need a thicker restrictor disc to keep it from rattling around between rail face and valve face.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 12-03-2009, 10:14 AM   #282
Deadman's Avatar
Posts: 868   (View Stats)
if i had the pieces in hand i could have a disc turned down to the exact size (slip fit) and boom all done. measurements?! :p
Deadman is offline
 Old 12-03-2009, 10:24 AM   #283
masskaos's Avatar
Posts: 262   (View Stats)
masskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond repute
thicker = great idea.
it would suck to have the orifice bend or crack.
masskaos is offline
 Old 12-03-2009, 10:28 AM   #284
throw some putty on the spare rail and thread the valve in Dustin and see how much room you have to play with.
Lex is offline
 Old 12-03-2009, 10:41 AM   #285
Captain
I'll bring my calipers home tonight and measure the depth of the rail and valve.
The rail side is concave, like a inward dome. You can kinda tell from the pics i posted above.
Putty is a great idea too. Kinda like a pseudo mold, lol.
Fuckin hate the double post merge, but oh well.
Here's the drawing:
You can see there is a 0.4395 to 0.5155 inch gap between the nozzle and end of the threaded bore.
Here's valve diameter:
And valve pitch:
If anyone wants to bump this post to notify people, feel free
www.permtuning.com
 Old 12-03-2009, 09:35 PM   #286
mkriebs's Avatar
Posts: 198   (View Stats)
mkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the worldmkriebs is the leader of the world
I'll bump it, lol. Looks like progress is coming along well. I hope you all well, and I will continue to sneak behind the scenes and steal some ideas from your platforms. Us Cobalt Owners appreciate it!
mkriebs is offline
 Old 12-04-2009, 12:46 AM   #287
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
When you measure threads, try to measure from one point on one thread, to the exact same point on the next.
In that picture it looks like you are measuring from the outside of the crests.
I've been looking at thread charts and I can't seem to find a M12 with that pitch. At least not a standard pitch.
There are:
M12x1.75 (Coarse)
M12x1.50 (Fine 1)
M12x1.25 (Fine 2)
M12x1.00 (Fine 3)
I think we are dealing with the M12 Fine#3 (M12x1.00). Which is unfortunate because it is the most uncommon M12 thread pitch. The common M12 is the coarse one (M12x1.75).
Also, after looking closely at the valve; The chamfer that was being discussed is just a lead-in for the thread.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline
 Old 12-04-2009, 02:12 AM   #288
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
bump...dont take a dump...bump bump
SpeedSixxx is offline
 Old 12-04-2009, 09:30 AM   #289
Captain
....M12x1.00 (Fine 3)
Haha, i was trying measure from a common point lol. Definitely looks like a 1mm pitch though, which is indeed unfortunate. I emailed macmaster carr inquiring where in the hell to find a threaded rod with those dimensions. If it really comes down to it, it may be possible to just get a local machine shop to turn out a few for us. There's one guy close to my work who could definitely do this, and probably for cheap (he's a motor head too ).
I like the idea of a threaded restrictor pill, cause it would hold the pill stead in the rail and keep it from rattling around or anything.
Wish i could find this domestically:
12mm 12 x 1.0 Metric Die M12 x 1mm Pitch on eBay (end time 03-Jan-10 08:19:29 GMT)
Wish and ye shall receive:
12mm 12 x 1.0 Metric Die M12 x 1mm Pitch - eBay (item 110465777875 end time Jan-03-10 00:19:29 PST)
www.permtuning.com
 Old 12-04-2009, 12:39 PM   #290
phantom3's Avatar
Groans: 190
Lol... I just checked my tap & Die set... I actually have this die!
phantom3 is offline
 Old 12-04-2009, 12:43 PM   #291
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
Get some stock, thread it, cut it into proper thickness disks, and put like a flathead slot in it. and in the center of the disk, put the .060 hole.
socks is offline
 Old 12-04-2009, 12:58 PM   #292
Captain
Hell yeah, do it. Talk about an easy solution, lol, this is about as easy as it gets.
www.permtuning.com
 Old 12-04-2009, 01:05 PM   #293
phantom3's Avatar
Groans: 190
I'll see what I can come up with. I just check my drill set and my 1/16 is snapped.
phantom3 is offline
 Old 12-04-2009, 01:12 PM   #294
Captain
I might go buy a die set today. I took a half day cause i'm still feeling all f-d up.
www.permtuning.com
 Old 12-04-2009, 01:21 PM   #295
phantom3's Avatar
Groans: 190
DJ, can you send me a schematic or how to for the ckt? I'll make one up and get Andrew to run it with his AP and the fuel restrictor.
phantom3 is offline
 Old 12-04-2009, 01:28 PM   #296
Captain
Schematic is on the first page of this thread. Be sure to use an lm324 op amp.
Radio shack has everything you need to build it: op-amp, 10k linear pot (i used the lil blue one cause it fit nicely on the 0.1" center ckt board), several different flavors of through-hole circuit board you can use, and lil project boxes to put it in.
All the tap and die sets i see around here locally don't have that m12 x 1mm size. You must have a super set (which you prob do, lol). Any way you could built me up a restrictor? I'll happily paypal cost for materials + time + shipping .
www.permtuning.com
 Old 12-04-2009, 02:03 PM   #297
m4tic's Avatar
Posts: 4,928   (View Stats)
so am i trading for an evo or getting an ap for xmas :p
looks like good progress, this is exciting
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
m4tic is offline
 Old 12-04-2009, 02:04 PM   #298
SilverDemon's Avatar
Posts: 3,034   (View Stats)
M12x1 set screws, they come in all lengths, just drill what ever size hole you need in the center. If you have ever tried to thread round stock with out a lathe it is almost impossible to get the threads straight. In order to hold the set screw in place while the hole is drilled, thread two set screws into a nut, tighten them against each other, clamp it into a drill press and drill two at a time.
Edit: Scratch that, I thought metric set screws would come in the 1.0 thread, but I can not find them. Still might be better off starting with a bolt and modifying it to do want you want, instead of trying to thread round stock.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
SilverDemon is offline
 Old 12-04-2009, 02:52 PM   #299
Captain
Even the bolts are hard as hell to find.
www.permtuning.com
 Old 12-04-2009, 02:57 PM   #300
How many you need/want?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 12-04-2009, 02:57 PM   #301
Deadman's Avatar
try Home | Fastenal or http://www.memartin.net/
both companies we deal with through work.
EDIT:
dj im going to have this turned @ work on monday. I need to know how long it has to be ie.
| < insert inches > | i will pop a 1/16 hole in the center and send it to ya. If you get it done by then just lmk, and if not i don't think it will be a problem
Deadman is offline
 Old 12-04-2009, 03:54 PM   #302
JmkC's Avatar
Posts: 871   (View Stats)
JmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the world
Groans: 109
haha i like how you just volunteer him
JmkC is offline
 Old 12-04-2009, 06:28 PM   #303
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
Originally Posted by Deadman View Post
try Home | Fastenal or Untitled Document
EDIT:
andrew were going to work TOMM and getting this shit done haha we can install same day
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
 Old 12-04-2009, 06:44 PM   #304
Captain
EDIT:
Hell yeah! The gap between the end of the valve and the beginning of the angled portion of the bore is about 0.4395", but there is no need to make it exact imo. I say make it like 3/8" long or so.
Also if you want to make a handful or so, i think alot of people would be happy!!!
PM me your paypal so i can pay for the time+material+shipping and huge thanks man!
Also, like Sean said, it'd be rad if you could slot one end of it so we can thread it in with a screw driver or something.
www.permtuning.com
 Old 12-04-2009, 06:47 PM   #305
mkriebs's Avatar
You guys are doing amazing work with little resources! Way to step up guys. I wish the Cobalt community was more like this!
You almost have me considering a MSP6, lol.
mkriebs is offline
 Old 12-04-2009, 07:58 PM   #306
tmtbiker's Avatar
Posts: 287   (View Stats)
tmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the worldtmtbiker is the leader of the world
These guys are doing amazing work, no doubt about it. You have no idea what the community has been through to get to this point, though.
As 'loosh would say.."if you only knew...."
Originally Posted by huffentuff09 View Post
Some Dude with bike in his name from FLA don't like my pointless posts..
tmtbiker is offline
 Old 12-04-2009, 08:53 PM   #307
Fuck that cocksucker...
Haltech is offline
 Old 12-05-2009, 09:36 AM   #308
Deadman's Avatar
ya ill put a slot in it for a flathead. Ill have them made 3/8" long (ill make one about .01 - .02 under the length you measured)
Ill have him part out as many as he can off the piece of stock we use. DJ anything in particular ie. bronze, aluminum, steel.. hot roll? cold roll? ha lmk
Deadman is offline
 Old 12-05-2009, 10:39 AM   #309
Captain
Well it'll be exposed to gas at a very high pressure (and prob fairly high temp), so it needs be pretty corrosive resistant.
I guess the fuel rail is made of aluminum, and the valve is bronze... Hmmm, i may not be the right person to ask about this lol. I say bronze cause it looks cool .
www.permtuning.com
 Old 12-05-2009, 02:30 PM   #310
Do not make it out of similar metals, the threads will lock together. Make them out of non-corrosive dis-similar metals, for example brass, or 300 series stainless.
This is how I went about making the part. A stainless M8 SHCS has a head that measures just about 12 mm on the dot, I chucked it into the lathe and cut the threads on the head of the bolt, since it already has a hex in the end I can skip the step cutting a slot for a screwdriver. After I cut the threads I drilled the .060" port through the head, then parted off the head of the bolt. The finished restrictor measures .290"
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 12-05-2009, 02:53 PM   #311
socks's Avatar
Groans: 125
rock on! hole is a lil big eh?
socks is offline
 Old 12-05-2009, 03:08 PM   #312
It's between .060 - .070"
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 12-05-2009, 03:23 PM   #313
Captain
How many can you make? Thanks for that tip!
Between you and dead man, i think we'll be able to at least satisfy the need for all the beta testers .
www.permtuning.com
 Old 12-05-2009, 03:36 PM   #314
SpeedSixxx's Avatar
Groans: 778
this guy corbs is interested in using it if you or anyone else can make another..
he has speed 3...intake, tip, tbe, cobb ap, ptp hpfp and other mods...
he is interested in it and is prolly willing to install and dyno tune with atr.
i sent him the link to this and he will be reading over everything.
 Old 12-05-2009, 05:01 PM   #315
I asked yesterday how many was needed or wanted, but no one responded (I do not think I ever saw or at least remember how many people received the beta circuit). I generally do not get time on the machines until the weekend, so it will be at least another week (if I get to work on the weekend) until I can make any more.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 12-05-2009, 05:02 PM   #316
spnkr21's Avatar
Posts: 2,827   (View Stats)
If someone wants to send me a restrictor I'll take one. I'm running standback so won't need the djckt. Lemme know! Cost?
spnkr21 is offline
 Old 12-05-2009, 05:47 PM   #317
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
My results will be pretty useless for you guys, but I'll take a restrictor as well....
SSinstaller is offline
 Old 12-05-2009, 08:20 PM   #318
Captain
LOL, sorry man if you felt ignored, this thread has been moving along quite fast. I sent out 5 ckt's total, including myself that's 6. I think deadman will prob make a few as well, but honestly i think the more the merrier, cause AFAIK, they are just as needed for the SB guys as they are for us djckt guys.
I wouldn't make more than 10 though honestly. Who knows if the hole size needs to change yet. It's still alot of speculation that 60-70 thousandths will be small enough. We'll see.
I don't think any of these results are worthless. The basic principle behind both methods is the same, simply increased rail pressure, and how far it will take us. Just keep us posted with your findings!
www.permtuning.com
 Old 12-05-2009, 08:30 PM   #319
No Worries!! I will wait and see what size will work the best before I make a batch of them. One thing I would like to see is a thread pitch gauge on the sensor just to make sure this is the right pitch. Last thing I want is to get one of these cross threaded in the fuel rail.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 12-07-2009, 11:54 AM   #320
m4tic's Avatar
this thread has not been updated in 2 days wtfwtfwtfwtfwtf
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 08-02-2019 11:09 PM
TIRE PRESSURE SENSOR... redneckrecon MazdaSpeed 3/6 - Wheels & Tires 12 01-21-2011 07:23 PM
How to scale the HPFP pressure sensor djuosnteisn MazdaSpeed 3/6 - ECU Computer Tuning 521 04-07-2010 08:39 AM
Page generated in 0.58226 seconds with 36 queries
