![]() | | #81 | ![]() |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| The result...well...mixed at best. I'm seeing KR up to 5.5 in the 1.6-1.8 load range, and between 4700 and 5700rpm. On my latest map I forgot to enable the knock sensor above 5700, so I'm assuming/extrapolating that it continued to knock up near the redline as well. My map is based on a 91 Octane Stage 1, CpN OTS map from Cobb, but I've tweaked Boost, AFR, and timing per Abilor's/Bucker's guides. This is the first time I've seen this much knock at WOT, so I'm wondering if you guys think it might be transitory (spark plugs, bad gas, etc...), or something a little more serious. Apologies in advance for the log. I took the knocking portions of my long-ass log and dumped them into a single CSV file with each separate occurrence separated by a single line gap. Thanks in advance for any insights you might have! EDIT: For anyone looking for an example of what not to do, check my log. I believe that my knock was real, but related to a few pretty easy-to-fix things (please let me know if I'm wrong). 1) I was running significantly too much timing in the mid-upper rev range given my modest mods. 2) BATs were reasonably high (100*-120*) 3) IAT was reasonably high as well (that's what I get for having an SRI). At any rate, I flashed to a map with significantly less aggressive timing and now things are running more or less perfectly again (0-.35* knock), and on my last log, I made about 25lb-ft more (though 10whp less) than the more aggressive map.
![]() | | #82 | ![]() |
![]() Join Date: Feb 2011 Location: Aurora, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,094
Groans: 39
| Not Ranked : 0 score
I NEED ANSWERS. I'm running a Stage 2 91 SF+TIH+IC. Side note: i did add some octane booster to this tank, so we will see.
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" | |
![]() | | #83 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score Yeah, i got DJ Look into that. then got a reevised map that looks much better now. I bearely See KRs now. I'll check what changed on that map and Update you.
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. |
![]() | | #84 | ![]() |
Groans: 39
| Not Ranked : 0 score Thanks man.
![]() | | #85 | ![]() |
![]() Join Date: Nov 2011 Location: San Diego, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
| Not Ranked : 0 score good thread @Lex. starting my tune from @atvfreek tomorrow for 50/50 (assuming he thought my logs looked good enough to warrant this). looking forward to meeting you finally in a few weeks for the SOCAL NATOR dyno day; ill keep ya posted on what i find in my new tune
__________________ 09 CWP MS3: COBB AP / MSD DH / AT HPFP / CPE SRI / CS TIP / CS BT-RH / M2 DP / CNT CBE / HKS BPV / EVO X / E85 PERM FREEKTUNE 330/38007 TGM MS6: COBB AP / JBR PP SRI/TIP/ JBR BT-RH / CS CBE / FORGE V1 / JBR RMM / H&R CO Stratified OTS 07 BM MS6: DREADNAUGHT / JUGGERNAUT / SU DMM*PMM*TMM / JBR RMM / BC CO / MAGNAFLOW CBE / JBR OCC / SURE BSD / PRODRIVE GC06-H ![]() Long Signature made especially for Micha |
![]() | | #86 | ![]() |
Groans: 39
Any in-site on this from the guru's?
![]() | | #87 | ![]() |
![]() | | #88 | ![]() |
| Not Ranked : 0 score If injector seals are a suspect of false KR, is there a specific portion of the rev band in which KR would be reported or is it random? |
![]() | | #89 | ![]() |
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score How much knock can these cars handle before causing damage? If timing is out causing knock of around 5* throughout WOT runs, can there be immediate engine damage?
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
![]() | | #90 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes there can be damage. The longer you are in those conditions the more likelihood for damage.
![]() | | #91 | ![]() |
![]() Join Date: Feb 2011 Location: Nellis AFB , NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 336
Groaned at 92 Times in 11 Posts
| Not Ranked : 0 score If i ever once logged KR over 2 in my car at any time during WOT, i would pull over, turn the car off, kneel down by the front driver side quarter panel, and quietly apologize to my 2.3 DISI until I was deemed forgiven by the car Gods.
__________________ --Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned -- |
| The Following User Says Thank You to x09MS3GT For This Useful Post: | CWP_MS3 (10-09-2014) |
![]() | | #92 | ![]() |
| Not Ranked : 0 score I wasn't out long, about 5 miles, consisting of a 3/4/5/6 4/5/6 and then slowly back home... Consistent knock in every run, every gear seeing around about 5 My normal timing is around 7, it was up around 20 this time however ![]() Hopefully no damage done
![]() | | #93 | ![]() |
![]() Join Date: Oct 2011 Location: brooklyn, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
| Not Ranked : 0 score hey im looking for a little help with my logs im seeing the last couple of days.. im on a stage 1 ots stock tune, only upgrade i have is kmd internals. my kr is all over the place. fuel pressure is good, my a/f ratios are a bit iffy as well.. it fluctuates from 11's to 12's.. im not sure whats going on, maybe one the tuning gurus on here can help me out.. |
![]() | | #94 | ![]() |
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() | | #95 | ![]() |
(Thread Starter) | Not Ranked : 0 score This was a bug with VT. Make sure you upgrade to 1.7.2
![]() | | #96 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| DISCUSS HERE: KR explained
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| KR explained | Lex | MazdaSpeed 3/6 - ECU Computer Tuning | 161 | 04-29-2015 10:07 AM |
| PID tuning explained | wassup61 | Mazdaspeed3/6 General Discussion | 7 | 03-21-2009 09:47 AM |
