(Thread Starter) | Not Ranked : 0 score 1. Spool up KR. Here you will see a bit of KR (anything under 1.0 I just take as a "we've reached the efficient point" sign). This is common and not to worry you if it dies down like it does here and does not exceed 2.0. Remember the ECU drops KR in steps over a certain period of time and you can see this here and in all logs. If the KR is dropping it means no more knock is detected and the ECU is returning the timing to the base table. Why in this log? Look at your BATs - they are higher than in other logs. 2. High RPM KR that is a result of mechanical noise/shifting. Again the same log you will see that over 6K RPM there is a 0.7-1.0 or so of KR creeping in. This is a sign of mechanical noise but at 0.7 it's not something to really worry about. Then take a look at the 2.1 value there before it goes to 0. That is where you let off the throttle and the motor moved in the engine bay causing again mechanical noise. This is very common - a fast spike just as you shift or right when you let go of the throttle. This is not knock - just the engine moving around in the engine bay - don't worry about this. You can decrease the sensitivity of the sensor in the high RPM region. However if it is very high KR (2-3+), you're either indeed detonating or have a VERY noisy engine (see comment below) If you see consistent high KR (5+ during WOT runs) and it is not due to timing or during shifting this is caused by other mechanical parts. Anything from a timing chain, to injector seals, to a bent rod. So keep an eye and diagnose this instead of trying to tune around it. Below is that turned out to be KR caused by a bent rod. As you can see it ramps right up to the max 5.95 and sits there regardless of timing (which drops into negative numbers). 3. Cold engine KR. When the car is not fully warmed up (even if the temperature gauge tells you it's fine) you may experience more KR than usual going up in the RPM range or under boost. This is because the engine internals have not reached operating temperature and expansion and are just noisier. Rule of thumb is to drive the car for at least 15 minutes before doing full WOT runs ... or to get an oil temperature gauge. Either way, if the car is cold, it's best to let it warm anyways before really getting on it so this KR serves as a friendly reminder.
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,160
Groans: 201
| Not Ranked : 0 score I officially propose we change Lex's username to "Professor Lex" and make him the wheelchair-bound, bald leader of the "Lex-Men."
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
![]() Join Date: May 2010 Location: Colorado Springs, CO 80915
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 921
| Not Ranked : 0 score @Lex my buddy just got back from getting his car tuned. He did like 20 runs with no knock and is now hitting 5.9. He says it does it all the time now. I told him to watch for what you stated. Hes going back in to get tuned again, so we'll see what happens.
__________________ 2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD 2012 Jeep Wrangler Unlimited Sport: Current DD |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score good shit, Lex. I mean, The Professor. :bows:
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() Join Date: Dec 2009 Location: Dublin, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 443
Groans: 54
| Not Ranked : 0 score fucking kr
__________________ Parting out! http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/ |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score So I've got a question, What temp should the oil be at to be considered "warmed up"?
__________________ TEAM LUXURY |
That is a very deep topic. If you have a gauge, consider the temperature you see after 20 minutes of normal driving warm. If you don't have a gauge, drive normally for the first 15-20 minutes without intentionally doing WOT pulls to redline.
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
I have both a pressure and temp guage. not knowing how accurate the pressure guage is before it warms up, when my engine is first started cold pressure is around 80 psi, if I was to drive right away it maxes out my guage. once the temp guage is 180ish degrees then I see 15-20 psi at idle and 60 psi driving. coolant temp gets hotter faster so when it reaches 180 the oil is normally 150 degrees. I usually drive off for wot runs once the coolant is 180 at least which is measurable in a cobb ap
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC | |
| Not Ranked : 0 score Once my coolant temp reaches 175*f, I no longer get part throttle or wot knock. (well, the type caused by low engine operating temp anyway). |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Miltron (06-10-2013) |
![]() Join Date: May 2011 Location: Sykesville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 539
| Not Ranked : 0 score Great write up, this should definitely be man a sticky. A lot of people are always asking about these cases of KR.
__________________ 2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03 FREEKTUNE |
![]() Join Date: Jun 2011 Location: Epping, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score Cruising knock has been driving my crazy! Car is great at WOT and thats what matters but god that can sure be annoying! ! I have seen it up to 8.1.
__________________ Cobb SRI Cobb BPV SURE TIP SURE RMM KMD Internals SU Test Pipe JBR Stage 2 FREEKTOONZ |
| Not Ranked : 0 score @Raider...can we get a sticky? |
![]() Join Date: Jan 2011 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 303
| Not Ranked : 0 score this is exactly the info i needed. thanks so much! |
| Not Ranked : 0 score I agree on sticky as well. Nice write up Lex! Tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
Groans: 278
| Not Ranked : 0 score s@Lex whats your theory on why it seems like 08.5 and 09 Speeds do no react well to FFS'ing?
Groans: 201
| Not Ranked : 0 score And btw folks -- them be MY logs lol. So my noobiness has been turned around into a learning experience for many. YAY! @Lex -- played with the 1.6 map a bit and had no KR over 1.4, even during a 0-60 pull. And what I did have fit both your categories above. Only took one log, so I'll send you more later in the week, when I'm awake enough to drive safely again.
| Not Ranked : 0 score Stuck...Ill reward op when I get a chance. |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Updated OP with bent rod KR.
![]() | | #20 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score so...you seem to explain everything but actual predetonation knock.....so what exactly does predetonation knock look like? |
![]() | | #21 | ![]() |
![]() Join Date: Aug 2011 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score @hank25 I agree with that cruising kr being annoying as hell. Totally fine during WOT but I consistently see 6.0 until the slightest load. timing chain issue? or nothing to worry about like I have heard/read a million times.
__________________ 2006 Mazdaspeed6: Cobb AP Stage 1 - Cobb SRI - ETS TMIC - OBX Testpipe - Corksport Catback - Mazdaspeed Coilovers - Sure RMM - TWM Stage 2 - ITV 22 - Varrstoen 2.2.1 - Hankook V2 Ventus. Anddd when the temperature is above 50 degrees: 2009 Ducati 848 |
![]() | | #22 | ![]() |
![]() Join Date: Feb 2010 Location: Lynn, MA
Rep Power: 3402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,058
Groans: 76
Groaned at 22 Times in 20 Posts
| Not Ranked : 0 score Ahhhh yes the good olll fucking cruising then look down at my AP and see 4.3kr for no god damn reason KR lol.....
__________________ 2006 Mazdaspeed 6 BNR S4 and supporting mods 2007 Mazdaspeed 3 Bolt on's and tune 2015 Taurus S.H.O Intake/Tune 2016 Ford Explorer Sport Stock |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Here is a log of some "real knock". You can see the kr, and then as it starts to put timing back in, it pulls more. Sometimes you will see this if you fill up at a shitty gas station or driving real hard when the tune is pretty aggresive. This happened to be after a hard shift. The kr is less than 2, so it's well within the pcm's capability of pulling timing. Sorry for just the log and no pic.
![]() | | #24 | ![]() |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
| Not Ranked : 0 score awesome thread
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" |
![]() | | #25 | ![]() |
![]() Join Date: Sep 2011 Location: Lexington Park, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,852
Groans: 165
| Not Ranked : 0 score @Lex Thank you for spelling this out clearly.
__________________ New....Camaro SS/RS Stocked out selling parts.2011 Black MS3 -GTX3071R , 38mm Tial Wastegate, CPE Exhaust Manifold, Cobb AP, HKS SSQV 4, Autotech Internals, JBR SSP & Bushings, JBR Fully mounted 88 duro, JBR OCC, JBR EGR delete, TWM M1Knob, H&R springs, Ultimate Racing Turbo back, NKG plugs, CP-E FMIC, big MAF, big TIP, Grimmspeed MBC, SPC Rear Camber Arms, JBR Sway bar. 2006 Jeep Wrangler -20 grand of Shit |
![]() | | #26 | ![]() |
![]() Join Date: Nov 2011 Location: Corona, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 220
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . | |
![]() | | #27 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Excellent write up!
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() | | #28 | ![]() |
| Not Ranked : 0 score excellent info lex, thanks!
![]() | | #29 | ![]() |
![]() Join Date: May 2009 Location: Calgary
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 892
![]() | | #30 | ![]() |
Also if you happen to fill up at a mom and pops gas station, and start getting kr that you haven't been getting. Just ride out that tank easy until you can refill at a known good station.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | ||
![]() | | #31 | ![]() |
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score any familiar characteristics of bent-rod knock? or does it just fall under the "engine noises" category? Awesome writeup that puts a little more mind at ease. Thanks.
__________________ |
![]() | | #32 | ![]() |
Groans: 201
![]() | | #33 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score Subbed.
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score The one I posted didn't. Not that he could tell at least. Car ran like this for 2 weeks before venting #4 in front of the mall.
![]() | | #36 | ![]() |
So many vented blocks during casual driving. I understand the idea that the damage has been done, but it is just crazy how people seem to vent the block @ low rpms. | |
![]() | | #37 | ![]() |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks | |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's probably just statistics. How much time do we spend at part throttle versus at WOT? Also it always seems to happen after a shift which we again do many times a day.
![]() | | #39 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score I'd say about 75% of the time, i get some kr less than one on my logs, usually right after spool at max boost, and it drops it in steps.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
![]() | | #40 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
| Not Ranked : 0 score Any thoughts on KR in a particular gear, I'm getting anywhere between 2-4KR @~4.5k but only in 5th gear@ WOT?? @Lex @rfinkle2
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! |
| Display Modes | |
| KR explained | Lex | MazdaSpeed 3/6 - ECU Computer Tuning | 161 | 04-29-2015 10:07 AM |
| PID tuning explained | wassup61 | Mazdaspeed3/6 General Discussion | 7 | 03-21-2009 09:47 AM |
