![]() | | #121 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
__________________ www.tunedbynishan.com | |
![]() | | #122 | ![]() |
![]() | | #123 | ![]() |
![]() Join Date: Nov 2010 Location: Dover, DE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 429
| Not Ranked : 0 score This is great! Thank you for this!
__________________ 2012 CWP MS3 w/ Tech Package Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder |
![]() | | #124 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not a problem. If you have any other questions, feel free to ask.
![]() | | #125 | ![]() |
![]() Join Date: Oct 2011 Location: Murrieta, CA
Rep Power: 2715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,575
| Not Ranked : 0 score If this was covered before, I apologize. I am looking for a consensus. 1. What is the target # and what is an acceptable #. (for example, anything less than .08 etc. with 0 being ideal.) Also, is there a oh crap moment? (If it is above 10.0 do a maf cal right now kind of thing) 2. Is a + or - number prefered if there are LTFT values. 3. Do you believe revisions are necessary? If so at what interval. 4. If someone is doing a cal, starting with + numbers, next revision they are -, and the third revision they are back in the +, what is the best course of action? Thanks a bunch in advance. This is a great tool! |
![]() | | #126 | ![]() |
2. They can be + or - (absolute value). The ECU will either be pulling fuel out (-) or adding fuel in (+). As long as your within + or - 3%, you have a good maf calibration. 3. What exactly do you mean? It usually takes a couple revisions until your MAF cal is nice and tight. If you add any intake flow mods, you will have to revise. 4. This can happen a lot. For example, someone might have a 4.7% LTFT. Then they take 4.7% out, and now they have a LTFT of -3.9%. And then they try to add 3.9% and the same thing happens. This is usually the cause of not putting enough miles on the car before taking a maf cal log. Also some people like to only add as much as they need..For example, if your LTFT is +4.7%, some people might add only 4% to the maf breakpoint in order to bring the LTFT's around 0.7%. That is another way of going about it. Takes some time and practice. Also make sure you have no leaks.
![]() | | #127 | ![]() |
Negative is probably preferred for the closed to open loop transition range. The thinking is the car will be biased rich as it transitions, thus being safer. It doesn't exactly work this way, but whatev, it's a good sentiment haha. Revisions are usually only necessary when hard parts change. I tend to leave them as is so I can identify significant variances caused by other issues. Again, 1 proper Cal is typically all it takes. [If you dick with vtcs or repair issues, this may not be true]. If you're doing a MAF Cal right, you won't have revisions with significant variance after. If you see big swings, you're likely trying to tune around a leak.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
![]() | | #128 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Discuss Here: MAF Calibration Tutorial
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/maf-calibration-tutorial-125204/ | ||||
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-03-2014 01:36 PM | |
| MAF Calibration Tutorial | ms3blackmica | MazdaSpeed 3/6 - ECU Computer Tuning | 301 | 04-09-2019 07:50 AM |
| Monterey: 2012 Pebble Beach Concept Car Lawn offers a tutorial in cars to come | Haltech | Automotive News | 0 | 08-19-2012 05:50 PM |
| AP maf calibration | buckeyepost | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 08-24-2011 10:20 AM |
