| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
(Thread Starter) | Neutral : +4 score If you have a larger than stock intake, you will develop a scalar first and THEN follow this tutorial. If you have a stock sized aftermarket intake, skip right to the videos. In order to develop a scalar for a larger than stock intake diameter, you must take the (New MAF Cross-Sectional Area) and divide (/) it by the (Stock MAF Cross Sectional Area). __________________________________________________ __________________________________________________ ______ You already know the cross section of the MAF housing is a circle and the area of a circle can is derived as (pi*r^2). Another derivation of this formula is (pi*d^2)/(4). When deviding the two cross sections, pi and all other constants will cancel. Therefor, all you need to do is take the square of the new MAF Diameter and divided it by the square of the stock MAF diameter. Simple as that. Example Scalar: You decide to upgrade to a 3" intake (76.2mm). The stock MAF housing is 66.5mm diamter (2.61811"). You can either convert millimeters to inches or inches to millimeters, the choice is yours. (76.2^2) / (66.5^2) = 1.313 Take 1.313 and multiply it by the entire MAF curve. Now you are ready to start your MAF Calibration. This is ONLY for vehicles with a larger than stock intake installed. This is only an example for a 3" intake. __________________________________________________ __________________________________________________ ______ ***Please be careful when performing WOT (Wide Open Throttle) logs. You will be breaking the law because of the speeds you will be accelerating to in 4th gear. Make sure your tires are in good condition, have adequite pressure, and that your car is aligned properly. Anything can go wrong at over 100 MPH and extra caution must be taken when logging these pulls. You are at your own risk when performing WOT logs and you must take every precaution before starting. For best results, watch in 720p HD and full screen and in the order they are placed. You can also download the zipfile to keep them on your computer and watch offline. Also i apologize for constantly coughing. I was still getting over having a sore throat from a cold. If you would like to know how i mounted my AP, you can visit this thread... http://www.mazdaspeedforum.org/forum/foru...ssport-121495/ Setting up your Accessport How to perform a closed loop MAF Cal Log How to analyze the data from your closed loop MAF Cal log and make the appropriate changes in AccessTuner Race Making Sure you do not have any dips in your MAF Curve! How to perform a WOT (Wide Open Throttle) Log How to analyze the data from your WOT MAF Cal log and make the appropriate changes in AccessTuner Race
__________________ www.tunedbynishan.com Last edited by Raider; 10-08-2012 at 06:06 AM. Reason: Updated 10-8-2012 per OP in OG thread |
| The Following 29 Users Say Thank You to ms3blackmica For This Useful Post: | 2eatV8everyday (06-28-2016), ABolewski (12-23-2012), Arnie1229 (12-22-2014), BlackFlag (01-25-2015), blicaspd3 (01-31-2015), BruhhWill (07-18-2013), Cheapspeed (11-30-2013), Dahouse702 (12-13-2012), Dark_Signal (02-07-2013), Dimenus (12-14-2012), Donut (03-13-2013), Fstrnyou (11-27-2016), GOAT (08-15-2014), Hush (01-01-2013), ihasmazda (12-21-2013), imoonpigs (11-11-2012), ItsNox (02-09-2014), lat0102 (10-26-2013), LumberJack (01-25-2013), MarcoAntonio (09-20-2014), mazdaspeed916 (10-07-2012), Mistersix (02-08-2013), ms6mil (07-12-2013), Rich990 (10-05-2012), RLam (03-05-2013), Roddiy (04-03-2013), some call me...Tim (02-24-2015), stockms3 (07-27-2013), Tres3 (09-03-2014) |
| POWERED BY POLSKA ![]() Join Date: Apr 2010 Location: Eagle, WI
Rep Power: 389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 948
Groans: 38
| Not Ranked : 0 score Good job, that should help some guys.
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED |
![]() Join Date: Feb 2012 Location: Gibsonville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score Great videos, Thanks man. I am saving now for an AP and these videos just solidified what I thought I needed to do when I finally started doing power mods and needed a MAF Cal. Videos are always so much help when showing people how to do things rather than trying to explain how to do it. I wish everyone on this site, when doing a tutorial on a "how to" included video just to back up what they are trying to teach us noobs.
__________________ [SIGPIC] [/SIGPIC] 2012 Black Mica W/Tech Cobb AP AutoTech Internals JBR 88DM RMMJBR Heavy Knob JBR 3" WP JBR Rear camber arms UR TP Ford MOFO Tranny juice Rotella T6 Self Tune - (Work in Process) NGK Step 1 colder 5/7 corn fed |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score Needs to be a sticky tapafuck
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
![]() ![]() Join Date: Apr 2011 Location: Winston-Salem, NC
Rep Power: 3104 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,046
Groans: 221
| Good post...
__________________ EMWNM 2013 Beating Black women one 5.0 at a time... ![]() 2008 mazdaspeed 3 true red Tuned by Nishan , 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.![]() Build in progress. Track whore in the making. |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
| Not Ranked : 0 score Definitely sticky worthy Sent from my DROID RAZR using Tapatalk
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
| Not Ranked : 0 score Now the noobs have no excuse to not do this. And get slapped when they fuck it up. Guess I should upload my video where I show people how to use and setup and ap to log the right things to tune. |
![]() Join Date: Jan 2012 Location: Sutton, Massachusetts
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 329
| Not Ranked : 0 score WOT Cal video? |
(Thread Starter) | Not Ranked : 0 score I plan on doing this real soon. My only problem is that my actual map (the one i used for the video is just a dummy map) hits my AFR's spot on. I don't want to "theoretically" show noobz how to do it, i want the AFR's to actually be wrong so i can show them what to do. I'll try and work something out. I might have an old WOT log that had some AFR's off. I'll take a video of how to do the corrections for that. And because of pure humor at the questions @dantes5823 gets, i might just have to do an in-car WOT pull LOL totally unsafe. Ganna need someone to hold the camera
__________________ www.tunedbynishan.com |
| Members make this community what it is. Thanks for your contribution. ** Edit ** I ripped the videos and made them viewable offline while in the car if you dont have net access.
| The Following 2 Users Say Thank You to Haltech For This Useful Post: | ItsNox (02-09-2014), ms3blackmica (12-13-2012) |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score Nice Job. Will be usefull to the new guys...
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
Thank you for doing that ! However please stay tuned, as i will be uploading one last youtube video for WOT Maf Calibrations shortly and you can add that to the zip file
__________________ www.tunedbynishan.com | |
| Not Ranked : 0 score Might as well just make this "AP usage for dummies" and make a "setting up your ap" and then maf, wot maf, and just normal wot. I haz go pro if it helps man. |
UPDATE I was able to obtain a friend's WOT log and added a WOT Maf Calibration video to the OP. Also @Haltech, i know i posted this is in the Gen 1 forums. The same concept goes for the Gen 2's as well so if you can make sure they will see this thread even in thier department (if its possible).
| Not Ranked : 0 score Awesome. Thanks for taking the time to do this ms3blackmica! |
![]() Join Date: May 2011 Location: Alhambra, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,199
| Not Ranked : 0 score This is just awesome of you to take time and do this. So newbs... you have no excuse for not doing this.
__________________ ![]() 2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub. 346hp 392lbs of sexyness |
(Thread Starter) | Not Ranked : 0 score Anytime. I'm a very academic person and i can understand the complete blankness some people get when wanting to toy with their AP and ATR. I see how many noobs don't get it, and i felt that if we could just show them in person, they would understand ! So, a video is the next best thing ![]()
![]() i think i will most likely take a "clear" video of how to set up your AP to log the correct parameters for both Closed Loop MAF Cal and WOT MAF Cal as well and make that the first video as @dantes5823 recommended. I may even make a video of how to go WOT in a safe manner. I know it sounds silly but some people truly do not know. And the idea is to make sure people are safe when trying these things. The more resources we can provide for newcomers, the better this forum will be
![]() | | #19 | ![]() |
| Not Ranked : 0 score Not if I beat you to it!!! Muahahah And you. An just make one video for wot and use that for wot maf and a normal wot pull. |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score LOL oh snap ! Well the AP setup i can certainlly do shortly. But the WOT pull would have to wait until i see gilly tonight. Feel free to send me the link if you get a video, and i can throw it into the OP. EDIT: Jon i am not really good with editing videos or anything like that. I don't have any software to combine videos. Only thing i have is a screen capturing program that i used for these videos. I've always left the video editing for friends who are better at this lol
![]() | | #21 | ![]() |
| Not Ranked : 0 score I have a video already from a while back for setting up the ap. but I won't use it. And as far as the using for thin I'm saying just be like hey this is a wot pull. Then next video be like ok this is what you look at for maf and then all this shit is what you use to tune. |
![]() | | #22 | ![]() |
What i can do though, is when i am making the video for the WOT pull i will be sure to mention at the end "The next video will demonstrate how to analyze the data from this log in order to tune your WOT Maf Curve". Then when i am all done, i will Number each video Part X of X and in the order they should be watched.
![]() | | #23 | ![]() |
| Not Ranked : 0 score Boom there you go. Do work son. And now that I think of it. My car is prob horrible for making a video. All you'll hear is clutch chatter. My car shaking to peaces and then my ewg cracking open lol |
![]() | | #24 | ![]() |
![]() Join Date: Apr 2011 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 708
| Not Ranked : 0 score Good refresher for me as Im about to install my 3" Intake and TIP
__________________ 2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck. |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
![]() | | #27 | ![]() |
![]() Join Date: Sep 2011 Location: Worcester, MA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 216
| Not Ranked : 0 score awesome videos! thanks for doing this. I think i may run home tonight and try to do my MAF Cal. now. I was hesitant because i have no idea what i'm doing in ATR, and just haven't had time to re-read abilor's guide.
__________________ 2008 MS3 GT - Guardian Angel, Cobb Acessport, hacked up mazda CAI converted to SRI, Turbosmart BPV |
![]() | | #28 | ![]() |
Just make sure you drive around as much as possible (about 50 miles). I personally like to monitor Mass Airflow (g/s) on the screen while driving around to make sure that when i get on the gas, that i am hitting up to 80~100 g/s to make sure that there are some learned trims up there for best results.
![]() | | #29 | ![]() |
| Not Ranked : 0 score The stock break points are different among cars tho if I remember correctly. I mean gen1,2 speed6. |
![]() | | #30 | ![]() |
They all go from.. 0-5.70 5.70-18.00 18.00-30.00 30.00-200.00 The 2011/2012 stock mapping goes from 18.00-200.00. I don't have ATR for 2007/2008 or 2010 so i don't know what the stock mapping has for that. Nonetheless, i like to create the other breakpoints at g/s values that i typically drive around. I do a lot of 6th gear highway cruising on my daily commute and night time driving and i usually cruise around 23 g/s and somewhere around 37 g/s so thats why i have the breakpoint from 18.00-30.00 and 30.00 to 50.00. And i don't normally get on it very often and when i do, im usually around 60 g/s to 85 g/s. I basically taylored the breakpoints to the way i drive to get best results. Doing this yeilded me very precise results for the average of LTFT and allowed me to really tighten up the MAF values. I'm usually around 0.68% LTFT and dont normally see more than 1.6% LTFT
![]() | | #31 | ![]() |
__________________ 2008 MS3 GT - Guardian Angel, Cobb Acessport, hacked up mazda CAI converted to SRI, Turbosmart BPV | |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score yeah if you re-flash any map, your LTFT's will reset and be at 0 again so you need to put some miles on to learn some trims
![]() | | #33 | ![]() |
| Not Ranked : 0 score yeah, plenty of miles have been attained on this map, so it should have relearned whatever it needed to.
![]() | | #34 | ![]() |
![]() But once you make your corrections, and re-flash your map, you'll need to accumulate the miles again before your next log. Once you get to calibrating your WOT AFR's, you dont need to put any miles on because at WOT you will be in open loop and the ECU will not have any saved trims, it will go strictly off the values you put in your MAF table. So for correcting WOT AFR's, just reflash, and go WOT. I will make a note of this in the 5th video that is still yet to come. On the bright side, calibrating WOT AFR's usually goes by rather quickly. I like to bring my laptop out with me and grab a log, pull into Dunkin Donuts, get a drink and do my ATR work. And then i'll go back out, reflash, and grab another log. You can have it done in a night if your willing..
![]() | | #35 | ![]() |
| Just waiting for #5
![]() | | #36 | ![]() |
hopefully i will have dry roads by tonight and will have someone hold the camera from the back seat.
![]() | | #37 | ![]() |
| Not Ranked : 0 score Had a chance to watch all the videos today and would like to thank you for the great contribution. If you make a video on WGDC adjustment I'm sure that all of MSF will be able to adjust OTS maps to fit their cars better.
![]() | | #38 | ![]() |
But as far just simple wastegate duty cycle corrections go, i can do that
![]() | | #39 | ![]() |
| Not Ranked : 0 score ^^ this. Wgdc isn't hard to mess with but a few things play a roll on that. Like load based tuning and then your dynamic tables. |
![]() | | #40 | ![]() |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 364 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 480
Sent from my ADR6300 using Tapatalk 2
__________________ CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers! | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/maf-calibration-tutorial-125204/ | ||||
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-03-2014 01:36 PM | |
| MAF Calibration Tutorial | ms3blackmica | MazdaSpeed 3/6 - ECU Computer Tuning | 301 | 04-09-2019 07:50 AM |
| Monterey: 2012 Pebble Beach Concept Car Lawn offers a tutorial in cars to come | Haltech | Automotive News | 0 | 08-19-2012 05:50 PM |
| AP maf calibration | buckeyepost | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 08-24-2011 10:20 AM |
