![]() | | #41 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
(Thread Starter) | Not Ranked : 0 score I added the the 5th video to the original post. All 6 videos are now up and running. @Haltech, you can go ahead and throw all 6 videos into the zip file. I'm glad this thread is helping a lot you.
__________________ www.tunedbynishan.com |
![]() | | #42 | ![]() |
| Other 3 videos added in archive.
![]() | | #43 | ![]() |
![]() Join Date: Jan 2012 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 595
| Not Ranked : 0 score You are the man ms316w |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thank you for doing that @Haltech. That was a definitely good a call as members can now have the videos saved and bring their laptops out with them to the car. no problem glad i could help
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score update in the OP on AP mounting (due to many questions asked)
![]() | | #46 | ![]() |
| Lurkers Join Date: Apr 2012 Location: Wroclaw, POLAND
Rep Power: 0 ![]() ![]() Thanks: 10
Groaned at 16 Times in 8 Posts
| Not Ranked : 0 score hi! thanks for this tutorial. I still have some questions ![]() Why do you make changes in the maf table based on the volts? In albior tooning guide it is said to make changes by the breakpoints f.ex. 0-5,7g/s - one multiplier. 5,7-18 second and so on. You change the multiplier in between (exactly where you see the change in your log). Which method is correct? |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score because the g/s could be anywhere on the table. technically the g/s are wherever you put them and they can be wrong. thats why its best to go by the maf volts and go by what the cars telling you
![]() | | #48 | ![]() |
| Not Ranked : 0 score it is very hard to find out what is the volts boarder below 5,7g/s because it is already 3,3 at idle and with small touch of gas pedal it shoots over 5,7. |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score you can just edit from 0 volts to the first voltage that the ECU switches its breakpoint at
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score more noob threads coming later today
![]() | | #51 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score How to repare broken BPV bolts (because they WILL break) How to set up a good economy map (very short, only few minutes video)
| The Following User Says Thank You to ms3blackmica For This Useful Post: | Pointless (08-12-2013) |
![]() | | #53 | ![]() |
| Not Ranked : 0 score @voltron knows all about the broken bolt. As do I. |
![]() | | #54 | ![]() |
| Hide Yo Kids-No really, Hide them! ![]() Join Date: Oct 2011 Location: PMITA Jail until 12/2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,515
Groans: 77
| Not Ranked : 0 score Yo fuck that bolt. @dantes5823 |
![]() | | #55 | ![]() |
![]() | | #56 | ![]() |
![]() | | #57 | ![]() |
![]() | | #58 | ![]() |
| Not Ranked : 0 score So I end up hitting OL(-.16 LTFT) pretty early in my MAF Cal logs, does that mean I should log AFR as well and basically do a WOT MAF Cal, but for part throttle?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score You are either giving it too much throttle or didnt drive enough. What g/s are you hitting -. 16 ltft?
![]() | | #60 | ![]() |
| Not Ranked : 0 score I'll have to check when I get home. This isn't a problem for anyone else though? Most people transition to OL pretty early.
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not that i know of. I can usually get up to about 100 g/s sometimes 80 before losing the trims. Also if your seeing -. 16 in the lower g/s thats a sign that the ecu hasnt learned anything in that breakpoint yet
![]() | | #62 | ![]() |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 364 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 480
| Not Ranked : 0 score When I tuned using Albilors tunning guide he talks about changing the Cl/ol transition point to make it transition earlier. If your having trouble staying ol would it be a good idea to raise the transition point so that during the maf calc it stays ol? One time I pressed the accelerator so slowly I never even hit 100g/s at redline, but it was still enough to switch to cl due to me adjusting the transition point. Sent from my ADR6300 using Tapatalk 2
__________________ CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers! |
![]() | | #63 | ![]() |
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #64 | ![]() |
What do you currently have them set to? Raising them to something like 1.50 Load might help you to not enter open loop so early. Make sure you revert back to whatever values you currently had after you've gotten your MAF Cal done for closed loop fueling. Try out what i said just above
__________________ www.tunedbynishan.com | |
![]() | | #65 | ![]() |
| Not Ranked : 0 score but isn't it possible that there is -.16 because the Ecu just doesn't have to make correction? the measure is just right at this breakpoint? |
![]() | | #66 | ![]() |
temperature changes, fuel quality, elevation, etc... can all change simultaneously so your ECU will always be doing some work to correct fueling. Do me a favor and post up your MAF Cal log where you keep seeing your LTFT go to 0 so i can see whats going on
![]() | | #67 | ![]() |
| Not Ranked : 0 score 18-30g/s: in 4 different logs on 4 different days: Attachment 71355 |
![]() | | #68 | ![]() |
It would appear that you did not drive in the 18-30 g/s breakpoint long enough for any trims to be learned
![]() | | #69 | ![]() |
| Not Ranked : 0 score its after 50 city miles (~10 key cycles) last log is after probavly 80-100 miles |
![]() | | #70 | ![]() |
Do me a favor though....grab another MAF Cal log but this time also Log STFT (Short Term Fuel Trim) as well and lets see how the ECU is working instantaneously in that breakpoint. Log: MAF Volts LTFT STFT MAF g/s
![]() | | #71 | ![]() |
| Not Ranked : 0 score ok. will do that today/tomorrow. I'm finishing new 50 mile cycle coz i made corrections based on that logs above. |
![]() | | #72 | ![]() |
It could be that your MAF values in that breakpoint are so accurate that it barely needs to make any correction to fueling, and its such a small percent that its not registering any average for a LTFT because it does not correct for long enough. We shall see when you post the log.
![]() | | #73 | ![]() |
__________________ CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers! | |
![]() | | #74 | ![]() |
![]() Join Date: Sep 2011 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score Pulled the data from my maf cal but I couldn't reach the 100 g/s threshold by redline. Is it normal or necessary or could it be due to the 100 degree temps outside which lowers the air density? |
![]() | | #75 | ![]() |
EDIT: For example, if at 4500 RPM your at 15% position on your accelerator pedal, then you need to gradually increase to 20% by slowly going from 15 to 16~17~18~19 to 20. That should be just enough to get you over 100 g/s.
![]() | | #76 | ![]() |
| Not Ranked : 0 score ok. i've found the base logs for my maf cal so I added the stft data to the xls file I posted before: Attachment 71648 what does it say? |
![]() | | #77 | ![]() |
Anyway, Log #1 and #3 show that the ECU is not really making much correction to hit your proper fuel target. My guess is that its not enough to register a solid average for a LTFT. Keep driving on this map for more and more miles and let me know if you ever develop a LTFT for the 18 g/s - 30 g/s breakpoint. It is possible that your MAF values for that breakpoint are just damn near spot on.
![]() | | #78 | ![]() |
| Not Ranked : 0 score Yeah i turn on AC on my maf cal for like 50% of time. I am not on this map anymore - I made corrections to stage 1 ots map and now it looks like this: Attachment 71752 |
![]() | | #79 | ![]() |
![]() | | #80 | ![]() |
| Not Ranked : 0 score this log was made with around 40 miles. Now I have over 200 miles on it but didn't log it yet. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/maf-calibration-tutorial-125204/ | ||||
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-03-2014 01:36 PM | |
| Display Modes | |
| MAF Calibration Tutorial | ms3blackmica | MazdaSpeed 3/6 - ECU Computer Tuning | 301 | 04-09-2019 07:50 AM |
| Monterey: 2012 Pebble Beach Concept Car Lawn offers a tutorial in cars to come | Haltech | Automotive News | 0 | 08-19-2012 05:50 PM |
| AP maf calibration | buckeyepost | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 08-24-2011 10:20 AM |
