![]() | | #81 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
Your really goin far to get your MAF curve spot on
__________________ www.tunedbynishan.com | |
![]() | | #82 | ![]() |
(Thread Starter) | Not Ranked : 0 score might be making a video on a complete ATR walkthrough so that all these noobz can understand whats really going on when they edit all these tables we have.
![]() | | #83 | ![]() |
(Thread Starter) | Not Ranked : 0 score i think Mazdaspeed TV episode 2 is cominng out soon !
![]() | | #84 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
| Not Ranked : 0 score You must be really bored lol |
![]() | | #85 | ![]() |
(Thread Starter) | Not Ranked : 0 score extremely !! i think i am going to contribute to MSF this year by making it the year of the least noob posts lol
![]() | | #86 | ![]() |
![]() | | #87 | ![]() |
![]() | | #88 | ![]() |
![]() | | #89 | ![]() |
![]() | | #90 | ![]() |
![]() Join Date: Dec 2008 Location: Flint, MI
Rep Power: 206 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 955
| Not Ranked : 0 score @ms3blackmica once again thanks for you awesome guides. I have a question I was hoping you can answer. So Ive already done my CL MafCal, now I am moving to OL WOT MafCal. My problem is that I am using a stage 1 ots map as my baseline and for some reason the taregeted AFR on these maps are all over the place. My question is will it be a better idea to set my commanded AFR as per Abilors guide, say 11.4 for everything over 1.25 load and 2500 RPM in CL and OL tables, and then do the WOT MafCal. What will you recommend, and thanks in advance.
__________________ HKS Intake l Cobb TIP l CorkSport TMIC l Cobb AP l AT Internals l SU Test Pipe Turbosmart Dual Port l Stratified Shift Extension/Knob l CPE RMM l Dashawk |
![]() | | #91 | ![]() |
Generally what i do is this...I'll set a pretty rich AFR like 11.0. Its a nice even number. And is also plenty rich that i should not see any knock. I will dial the car in like this and do my WOT Maf Cal until i hit 11.0 everywhere. Once you see your AFR's nice and steady, all i have to do is go back to my fueling tables and set it to whatever i want (i.e. 11.4, 11.5, 11.6, etc...) This usually helps get the WOT Maf Cal down pretty easy. If you see a lot of knock during the pull, you won't be able to use any data during the knock event. So to keep knock to a minimum, you can do a WOT Maf cal with a rich AFR. Then once your done, lean it up a bit to whatever you want or whatever your gas can handle.
![]() | | #92 | ![]() |
Again thanks for you awesome advice I really appreciate it. Sorry to keep tagging you in my questions by after seeing the race videos of you and your friends and after following your guides I can see that you have and exceptional tuning knowledge for this car.
__________________ HKS Intake l Cobb TIP l CorkSport TMIC l Cobb AP l AT Internals l SU Test Pipe Turbosmart Dual Port l Stratified Shift Extension/Knob l CPE RMM l Dashawk | |
![]() | | #93 | ![]() |
The OTS maps are a mess in regards to fuel. But you have to understand that they make the target AFR richer as the RPM increases in order to keep the combustion chamber cool and not cause any knock. They are just being safe. I personally think it is best to set your AFR's to something simple, easy, and consistent. If you want to richen it up in the higher RPM for safety (or to get more timing) you can certainlly do that as well. But you can set your AFR's to even numbers and not the crazy values the OTS maps have with 3 decimal points.
![]() | | #94 | ![]() |
![]() Join Date: Jun 2012 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
Thanks
__________________ Autotech CDFP internals, Cobb AP, CS Stage II PS SRI/TiP with Airbox, JB RMM, CS SSP ~ Fast---Cheap---Reliable.....you can only pick 2 ~ | |
![]() | | #95 | ![]() |
| Banned ![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 101 Times in 11 Posts
| Not Ranked : 0 score Hi,I live in South Africa and I have a 2009 Mazda 3 Mps with a gt35 turbo with a built motor and I have an upfraded fuel pump.The problem is that I have an 100mm intake on and my ltft stays at -0.16 for all mass air volumes. |
![]() | | #96 | ![]() |
I was able to download it. I don't know much about any download issues from the site. @Haltech could you chime in ? Has the tune been calibrated for the 100mm intake ?
![]() | | #97 | ![]() |
| Not Ranked : 0 score I used the Cobb worksheet to calibrate it,yes. |
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score And how did you scale the MAF curve for the large intake size ?
![]() | | #99 | ![]() |
| Not Ranked : 0 score Your tutorial was very good,thank you. |
![]() | | #100 | ![]() |
(Thread Starter) | Not Ranked : 0 score You do realize that you have to scale the MAF curve for larger than stock intakes right ?
![]() | | #101 | ![]() |
| Not Ranked : 0 score Yes,I used the global intake calibratio tool and it gave me 1.5038.I then used that on the stock Maf curve. |
![]() | | #102 | ![]() |
| Not Ranked : 0 score I might not have driven far enough for the ltft to kick in as I have been loading plenty of maps. |
![]() | | #103 | ![]() |
You usually start see LTFT's after a few miles. But requires about 50 miles for a MAF Cal log. You can see your STFT's changing right away though.
__________________ www.tunedbynishan.com | ||
![]() | | #104 | ![]() |
| Not Ranked : 0 score I used the stock values that I got from the stock map I got with the AP.I drove less than 10 miles. The stft were as high as 35. |
![]() | | #105 | ![]() |
the stock map doesn't tell you the MAF housing cross sectional area. It only shows you the non linear relationship of MAF voltage to mass air flow g/s. When you put a larger than stock intake on, you need to come up with a scalar. This scalar is the ratio of the 100mm intake to the factory intake size (which i do not remember off hand). Do you mean the STFT were as high as 25? 25 is the max amount the ecu can correct. Was the trim + or - ?
![]() | | #106 | ![]() |
| Not Ranked : 0 score I got it from the cobb maf calibrator and the I used the multiplier on the stock values of a stock map with stock intake.I then copied that to a stage 2 maps maf curve.I got stft from+47 to -25. |
![]() | | #107 | ![]() |
I think there is a miscommunication here
![]() | | #108 | ![]() |
| Not Ranked : 0 score 47 and 25 |
![]() | | #109 | ![]() |
| Not Ranked : 0 score Have a look at the log. |
![]() | | #110 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay first off, there is nothing in that excel document that shows you/gives you any scalar for a bigger intake. That document was just to show how the ECU calculates final ignition timing. You need to tell us more about your car. What are the full list of mods? How is it set up? Looking at your log, your ECU is making enormous corrections to fueling (both pulling fuel and adding fuel) and this is not good. It is evident that your MAF Calibration is not correct. While i do not remember the stock intake diameter, I can already tell you a scalar of 1.5 is deff not enough for a step up to 100mm. This may be why you have so much more fuel being added in the higher g/s range. I think you need to start from scratch with a base OTS map, multiply your scalar and then start dialing in the car. @rfinkle2, what is the stock MAF housing diameter? I cannot remember for the life of me and I don't wanna take mine apart to check lol
![]() | | #111 | ![]() |
| Not Ranked : 0 score Try this one |
![]() | | #112 | ![]() |
| Not Ranked : 0 score Global Intake Calibration Multiplier 3.14159 = pi This calculation should only be used to assist you in the generation of a base map so that you can start your vehicle which has a MAF housing other than stock installed on it. Tuning your Intake Calibration table must be performed after you have started your vehicle. Please refer to the "AccessTUNER Software Calibration and Tuning Guides for Subaru v1.XX.pdf" document which explains how to tune your intake calibration using the live tuning features of the AccessTUNER Pro and AccessTUNER Race software. When switching your intake to an aftermarket you can use this multiplier to glabaly modify your Intake Calibration table based on the difference in diameters (surface area) between the two intakes, follow Step 1) below 66.5 Step 1) Enter the inside diameter for your stock MAF housing, choose from below list. 100.0 Step 2) Enter the inside diameter for aftermarket MAF housing. = 1.5038 Step 3) Your Global Intake Calibration Multiplier Step 4) Copy (CTRL+C) the data from cell B15 from this worksheet, highlight all of the lower cells in the Intake Calibration table, press the "m" key, then paste (CTRL+V) the copied value into the dialog box asking for a floating point value then press the Enter key. Surface Area of a Sphere = 4 pi r 2 Intake Diameter Surface Area 66.5 mm ~ ID of stock 2007-2009 USDM Mazda 2.3L DISI MAF housing 65.0 mm ~ ID of Injen STi Cold Air Intake System - 65mm, P/N IS1201 |
![]() | | #113 | ![]() |
(Thread Starter) | Not Ranked : 0 score Your Scalar should be 2.2613. It doesn't matter if you use the formula for cross section or area of a sphere. 4 and pi will cancel out. Let me show you the math. (New MAF cross sectional area) / (Stock MAF cross sectional area) (pi * (100/2)^2) = 7853.981634 mm^2 ----For 100mm intake (pi * (66.5/2)^2) = 3473.227028 mm^2 ----For Stock 66.5mm intake Divide the two. (7853.981634) / (3473.227028) = 2.2613 (rounded off) this means that the 100mm intake has a cross sectional area 2.2613 times larger than the cross sectional area of the 66.5mm intake The reason you kept getting 1.5038 is because the formula embedded in that excel file did not square the radius of both intake sizes. Start from scratch again and use 2.2613 as your scalar now.
![]() | | #114 | ![]() |
| Not Ranked : 0 score Sorry I'm late, but as posted above 66.5mm. |
![]() | | #115 | ![]() |
| Works fine on my end.. If others want to download to confirm... I'd appreciate it.
![]() | | #116 | ![]() |
![]() | | #117 | ![]() |
worked with no issues. i'm not sure why he was having any.
![]() | | #118 | ![]() |
| lulz @Raider ![]() Join Date: Jun 2010 Location: St Louis Mo
Rep Power: 3779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,132
| Not Ranked : 0 score subbed for gr8ness
__________________ 2008 MS3 gt 470hp/463tq on GT35r at 29psi Wiseco Pistons/Molar Rods/ACT 6 Puck/ARP Head Studs/TurboXS FMIC DP and RP/TurboSmart BOV/Tial 38mm EWG/PERM 5th/6th port injectors HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned |
![]() | | #119 | ![]() |
![]() | | #120 | ![]() |
| Not Ranked : 0 score @ms3blackmica can the 4th gear portion of the cal be done on a dyno? I only ask because: A. I want to dyno the car for numbers, and I can then kill 2 birds with one stone, and B. It aleviates trying to find an area around here where I can open up to that speed while logging, traffic and cops.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/maf-calibration-tutorial-125204/ | ||||
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-03-2014 01:36 PM | |
| Display Modes | |
| MAF Calibration Tutorial | ms3blackmica | MazdaSpeed 3/6 - ECU Computer Tuning | 301 | 04-09-2019 07:50 AM |
| Monterey: 2012 Pebble Beach Concept Car Lawn offers a tutorial in cars to come | Haltech | Automotive News | 0 | 08-19-2012 05:50 PM |
| AP maf calibration | buckeyepost | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 08-24-2011 10:20 AM |
