 Old 01-05-2012, 03:14 PM   #1
JTMS3's Avatar
Posts: 2,306   (View Stats)
Default OFFICIAL TUNING DEVICE THREAD FOR YOUR MS3/MS6
updated 8/26/15, thanks @SofaKingAwesome;!
This thread is to educate new users on the most commonly used devices for our platform when tuning the ECU.
There are other options out there, but these are the most widely used and supported.
** First things first. You do this at your own risk!**
• There is not a single dealership that will approve this mod! It would be wise to uninstall all modded ECU maps before any trips to the dealer.
• Like any mod, there is a risk involved, so it is highly recommended you work with the manufacturer or a pro tuner before beginning to make sure the solution is right for you. This will serve to get your knowledge to where it needs to be before making any major changes to the ECU.
• An HPFP upgrade is required for most tunes, more information here.
Cobb Tuning AccessPort
COBB Tuning - MAZDASPEED Accessport V3
Supported models:
■ 2007-2013 MAZDASPEED3
■ 2006-2007 MAZDASPEED6
■ 2007-2013 MAZDASPEED Axela
■ 2004-2006 MAZDASPEED Atenza
■ 2007-2013 Mazda3 MPS
■ 2004-2006 Mazda6 MPS
Description:
Simple ECU flashing with gauge package! The new in-cabin mountable Accessport V3 has a large, full color, higher resolution screen which allows you to monitor up to six parameters in real time. Fully customizable from the look (multiple bezel colors), layout (set up race, street, or dyno gauge clusters), and mounting options (choose from 1,000s of standard vehicle mounts). And what's looks without brains? More processing power, memory, and storage to flash faster while saving all of your maps and logs. This is your new Accessport.
Why?
The Accessport is the world's best selling, most flexible, and easiest to use ECU upgrade solution for your Mazda. Unlock power hidden within the vehicle by replacing conservative factory settings with more aggressive calibrations. Follow our staged upgrade path with pre-loaded Off The Shelf (OTS) maps or use custom mapping for any modification level. It's the last engine management solution you'll ever need.
Features:
MAZDASPEED Accessport V3 (AP3-MAZ-002)
•Larger, full color, higher resolution screen
•Customizable multi-gauge display
•In vehicle mount, with on/off switch
•Faster and easier to use with a familiar face
•Interchangeable faceplates
AccessPort helpful links:
AP User Manual
V2 (discontinued)
http://accessecu.com/support/docs/ma...UserManual.pdf
V3
https://cobb.app.box.com/ap3-maz-qsg
Typical data logging results:
http://accessecu.com/support/docs/su...0Guidance.html
Differences between the Gen1 vs Gen2 MS3:
http://accessecu.com/support/docs/su...%20Support.pdf
ATR Helpfile:
http://www.accessecu.com/support/doc...MAZDASPEED.pdf
OTS Maps:
COBB Tuning - Maps
Cobb MSF vendor page:
Cobb Tuning - Mazdaspeed Forums
VersaTuner
VersaTuner - An Innovative Tuning Solution -
Supported models:
■ 2007-2009 CX-7
VersaTuner is easy to use. You don't need to be an engine tuning guru to use it. It is wizard driven to help you perform common tasks, provides visual cues and uses easy to understand terms to describe what is being done. Forget about tinkering with small buttons and tiny screens of embedded tuning devices. Enjoy a premium tuning experience on the large color screen of your Windows PC, laptop or tablet. Keyboard shortcuts and large uncluttered information screens are provided for in-car tasks, such as data logging. Audiovisual alerts are employed to keep distractions to a minimum.
VersaTuner is a Windows™ application, so it runs on regular computers and requires no fancy hardware apart from an easily obtainable J2534 Pass-Thru device, used to talk to the car. Connect one end of the cable to the OBD-II port of the car, connect the other end to a USB port on your computer and start tuning. There’s no need to splice any wires, install additional electronic modules or take out your ECU.
Features:
•Online tune database
•Deep control of ECU
•Tune editor
•Dashboard and data logging
•Next generation log viewer
•Extensive diagnostics
•Launch control and no lift shifting
•Community-centric approach
•Global availability
VersaTune now offers tuning of load to 4.0 and RPM to 8000 in key relevant tables.
Originally Posted by Steve@VersaTune
Extended Load and RPM Axes
Twenty One tables deemed critical to performance tuning and drivability have had their axes extended to 4.0 load and/or 8000 RPM. The tables modified include load targeting, fueling, ignition, valve timing, throttle, and boost control. Proper tuning of large turbo equipped vehicles is finally possible. Drivability is radically improved by removing the on/off behavior of tunes limited to a load of 2.0. All extended tables have “Extended” in the table name.
We are in the process of adding this to Gen2. It should be ready shortly.
Thanks,
Steve
VersaTuner helpful links:
Features:
VersaTuner - Features
Available Tunes:
VersaTuner - Available Tunes
Tech Specs:
VersaTuner - Technical Specifications - 2006 - 2007 MAZDASPEED6, Mazda 6 MPS, MAZDASPEED Atenza
VersaTune MSF page:
VersaTune - Mazdaspeed Forums
Hypertech MaxEnergy Sport
Max Energy Sport - Hypertech - [B]
Supported models:
Max Energy Power Tuning extracts every bit of energy possible out of every molecule of fuel giving you more miles at part-throttle and more power at wide-open throttle. In order to increase engine efficiency, horsepower and torque, our engineers first make hundreds of dyno runs to optimize the spark and air-fuel curves point by point over the entire rpm band from just off idle to wide open throttle. Next we take the vehicle with the new tune to the track and the street to verify real world performance gains. The results…maximum power, quicker acceleration, smoother shifting and better driveability.
Features:
• Intakes supported: Cold Air Intake Tuning AEM Brute Force, BEGi Cool Air System, Cobb Tuning SF Intake, CorkSport Short Ram, Custom Performance Engineering Xcel Nano Air, Custom Performance Engineering Xcel Cold Air, HKS Racing Suction Intake System, Injen Cold Air, K&N Typhoon, MAZDASPEED Cold Air, Takeda Attack
•Top Speed Limiter 25 - 75 MPH in 5 MPH increments, 81 to 255 MPH to match speed rated tires
•Rev Limit -500 to +500 RPM
•0-60 MPH Restriction
•DTCs Read and Clear
•Return Back To Stock
•Internet Updateable
•Engine Idle RPM -100 to + 200 RPM in 50 RPM increments
MaxEnergy helpful links:
Ref Guide and Manual:
http://hypertech.com/ProductManuals/sport.pdf
Hypertech FAQs:
FAQs - Hypertech
Tuner Software Update:
http://www.webservice99.com/webdownl...structions.pdf
MSF Tuning Vendors
Freektune - http://www.mazdaspeedforum.org/forum/forum/f699/
Hypnotic Tuning - http://www.mazdaspeedforum.org/forum/forum/f737/
Stratified Automotive Controls - http://www.mazdaspeedforum.org/forum/forum/f600/
JTMS3 is offline
 Old 09-19-2012, 01:27 PM   #2
Discuss
http://www.mazdaspeedforum.org/forum/foru...ed-6-a-101420/
Raider is offline
OFFICIAL TUNING DEVICE THREAD FOR YOUR MS3/MS6 JTMS3 MazdaSpeed 3/6 - ECU Computer Tuning 39 09-11-2017 04:45 PM
OFFICIAL: New ATR Tuning Thread superskaterxes
Cobb ATR Support
250 10-19-2013 08:32 AM
OFFICIAL TUNING DEVICE THREAD FOR YOUR MS3/MS6 JTMS3 Gen2 MS3 General Discussion 1 01-05-2012 04:48 PM
Hypertech Tuning Device holeinmypocket MazdaSpeed 3/6 - ECU Computer Tuning 214 07-06-2010 08:35 PM
Official Newb to Tuning Thread: Ironside 2010 MS3 - ECU Computer Tuning 4 05-20-2010 03:47 PM
Page generated in 0.27298 seconds with 21 queries
