Spark Plug Database - Colder Than Stock ( Stage 1&2 ) This is a compiled database for spark plugs who's heat range is 1 and 2 stages colder than stock. Please add your plugs and we will update this thread. Mazdaspeed Forums Spark Plug Index Database Gap size - 0.26 - 0.32 | Preferred gap is between 0.26 to 0.28 Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug Heat Range Conversion Chart Code:
NGK Copper Plugs LZTR4A-11 (5306) LZTR5A-13 (4306) BKR7E |
Heh, was about to correct you on the gap. Also perhaps we should sort them by Iridium/Platinum/Copper etc and list a link/price? Great idea though. why preferrably between .03 and .032? I jsut gapped mine to .028 dammit!!! lol |
Autolite APP5364. Stock heat range as far as I can tell - Platinum - $3.99 AutoZone.com | Shopping | Parts | Product Detail - Spark Plug |
We want colder stage plugs please. We can find stock plug applications all day long, but this isn't why this database is being created. You also do NOT want to be running platinum plugs in boosted applications. Big NONO.. Copper or Iridium plugs only please. Thanks! |
How is platinum a big no no. WRXs come with them stock |
Quote:
Quote:
Thanks for the info. Guess I need to change mine again, LOL. At least they were only 16 bucks. Hope we can find some copper ones in the right size. |
Im trying to get some copper numbers, but so far, im having no luck. Hopefully when NGK answers my email, i can get some numbers. |
sub |
14mm; 5/8 hex; 25mm reach; projected tip; resistor plug. some useful info: for those looking for a traditional NGK copper core spark plug..... |
here are the specs of the NGK LTR7IX-11 (6510) Iridium IX Plug, 14mm Thread, 25mm (.984") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Fine Wire (0.6mm) Iridium Center Electrode, Tapered Cut Ground Electrode, .044" (1.1mm) Gap |
Quote:
yeah good call. i just quit at this whole spark plug thing, lol |
Quote:
Not trying to jump off topic or anything, but would there be a greater benefit to going 2 stages colder plugs? I was gonna go colder, but haven't heard of the 2 steps colder plugs till now. I am mild to heavily (at least soon to be) modded. |
2 stages will make you idle a little more rough but will be fine.. You will lose a bit of power with stage 2 plugs, over stage 1, but your safety margin is greater. |
If a plug is too cold, will it foul easier/faster? |
2 stages isnt cold enough to cause fouling. Not with 20 psi of boost. |
Here is some initial work. IMO, the stock plugs for the STi and EVO9 are excellent and should be used where possible. Although, I do like copper plugs due to them being less expensive. The below picture has (from left to right) the MS3 stock 6 temp range plug, a 7 temp range plug for the EVO9, and a 7 temp range plug for the STi. Unfortunately, the STi and EVO9 plugs do not seat against the head the same! Otherwise, these would be excellent stock MS3 replacements. http://www.accessecu.com/Christian/B... for Mazda.jpg The ILTR6A stock MS3 plug is gapped at ~.031" from the factory. The LFR7AIX Iridium STi (one range colder than stock) plug is gapped at ~.029" from the factory. The ILFR7H Laser Iridium EVO9 plug is gapped at ~.022" from the factory. A few things to note, the different plug MFGs use different numbers for temperature ranges. For NGK and Denso, the higher the number the colder the plug (or the more heat the plug pulls from the combustion chamber and transfers to the head/coolant passages). Temperature ranges of 6 and 7 should be fine choices for most cars. You cannot easily adjust the gap on platinum, iridium, or laser iridium plugs without scratching off the special coatings that make these plugs so expensive...so please be careful. We should be able to find a good replacement spark plug soon, and we will have better input once we analyze the stock used plugs that are being shipped to us by customers. Christian. |
Quote:
I said on US (backwards) the HKS 50003-M40LF is a heat range of 8, so it's 2 step colder not stock need to edit that first post lol. And don't forget the itv27 3 step colder (or 3.5). Sorry off topic. I really don't like US (backwards) due to a wholesale account not getting done with them. I buy my stuff from PG now. I had $10,000 to do an initial buy from them, so now I'm spending it at PG. :laugh2: And will be coming to this forum more often also. :friday: |
From NGK... Quote:
Quote:
So .036 reduction is the least safest with iridium. Copper would be best then, as said before lol. |
Anyone know what the Denso itv-20/22/24s are gapped at? |
itv20 1.1mm or .044 can gap down to .036 itv22 0.8mm or .032 can gap down to .024 itv24 0.8mm or .032 can gap down to .024 itv27 0.8mm or .032 can gap down to .024 |
Awesome, looks like the ITV 22/24/27 will work great for us |
Heat Range Conversion Chart HKS 25 30 35 40 45 50 52.5 55 DENSO 16 20 22 24 27 31 32 34 NGK 5 6 7 8 9 10 10.5 11 * Above information is just for reference |
What heat range is the 27? 3 stage colder or 4? |
I'm guessing 3.5, since they are increamenting 2 numbers per 1 heat range number. |
Quote:
M35LF is 7 heat range - 1 step colder M40LF is 8 heat range - 2 step colder |
fixed |
Do we have any answers as too which are the best plugs to run when upping the boost? |
denso itv22 recommended by me! |
Denso hands down. |
at what point do you all think 2 steps colder should be used? |
Bump |
I like my ste2 colder, I had requested 1 step colder but got 2 step does this cost power? Car runs great, but am I losing a tad of power with the 24 vs 22? |
sub |
any sources on the Denso Iridium itv-24 - 2 stage colder heat range plugs? haven't had much luck locally |
what step colder would i want for this setup 1.Cobb inlet 2.cobb SRI 3.Cobb Turboback exhaust 4.SU TMIC 5.denso ?????????? 6.hks bpv 7.cpe HPFP 8.cpe standback |
| All times are GMT -7. The time now is 09:06 PM. |
