 Old 06-24-2009, 10:16 AM   #361
kore2000's Avatar
Posts: 448   (View Stats)
kore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the world
Groans: 90
Groaned at 69 Times in 21 Posts
Originally Posted by yang_jackson View Post
kore, try a wot log and see how it comes out. you dont need the blackbox at the time of log.... at least i didnt. i had a few logs first, dl the bb software, and it works great. if you wanna see some logs posted w/bb, scroll up...... i posted some 4th gear logs earlier.
Can you post the BBX file? I can see the pics just fine, but I want to get a raw .bbx file and see if the software works. If it works with another log file, then my log is likely jacked for some reason. If it doesn't work with the known working log, then something is wrong with the program.
kore2000 is offline
 Old 06-24-2009, 10:48 AM   #362
yang_jackson's Avatar
Posts: 432   (View Stats)
yang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the world
Groaned at 56 Times in 24 Posts
its posted in this thread... i think around page 4 or 5
chief moped rider..... i just never let my friends see the moped. mopeds are great. they will do anything!
yang_jackson is offline
 Old 06-24-2009, 03:53 PM   #363
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
Groans: 38
are afr read accurately w/dashawk after sb is installed? or does it skew the reading?
DH is accurate.
bykeryder4life is offline
 Old 06-25-2009, 03:03 AM   #364
kore2000's Avatar
Groans: 90
I'm pretty tired so maybe I missed it, but I just looked at pages 1-7 and all I saw was a bunch of jpgs and gifs, no bbx files. Could you point me to the post with the BBX log. Thank you.
kore2000 is offline
 Old 06-25-2009, 09:54 AM   #365
its post #98
 Old 06-25-2009, 09:58 AM   #366
kore2000's Avatar
Groans: 90
its post #98
That is the black box software (PMP.exe), I was wanting an actual log file (XXX.bbx). I already have downloaded the software twice to different locations. I wanted to test the software's functionality on my computer with a log file that was known good. I'm thinking that my log is the problem, not the software, but I wanted to confirm it. Could you or someone post one of the log files (Log1.bbx) please. Thanks
kore2000 is offline
 Old 06-26-2009, 01:08 PM   #367
anyone throw a p0101 cel code after installing sb? mass air 'a' circuit was the actual code. any help will be appreciated
 Old 06-26-2009, 01:15 PM   #368
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i used to throw fuel rail pressure sensor codes all the fucking time. that shit has been decent though
phillyb is offline
 Old 06-26-2009, 02:35 PM   #369
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Did you install the bypass plug and take it for a drive with just the PNP harness?
If not I would recommend doing that before hooking up the SB. If you clear the MIL and it reappears, you probably bent a connector pin.
AndyMS3 is offline
 Old 06-26-2009, 02:38 PM   #370
Groans: 38
ya man my first install of the pnp there was something lodged in the connector pins and it prevented the harness from fully engaging the pins. my car ran like shit and threw cel's. Check your pnp
 Old 06-26-2009, 03:28 PM   #371
my pnp has been in for 2 weeks w/no probs til now.... so im pretty sure thats not my prob. i just cleared the code w/my dashdaq.... if it comes back on, ill un/reinstall the pnp and clean my maf..... hopefully it wont come back on.
 Old 06-29-2009, 03:27 PM   #372
so i have been getting audible partial throttle knock up to 6 degrees since i got the sb and upped the boost to 17. i let jordan know and he tweaked my maps in a major way. instead of setting the boost at 17 psi all the way across, he set up my variable boost table to gradually work its way up to 17 at the top of my power band. just went for a drive on my lunch break and NO PT KNOCK!!! i was getting it almost every time i would downshift from 6th and punch the throttle (to pass). i did that several times and no knock w/new map. i also ran wot through the 1st 4 gears and no knock.... so far so good. ill let you guys know how it goes long term...
 Old 06-29-2009, 03:28 PM   #373
phillyb's Avatar
Groans: 1,940
very cool
phillyb is offline
 Old 06-29-2009, 04:15 PM   #374
Originally Posted by phaillyb View Post
very cool
werd... if you are interested, i can post a screen shot of my variable boost table when i get home from work..... lemme know. im set at 17psi max boost....
 Old 06-29-2009, 04:22 PM   #375
phillyb's Avatar
Groans: 1,940
yeah, show me, or send through pm or whatever
phillyb is offline
 Old 06-30-2009, 12:36 AM   #376
Groans: 38
thats how i set my boost table up, only I did it so i wont spike or boost high at low rpm's. I start with only like 16psi down low and work up to 19psi by the topend, so when I get on it down low the motor wont load up with alot of boost, but it will easily hold 18psi up top. boost table ftw
 Old 06-30-2009, 02:10 AM   #377
jordan started mine pretty low... i can def feel the decrease in power down low, so im gonna tweak it and find a happy medium. drove an ass ton of miles tonight, plenty of wot pulls up to 120mph. only knocked once and i think it was due to funky shifting.... usually, i knock a whole lot more. anyway, here it is. and i cant wait til i get this thing dialed in perfect...
File Type: jpg boost_table.JPG (0, 0 views)
 Old 07-08-2009, 03:06 AM   #378
steven88's Avatar
Posts: 773   (View Stats)
steven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the world
Groaned at 9 Times in 5 Posts
hey guys i'm gonna be subbin in this thread...gonna pick up a SBv2 and PNP very shortly and want to learn as much as I can about it!
quick question though...do I need a dash hawk to datalog? I read that the SB can datalog but I am wondering why people use their dash hawks still?
steven88 is offline
 Old 07-08-2009, 08:18 AM   #379
Phantom's Avatar
Posts: 313   (View Stats)
Phantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud of
I have setup my map to zero and changed the boost to 16 psi. I have been getting some bucking at WOT at times. I did a quick DH data log and noticed I get fuel pressure spikes to 2100 psi. I am not sure what is going on but when I use my Aeroforce gauge the AFR shows quite rich (10.5 - 9.8) but the DH shows different from (12.5 - 11.0). Just odd. Hope I don't have to replace my WB again.
Maybe the boost is rising too quickly? Higher KD=slower climb right?
Maybe not enough fuel?
Any ideas? I can post a log tonight.
Phantom is offline
 Old 07-08-2009, 10:10 AM   #380
ALL-IN.
AndyMS3's Avatar
Groans: 30
You can datalog with the SB, but you can't log knock or the stock wideband, two very important parameters.
2100psi? Seems high to me. Perhaps you are dumping too much.
Moar log pls.
AndyMS3 is offline
 Old 07-08-2009, 01:49 PM   #381
Phantom's Avatar
Found the problem. I must have reset the config page and adjusted the KD value. I checked my map today and found my KD set to 10. I think that was a little bit too fast for boost climb. I adjusted to 250 from the CPE CAI TBE map and did a few tests and is working fine now.
CPE CAI|TRZ Motor Mount (Poly)|Hoen Xenonmatch Fogs/Highs |Hotchkis Rear Sway Bar|Prosport Boost Gauge|Buddy Club Condenser|18x8 OZ Ultraleggera Matte Black|Gorilla Black Lugs|G2 Red Calipers|Autoexe Stainless Steel Brake Lines|Chromium Signals|Hella Supertone|sk07 Accel Pedal|CPE DP|Cobb Shift Weight|Evo Turbo Timer|Dual AeroForce|TurboSmart BOV|Denso ITV22 Plugs|CPE HPFP|H&R Springs|Koni Yellows (Struts/Shocks)|Autoexe Street Pads|Rotora Slotted Rotors|SPC Camber Kit|CPE PNP|CPE Standback|CPE Pro Fuel Controller|Labonte Stage 1 Water/Meth Injection Kit|Tribute Oil Filter Converstion
Phantom is offline
 Old 07-10-2009, 10:28 AM   #382
Cue
Cue's Avatar
Posts: 157   (View Stats)
Cue is the leader of the worldCue is the leader of the worldCue is the leader of the worldCue is the leader of the worldCue is the leader of the worldCue is the leader of the worldCue is the leader of the worldCue is the leader of the worldCue is the leader of the worldCue is the leader of the worldCue is the leader of the world
took about 30 minutes to install last night. initial impression is MY CAR PULLS HARD!!! i upped the boost to 17psi and the turbo limiter was automatically turned off. these 2 things alone made a HUGE difference. randy (palerider) helped me set up the base map. and kyle (inspector gadget) helped me w/install. a big thanks to the both of you! also sent jordan at cp-e an email. im waiting for his response before really trying to tune the car. on sunday, i am going to ryan's (cali_axela) house to play with it a little more.... see if i can get my LTFTs to settle down a bit. im telling you.... WORLDS OF DIFFERENCE!!! i cant wait to get this thing dialed in!
anyone got any general tips for a standback noob? hopefully i will be able to post something useful in the not too distant future.
I succesfully had my CX-7 tuned at 19psi (4800 and under). CX-7 has a smaller inlet and outlet as well. 17 to 19 is another world of difference.
2008 CX-7 Crystal White Pearl AWD
CP-E Standback2 w/PNP, CP-E FCF, AEM SRI, AC FMIC, Forge BPV, CP-E 3" Midpipe, CP-E 3" Dual CBE, MSD Dash Hawk
Cue is offline
 Old 07-10-2009, 09:46 PM   #383
steven88's Avatar
I think this has been answered before...but I'm gonna ask again just to be sure
Can I still play with my standback without having to install the toggle switch?
I don't plan to switch between maps anyway...
steven88 is offline
 Old 07-10-2009, 09:54 PM   #384
awd>fwd
jwdp54's Avatar
Posts: 627   (View Stats)
jwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the world
Groans: 27
Groaned at 53 Times in 33 Posts
yea you can without it but since it's there you my as well use it.i actually installed mine under the hood on my battery tray so i have my safe map i run daily and when i go to the track i just pop the hood and switch it to my agressive map. i did it basically so i wouldn't get in trouble racing since i can't switch it on the fly.
MS3 310whp/320tq- SOLD finally(5/5/10)
evo 8-tuned to E85
jwdp54 is offline
 Old 07-10-2009, 09:57 PM   #385
steven88's Avatar
cool...I just want to run 1 map...so without the toggle switch installed, it will default to the PRIMARY map right?
I can always just zero out the SB if I'm having problems
steven88 is offline
 Old 07-10-2009, 10:26 PM   #386
awd>fwd
jwdp54's Avatar
Groans: 27
yea without it your on your primary only. i actually zero out my maps every couple of weeks and redo them for the weather changes. for boost though use the table so you don't get spike and load at low rpms. heres my table. it's post 13
http://www.mazdaspeedforum.org/forum/foru...tml#post166551
evo 8-tuned to E85
jwdp54 is offline
 Old 07-12-2009, 01:04 AM   #387
steven88's Avatar
hey guys I am having this one problem...
Under CONFIG, Boost Tab, wtf is Map Filt Len and WG Filt Len?
I understand all of the parameters here are suppose to be zero...unless I want to mess around with advanced boost settings...but every single time I try to Zero Map Filt Len and WG Filt Len, it gives me this error and keeps putting it to numerical value "01"...everytime I put it to "0" or "00" and sending it to the standback...it gives me this error
are you guys getting the same?
Also what are your fuel cut settings and advanced boost settings at? Mine is all zero except for the Map Filt len and WG Filt Len...I cannot put these values to 0, it keeps giving me that error...and when I try to save it to the standback as 0, and when I load the info later on, it keeps returning as 01 value
steven88 is offline
 Old 07-12-2009, 07:22 AM   #388
Phantom's Avatar
Anything I have read from Jordan was that the Map Filt Len and WG Filt Len should be left alone.
Boost settings are:
KP:30
KD:250
KI: .09
Boost Clip PSI: 08
MAP Filt Len: 05
WG Filt Len: 09
The fuel cut settings I am using are:
TPS Restore: 1
RPM Retore: 1100
MAF Volts: 1.20
MAF Volt Clip: 4.99
Min MAP FC Enable: -04
I am using the Turbo Smart BOV in hybrid mode. I was always using full recirc before the SB as in hybrid it would back fire a lot. Now I get a little pop/gargle from the exhaust but nothing like the bangs/booms I was getting before. I am still recircing some air back so that might be part of small noise now. I was just to lazy to swap to full VTA.
Phantom is offline
 Old 07-16-2009, 02:43 PM   #389
Cue
Cue's Avatar
I recommend you run the switch with 2 maps (race and conservative). If you get yourself in major heat soak conditions (summer time), you will knock mad with a race tune (depending how aggressive you get). Even with a FMIC, if your combustion chamber is up in temps, it'll be tough and long to cool down....
Cue is offline
 Old 09-11-2009, 01:33 PM   #390
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
I was tuning my car last night and got it running great adjusting the MAF and getting no knock except around 3k when i start the pull(I think i need progressive boost table to fix this) i was getting a weird drop in RPM and timing shoots to -3 then restores to normal power band. now when i go into WOT the car dont go it chokes and crams and bucks like its not igniting, not sparking correctly. I had this happen to me before when trying to tune and I had to replace spark plugs and shit.
I bypassed the SB and i still he this kicking in boost, before bypassing sb i only got low boost on boost gauge. now its showing 15 but still does that bucking and kicking not as severely with sb connected. wth is going on here. i dont think i blew the engine or anything runs perfect till you try to go into boost. no extra vibrations or motor struggles.
it registers NO KNOCK when doing this, ITS WEIRD ! I pull my DH logs and I cant show any abnormalities on the DH logs to show the issue.
I reset ECU 2 times and have SB bypassed, I am still having the issue, seems to be getting better but It should not be an issue at all.
I am running cpe fmic, cobb inlet, cpe cai, cpe catted dp, borla catback, cpe PNP + sb set to 17 psi, Grounding and big 3 kit. NGK iridium 1 step colder plugs gapped .030, turboxs Hybrid BOV, MSD DH, prosport Boost Gauge, PG FP Internals(released May 09), Medeival tranny mount, SU rear Engine Mount
I have pretty much isolated it down to it being the same issue i was having here Major Engine Cut with Stanback PnP
Freaking plug is fried again. why is the car nuking plugs ! Dashhawk has trouble code of cyl 4 misfiring. I pull the plug out, the arm is glazed over white
Nitr0EngiE is offline
 Old 09-12-2009, 02:33 PM   #391
ALL-IN.
AndyMS3's Avatar
Groans: 30
Have you logged your fuel pump pressures? I know my car started doing this last week while I was making a more aggresive tune and noticed my FP was starting to dip so it's time to upgrade.
AndyMS3 is offline
 Old 01-03-2010, 02:29 PM   #392
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
Hey everyone, I just got my MS3 and I'm trying to run a data log and I'm having connection problems with the StandBack. When I plug the cable into the computer and the SB I get a window saying that the driver is unidentified and has a problem. It says the software for the driver is installed but when I load the software it says "Standback ECU not detected". I have the V2.11A disc and I even downloaded Jordan's updated version but it still says the same thing. Any suggestions? I'm a complete noob if you can't tell already...
wette460 is offline
 Old 01-03-2010, 02:52 PM   #393
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Wette460. Download this file: Standback Drivers 2.04.16.zip
www.cp-e.com is offline
 Old 01-18-2010, 07:39 AM   #394
sleeper329's Avatar
Posts: 511   (View Stats)
sleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the world
EDIT: link found... forget i asked.
^^USE THIS LINK AND COUPON CODE SURIOT AT CHECKOUT FOR A DISCOUNT!^^
sleeper329 is offline
 Old 01-19-2010, 01:10 PM   #395
kcmousa's Avatar
Posts: 6   (View Stats)
kcmousa is an unknown quantity at this point
Default Info
A lot of very good information from Jordan. I am a newbie at tuning and this post has helped me way so much on where to begin.
Cheers from the North Coast..........
kcmousa is offline
 Old 02-13-2010, 01:37 AM   #396
nesiospeed's Avatar
Posts: 29   (View Stats)
nesiospeed will become famous soon enough
VERY GOOD EXPLANATION...THANKS
HI GUYS IM FROM CANCUN , I NEED SOME HELP TO TUNE MY CAR , IM JUST GET MY STANDBACK FEW DAYS AGO , BUT I DONT HAVE ANY EXPERIENCE WITH ELECTRONIC TUNING, I PRECIATE YOUR HELP , O IF SOMEBODY COMES TO CANCUN IN THE NEXT MONTHS , JUST LET ME KNOW I WILL TAKE CARE YOU...
nesiospeed is offline
 Old 02-13-2010, 06:28 AM   #397
sleeper329's Avatar
If you have a dash hawk, get in touch with CPE. They have been talking about doing Etunes. They just need the logs from the DH to know what changes they need to make in the tune.
 Old 02-13-2010, 05:50 PM   #398
nesiospeed's Avatar
thanks sleeper329 !! i need to wait until they changed my pnp harness becouse is faulty,
i did a full control flash with cp-e , but i monitoring the tps with my dashhawk and i see only 87% tps , do you know if i am checking wrong my tps???
 Old 02-13-2010, 09:23 PM   #399
FearUndersteer's Avatar
Posts: 189   (View Stats)
FearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the worldFearUndersteer is the leader of the world
I am considering getting this flash soon, what are your impressions?
2009 MazdaSpeed3 | True Red
35% Tint
CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC
FearUndersteer is offline
 Old 02-14-2010, 06:39 AM   #400
sleeper329's Avatar
Honestly i only got my DH a week or two ago so i'm not really sure. If you start a thread real quick and ask i'm sure youd get an answer. Not many ppl polk there heads in here. they're all AP guys.
"Standback Tuning For Dummies Guide" The Official Q&A... AutoXRacer MazdaSpeed 3/6 - ECU Computer Tuning 929 06-19-2012 10:07 AM
Official: How do you say "Chrysler minivan" in Italian? "Lancia Voyager" Haltech Automotive News 0 10-20-2011 02:20 PM
Standback Tuning for Dummies thread?? vbt101 MazdaSpeed 3/6 - ECU Computer Tuning 12 09-02-2009 09:13 AM
Automotive Traveler offers "Car photography for dummies" Haltech Automotive News 0 06-28-2008 03:50 PM
Page generated in 0.65832 seconds with 36 queries
