![]() | | #761 | ![]() |
![]() Join Date: Mar 2011 Location: Las Vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
| Not Ranked : 0 score
__________________ 2007 Mazdaspeed 3 GT: Cobb AP running stage 2+ 91 oct. w/ 3.5 gallons E85, cp-e Xcel CAI, cp-e FMIC, cp-e injector seals, Dashhawk 2 w/ cp-e mount, cp-e side engine mounts, Magnaflow CBE, M2 (ebay) Downpipe, TRZ Dogbone RMM, Denso ITV 22's, SURE Sidewinder TIP, SURE Return, SURE Intake Plenum and Throttle Body TIGs, SURE Shortcut and Countershift, SURE Anchors, KMD HPFP Internals, PNP'd Intake manifold and Throttle Body by Grimmspeed Working on my Tune In garage: New exhaust Mani |
![]() | | #762 | ![]() |
| Not Ranked : 0 score Also Richie I would PM you but I have to get to 15 posts first. I will as soon as I get there. WOuld love some base maps. Thanks again for the offer
![]() | | #763 | ![]() |
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 541
| Not Ranked : 0 score Honestly anything lower than 10 psi is probably fine. Higher and you could hit boost cut. 13psi is probably the upper limit of it working ok, though there is no downside to having it set lower. That way the ECU won't cut boost as it always thinks its so low.
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) |
![]() | | #764 | ![]() |
| Not Ranked : 0 score I'll be trying that tomorrow. THanks
![]() | | #765 | ![]() |
![]() Join Date: Jul 2008 Location: Canton, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,233
| Not Ranked : 0 score setting it to 4 or 5 should give you full boost in all gears (not that you'll have traction in first and 2nd). i just wanted to be sure the ecu wasn't limiting boost in any way. as far as your logs. it looks like it takes forever for the afr's to go down. i was going by your spark advance as to when you hit the throttle. but, with no knock it seems ok. it would be better to see a standback log of your runs. here is my lame KR that comes on at almost the same point in every run. I have lowered boost and it lessened the knock a little. 3.5 degrees down to 2.8. I'll play around with a few things to see if i can at least get it to 0. Not sure if it needs more fuel to help cooling. usually my boost is stable, this particular run it oscillated just a bit. FMIC for the win. Temps have never went up during a WOT run. On this run the ambient temp was about 42-45 degrees
__________________ cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC |
![]() | | #766 | ![]() |
| Not Ranked : 0 score I always got knock at that range. Started at 4900ish and then another peak at 5300ish. I never got that 100% under control. Pulled all kinds of timing, played with AFR, and 1 in 3 runs would have it.
![]() | | #767 | ![]() |
WHat should I log with the standback? Spark Timing, RPM, what else?
__________________ 2007 Mazdaspeed 3 GT: Cobb AP running stage 2+ 91 oct. w/ 3.5 gallons E85, cp-e Xcel CAI, cp-e FMIC, cp-e injector seals, Dashhawk 2 w/ cp-e mount, cp-e side engine mounts, Magnaflow CBE, M2 (ebay) Downpipe, TRZ Dogbone RMM, Denso ITV 22's, SURE Sidewinder TIP, SURE Return, SURE Intake Plenum and Throttle Body TIGs, SURE Shortcut and Countershift, SURE Anchors, KMD HPFP Internals, PNP'd Intake manifold and Throttle Body by Grimmspeed Working on my Tune In garage: New exhaust Mani | |
![]() | | #768 | ![]() |
| Not Ranked : 0 score SB should log everything. You don't have to choose what to log. You do choose what you wanted displayed on the graphs, but everything is logged.
![]() | | #769 | ![]() |
You want to be at around 11.5-11.8 generally close to after you go WOT.
Take away my raised fuel pressure -> test Take away more boost -> test Add more fuel -> test Reduce timing -> test
__________________ cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC | ||
![]() | | #770 | ![]() |
THis is just something that I have read from being on the forums. Haven't had the experience of testing it much.
![]() | | #771 | ![]() |
| Not Ranked : 0 score When you first asked this I basically answered from memory but now I have been looking into it more. I was told that my LTFTs should be under 8. When at cruise speed my LTFTs are at 3.9 but if I step into the throttle it goes to 12.5. Is this something that needs to be adjusted. I have been trying to read up on LTFT and STFT but does anyone have a simple explanation and/or some advice.
![]() | | #772 | ![]() |
| Not Ranked : 0 score LTFT is the only one you need to watch. It should be under +/- 8% while in closed loop (not WOT). Closer to 0 the better as this will change with temperature etc, so having it a -8% could go -12% with changes. In open loop it should be 0%. If it is not, then reset the ECU (unplug battery for 5 mins) and just drive normally for 30 miles or so (no wot). The ECU will relearn the trims. Hopefully then your WOT LTFT will be 0%. The way to adjust LTFT is via the MAF transfer table. If you have a -5% in a certain maf volts range then in that same maf volts range in the MAF transfer table, start decreasing the numbers (-1, -2, etc) until that range it closer to 0 in your LTFT. Changes to LTFT are not instant, they change over time. The STFT is instant but not a good gauge to what you need to change, so ignore it really.
![]() | | #773 | ![]() |
| Not Ranked : 0 score Cool. I think that is what I should do is reset my ECU. I don't know if I ever drove very tame for 30 miles after my standback install. Thanks
![]() | | #774 | ![]() |
| Not Ranked : 0 score Np. You may need/want to reset it a few times. Reset, adjust MAF transfer, learn trims, reset, adjust again, etc. You really just want you LTFT perfect before you go any further. If your not in a hurry, give it more than 30 miles. They can definitely take time to adjust, especially in the higher MAF volt range.
![]() | | #775 | ![]() |
![]() | | #776 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score You shouldn't have to change the maf xfer. I think 12 for ltft isn't bad. You should check for boost/vac leaks, not change maf xfer.
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | | #777 | ![]() |
| Not Ranked : 0 score High LTFT is normal if you have mods and not tuned. With my SB removed my LTFT are around 15% or so. I definitely had to modify the maf transfer to get it all in line. You shouldn't need to log. Just watch the LTFT and take note of when it changes. There are only 4-5 different ranges, so its not like it will change for each different MAF volts. Theranges are around <=1.3v, 1.3v-1.7v, 1.7v-2.1v, 2.1v-2.5v, 2.5v+. They are total estimates but it gives you an idea.
![]() | | #778 | ![]() |
Never mind found answer in one of your previous posts
![]() | | #779 | ![]() |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
the high trim is your ecu's way of saying "there is fuel lacking, so i'm providing more" you need to trick it and make it think there is more voltage then there is from the maf - already more fuel you can just start the car up with the sb already connected and a read done (with a buddy) - don't try and read with the car on - then you can just input the numbers where you are highlighted as you idle/cruise and watch your trims decrease or increase just keep in mind when you make a change on the mafxfer that it's for all rpm ranges - so if you add fuel at 1v - it's basically like adding a 1 on the 30x30 table from top to bottom at 1v also don't forget trims are highly variable depending on weather - so if it's cool now and you do this - when the weather changes all this may need done again..
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) | |
![]() | | #780 | ![]() |
![]() Join Date: Jul 2009 Location: Ville, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,037
I will just say, that since our cars are so MAF based, I like the trims as close to zero as possible. I do log LTFT's and MAF to see what changes to make at the break points to get it nicely done (This is probably overkill though) | |
![]() | | #781 | ![]() |
Groans: 27
![]() | | #782 | ![]() |
| Not Ranked : 0 score Well I just said fuck it and ordered up the the fuel cut ad full control flash. BUt now I read the post above about needing the big maf flash. What if I have the original CAI that cp-e released, do I still need that flash?. DO I need to amend my order?
![]() | | #783 | ![]() |
Groans: 27
ideally if you are on stock turbo - you would get both the bigger inlet and the bigger maf in order to have the best trims on the big maf/load cap flash
![]() | | #784 | ![]() |
![]() | | #785 | ![]() |
![]() | | #786 | ![]() |
| Not Ranked : 0 score Ya. On the way to PostNet I called the local dealership to get a price on an ECU and it was $1180 and change so I insured for $1200. Absolutely wasn't going to be caught with my pants down on that one
![]() | | #787 | ![]() |
| Not Ranked : 0 score Quick status update: I got this working but it has slowed down the logging quite a bit (2-3 samples a second), so I am in the process of getting that back to 6-8 samples a second it was before. Will post when its available on website.
![]() | | #788 | ![]() |
I, and am sure everyone else here using the SB is really looking forward to this. Thanks for your continued work on this... ![]() Guessing we would just need a OBD II to usb cable as far as hardware to run this? | |
![]() | | #789 | ![]() |
| Not Ranked : 0 score You will need an elm327 device. I have this one: ELM327 1.5V USB ELM 327 CAN-BUS V1.5a OBD Scanner tool | eBay But there are tons on ebay that should work. I have only used the USB and serial versions. Not used the bluetooth so no idea how they work exactly. Ill post when I have it sampling at a fast rate.
![]() | | #790 | ![]() |
![]() Join Date: Apr 2010 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 553
| Not Ranked : 0 score I've got a bluetooth elm327, so when this MST update is available, I'll try. Its probably just a bluetooth->serial bridge, so I would expect it to work as long as its paired with the laptop.
__________________ 2008.5 MGM Mazdaspeed 3 GT Cobb AP | cp-e SRI | cp-e TMIC | UR TP | cp-e RMM | JBR SSP | JBR Spherical Shift Knob | JBR RSB | Autotech HPFP | Spin-on |
![]() | | #791 | ![]() |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
| Not Ranked : 0 score What is the purpose of using this device?
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 |
![]() | | #792 | ![]() |
| Not Ranked : 0 score Read OBD data from the car via your laptop (i.e Dashhawk).
![]() | | #793 | ![]() |
Groans: 35
| Not Ranked : 0 score Yeah but what is the advantage of using this over the DH or SB software you've created?
![]() | | #794 | ![]() |
| Not Ranked : 0 score The ELM327 just plugs into the car where DH does and then other end plugs into laptop. My SB software will read the AFR, BAT, Kr, etc from the ELM327 at the same time it logs SB data and combine the 2 into 1 log file.
![]() | | #795 | ![]() |
| Not Ranked : 0 score I also use it to monitor via the Torque app on my phone.
![]() | | #796 | ![]() |
Groans: 35
| Not Ranked : 0 score Guys...thats pimp!
![]() | | #797 | ![]() |
| Not Ranked : 0 score So I got my flashed ECU back and I have a question that I think I already know the answer to. Using my dashhawk and putting the pedal all the way to the floor, the dashwak only shows 77% on the TPS. Is this because this is what the flashed ECU is relaying or am I only getting 77% of open throttle? If I logged with the standback would it show full control over the throttle?
![]() | | #798 | ![]() |
| Not Ranked : 0 score Yes
![]() | | #799 | ![]() |
| Not Ranked : 0 score yea, when you look at a SB log the TPS voltage will go to something higher than 4 volts. probably hover around 4.3-4.6v
![]() | | #800 | ![]() |
![]() Join Date: Jun 2009 Location: NS, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 171
Groaned at 10 Times in 1 Post
| Not Ranked : 0 score So I just picked up a used Standback2 and PnP a few days ago, as did a friend of mine and we are gonna give this tuning thing a try together. I realize that everyone is going to the AP, but I liked the price point of the SB and don't plan on going BT anytime soon so I'm hoping this will be okay. Anyway, I just read every single post here and learned a lot, made a bunch of notes. I gathered from what I read that the first thing I should do is nail down my LTFT's as much as possible. I was pretty surprised when I looked at my Dashhawk and it was reading -14 at idle! A little blip on the throttle brings it to -9. Is it normal to see numbers this negative? I've made the adjustments to my MafXfer table (0-1.5v: -2, 1.5-2.1v: -1) and will reset the ECU and go for a cruise tomorrow to test. Anybody still monitoring this thread and mind helping me out once I get some logs done? Also I'm using the modified software by MattJackson and really like it. Colin
__________________ 2008 Mazdaspeed3 / Bolted (mostly) / Parting out. |
| "Standback Tuning For Dummies Guide" The Official Q&A... | AutoXRacer | MazdaSpeed 3/6 - ECU Computer Tuning | 929 | 06-19-2012 10:07 AM |
| Official: How do you say "Chrysler minivan" in Italian? "Lancia Voyager" | Haltech | Automotive News | 0 | 10-20-2011 02:20 PM |
| Standback Tuning for Dummies thread?? | vbt101 | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 09-02-2009 09:13 AM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
| Automotive Traveler offers "Car photography for dummies" | Haltech | Automotive News | 0 | 06-28-2008 03:50 PM |
