 Old 12-19-2008, 07:53 AM   #201
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
Originally Posted by jhershorin View Post
But the lower the Kd that faster the turbo spools the more it will over shoot. God i miss my externally gated 35r.
Really? Did I miss that one... I thought the higher you went, the faster the spool...??
Its been a while since I played with these...these settings are the hardest for me to remember how they react since its not something I play with frequently...
Maybe then I'll leave mine as is...
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline
 Old 12-20-2008, 12:51 PM   #202
awd>fwd
jwdp54's Avatar
Posts: 627   (View Stats)
jwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the world
Groans: 27
Groaned at 53 Times in 33 Posts
i know this has been answered but i just got my denso one step colder plugs. what do i gap them at? i'm going to go log some data real fast while the weather on my side.
jwdp54 is offline
 Old 12-20-2008, 06:55 PM   #203
awd>fwd
jwdp54's Avatar
Groans: 27
i must be a dumbass or the person that sold me the dashhawk had broken it. for some reason i can't get the dashhawk to hook up to the computer. it always says disconnected. he sent me an older version(2.0) so i had to download the one off of the website(2.5). does that one not work? plus i must have an older version on the dashhawk it's self because i can not find kn rt and i can't seem to get the datalogger to work....
jwdp54 is offline
 Old 12-21-2008, 08:25 PM   #204
AutoXRacer's Avatar
The Denso come already pre-gapped!! Just install them and have fun...
 Old 12-21-2008, 11:36 PM   #205
awd>fwd
jwdp54's Avatar
Groans: 27
good cuz that's what i did lol got the dashhawk working and hopefully taking it to the dyno to get tuned tomorrow.
jwdp54 is offline
 Old 12-22-2008, 12:03 PM   #206
timv's Avatar
Posts: 179   (View Stats)
timv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud of
I just noticed even with the new v2.52 version, the MAF transfer still doesn't hold values for the 2nd column....
LOL!! One day we'll get that straightened out. I'll mention it to him again.
Good call! I will mention this as well.
Thanks for the comments guys
timv is offline
 Old 12-22-2008, 04:37 PM   #207
timv's Avatar
I noticed the AFR transfer issue when working offline in the software. If I hooked up my laptop to the standback and read all data, the values were still in the stand back so maybe it was something weird with my tune file......
timv is offline
 Old 12-23-2008, 05:51 AM   #208
racersir's Avatar
Posts: 71   (View Stats)
racersir is an unknown quantity at this point
Here are 2 logs on 4th gear with the map Jordan gave me any suggestions? Max Knock was 1.1 on first run and 1.4 on the 2nd run
2nd run
racersir is offline
 Old 12-23-2008, 10:49 AM   #209
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Hey, not too bad!
What I'm going to do is tweak your timing a little in the 4500-6000rpm range to quell some of that knock. The knock isn't bad but it is consistent, so I'm just going to yank a modest amount of timing in that region, and then restore the timing as you pass 6000rpm and boost pressure starts tapering off.
I didn't pull enough fuel in the top-end, so I pulled a little more. Give this map a shot and see if your AFR above 5500rpm looks more reasonable.
How did the car feel? How did the boost settings work for you?
www.cp-e.com is offline
 Old 12-23-2008, 11:44 AM   #210
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i should post some fucking logs.
my car is backfiring a ton and i need help
phillyb is offline
 Old 12-23-2008, 01:12 PM   #211
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
I don't why some peoploe get knock and some don't. I did some runs with mario "elbartoex" on here last weekend and he was getting 5 knock above 5000 rpm.. on low boost with no tune.
gsrtype1 is offline
 Old 12-23-2008, 07:39 PM   #212
phillyb's Avatar
Groans: 1,940
third gear...nvm
i have to load the "tune" that my awesome car is running. don't help me yet. just look at my shitty log
phillyb is offline
 Old 12-23-2008, 08:16 PM   #213
racersir's Avatar
Hey, not too bad!
I will try that map, car feels great pulls hard. The boost setting are working great. Thanks a lot Jordan for your help I will post some logs as soon as I have them Thanks again
racersir is offline
 Old 12-23-2008, 09:14 PM   #214
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
third gear
Looks like you need a fuel pump or internals.
2008 MS3
Forge BPV, COBB SRI, AP ATR Stg 2+SF v107 FMIC, RPMC turbo inlet, Exhaust Depot DP, CP-E CBE, KMD internals, TT, DH, OF conversion, TRZ Poly mount, Exhaust Depot FMIC,TWM ss w/bushings, ITV22, AIS meth injection
Speedn3 is offline
 Old 12-23-2008, 09:48 PM   #215
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
just about to say that.
Grim is offline
 Old 12-23-2008, 10:40 PM   #216
phillyb's Avatar
Groans: 1,940
yeah. i saw that. that's the first log i've ever seen a problem with my fuel pressure. i've logged it at least 30 times. oh well.
weird. do i need fp before i can even tune?
phillyb is offline
 Old 12-24-2008, 07:55 PM   #217
SyntaxEscobar's Avatar
Posts: 21   (View Stats)
SyntaxEscobar will become famous soon enough
Wrong SN buddy. It's all good tho. I did several WOT runs monday in 3rd and 4th and got very few blips under 1 and only once up to 1.2 while at 6K rpm.
HOKAY! I got the Standback installed and want to log w/ it.
Can I record the AFR through the stock wideband on the standback? (plz don't tell me I ran a USB cable inside to have incomplete logs!!!)
Life is hard. After all, it kills you.
SyntaxEscobar is offline
 Old 12-24-2008, 10:24 PM   #218
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
you can not currently log the stock wideband with the SB
SSinstaller is offline
 Old 12-25-2008, 01:13 AM   #219
Speedn3's Avatar
When I first started to log my fp never dropped. After I got the ap and started to tune the fp dropped sporiactly(sp).
Installed the internals and haven't had an issue since.
I would take care of the pump prior to tuning. Looks like it happening in the upper rpms which isn't good.
2008 MS3
Speedn3 is offline
 Old 12-25-2008, 08:39 AM   #220
awd>fwd
jwdp54's Avatar
Groans: 27
wow what the hell?? so this is with my sb zeroed out and set to 18.0 the temp outside was around 20.boost held great til that unknown hiccup at about 6500. i don't know if i wanna be happy that i'm not getting much knock(never got past .4) but i'm pissed cuz my fuel pump is shot. help!!!! lol
jwdp54 is offline
 Old 12-25-2008, 11:39 AM   #221
awd>fwd
jwdp54's Avatar
Groans: 27
here are 2 more logs that i just went out and did.
knock was still at i think .4
jwdp54 is offline
 Old 12-25-2008, 07:30 PM   #222
Speedn3's Avatar
Yep...definitely need the pump or internals.
You're in luck...I read a post from Ken stating he has them in stock.
2008 MS3
Speedn3 is offline
 Old 12-27-2008, 11:18 PM   #223
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
Hey guys,
Picked up a Standback v2 PNP and here is a 4th gear log that I took with settings to be posted soon.
What should I do/Where should I go from here?
Jeff
All wagon, No traction
wassup61 is offline
 Old 12-27-2008, 11:23 PM   #224
wassup61's Avatar
And standback tables as promised.
ETA: I was seeing some knock of .4-.7 in the same area it is now, so i took away timing and added fuel in that area. However, now, in the region with nothing changed and -4 timing I am getting knock. Whats the deal???
wassup61 is offline
 Old 12-28-2008, 10:15 PM   #225
AutoXRacer's Avatar
Can't really read your log... Details are not readable... Try to post them like others have and use that formal (zoom, etc)...
 Old 12-28-2008, 10:39 PM   #226
wassup61's Avatar
if you scroll over the image and then over the lefthand corner there is a button to expand the image.
wassup61 is offline
 Old 12-28-2008, 10:54 PM   #227
AutoXRacer's Avatar
First thing I would do is lean out your AFR starting at 4900 RPM to 12.0...
Regarding KR, what type of fuel are you using?
I would start pulling timing at the latest at the 4.0 TPS Volts; I personally start pulling at around 3.0.
Maybe that would help your KR, though the most I pull is -2 in certain spots...other than that I mostly pull 1.5 max. Though I use 93 Octane.
 Old 12-28-2008, 11:28 PM   #228
wassup61's Avatar
I am running 93 octane, and timing pulled is what jordan sent me as a base map, I just pulled a little more where I saw knock. pulling -1.5 timing seems a bit low, though you are running 2 step colder plugs where I am running 1 step colder. all the knock is below 1 degree except for the later KR which is 1.1 degrees. What the fuck!
wassup61 is offline
 Old 12-29-2008, 12:46 AM   #229
phillyb's Avatar
Groans: 1,940
ok, so i have my afr dialed in pretty well, but i'm having a problem with the areas in between the software rpm parameters. for instance, my afr at 43xx and 45xx are ok, but in between there is a jump. how do i work with that?
phillyb is offline
 Old 12-29-2008, 03:31 AM   #230
CP-E, are you guys working on getting stock wideband to log on the SB or have you given up on that? (the Xtended Fuel Controller for Mazda3s can do it)
When using my own wideband, what brand or type of sensor am I expected to connect to the SB's wideband wires?
Also, could someone tell me where I can grab a VTA map?
Thanx in advanced.
 Old 12-29-2008, 07:09 AM   #231
Phantom's Avatar
Posts: 313   (View Stats)
Phantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud of
Thanx in advanced.
http://www.mazdaspeedforum.org/forum/...standback-tuning-dummies-guide-official-post#6
Phantom is offline
 Old 12-31-2008, 03:11 AM   #232
racersir's Avatar
Just did 2 pulls of 4th gear only saw .4 KR, will post these maps later when I get home
racersir is offline
 Old 01-15-2009, 11:22 AM   #233
Driverman5777's Avatar
Posts: 685   (View Stats)
Driverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the world
Groans: 76
amazing thread guys... lots of awesome information. I just got my standback installed in my 06 speed6 with a base map from jordan set to 17.5 PSI and a bit of timing pulled. Waiting on my dashhawk to arrive in the mail, and I have to get my gasket for my BOV because the dealer lost it when they replaced my engine.
So I am meeting up with Jordan on saturday to get some help with tuning and then I should be posting some datalogs and seeing what you guys think.
Keep the info coming!!!
Driverman5777 is offline
 Old 01-15-2009, 05:14 PM   #234
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
@Driverman5777
Is Jordan going to be giving you a lesson in tuning? If so, I wouldn't mind meeting up with you guys. I'm really interested in figuring out how to get the standback dialed in. This thread is really helpful, but its definitely nice having someone with experience around. I have to bring my standback in anyway. And, my dashhawk came in yesterday, in case yours doesn't show up by Saturday.
Let me know.
vbt101 is offline
 Old 01-15-2009, 06:46 PM   #235
Groans: 76
so after reading everything I have a few questions...
Explain Ki, Kp, Kd a little bit more… (toaster oven) perhaps in simpler terms… I think I get it, I guess I just want reclarification.
What is LIFT(Long term fuel Trims)? Where are they in the standback? What do they do?
How do I Fine tune VTA??? So that pop and the sort of stutter after shifting is eliminated
I see everyone talking about upwards of 18 psi… I thought 18.5 was the max efficiency of the stock turbo???
I heard the stock boost sensor can only read up to 22.5 psi, is that true?
Tuning with MAP instead of MAF… wouldn’t this be better with VTA? Would there be a difference?
Also... how will weather affect tuning with the standback... Its pretty cold here in MD... around 10 outside right now, and I've been reading that weather plays a pretty big role in AFR... Can someone explain this?
 Old 01-16-2009, 11:29 AM   #236
awd>fwd
jwdp54's Avatar
Groans: 27
i'm waiting til it warms up a bit. temps are in the teens here too but next week should be in the 40's.
jwdp54 is offline
 Old 01-16-2009, 11:37 AM   #237
Smoker6's Avatar
Posts: 984   (View Stats)
Smoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the world
The colder it is the denser the air the more fuel needs to be added in to maintain the desired AFR. As laloosh pointed out once you have your tune you can adjust the whole AFR line by bumping/lowering the MAFxfer function. Keep in mind also that currently what you're getting at the pumps is shitty winter fuel mix which is ftl.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout.
Smoker6 is offline
 Old 01-18-2009, 04:34 PM   #238
Sanch's Avatar
Posts: 115   (View Stats)
Sanch is a splendid one to beholdSanch is a splendid one to beholdSanch is a splendid one to beholdSanch is a splendid one to beholdSanch is a splendid one to beholdSanch is a splendid one to behold
I am getting 5.3 knock thats hella bad.
HAVING A NINE SECOND HONDA IS LIKE COMING OUT OF THE CLOSET AT FIRST EVERYONE IS AMAZED BUT IN THE END YOUR STILL GAY!
Sanch is offline
 Old 01-19-2009, 04:32 PM   #239
wassup61's Avatar
From your log, you have fuel cut. You need a CDFP upgrade
wassup61 is offline
 Old 01-19-2009, 05:20 PM   #240
spnkr21's Avatar
Posts: 2,827   (View Stats)
I'd like to see an answer for the wideband question. Are you able to buy a different wideband sensor and hook it up to the SB and datalog with that?
spnkr21 is offline
"Standback Tuning For Dummies Guide" The Official Q&A... AutoXRacer MazdaSpeed 3/6 - ECU Computer Tuning 929 06-19-2012 10:07 AM
Official: How do you say "Chrysler minivan" in Italian? "Lancia Voyager" Haltech Automotive News 0 10-20-2011 02:20 PM
Standback Tuning for Dummies thread?? vbt101 MazdaSpeed 3/6 - ECU Computer Tuning 12 09-02-2009 09:13 AM
Automotive Traveler offers "Car photography for dummies" Haltech Automotive News 0 06-28-2008 03:50 PM
Page generated in 0.73569 seconds with 38 queries
