![]() | | #281 | ![]() |
![]() Join Date: Jan 2009 Location: Towson, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,747
Groans: 76
![]() | | #282 | ![]() |
![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 249
![]() | | #283 | ![]() |
Groans: 76
| Not Ranked : 0 score thats a really really cool idea |
![]() | | #284 | ![]() |
![]() Join Date: Aug 2008 Location: Behind the wheel
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
I wonder why the DashHawk can't/doesn't display TPS volts.... oh well. | |
![]() | | #285 | ![]() |
![]() Join Date: May 2008 Location: Saint John, NB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score Doesn't the DH show TPS but it doesn't look like volts. It runs from 0 to 50. So I was thinking that 50 is 5.0. Anyone know if this is a correct assumption? |
![]() | | #286 | ![]() |
| Not Ranked : 0 score Maybe I am looking at the wrong TPS... I normally get a percentage that I've seen get as high as around 80%. I had heard, you know those internet truths, that it was incorrectly reported as a percentage but was actually degrees (0 being closed and 90 being fully open). |
![]() | | #287 | ![]() |
| awd>fwd ![]() Join Date: Aug 2008 Location: Phoenix, AZ
Rep Power: 197 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 394
Groans: 27
Groaned at 53 Times in 33 Posts
| Not Ranked : 0 score what else could i do to get that line a little bit straighter? |
![]() | | #288 | ![]() |
![]() Join Date: Nov 2008 Location: tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groaned at 16 Times in 4 Posts
| Not Ranked : 0 score any recomendations?
__________________ 2010 mazdaspeed3 (current) jbr rmm, jbr stage 2 intake, jbr shifter bushings, cpe hpfp, obx cbe, catless downpipe, cobb fmic , bosh 3 bar map , jbr 3 port ebc,jbr IM and TB thermal gaskets, jbr egr delete, HKS ssqv,jbr short shift plate . |
![]() | | #289 | ![]() |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
Groaned at 42 Times in 35 Posts
| Not Ranked : 0 score minime do you have a fuel pump? you have an odd pressure drop, and whats with the knock? |
![]() | | #290 | ![]() |
| Not Ranked : 0 score im runing the stock fp my v2 internasl ship the 11th adn i need help with the kr im getting 2.8 for a fe 100 rpms
![]() | | #291 | ![]() |
![]() | | #292 | ![]() |
| Not Ranked : 0 score cacant i just pull some timing? i only havr intake amd dp
![]() | | #293 | ![]() |
![]() | | #294 | ![]() |
| Not Ranked : 0 score yea i have a sb and il jus run my secondary map untill my cdfp comes in thank you very much
![]() | | #295 | ![]() |
![]() | | #296 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: northern nj
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 350
| Not Ranked : 0 score Im new wiht the stand back i was trying to understand the pids.Tell me if im right if i spike over my desinated boosti will have to higher the kd and lower the kp.And if i wana keep it from dropping off from my desired boost i will have to adjust the ki.tell me if im correct befor ei start fucking wiht it. lol thanks guys |
![]() | | #297 | ![]() |
| Not Ranked : 0 score im acyually on the m3f but im always on the what have you beat tread
![]() | | #298 | ![]() |
![]() Join Date: Jan 2009 Location: Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 264
| Not Ranked : 0 score ^ What's up man? I've seen ya around the webs. |
![]() | | #299 | ![]() |
| Not Ranked : 0 score nothing much an just waiting on the cdfp to finish tuning my car
![]() | | #300 | ![]() |
![]() Join Date: Jun 2008 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
Groaned at 6 Times in 1 Post
| Not Ranked : 0 score Man i read all this and i still have no idea where to start on tuning the car. i have never done nething like this before and i want to get this thing tuned bad. anyone wanna throw some help my way if i give ya the link to my DH logs? |
![]() | | #301 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score If your still looking for help post up your dashhawk logs and I'll check back. I tuned my car and once you get the hang of the standback it's really easy. |
![]() | | #302 | ![]() |
![]() Join Date: Mar 2008 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 456
| Not Ranked : 0 score Werd +1 to that. I had help the first time and that way I learned wtf to do, and after that it made sense. Once you get your head around everything its very straight forward.
__________________ '06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s | CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout. |
![]() | | #303 | ![]() |
| Not Ranked : 0 score Alright well the 3 logs that i did post are on this page here Standback Tunning If you click the link below the logs u can zoom in on the pics so that way u can actually tell what the numbers are that you are looking at. I have the one guy on here helping me out now so hopefully we should be alright. he seems very knowledgeable with the standback and is very nice! but all insight is much appreciated! thanks everyone for responding! |
![]() | | #304 | ![]() |
| Not Ranked : 0 score So did they make an official map to be used as a kill switch? |
![]() | | #305 | ![]() |
| Not Ranked : 0 score Hey guys im having a problem of my turbo spooling up really fast and falling of quick.Can ya give me a idea on how to keep the turbo from spooling so fast.Can i use the kd ki and kp.And doe sanyone have the numbers there runnning on those.Im fully bolted |
![]() | | #306 | ![]() |
![]() Join Date: Apr 2008 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 577
Groans: 38
| Not Ranked : 0 score what are your pid settings? you need less kp, more kd,.... |
![]() | | #307 | ![]() |
![]() | | #308 | ![]() |
![]() Join Date: Jan 2009 Location: DC
Rep Power: 228 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 408
| Not Ranked : 0 score 2 questions: First, the Standback allows you to tune relative to the MAP sensor, as well as fuel pressure. Everything that I've read uses the MAF sensor. What are the advantages to the other two methods? Also, are all of my tuning adjustments cumulative? That is, if I made adjustments to all of the tables (MAF, MAP, FuelPSI), would all of those be signals be cooked simultaneously at a given moment? |
![]() | | #309 | ![]() |
Groans: 38
![]() | | #310 | ![]() |
Groans: 38
![]() | | #311 | ![]() |
| Not Ranked : 0 score Thought of another one: Meth tuning. What's the best strategy? I have the ProFuel controller. My SB hasn't been tuned at all, and my goal is to run safely at 19psi, so I was thinking by approach was going to be... 1. Set boost to 17.5psi to start (just to be safe) 2. Spray where necessary to eliminate KR 3. Pull/add fuel to achieve 12.5 AFR 4. Repeat steps 2 and 3 until 12.5AFR and 0KR. 5. Up the boost to 19psi and repeat 6. +1 meth (arbitrarily, because I have no idea). 7. Advance until AFRs hit 12.5 again. 8. Quell knock with another +1 meth. If knock still exists, -1 meth, retard 2 degrees (or until KR=0), and consider that portion of the table tuned. I'm assuming that if adding a little more meth doesn't help the knock much, then I'm probably close the the safe timing advance limit. Is this a good assumption? 9. Repeat 6,7,8. What do you guys think? Any safe way to shorten this so I don't have to do 700 pulls? Is it safe to skip straight to 19psi (I have a CPe FMIC)? |
![]() | | #312 | ![]() |
| Not Ranked : 0 score The other two methods were by adjusting the MAP and/or FuelPSI tables, rather than the MAF table. |
![]() | | #313 | ![]() |
Groans: 38
| Not Ranked : 0 score I just use the maf table not the map or fuelpsi one so I dont know how that would work out. As far as tuning you have a pretty good idea of whats up. yes you will have to do 700pulls to really get your car dialed in, it takes time to DIY so be patient. If I was you I would put boost straight to 19.5 psi so you dont have to tune the car twice. Send a pm to someone like speed3shon or subparpunk03-they have used meth with the standback/profuel and could tell you where to start out at with the spray, and from there you can easily do the tweaking to your afr's and pull timing where needed. I know 12.5 is ok to do on a DI car but if I was you I would tune and shoot for 11.7 to 11.9 so you have a safety net on your afrs if weather/shit changes |
![]() | | #314 | ![]() |
| Not Ranked : 0 score That makes sense about setting your AFR to allow for weather/slight mods without having to retune. I think you can use the MAF xFer function to quickly shift the AFR line up or down (assuming you're using the MAF table to tune) to account for these changes though. So, I assume MAF xFer won't affect the meth spray at all. If I adjust the MAF xFer to move the AFR line, will I have to retune the meth table? |
![]() | | #315 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score I didnt actually use the profuel controller. But i love the way it works. Because you know exactly where your spraying, so you should know exactly where to start adjusting your fueling. It seems to me like you have a good procedure to go by. Baby steps is the safest way. But dont forget you can also alter your air fuel with timing. I wouldnt go too crazy with it, but once you get close by pulling fuel, start to play with timing. Like i said, its great with the profuel cuz you know where, when and exactly how much meth you are spraying based on the tables you are using to alter your fueling. on mine it was very broad, because i was basically spraying meth anywhere over 10psi... that was alot of different circumstances on the tables in the standback. Another good thing about the standback is that you can do what you want, but the ECU will still for the most part keep you safe. Have fun, drive safe.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
![]() | | #316 | ![]() |
Groans: 125
as stated before, stick with the maf tables for fueling changes.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 | |
![]() | | #317 | ![]() |
![]() Join Date: Feb 2009 Location: Calgary, AB. Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score Here's how I tuned. All this starting with timing pulled (about -5 to -7 from 4000rpm to 6000rpm) - The first thing you should do is find your turbo's effeciency range, during certain areas of the rpm band. Set your boost to that. 19psi isn't necessarily a good thing, cause over 4900rpm, the turbo can't do it... I think the max for MS3/6's is about 16 over 5000rpm. Having it set at 19 will just start blowing extemely hot useless air (while overheating your combustion chamber increasing temperatures and knock issues). For me (CX7) this is what I have set in my table..... 4100-4600 - 18psi 4600-4800 - 17psi 4800-5000 - 16ish psi 5000-5300 - 14.5ish psi 5300+ - 14psi - Second, set your afr tables. I'm running from about 14afr (3800rpm) to about 11.7 (5500rpm). - then start advancing your timing until you knock. Afterwards, pull another .5 to be safe. All this being said, you should be logging and tuning at consistent BAT temps (Dashhawk). I'd say between 100-130. Below 100, you can tune much more aggressively, but really majority of the time, your not under 100. And not over 130, cause it's really not a good idea to be racing your engine that hot.
__________________ 2008 CX-7 Crystal White Pearl AWD CP-E Standback2 w/PNP, CP-E FCF, AEM SRI, AC FMIC, Forge BPV, CP-E 3" Midpipe, CP-E 3" Dual CBE, MSD Dash Hawk |
![]() | | #318 | ![]() |
| Not Ranked : 0 score ...oh, and the MAP table works as a map clamp. Same as the boost clip, but more specific to certain areas. Really a useless table. Just set your boost clip to 6, 7, 8psi... And in terms of Fuel Pressure table... I'm not 100% sure, so I don't use it. Seeing our fuel depends on the MAF sensor, and according to it's readings needs to supply x amount of fuel, I can't see why you would need to change the pressure??... So again, I leave it at 0.
![]() | | #319 | ![]() |
Thanks for chiming in. That's interesting. So, if you are going to have to change the MAF table anyway, then what's the advantage to the MAF xFer? | |
![]() | | #320 | ![]() |
| Not Ranked : 0 score Maf changes fueling at specific points, where as MafXF changes the entire band....
| "Standback Tuning For Dummies Guide" The Official Q&A... | AutoXRacer | MazdaSpeed 3/6 - ECU Computer Tuning | 929 | 06-19-2012 10:07 AM |
| Official: How do you say "Chrysler minivan" in Italian? "Lancia Voyager" | Haltech | Automotive News | 0 | 10-20-2011 02:20 PM |
| Standback Tuning for Dummies thread?? | vbt101 | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 09-02-2009 09:13 AM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
| Automotive Traveler offers "Car photography for dummies" | Haltech | Automotive News | 0 | 06-28-2008 03:50 PM |
