![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
| Not Ranked : 0 score Lol oh I have been. My car has been a dirty whore lately so we have been swapping maps for the last 48 hours. I was just busting his balls. Those AFR's are sick though! Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. |
| Not Ranked : 0 score I ran this on my new Mazda maf sensor (finally got tired of reman inconsistencies). The curve looks beautiful, I can't wait to load it up and take it for a spin. Just an FYI for any dummies out there like me, when @TiGraySpeed6; provided his excel example and included =J2*I2^K2 where J = base, I = MAF volts from ATR, and K2 = power, this equation has to be entered exactly this way in Excel or the computation is wrong. I was doing I2*J2^K2 and my numbers were wrong (of course because its the base to power). Use a row of @TiGraySpeed6;'s and/or @rfinkle2;'s data to verify the equation and numbers in your own spreadsheet as a check before running your own data, i.e. run a row of their data in your equation and make sure the numbers match theirs. I did this to figure out what I did wrong.
| Not Ranked : 0 score I'll make a thread about it maybe, but I found the reman had poorer granularity and flat spots in its response through the voltage range. Even on my initial comparisons, the Mazda OEM MAF responds more linearly across its response range and even has better voltage range response given the same airflow. Of course I don't flow any more, but now the sensor responds from 0-4.3v whereas the reman only responded from 0-4.1v in my car. Doesn't sound like much but this gives more granularity in the MAF sensor calibration table and will probably give me a much flatter AFR curve.
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
.2 is still like about 4.88 percent.... Plenty of error/room to screw things up.
__________________ "I only do what the voices in my wife’s head tell her to tell me to do" | |
| Not Ranked : 0 score This should be added to the KB and stickied. @Raider;
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | rfinkle2 (02-15-2013), VulgarKyle (07-16-2013) |
| Display Modes | |
| Using Excel to dial in your maf curve (meth users, perfectionists, etc.) | rfinkle2 | 2010 MS3 - ECU Computer Tuning | 1005 | 07-14-2018 10:06 AM |
| Trying to dial in this tune | Guerra88 | 2010 MS3 - ECU Computer Tuning | 23 | 05-24-2012 10:50 PM |
| Help me dial in my 3076. :) | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 63 | 09-04-2011 09:45 AM |
| cpe stand back users and meth | phillyb | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 14 | 04-24-2009 12:06 PM |
