> MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline
 Old 07-07-2009, 01:58 PM   #41
SPD6Tuner's Avatar
Posts: 391   (View Stats)
SPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant future
I broke 2 T40 sockets and have no car to go buy another one. One of which was a craftsman. I have to get to sears to replace it, so I am going to have to stop untill tomorrow. But I did find my misfire problem. Cylinder 3 has a seal leak and is very dirty like aaronc's.
SPD6Tuner is offline
 Old 07-14-2009, 09:58 PM   #42
SPD6Tuner's Avatar
I cant get the 2nd or 4th torx screw off. If I pull on the fuel rail I know they will come off the injectors but is that bad. Is there a clip holding the injector on the rail or is this ok.
 Old 07-15-2009, 08:46 PM   #43
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
SPD6TUNER,
I am also replacing my injector seals right now, you need at T41 (not a T40) for your torx soquet to take off the little brackets that hold the injectors in place. I twisted two off my T41 torx soquets because they were a cheapy kind but I'm buying a good one tomorrow.
11cruzito11 is offline
 Old 07-15-2009, 08:56 PM   #44
my bad i meant you need a T40 soquet (which you have), but make sure to get a good solid one.
 Old 07-15-2009, 10:32 PM   #45
SPD6Tuner's Avatar
I was using craftsman. Can they get any more solid than that?
 Old 07-16-2009, 08:37 AM   #46
I'm having trouble removing mine as well, I'll let you know what works for me today!
 Old 07-16-2009, 08:43 AM   #47
SPD6Tuner's Avatar
I think I am just going to cut a slot into mine and remove them with a flathead screwdriver cause mine are already stripped so I have no other choice. Then I will go to mazda and pick up new ones.
 Old 07-16-2009, 12:05 PM   #48
I just the impact gun today with the T40 and all the brackets came out. Sorry to hear yours stripped man.
 Old 03-17-2010, 07:55 AM   #49
shpankey's Avatar
Posts: 496   (View Stats)
shpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the world
Snap-On?
09 Speed 3 GT
shpankey is offline
 Old 03-29-2010, 09:33 PM   #50
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
Is there a specific orientation for the throttle body gasket?
vbt101 is offline
 Old 08-16-2011, 12:37 AM   #51
Delphie's Avatar
Posts: 150   (View Stats)
Delphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the worldDelphie is the leader of the world
Another great thread gone to shit because people think that Photobucket is good for some reason. Jesus tapdancing fucking christ people, STOP USING PHOTOBUCKET.
2007 Velocity Red Mazdaspeed 6 | SURE Dreadnought Rear Diff Mount | CP-E WishBone Motor Mount | AutoMeter 5777 Boost Gauge | Cobb SRI | RPM Sport Springs | JBR Stage 1 SSP | JBR Heavy Shift Knob | Type-M V2 18x8 rims | Hankook V12 235/40/18 tires | Hypertech Tune | Dashhawk V2
Delphie is offline
 Old 08-18-2011, 10:36 PM   #52
evidence's Avatar
Posts: 1,033   (View Stats)
More recent photobucket
How To CPE Injector Seals + Studs + EGR Delete
Some things.
evidence is offline
 Old 06-18-2012, 12:44 PM   #53
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Subbed so I can see the pics at home.
Pickles Tune in progress
himurax13 is offline
 Old 06-18-2012, 12:52 PM   #54
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
you aren't going to see shit b/c the pics are all removed.
to get to the seals, follow the various "how to" threads. like this one:
How-To: Injector & Intake Manifold Removal
you could also follow JBR's guide to do the TIG. this will get you 90% of the way there.
http://jamesbaroneracing.com/support...structions.pdf
and if you're doing the injector seals, you might as well clean the valves as well. i want you to feel like you contributed, though, so i won't link all the how tos for that.
it's fun to do bad things
jack_hammer is offline
 Old 09-19-2012, 02:04 PM   #55
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: Injector Seals Replaced
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
injector seals help mczimer Mazdaspeed3/6 General Discussion 16 07-27-2012 10:21 AM
Injector Seals Replaced aaronc7 MazdaSpeed 3 - Engine, Transmission & Driveline 53 06-18-2012 12:52 PM
CP-e Injector Seals ak_spray Revolution Performance Motorsports 11 01-25-2012 10:20 PM
Page generated in 0.35114 seconds with 28 queries
