> MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline
 Old 04-01-2012, 02:40 PM   #281
Snotrocket's Avatar
Posts: 900   (View Stats)
Originally Posted by mazdafreak View Post
@Snotrocket, did u replace anything else, like studs, washers or just replaced the stock injector seals with these Toyota ones??
Thanks.
Just seals.
Tapped
2010 MS3 Black
395whp/386wtq
Snotrocket is offline
 Old 04-01-2012, 08:40 PM   #282
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Ahh okay thank u!
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
mazdafreak is offline
 Old 04-02-2012, 07:30 PM   #283
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
I didn't realize that PTP sold a stud kit, that's cool. I have a set of the studs, nuts, and washers from Fastenal back when we first figured out all the part numbers, but now since I have to order another set for the other car, I won't have to go digging around for that thread or my receipt. Word.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 04-02-2012, 08:23 PM   #284
Snotrocket's Avatar
now as far as i understand it if i have leakage it will show up as false knock? How much knock usually? are there any other tell tail signs?
2010 MS3 Black
395whp/386wtq
 Old 04-02-2012, 10:11 PM   #285
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Yeah, the magnitude of kr will depend on how bad the seals are. If you find that you are getting kr, run 2-3 gallons of E85 in a tank of fuel. If the knock is still present, something else is causing kr. Either noise or seals.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
 Old 04-03-2012, 09:27 PM   #286
Snotrocket's Avatar
Today i took the time to redo these seals because as you know i put them in flat side to the head originally. They are now sitting flat side to the injector as suggested by everyone here. I am a slightly concerned now tho as i am getting some consistent knock between 3000-4000 RPM when my loads are the highest. Because we can not get E85 here in ontario i decided to flash with the cobb stage 2 93 oct shelf map. I am still getting this knock.. Could this be an issue with the seals?
Edit: Knock is less then 1 degree and resolves post 4000
2010 MS3 Black
395whp/386wtq
 Old 04-03-2012, 10:38 PM   #287
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
It is possible the seal isn't functionion due to it being slightly compressed upside down. Perhaps buy another set.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
mrmonk7663 is offline
 Old 04-03-2012, 11:27 PM   #288
xb2ms3's Avatar
Posts: 636   (View Stats)
xb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the world
try octane booster if you cant get e85
2011 Black Mica MS3
NJSPEED3 Ported IM + other shit
NJ NATOR NY
316.52 hp / 352.12 tq 93 oct K04@ Nator DC Dyno Day 11.10.12
xb2ms3 is offline
 Old 04-04-2012, 06:18 AM   #289
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Today i took the time to redo these seals because as you know i put them in flat side to the head originally. They are now sitting flat side to the injector as suggested by everyone here. I am a slightly concerned now tho as i am getting some consistent knock between 3000-4000 RPM when my loads are the highest. ...Could this be an issue with the seals?
I didn't think these toyota seals could be re-used. I thought they deformed as they created the seal, and if removed & reinstalled would never be able to properly form the seal again.
I'm gonna say redo with a fresh set
340hp / 371tq
TiGraySpeed6 is offline
 Old 04-04-2012, 06:23 AM   #290
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
+1 on this. Redo
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline
 Old 04-04-2012, 06:33 AM   #291
Snotrocket's Avatar
i used new ones... I'm never doing them again.. lol
2010 MS3 Black
395whp/386wtq
 Old 04-04-2012, 06:41 AM   #292
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
KR less than 1 degree around max torque is pretty normal. I'd say I get this in 75% of my logs since I have had my AP.
G26 is offline
 Old 04-04-2012, 06:43 AM   #293
Snotrocket's Avatar
i hear ya.. i was getting the same.. only now I'm getting it in 100% of my logs.... Maybe its a non issue i dunno.
2010 MS3 Black
395whp/386wtq
 Old 04-04-2012, 06:44 AM   #294
G26
G26's Avatar
Groans: 39
Phate had a thread on it, said it was normal. Either way, my seals are getting done at 20k miles (at 15k right now)
G26 is offline
 Old 04-04-2012, 08:13 AM   #295
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
False.
"Exclusivity" - CP-enis
Demodded.
The Seals
Tokay444 is offline
 Old 04-05-2012, 03:23 PM   #296
Snotrocket's Avatar
Ok,correction... It's a pain in the ass for me to get.
Tapped
2010 MS3 Black
395whp/386wtq
 Old 04-05-2012, 03:28 PM   #297
knarfies's Avatar
Posts: 2,568   (View Stats)
knarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the world
Found a local dealer in ABQ NM that had to order them but they will be here tomorrow at $1.90 a pop.
**********************Riding Rainbows Since 1986.**************************
knarfies is offline
 Old 04-05-2012, 05:44 PM   #298
aviator79's Avatar
Posts: 3,934   (View Stats)
Originally Posted by thatsmrgimp2u View Post
I ordered the ptp studs... Was worth the 40 bucks to not have to cut the old bolts. Im going to put the studs in just past hand tight with red loctite and torq the nuts to ~17ft/lbs.
Wow you must be rich...
...it was my understanding the washers it comes with actually fits the crow's feet better than the tapered OE washer. The thought is the taper doesn't allow for even TQ distribution across the foot and is why they work lose...
Thats a bunch of same BS IMO but good advertising as expected...
This may have been answered but i don't have time to go through the thread.. can anyone tell me what way they go in? Flat side to block or to injector?
Doesnt matter IMO...
Originally Posted by ColonR View Post
You need (4) 8mm x 1.25 pitch studs 46mm or 50mm in length. You also need 4 flat washers and 4 nuts for them as well. You have to cut the old bolts to get the tapered washers off and you will reuse them after drilling them out to 8mm holes. I reused the torx tho i as to lazy to get new studs haha someone earlier mentioned the torque you need.
If getting studs be sure that if they are not threaded all the way down that you get ones short enought that will allow you to tighten the nut all the way down before it bottoms out. I mentioned this before. The ones I got at sears I had to use were like 40mm.
the flat part should be facing the base of the injector so it gets a tight seal. the rounded will face out.
Is this per toyata install manual?
Welp just picked mine up. Dont look brass though. There is a rounded and flat side. I have never taken out to the injectors and these are new to me, so go easy on me.... What part faces the injector? Flat or round?
@ColonR
Sent from an iPhone conformist using Tapatalk
I didnt even noticed a difference in sides. They will both be deformed once crushed. The flat or curved side is probably just due the tool press used to make them.
Are you sure you didnt reuse the same seals? Should have left it alone while it was working and it would have been fine. Maybe you didnt tighten one enogh this time. Do it again! what a PITA...
aviator79 is offline
 Old 04-05-2012, 06:41 PM   #299
Snotrocket's Avatar
@aviator79 I did them again anyway but I'm getting the same minor knock at peak torque as i was with them flat side to the head...
2010 MS3 Black
395whp/386wtq
 Old 04-05-2012, 06:50 PM   #300
aviator79's Avatar
I dont have my DH or AP hooked up so ive no idea if im knocking. But car seams to be running great so im happy for now until I can figure out how to use the AP thingamagig.
 Old 04-05-2012, 06:52 PM   #301
Snotrocket's Avatar
The AP thingamajig is pretty easy to use...
2010 MS3 Black
395whp/386wtq
 Old 04-05-2012, 07:23 PM   #302
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I think I'll respectfully disagree with you until I have had both side by side. The PTP washers are uber thick and flat on one side that faces the crow's foot. I doubt very seriously the OE setup is as substantial.
stay tuned for an objective review with pics...
Dano is offline
 Old 04-05-2012, 07:31 PM   #303
aviator79's Avatar
Time is my issue...have none. Work is crazy, sent me to WPB twice in past month to work a sikorsky facility down there on new helicopter manual, working 80 hours this week and for the next few weeks on update to another manual and then likely back down to WPB for may. Plus stereo install ive been working on for 3 years I still cant get working right, installing MF CBE that I like but had to remove mufflers to cut off tips (hated my CPE dual), fish pond needs spring cleaning along with all the other house/yard work I need to do. And an 8mo boy. Just wish I had DJ or LEX or somone local that could just tune my car for me as I have no time.
 Old 04-05-2012, 07:39 PM   #304
aviator79's Avatar
So it just a big fat washer? OEM washer are fine IMO is all I am saying. No need to spend $40, but again that is just my opinion which is obviusly correct...haha. No seriously im sure they will work but I just dont think they are needed. Good luck with it.
 Old 04-05-2012, 07:53 PM   #305
mazdamx3freak's Avatar
Posts: 219   (View Stats)
mazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond repute
am I the only one who recieved them in a shipping package that cost probly 10x the amount that would of cost if they just shipping them in a letter?
2008.5 CPW
JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate.
Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm
mazdamx3freak is offline
 Old 04-05-2012, 08:44 PM   #306
Snotrocket's Avatar
You're just talking about data logging with it for now? Plug it in.. let it marry with your ecu and you are ready to log. As for tuning you can flash your ecu my just picking the appropriate shelf map for your platform and it does the rest. Takes no more then 20 mins
2010 MS3 Black
395whp/386wtq
 Old 04-06-2012, 12:44 AM   #307
mrmonk7663's Avatar
I can attest the washers are not something you can buy at the hardware store. They are custom made, thick, and curved on one side to apply equal pressure to the crows foot.
 Old 04-06-2012, 01:31 AM   #308
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Subbed. I wonder how long til the stock seals need to be replaced
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline
 Old 04-06-2012, 05:39 AM   #309
aviator79's Avatar
Ya...ok so im lazy. I will be doing it soon. Cant wait. Ive only used the SB.
 Old 04-06-2012, 05:39 AM   #310
Tokay444's Avatar
Groans: 793
I wouldn't go flashing maps if he hasn't read the helpfile and knows what to look for in his logs.
Demodded.
The Seals
Tokay444 is offline
 Old 04-06-2012, 09:01 AM   #311
Trail of Fail
Dano's Avatar
Haha. They are alloy washers about 1/4" thick. To me time is money so 40 to keep from sourcing the studs and washers was worth it. Also, John gave me a 600 FP sensor so I came our ahead. Lol. Well the sensor isn't necessarily 600 but you can only get them w the fuel rail which is 600.
Could the washers be overkill? Sure.
I'll take pics of them both when I get around to the install.
Tappin
Dano is offline
 Old 04-08-2012, 06:49 PM   #312
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Just got mine in with the PTP stud kit. Install was super smooth and i was able to get the injectors out along with the old seals without a tool. They looked like shit though... Glad I did this sooner than later. Cleaning my valves while im at it
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline
 Old 04-08-2012, 07:21 PM   #313
daztdMS6's Avatar
Question
I was able to get the injectors out along with the old seals without a tool.
You just used your fingers to twist them out??
MazdaSpeed 6
daztdMS6 is offline
 Old 04-08-2012, 07:24 PM   #314
Yeah a whole lot of back and forths with an occasional wiggle. Only one gave me a qwazi hard time.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 04-08-2012, 09:01 PM   #315
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I decided to install my Toyota seals and injector studs while I had my IM off, and apparently my cylinders 1&2 were both leaking a little. All four of my stock seals came right out with the injectors.
silvapain is offline
 Old 04-09-2012, 10:05 AM   #316
Is there a special way to put the fuel rail back on? I just started my car and now have a puddle of gas underneath it... Like... a lot.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 04-09-2012, 10:24 AM   #317
silvapain's Avatar
Groans: 136
The factory manual says to torque the rail down from the center out to the ends. It's a very low torque spec though; under 20 ft-lbs if I remember correctly.
Did you pull the injectors out of the rail? If so, you might have nicked one of the O-rings. Same with the hard line from the HPFP. I use a light coating of engine oil on O-rings like that when reinstalling.
Tapadatass
 Old 04-09-2012, 11:08 AM   #318
I got complacent when pulling out the fuel rail. I couldnt get that plug off of it so i said screw it, and i didnt even see the o rings inside the rail. Super nube mistake. looks like im shopping for the rings now.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 04-09-2012, 04:00 PM   #319
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
proper upgraded studs/nuts per @SilverDemon if anyone is curious. thanks dude!
edit: no washers, you need to use the stock ones (cut stock bolts to get them off, then drill out slightly to fit over new studs)
File Type: png Screenshot-Shopping Cart | Fastenal - Mozilla Firefox.png (203.0 KB, 7 views)
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
 Old 04-09-2012, 04:27 PM   #320
SilverDemon's Avatar
Posts: 3,034   (View Stats)
glad I could help! Very interested in how everything pans out with these.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
SilverDemon is offline
Injector seals solution. Version A paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 756 05-23-2017 10:38 AM
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 03:39 AM
Injector seals solution. Version B paveltol MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 463 11-12-2016 09:30 AM
Injector seals solution. paveltol 2010 MS3 - Engine, Transmission & Driveline 397 07-25-2014 08:34 PM
Injector seals solution. paveltol MSF KB - Mazdaspeed 3/6 - Fuel 401 09-19-2012 01:49 PM
Page generated in 0.61223 seconds with 39 queries
