| JimmyMac | 05-30-2008 01:44 AM | Currently updating!
If you have info on which Rod # goes with what cylinder, please let me know. I'm listing cylinder 1 as passenger side. through cylinder 4 as drivers side. If you have any other idea's on what else to add, let me know. Thanks. - bmman93 Mazdaspeedforums
Car; 2008 Mazdaspeed 3 with 8100 miles.
Cylinder; #1
Damage; Tossed Rod. Holes in block front and rear. Cracked oil pan. Rod #1
RPM; ??
Mods; MS Intake
Exhaust Manifold; Stock??
Situation; It blew just driving down the street.
Warranty; ?
Oil; ? - palerider Mazdaspeedforums
Car; 2007 Mazdaspeed 3 with 29,000 total miles and 4500 on the current setup.
Cylinder; #2?
Damage; Tossed rod. Hole up front. Rod #4?
RPM; 4000-4500
Mods; gt3071r turbo @ 18 psi, ms cai, inlet, fmic, turbo mani, bpv, cdfp, catted tbe, semi tuned standback.
Exhaust Manifold; Brand??
Situation; Car blew partial throttle into boost, third gear around 4000-4500 rpms, going up a hill.
Warranty; ? No
Oil; ? - CMESCOOT Mazdaspeedforums
Cylinder; #1
Damage; Tossed rod. Hole at the bottom front passenger side.
RPM; ?? See speed.
Mods; FMIC, CAI, CDFP, PG manifold, Downpipe and race pipe, 3" straight exhaust, Hybrid BOV, Reworked stock turbo.
Exhaust Manifold; PG
Situation; 6th gear cruising at 75 on a flat highway.
Warranty; ?
Oil; ? - desertrat Mazdaspeedforums
Cylinder; #2 & #4 most water. #1 & #4 little water.
Damage; Hydrolock. Water in cylinders. Water in intercooler. Broken crank. Cracked block.
RPM; ?? See speed.
Mods; MS CAI
Situation; I was stuck between a rock and a hard place, on a two way street and in a down pour of rain. I was going about 25 mph and through about 12" deep gully. I had cars behind me and on the other side I had no choice but to risk it. I did the initial inspection, water in the intercooler and the cylinders mostly in 2 and 4 I think and a little in 1 and 3. I suck out the water and tried to start it nothing. I ended up at the dealer to find out I broke the crank and it imbeded its self into the block causing it to crack.
Warranty; ?
Oil; ? - paulfitipauldi Mazdaspeedforums
Car; 200? Mazdaspeed 3 2000miles.
Cylinder; #1 & #4?
Damage; Bent two rods , the #1 and #4.
RPM; ?? See speed.
Mods; Stock
Exhaust Manifold; Stock.
Situation; Cruising at 60mph in 6th gear, I hit the breaks for a bump in the highway. When I accelerated again at partial throttle I heard that psshh noise and later that, a knock noise.
Warranty; ?
Oil; ? - 08ms3bm Mazdaspeedforums
Car; 2008? Mazdaspeed 3?
Cylinder; ?
Damage; Bad 3rd injector. Spun a bearing. Snapped rod. Snapped wrist-pin. Bent 1 valve.
RPM; ??
Mods; Stock
Situation; Bad 3rd injector went lean.
Warranty; ?
Oil; ? - mrlilguy157 Mazdaspeedforums
Car; 2007 Mazdaspeed 3 14000 miles.
Cylinder; ?
Damage; ?
RPM; 8000
Mods; ATP 3071r bolt on turbo, mrlilguyCDFP, custom inlet and intake, txs downpipe/racepipe/hybrid bov, no ems. boost level set at 15psi.
Situation; Downshift to 2nd and 8000rpms = boom.
Warranty; ? No?
Oil; ? - k2white Mazda24/7
Car; 2007 Mazdaspeed 3 15000 miles first time.
Cylinder; #2 and #3
Damage; 1st time: Blown rod(s).
RPM; ?? See speed.
2nd time: Starter blew.
3rd time: Cam/Engine damage.
Mods; Stock
Situation; 1st time: I blew a rod in 6th gear doing 60mph on the way home from work, there was no warning.
2nd time: I got the car back and the next day the starter blew, another tow and a day later I got it back again and went about my business.
3rd time: Three weeks later, the car died again, in the same manner, driving along and it just dies. This time it was the timing in the cam which caused damage to the engine.
Additional info; Here it is word for word off the R. O.:
Customer states that the car had no heat and check engine light and traction control lights came on, within next mile vehicle engine and all power quit.
Check ECU for codes and found code P0117 stored. Checked for coolant temp issue and found car to be low on coolant. Road tested the car and found the engine to run at hot and overheat. Talked to Mazda and they advised us to replace theromostat. Replaced thermostat and road tested the car again. Then the temp guage read 1/2 and had good heat. rechecked cooling system and found contious bubbles flowing into overflow jug Tried to bleed system several 10 times but there wer still bubbles. Performed cylinder pressure test and #2 and #3 clinders to be blowing back through cooling system. Inspected plugs and found tiny metal flakes on spark plugs. Removed and replaced engine as per Mazda. Roadtested car thouroughly and no bubbles in coolant. All ok.
END
Warranty; Yes.
Oil; ? - TENCms3
Car; 2007 Mazdaspeed 3 41,218 miles.
Cylinder; #2 and #3
Damage; Cylinder 3's piston is scrap, nicked 2's a lil bit. No holes in the block.
RPM; ?? See speed.
Mods; MS CAI, corksport TP, rear motor mount(awr).
Situation; Turbo was going bad. Waited to long to take it in. Was leaving work going about 5 to 10mph. Jumped timing.
Warranty; No
Oil; ? - occschemguy
Car; 200? Mazdaspeed 6 20,000 miles.
Cylinder; #4
Damage; Holes on both sides of the block#4 piston
RPM; 3500
Mods; Magna flow eghaust, MS cai, HKS bov.
Situation; Mine blew during miss 3500 rpm 5 gear
Warranty; No
Oil; ? - ms3guy22
Car; 2007 Mazdaspeed 3 13,000 miles.
Cylinder; #3 and #4
Damage; Blown motor. Slipped a bearing a put a couple really big holes in my block cyclinder 4 and 3
RPM; ?? See speed.
Mods; fmic, tbe, pg manifold, mrlilguy cdfp,sri, cpe standback kinda tuned, 19 psi, reworked turbo.
Situation; I was slowly accelerating at 5 mph on my way to my garage, and kaboom!
Warranty; No
Oil; ? - kraz3y
Car; 2008 Mazdaspeed 3 23,xxx miles.
Cylinder; ? passenger side
Damage; Chunk of my engine on the under tray and a bolt missing the thread part and a clip...looked around theres a hole up near the starter...guessing thats the front of the engine.
RPM; 4500rpm drivng around 40-50mph.
Mods; stock boost, mbc, map clamp, cs dp/mp, cobb sf, trz mount, modified stock exhaust, hks bov
Situation; (4:30pm) driving home from picking up my lady and daughter my engine blew.... My guess i was heatsoakin like a mofo and i gunned it it bit ( 4.5k ) was drivng around 40-50 and then booommm ughhh (boost temps at 110-120ish, 90 ambient temp)
Warranty; Unknown
Oil; ? - tvissues
Car; 2007 MazdaSpeed 3 GT
Cylinder; #2
Damage; researching
RPM; researching
Mods; researching
Exhaust Manifold; researching
Situation; researching
Warranty; none
Oil; researching - IDRVSLO
Car; MazdaSpeed 3
Cylinder; 3
Damage; Blown engine. Hole in block #3 cylinder.
RPM; about 3000rpms
Mods; Cobb AP, COBB SRI, IDRVSLO custom Water to Air IC, PG V2 Manifold, HDFP, H&R springs, 17x8.5 RPF1s ET40 w/235/45/17s, Prosport boost gauge, TWM Bushings and Short Shifter, Turbosmart Hybrid Valve, Corksport DP and RP, DENSO ITV22 plugs, custom catback full 3" mandrel bent w/ Apexi N1 muffler and N2MB WOT Box w/ 2 step
Exhaust Manifold;
Situation; It was raining and I wasnt in boost. This is one day after picking up my car from the shop with what was suspected as a clutch/flywheel issue. It had brand new oil in it.....I just checked the levels 10 days ago....same day as it started having problems.
Previous situation that could of led up to this situation (cut and paste).
"Well here it goes. I was accelerating onto the freeway in 3rd gear last night. Nothing out of the ordinary happened. I did not over rev the motor or miss a shift! Boost hit 19psi as normal but when I went to shift into 4th I felt a vibration through my clutch pedal. It immediately reminded me of MS3guy22's post. I pulled over and shut the car off. Went to start it again and if fired right up. Car is in neutral and I press in the clutch. As soon as I begin to press it in I feel the vibration. When its all the way depressed the vibration is gone. I then got out and listened to the engine. I can here a clicking noise...definitely not a normal noise. It grows more audible at lower RPMs and less at higher. Any ideas? The car is currently up on jackstands right now. I have drained the oil and am about to take off the oil pan. I checked spark plugs there is nothing abnormal there. I can not find any holes in the block....yet. HELP.....so much for my dyno day today."
Warranty;
Oil; - JimmyMac
Cylinder; #4
Damage; Bent connecting rod. No other damage so far.
RPM; 4000-6000rpms
Mods; ATP GT2871R (20psi), ATP 3" Inlet pipe, CPe CAI, CPe FMIC, CPe catted DP, CPe Standback, CorkSport CB, Forge BPV, Saikou Michi Co OCC, Mrlilguy CDFP, BC Racing CoilOvers, Gram Lights Bronze 57C, Dunlap Direzza Sport Z1 Star Spec, N2MB WOT Box, Street Unit rear MM, TWM shift bushings, PG manifold
Situation; 2nd gear at 4000rpms went WOT, shift point around 6000rpms through 4th gear. Max psi recorded at 19.8. Slowed car down. Clutch pedal was vibrating when slightly touched. Engine sound ticking. Ticking speeds up when rpms increase. Car parked time problem is resolved.
Warranty; None
Oil; 5w30 Mobile 1. - Anonymous
Car; MazdaSpeed 3
Cylinder; unknown
Damage; tossed rod.
RPM; unknown
Mods; Anonymous
Exhaust Manifold; stock
Warranty; unknown
Oil; unknown - Unknown
Car; 200x MazdaSpeed 3 (x3)
Cylinder; unknown
Damage; hole in block
RPM; unknown
Mods; unknown
Exhaust Manifold; unknown
Situation; unknown Random stories, 1 in WA, 2 in NC.
Warranty; unknown
Oil; unknown - cageyvet
Car; MazdaSpeed 3
Cylinder; ?
Damage; Shot a rod through the block.
RPM; ? 50mph
Mods; ? Stock
Exhaust Manifold; ? Stock
Situation; I got my car back from the dealer a few weeks ago (11-22-08) after they rebuilt the transmission and replaced the clutch(this is a story of frustration all in itself). Last week the motor shot a rod through the block at aprprox. 50mph and out of boost. The car had 38 miles on it from the time i picked it up from the dealer(keep in mind it passed their complete "free" full circle service card inspection) until the motor blew in addition to being STOCK.I finally got around to having the car towed to the dealer, and the first thing i was told was i need to provide them with the history of the car's oil maintenance. I hope they warranty this without the drama that happened with the tranny. BTW, it appears this is nothing new considering the reaction i got @ the dealer when i took it to the service department. I am so pissed, 3 months of car note payments for less than an hour worth of driving. Im selling the car when i get it back.
Warranty; ? Maybe
Oil; ? - blackmica08
Car; 2008 MazdaSpeed 3 5000 miles?
Cylinder; #2?
Damage; Blown engine/rod.
RPM; researching
Mods; gt3071r , fmic, rp, dp , hks custom exhaust, greedy rs bov, fuel pump. 18 psi
Warranty; ?
Oil; researching - Unknown
Car; MazdaSpeed?
Cylinder; ?
Damage; ?(ticking)
RPM; ? 4th gear
Mods; CPe Catted DP, Cobb Intake, Dual Port BOV, 18psi.
Exhaust Manifold;
Situation; Got on the on ramp and guns it in 2nd then shifts to 3rd then goes into 4th and the car turns off, no noise no shaking nothing so we pull off to the side of the freeway and the first thin i do is look on the ground for oil and there wasnt any so told him turn it on and the famous loud ticking noise was there.
Warranty; ?
Oil; ? - Duy215
Car; MazdaSpeed 3?
Cylinder; ?
Damage; Blown Motor?
RPM; See situation.
Mods; I/TBE/AP/MM/BOV (Cobb Sri, TBE, AWR Motor mount, HKS BOV)?
Exhaust Manifold;
Situation; He hammered down on second from 3k to the top of the gear, shifted and the motor popped as soon as he let the clutch out.
Warranty; ?
Oil; ? - s-retire
Car; 2008 MazdaSpeed 3 3607
Cylinder; #3?
Damage; Hole in block about the size of a rod end, engine compartment fire
RPM; 3,000 to 3,500 (5th gear, 70 mph, down grade load)
Mods; Bone Stock
Situation; Highway speed (I5 in California) Cruise Control set, down grade.
Other: There was no indication of low oil condition prior to engine failure. The low oil pressure indicator light did not illuminate until after the motor quit. There was no increase in operating temp.
The oil was last changed at an authorized Mazda Dealer, so if you think using the dealer will protect you, think again.
I have written a letter to Mazda North American Operations to appeal the denial of warranty coverage. We’ll see what happens.
With the large number of denied warranty claims, has there been any thought to injured class action?
Has anyone else filed a NHTSA complaint?
Warranty; Denied - Inspecting dealer claims that servicing Mazda dealer left drain plug loose and cause was it fell out allowing oil to drain out.
Oil; Dealer supplied 5w/30 stock # 103050. Oil changed @2300 miles. - mlassek
Cylinder; #3
Damage; Bent Rod
RPM; 3000-4000rpms
Mods; TurboXS FMIC,ATP turbo inlet,PG CAI w/ AEM DryFlow filer,Turbosmart VTA BOV,NGK step colder iridiums,PG CDFP kit,TWM SS w/ bushings,Cobb shifter weight,TRZ dogbone,Corksport DP,Corksport RP,Mazdaspeed CBE,Hayden P/S cooler,CP-E PnP,CP-E Standback v2,CP-E Re-flash,Grounding kit,Prosport premium boost in ATI pod,Smoked Sidemarkers,20% tint,JDM window visors,Speedline mirrors,GV front lip,GV Eyelids,RE-A wing lip,CP-E TowPlate w/ "MS3 FTW"tags
Situation; bent #3 rod while shifting into 3rd at 3-4k rpms mid boost.
Warranty; unknown
Oil; Only seen mobil 1 oil until i put royal purple in last week (5-30) - tazman34685
Car; MS3
Cylinder;
RPM;
Mods;
Exhaust Manifold;
Situation;
Warranty; Nope
Oil; - Breakthestatic
Car;
Cylinder; 4
Damage;
RPM;
Mods;
Exhaust Manifold;
Situation;
Warranty; Nope
Oil; - buildabong
Car;
Cylinder; 4
Damage;
RPM;
Mods;
Exhaust Manifold;
Situation;
Warranty; Nope
Oil; - JerseySpeed
Car;
Cylinder; 4
Damage;
RPM;
Mods;
full bolt on;
Situation; Light load daily driving. shifting from 2nd to 3rd and boom.
Warranty; Nope
Oil;
Signs: None - griffeyfan25
Car;
Cylinder; 4
Damage;
RPM;
Mods;
full bolt on, GT2871 with EWG;
Situation; WG line popped off and car boosted 30 Psi
Warranty; Nope
Oil;
Signs: Vibrations in clutch - Jarods7920
Car;
Cylinder; 4
Damage;
RPM;
Mods;
Cobb ap 93 oct map rp, intake
Warranty; Nope
Oil;
Signs: none
