> MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline
 Old 03-02-2009, 05:54 PM   #161
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
people with blown motors shouldn't be saying there car runs good....
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
 Old 03-19-2009, 12:04 AM   #162
JerseySpeed's Avatar
Posts: 68   (View Stats)
JerseySpeed is a glorious beacon of lightJerseySpeed is a glorious beacon of lightJerseySpeed is a glorious beacon of lightJerseySpeed is a glorious beacon of lightJerseySpeed is a glorious beacon of light
Blew my motor a week ago.
I think its the #1 Rod/Cylinder.
Happened under light load. Daily Driving. Just Shifting from second to third gear and Kaboom. Dead. 5.6 Quarts frsh synthetic oil on the street. And coolant. Im fucking pissed.
Mods= Everything on cp-e website. Jordan Tuned.
I dont get it. Always a Rod. Mazda should be sued for such shit internals.
JerseySpeed is offline
 Old 03-19-2009, 12:16 AM   #163
Also i contaceted several dealerships to see if i could get it pushed thru under warranty.
They said:
"6 months ago we would have pushed it thru no problem no matter what mods you had" (Cause they needed the work)
Then they said:
"Mazda NA is cracking down on the warranty work so we cant push anything through"
GEEEEE wonder why mazda... not telling us something?
Maybe your worrried cause all your fucking shit ass fucking internals are pooping thru your blocks.
Hate to even say this but this shit dont happen to subbies or evo's
 Old 03-19-2009, 12:18 AM   #164
Fux Wit It
Darksun280's Avatar
Groans: 175
So whats your next step?
 Old 03-19-2009, 12:27 AM   #165
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
probably gonna remove the eye lids
phillyb is offline
 Old 03-19-2009, 12:31 AM   #166
Well im searching for a decent block to slap in the car right now.
But i just got sponsored by street unit and will be buying a brand new full forged block. Should have it in a couple weeks just waiting on some money from my other sponsor so i can get the ball rolling.
I could use any help that anyone could provide.
 Old 03-19-2009, 12:33 AM   #167
Fux Wit It
Darksun280's Avatar
Groans: 175
Seems to me like your already getting help. You'll be fine.
 Old 03-19-2009, 12:43 AM   #168
LoL already did smart ass. HAHA!!!.
I let this dick in my car club put them on. They looked like shit.
Coulda made my appointment for tinting the headlights and tailights if my car didnt blow.
 Old 03-19-2009, 12:43 AM   #169
 Old 03-19-2009, 06:21 AM   #170
Silo's Avatar
Posts: 72   (View Stats)
Silo has a spectacular aura aboutSilo has a spectacular aura aboutSilo has a spectacular aura about
It seems there is a significant number of rod failures. All reported blown engines I know of (here in Germany) suffered the same death. Apparently the rod comes lose from the piston. Interestingly it also happens almost always in light load / cruise situations.
Silo is offline
 Old 03-19-2009, 08:03 AM   #171
bf360's Avatar
Posts: 2,069   (View Stats)
bf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the world
Groaned at 42 Times in 35 Posts
where you in boost at all when it blew? any type of load, up hill or in fifth or sixth?
bf360 is offline
 Old 03-19-2009, 08:20 AM   #172
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
its funny that people think mazda is responsible for their engines after they put all the modifications they can on it. you know what you are getting into when you start modding.
bova is offline
 Old 03-19-2009, 09:11 AM   #173
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
JerseySpeed, I know you said you think it was cylinder 1, but did you have the BS taken out? how many miles on this change? what filter were you using? any WI?
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
 Old 03-19-2009, 09:17 AM   #174
Ok well what about the stock ones that are blowing with the same problem?
 Old 03-19-2009, 09:20 AM   #175
Whats the BS? Fram oil filter. No WI.
Happened at about 9000 miles. 5lbs of booost. No load. Flat road. Daily driving about 3-4000rpms in 3rd gear.
 Old 03-19-2009, 09:24 AM   #176
rabble rabble
802MS3's Avatar
Groans: 221
BS=balance shaft assembly, and was it the stock cartridge type or spin-on filter?
802MS3 is offline
 Old 03-19-2009, 10:00 AM   #177
Stock cartidge.
Should we remove the balance shaft assembly?
I need to know cause im going to be building a forged motor.
 Old 03-19-2009, 10:03 AM   #178
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
How did your logs look? Boost? AFR? BAT?
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline
 Old 03-19-2009, 10:13 AM   #179
Logs? Will my dashawk data log on its own without me setting it to?
If so i will check it.
But.. i always visually moitor it AFR was fine. No Knock. Boost was about 5-10lbs. BAT i dunno what that is.
 Old 03-19-2009, 10:15 AM   #180
badams118's Avatar
More importantly, what were these params at WOT. What had Jordan set your max PSI to? What probably happened is that the rod was damaged at WOT, then failed at cruise.
 Old 03-19-2009, 10:21 AM   #181
Boost set to 18psi.
We leaned it out a bit at WOT.
Added 2 degrees of timing.
 Old 03-19-2009, 10:22 AM   #182
rabble rabble
802MS3's Avatar
Groans: 221
Stock cartidge.
yes, many people think the balance shaft must be removed if the power is being upped in this motor. its still speculation, but it appears that the BS assembly puts unwanted load on the crank in one spot (the crank might not be the right word, someone can correct me on this, but basically BS=does nothing but cancel out vibrations/there for comfort only, not necessary for the motor to operate). There are numerous threads on this topic. Removing the balance shaft also gives you a another whole quart of oil capacity.
Also, myself and others would recommend going to the spin-on filters with the conversion. People have said the normal spin-on filters do a better job at filtering the oil, and also give a little bit more capacity.
With my last change, I fit about 7quarts of oil in with the BS delete and spin-on filter.
Another thing I am considering is an oil bypass filter. I'm still doing some research on this, but it seems that it wouldn't hurt for extra filtration.
802MS3 is offline
 Old 03-19-2009, 10:23 AM   #183
badams118's Avatar
So I assume ~12 AFR. If your BAT was good & no KR, that is worrisome.
 Old 03-19-2009, 12:52 PM   #184
bf360's Avatar
so you were part throttle boosting in the worst rpm area to do it
now i know why you blew
bf360 is offline
 Old 03-19-2009, 01:16 PM   #185
badams118's Avatar
That's a good point. I try to stay 2-3k with part boost. 3k+ is for WOT.
 Old 03-19-2009, 01:29 PM   #186
I still don't buy the "don't boost in this range" theory. The engine is capable of running through all operating conditions while stock.
However, yours clearly wasn't stock, so it's a bit more difficult to asses the issue.
Lex is offline
 Old 03-19-2009, 01:57 PM   #187
badams118's Avatar
That's not what he is saying.
FWIW, my car has never liked cruising at part boost below 4th gear at 3k+ rpms stock or otherwise. YMMV
Try cruising at 4k in 3rd. My car has always stuttered, even before I put my first mod on.
 Old 03-19-2009, 05:29 PM   #188
The car boosts when it boosts wtf.
Are you telling me this guy shifts before 3k rpms all day long just not to build boost.
That is the most retarded shit ive ever heard.
Bottom line is this. This motor is finiky as fuck and has shit internals and holds way to much heat. End of story.
If you think im gonna drive around alday shifting gears at 2900 rpms ur nuts.
 Old 03-19-2009, 05:31 PM   #189
bf360's Avatar
actually i shift at 2500, and the problem is the ecu staying in closed loop and staying lean while boosting and kaboom
bf360 is offline
 Old 03-19-2009, 05:43 PM   #190
badams118's Avatar
I shift by 3k when I'm cruising. I shift at anywhere between 3500 & red line when I'm WOT. I'm pretty sure that's how most people drive. I know that's what my car likes, anyway.
 Old 03-19-2009, 05:46 PM   #191
bf360's Avatar
btw meth woulda solve your heat problem
bf360 is offline
 Old 03-19-2009, 05:55 PM   #192
badams118's Avatar
Mine? Ya, that's why I got it.
 Old 03-19-2009, 07:20 PM   #193
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
still none blown with a bsd
and most cars going kaboom are sb cars, hmm
a built motor is not a built motor without being sleeved
fbpem1 is offline
 Old 03-19-2009, 07:23 PM   #194
kwsmithphoto's Avatar
Posts: 1,035   (View Stats)
kwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the world
Groaned at 41 Times in 9 Posts
Sure it does. Do some digging, you'll find plenty of sad stories.
BTW, this motor is being used in soccer mom SUV's (the CX-7) and they aren't blowing up. Maybe there's some logic in the auto trans that controls boosted load conditions better, I don't know. I'm curious to see exactly changes they made for 2010.
But I do know you had a pretty maxed out motor with all that CP-E stuff. Can't blame Mazda for denying the warranty claim, the whole car industry is cutting back wherever they can because of drastic sales declines. The first thing to go is fixing some guy's built motor under warranty.
Anyway, sorry it happened to you, it sucks to have to spend loads of money to fixing a new car that should be under warranty. But I have to agree that this is where you tread whenever you're modding a car. And yes, I know even stock ones have blown too so it could happen to me. As their profits decline they're going to get much more aggressive about denying warranty claims. Other than an upcoming MS CAI, installed by a dealer to cover my ass, I'm leaving my engine bone stock. Even the CAI puts me at some risk though, in today's economic climate.
It's not even close to your situation, but I blew out an upper strut mount at 3200 miles. Warranty denied because of Koni shocks. It's just reality these days. The mount failure had nothing to do with the Koni's but it could have as far as a judge would be concerned, so it wasn't worth fighting over, I just paid for it myself.
kwsmithphoto is offline
 Old 03-19-2009, 07:26 PM   #195
fbpem1's Avatar
why would you even take the car to a dealer when your modified or if your part has to do with what broke? thats just stupid in my opinion the dealer has every right to deny your repair under warranty if it was modified to run outside of factory spec.
fbpem1 is offline
 Old 03-19-2009, 09:06 PM   #196
evidence's Avatar
Posts: 1,033   (View Stats)
Not sure if most are actually SBs (and in his sig he said he was tuned by Jordan also), but anytime you leave the tuning to the end use they are going to push it further than a tuner trying to cover his ass (and one might say more intelligent in these matters also ) would. Watch when ATR comes out you'll probably see plenty with the AP doing the same
Some things.
evidence is offline
 Old 03-19-2009, 09:10 PM   #197
fbpem1's Avatar
tuning dosn't work for this car anways short of the flashes so i don't believe the sb or the ap really work in thier respects.
fbpem1 is offline
 Old 03-19-2009, 09:21 PM   #198
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I wouldn't say it's more standback cars that are blowing, just that the cars with more mods tend to use the standback.. The standback is effective and safe when used properly..
The tuning works, it's plain to see that pulling fuel with the SB or AP works, and anyone with a dashawk can see that adding or subtracting timing works. It's just some other part of the ECM's logic is holding us back/not allowing those changes to be as effective as we would expect...
SSinstaller is offline
 Old 03-19-2009, 10:59 PM   #199
I didnt ever take it to te dealer.
I knew some people that said they had a hook up and when it came down to it they couldnt do anything cause Mazda ws cracking down on waranty work.
6 months ago he sadi it would have been no pronlem.
Im building a motor, taking my head off this weekend to make sure its ok.
Buying a short block and sendin it to the machine shop.
No more crying and whinning.
 Old 03-19-2009, 11:19 PM   #200
bf360's Avatar
thats the thing, there is no tuning solution that has shown to actually produce more power, instead of loose it, ive seen ap cars make more without the ap, and ron made more power with just the flash then with the sb
bf360 is offline
MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 1441 06-25-2019 06:11 PM
Mazdaspeed 2.3L DISI Turbo Blown Engine Resource Thread Kennosuke MazdaSpeed 6 - Engine, Transmission & Driveline 1 04-27-2009 01:26 AM
Page generated in 0.56539 seconds with 33 queries
