> MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline
 Old 03-20-2009, 01:14 AM   #201
kwsmithphoto's Avatar
Posts: 1,035   (View Stats)
kwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the world
Groaned at 41 Times in 9 Posts
That's still a lot of work, time, and expense, so I feel for you. But look at it this way: you might get wind up with a better motor in the end if you discover the core of the problem!
BTW, do you have a windage or baffle tray in your oil pan? I'm not an engine guy but there seems to be some consistency in the same cylinder tossing the piston and lunging the rod out of the block. Couldn't that be a lubrication issue? If it was a build quality issue, I would expect less of a pattern. It's interesting that virtually all of the reports here point to the same basic failure mode, modified or not; they almost always let go in normal driving, not very often at WOT, and it almost always seems to be the #1 cylinder.
Point being, there MIGHT be an issue with the #1 cylinder not getting enough lube under full load so it wears faster (which should show up in UOA's). Then some freaky combo of relatively low RPM, and a corresponding lack of oil pressure, combined with some ECU weirdness under light throttle, conspires to stress an already weakened part to the breaking point.
Just a guess, anyway. I really don't know, but a pattern is a pattern.
As for the warranty, well I doubt you'd have gotten any love even 6 months ago. There's only so much a dealer hookup can do for you. Major repairs like this need to be approved by the factory zone rep, and they're the ones who are looking for any excuse to save corporate money on warranty reimbursements to a dealer.
Anyway, good luck, let us know how things progress.
kwsmithphoto is offline
 Old 03-20-2009, 04:35 AM   #202
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Did you have any increased engine noise prior to the failure?
Many people experience this when they bend a rod under high load, which causes large imbalance that manifest itself as lots more engine noise. This usually leads to the rod failing and exiting the block during normal driving.
cld12pk2go is offline
 Old 03-20-2009, 12:18 PM   #203
Betelgeuse's Avatar
Posts: 355   (View Stats)
Betelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant future
I still think there are a certain number of engines that are just defective (knock on wood). I'm not buying into the whole ' you have to shift before X rpms' or 'it's a partial boost' issue etc. Now with increased mods, I do agree one has to pay more attention to what's going on but for many who just have basic bolt-ons, it shouldn't be an issue.
I'm about to hit 50k, learned to drive stick on it, and have driven it every which way, and the engine just purrs like the day I bought it (knock on wood - harder this time ).
I usually shift between 3000-4000 rpms and and rev the hell out of it at least 5 times a day to, during and from work. Yeah, I'm almost stock, but the story I'm hearing is even close to the stock motors are blowing. I think mods will increase the likelihood of an already defective motor blowing much sooner. Just my 2 cents.
Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount
Betelgeuse is offline
 Old 03-20-2009, 01:09 PM   #204
mouse0330's Avatar
Posts: 1,104   (View Stats)
mouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the world
I agree with you, I have over 51k now, and just add tmic and inlet, I shift when I feel like it, so no certain pattern, but between 2500 to 6k rpm...I tried over 6500 a few times to see how the car response...
I do worry about the said blown engine thread like this here...and people started to come out of the woodwork with blown engine.....lately my right foot is getting heavy with the gas pedal after the tmic and inlet install...so I try to enjoy my car without worrying about blown engine....I do hope we figure out though .....I hope that is just some bad apple....
mouse0330 is offline
 Old 03-20-2009, 03:00 PM   #205
MZRDISI4's Avatar
Posts: 1,430   (View Stats)
MZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the world
Groans: 94
Groaned at 38 Times in 19 Posts
My engine is blowing. I just know it. I read it on the internets that someones engine did!
"We already have the Speed6 replacement" "It's just called the CX-7 now"
back at http://www.mcx7.com bitches, spam free
MZRDISI4 is offline
 Old 03-21-2009, 11:50 AM   #206
JerseySpeed's Avatar
Posts: 68   (View Stats)
JerseySpeed is a glorious beacon of lightJerseySpeed is a glorious beacon of lightJerseySpeed is a glorious beacon of lightJerseySpeed is a glorious beacon of lightJerseySpeed is a glorious beacon of light
Slight noise a day or 2 prior but to mee sounded like the HP fuel pump ticking. No Knock detected on dashawk. Fluids, AFR, EGT all good.
Once i heared the ticking noise i started to become anal about paying attention to parameters and gauges. No negative detection whatsoever
JerseySpeed is offline
 Old 03-21-2009, 05:23 PM   #207
lidokrantz's Avatar
Posts: 663   (View Stats)
lidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the world
stock cars are not popping...99.9% have mods on them....and i agree that shifting anywhere in the rpm zone up to 6000 should not be a issue.....but i have taken the position of not playing around too much in the 3000 rpm area going into boost....i boost or i do not, and i shift by 6000 max as Mouse mentioned.....the car was designed to run out of breath there, why push it past the K04 power curve, plus the throttle closes...and indeed members with 50,000 plus miles on stock or lightly moded cars have been fine.. Lastly, i do believe that Jersey's car has great parts on it and a fine safe tune, but something with the full combination of all this with added boost has put the motor in distress...would it of blown if the car was running stock boost, and stock tune??? Hopefully we will find out soon, so others can be prepared and avoid this type of issue...
Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock
SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty...
Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old)
lidokrantz is offline
 Old 03-21-2009, 06:59 PM   #208
Eth/Meth Junkie
cld12pk2go's Avatar
Many cars have had a very similar ticking to what you described prior to getting a hole in the block. The one guy that pulled his engine apart in time found a bent rod.
This is likely what your ticking was.
 Old 03-22-2009, 11:20 AM   #209
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
My car makes all types of nosies. even if I got a bent rod I'd never be able to hear it.
Carry on citizens....
10.7 @ 133 auto 1G DSM
Darksun280 is offline
 Old 03-22-2009, 11:59 AM   #210
MadOzodi's Avatar
Posts: 686   (View Stats)
MadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the world
Nope, you sure wouldn't. But apparently you'll definitely be able to feel it through the clutch pedal.
07 COSMIC BLUE MS3 GT
00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten
09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD
11 BLACK SUZUKI GSX-R750 - totaled
11 BLACK SUZUKI GSX-R750 - totaled...again
*OFFICIALLY RETIRED FROM TWO WHEELS*
MadOzodi is offline
 Old 03-22-2009, 03:12 PM   #211
Fux Wit It
Darksun280's Avatar
Groans: 175
Yeah your right. My days are numbered though I'm just waiting for the bent rod daemon to come claim me. Would be the perfect end to my MS3 career.
 Old 03-22-2009, 05:07 PM   #212
y2kc0wb0y's Avatar
Posts: 808   (View Stats)
y2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the world
I'd like to add that if you blow a MZR DISI engine is probably a minimum of $2500.00 for a use long block...If you plan to mod heavy allow me to suggest building it with forged parts.
y2kc0wb0y is offline
 Old 03-22-2009, 06:25 PM   #213
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Damn! If someone offered me $2500 for my used longblock I'd sell it tomorrrow. It was running perfectly when it was pulled at only 22K miles..
SSinstaller is offline
 Old 03-22-2009, 06:37 PM   #214
ms3guy22's Avatar
Posts: 530   (View Stats)
ms3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond repute
i'll trade you my built motor plus your stocker and 750.00... We each pay freight
I hate my mazdaspeed3 more than anything else in this world!
ms3guy22 is offline
 Old 03-22-2009, 08:12 PM   #215
TurboGhost's Avatar
Posts: 85   (View Stats)
TurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to behold
Originally Posted by bf360 View Post
so you were part throttle boosting in the worst rpm area to do it
now i know why you blew
I'm no wizard, but that sounds like voodoo. For the engine to worse off under part load than full for a mechanical failure unless there is severe detonation sounds like belief in magic. I don't know for a fact what is going on with these failures during part load, but here's a conjecture:
The initial failure point is a piston or rod (pretty safe bet!)
The failure starts with a bend in a rod or a crack partway through a piston, most likely while at full load.
Either will fail completely, matter of time.
SO...
90+% of driving time is spent in moderate throttle, medium rpm. The zombie parts are going to fail, they need only a certain amount of normal usage to do so as the crack propagates (piston) or the bent rod mayhem unfolds. Now when part has worked itself close to failing with via *any* kind of driving after the fatal injury, a slight extra load will hasten its death.
So, you're just driving along and don't realize you're actually on a dead engine. Then you reach a hill, go up an on-ramp or whatever and boom it finally lets go. You might think the last thing you did killed it, when in fact it was already shot, bleeding and just waiting to die.
That's only an edumacated guess but I think it's more likely than there being a Bermuda triangle of modest rpm and boost that magically kills healthy engines.
TurboGhost is offline
 Old 03-22-2009, 08:29 PM   #216
bf360's Avatar
Posts: 2,069   (View Stats)
bf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the world
Groaned at 42 Times in 35 Posts
theres no bermuda triangle lmao
its known that boosting around 3-4 the ecu has a tendency to stay in closed loop and run really lean which can easily blow a motor at only 5 psi
bf360 is offline
 Old 03-22-2009, 08:33 PM   #217
Eth/Meth Junkie
cld12pk2go's Avatar
I think you mean open loop, but yes this is the issue.
I am ~13.5:1 in open loop under boost and quickly drop to ~11-12:1 in closed loop.
 Old 03-22-2009, 08:40 PM   #218
Groans: 60
If I didn't already have a built motor that would be tempting... Unless someone has cash in hand, I'll just wait around until DCR comes up with something big and then send it to them to build using thier stuff.
 Old 03-22-2009, 08:46 PM   #219
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
Dude, look at all the blown engines. How many were at part throttle & how many were at WOT redline or some shit? Instead of calling it voodoo, maybe we should spend a little more time figuring out why. The entire CPU is fucking voodoo. It's not reading chicken entrails, its seeing people time after time blow at part throttle in open loop. Paying attention to the facts isn't superstition, it's called using your brain.
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline
 Old 03-22-2009, 09:01 PM   #220
bf360's Avatar
i honestly dont know of one blown engine at wot in the cars power band honestly
bf360 is offline
 Old 03-22-2009, 09:20 PM   #221
TurboGhost's Avatar
You gotta point, and combined with the lean spot bf360 pointed out I'm starting to be convinced. But you'd think more people would hear it if there is detonation severe enough to break things? It would have to be so severe that KR can't pull timing fast enough.
"its known that boosting around 3-4 the ecu has a tendency to stay in closed loop and run really lean which can easily blow a motor at only 5 psi "
-- Agreed. Detonation is a gravedigger and 5psi is a non-trivial load, it's more than WOT on a non-turbo engine.
Question: if you hit the pedal a bit more does that get it out of the danger area? I drive pretty moderately, but it's an MS6 and it goes into boost just pulling its weight around. I'm wondering if taking it easy with moderate throttle and rpm is actually riskier than WOT? I always use 93 and have never heard knock.
Edit: I hadn't seen this before
"i honestly dont know of one blown engine at wot in the cars power band honestly "
*That* points to the problem being the ECU programming, which means it can be fixed with a reflash.
 Old 03-22-2009, 09:23 PM   #222
bf360's Avatar
i hate part throttle boosting, i always try to drive around in as much vacum as possible and if i need to i downshift instead of boost, going wot is a lot safer than part throttle boosting
bf360 is offline
 Old 03-23-2009, 04:31 AM   #223
Eth/Meth Junkie
cld12pk2go's Avatar
My plan is to install an alkycontrol meth kit activating on a MAF voltage of ~2.8 and above.
This will richen up the AFR in open loop and greatly reduce any chance of detonation...
 Old 03-23-2009, 07:57 AM   #224
lidokrantz's Avatar
EXACTLY.... I SHOULD SAY IT AGAIN EXACTLY. Drive in vacuum or hit it in boost, no middle ground.... and IMO downshift instead of going hard on it in 5th or 6th from vacuum to boost...lugging sucks.
this simple boost gauge has kept me out of trouble and this issue is not a issue for me at all...this one is easily fixed thru correct shifting...so now the issue to be found is what else is happening to make our cars from popping....moded ones that is..LOL
 Old 03-23-2009, 07:59 AM   #225
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
this punny dick little turbo sucks for keeping out of boost big turbo ftw.
by the way i do not obey those rules at all...25.5k and going strong with great leak down, compression, and i scoped the motor and its fan fucking tastic.
a built motor is not a built motor without being sleeved
fbpem1 is offline
 Old 03-23-2009, 08:00 AM   #226
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
Go WOT or baby the shit out of it? No middle ground? That sucks!
DaleNixon is offline
 Old 03-23-2009, 08:07 AM   #227
Like I said before, think about this for a while. Do you think that this motor was only calibrated to run in vacuum or full boost? You think there was no part throttle "boosting" as part of the testing? You think a bunch of people with dashhawks have better instrumentation and knowledge about what is going on than the people that designed, calibrated, and tested the drivetrain?
This smells like another forum myth spreading through the internetz.
Lex is offline
 Old 03-23-2009, 08:09 AM   #228
fbpem1's Avatar
i'll tell you this, i don't trust anything generic to read proper sensor values IMO if you want testing done it needs to be data streamed in real time from factory equipment, that the car was made to work with.
Fuck generic shit, only time you get PROPER readings out of a generic tool would be your 6 and 7 thousand dollar machines or something comperable to factory equipment like the MODIS. that said i refuse the dashhawk never owned one never will.
fbpem1 is offline
 Old 03-23-2009, 08:43 AM   #229
lidokrantz's Avatar
not saying to go WOT...just saying to go more than hoovering in that area at part throttle...i very seldom go WOT FYI...i drive most of the time at way below WOT, but i do not pussy foot around the boost/vacuum line if i can help it.
as fpb mentioned, he has no issues at all with any of this open/closed loop issue so maybe this is all paranoia...but i drive conservatively and correct enough that i have never had a blow n engine in 30 years of driving.....and again going WOT all the time is not something i do...i probably drive car more conservativley than 99% of this forums members..ohla
 Old 03-23-2009, 08:46 AM   #230
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
but the dashhawk reads the factory sensors? its the same thing the ECU is reading...
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
 Old 03-23-2009, 08:48 AM   #231
fbpem1's Avatar
oh don't get me wrong i have blown engines before, but th eones i did i shoved 35-36psi through a huge turbo through and i knew it was coming.
In my opinion this is mass hysteria but there may be something to it, with the way the EGR purges, and how it does, IMO if you drive part throttle boost OVER 1/4 throttle your fine, because then the egr does not purge at all, if your 1/4 or under it does, and thats where i see people blowing, once they get out of that, it goes back and spikes lean becuase its missing that inhert gas that was being injected from the EGR. and the ecm can't compensate enough for it.
Thats only a theory, that was tested using mazda's datalogging equipment just so you know. the numbers i know this car does i use factory stuff becuase as i said i don't trust generics.
As for the closed/open loop thing i dont' think its that, its just what the egr is doing, and when you have all that extra breathing mods on the car it could happen hell we are all operating outside of the factory ecm specs.
i have a block off plate sitting here i keep neglecting to put on i should probably do that.
fbpem1 is offline
 Old 03-23-2009, 08:50 AM   #232
fbpem1's Avatar
no generic OBDII tool reads just like the factory, as it dosn't know everything the ECM is doing, the factory tool comes up with numbers differently and takes sensor values from other places.
heres a good example not a mazda but still, on a nissan quest with an adjustable TPS sensor, the correct reading is in the TCM not the ECM, the factory tool will give it to you, but a generic will not.
thats why they are generics they don't do even 1/4 of the shit a factory tool does.
fbpem1 is offline
 Old 03-23-2009, 08:51 AM   #233
rabble rabble
802MS3's Avatar
Groans: 221
so it appears that getting rid of the EGR is the next mod for me
802MS3 is offline
 Old 03-23-2009, 11:32 AM   #234
DaleNixon's Avatar
Groans: 91
Can you explain this further? I'm just looking for some info on the proper way to drive this car. Are you saying when the car is transitioning from vacuum to boost, you shouldn't be giving it less than, say, 1/2 throttle?
 Old 03-23-2009, 01:08 PM   #235
bf360's Avatar
honestly it really is speculation, but until someone blows this motor at full throttle in the powerband, and people keep poping this motor in that dam 3-4mark and part throttle boosting, my speculation is as acurate as you can get for now
Nixon i would say try to drive out of boost, it uses less gas and is a lot safer than risking it, if you need to downshift, if your around the 3k mark i am usually going to go wot just because i dont drive anywhere in the middle like most people
bf360 is offline
 Old 03-23-2009, 03:43 PM   #236
Betelgeuse's Avatar
SO...
+1
Other than some engines just being defective, this ^^^ seems to be the most plausible explanation for the bent rod induced failures IMO. I can guarantee that the majority of folks drive in that middle ground. If that was the cause, we'd hear of a lot more blown engines.
 Old 03-24-2009, 07:20 AM   #237
Superstretch18's Avatar
Posts: 318   (View Stats)
Superstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond repute
Alright, so since we're armchair quarterbacking, here's my .02 cents on WTF is going.
To me, it seems like there are two separate incidents in just about every blown engine case:
- bent rod event
- rod through the block event
Bent Rod Event:
The fact that rods are bending at all should point to some off-axis compression force. But how would an engine see ANY off-axis pressure? The most likely answer is the balance shaft, so that's what I'm going to go with. The past couple of blown engines have happened because of a severe overboost (35+ psi). In those cases, my hypothesis is that the BS is binding causing some deflexion in the cranshaft. = bent rod, vibrations through the clutch, metal knocking, etc., etc. It seems like that could happen at high rpms or any other high load situation as well.
That alone, however, does not grenade the motor, until...
Rod Through the Block Event:
The question that everyone should be asking is; why doesn't the event that bends the rod blow the motor? The answer is that even at high psi and high rpms, normal combustion is not the greatest force that an engine can see. Detonation is much more destructive. Depending on where in the compression stroke the detonation occurs, you can be talking about exponentially higher forces than under normal combustion. Even with the overactive knock sensor on our cars, the engine does still need to experience detonation before it can retard timing; no matter how quickly it does react. It seems like engines with straight rods can withstand those pressures fairly well, but it makes sense that a bent rod likely couldn't. Throw in the fact that the "bent rod engines" seem to be blowing in the same rpm range where just about everyone is experiencing random knocking and it seems pretty clear that is the catalyst that puts a rod through the block.
[/speculation]
Just my .02 cents; take it with a grain of salt as I've never personally looked inside the motor yet (blown or otherwise)...
Old - 2007 CX-7 Sport FWD
New - 2010 WRX Hatch
who has the most care? me 0 care.
Superstretch18 is offline
 Old 03-24-2009, 08:02 AM   #238
DaleNixon's Avatar
Groans: 91
So loading up the engine at low RPMs is bad. I've taken this and translated it into never loading up the engine hard below 3k in 5th or 6th. Even then, I don't mash the pedal to accelerate. WOT in 5th or 6th is for top speed runs I guess. Too bad the car magazines always brag about how there's no need to downshift to get power in this car. Everyone who reads that and buys an MS3 will be destroying their engine.
Edit: We should ask Cobb how they daily drive their MS3. It's seen a shitload of abuse and is still rock solid according to their blog.
 Old 03-24-2009, 08:17 AM   #239
Fux Wit It
Darksun280's Avatar
Groans: 175
Everything is supposedly bad. Theres no exact way to do things. You drive the car the way you drive it. If it blows you were doing something wrong if it doesn't blow you were doing something right. Or trade it in and you won't have to find out the answer either way.
 Old 03-24-2009, 08:21 AM   #240
DaleNixon's Avatar
Groans: 91
Fuck it. I love this car. I'll drive it til it pops and hope I'm doing things right!
MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 1441 06-25-2019 06:11 PM
Mazdaspeed 2.3L DISI Turbo Blown Engine Resource Thread Kennosuke MazdaSpeed 6 - Engine, Transmission & Driveline 1 04-27-2009 01:26 AM
Page generated in 0.61839 seconds with 40 queries
