![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
(Thread Starter) | Not Ranked : 0 score Can anyone else verify this? Sent from my ADR6425LVW using Tapatalk
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
![]() Join Date: Mar 2011 Location: Nor Cal- Pittsburg
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
| Not Ranked : 0 score Here is a link for the mains: STD OS .25 OS .50 1100A - PISTON, CRANKSHAFT & FLYWHEEL. Fits: 2007 Mazda MazdaSpeed6 | Jim Ellis Mazda I am in the process of having some connecting rod bearings done by ACL. So those will be available soon. Here are the sizes that are available for the mains from ACL now: STD .25 .50 .75 Part number 5M8174A Jason
__________________ JRL Tuning 510-459-7229 www.full-race.com |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score And by oversize we mean that the bore the bearings create is undersize?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
Groans: 40
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | | |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score I was just about to say that the .50s were not available anymore as i think that is why dustin had his problem.
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
Groans: 433
| Not Ranked : 0 score stuck
| Not Ranked : 0 score Since it is stuck now, here are the part numbers if someone wanted to use Clevite or Federal Mogul or King as an option. Some people like to have other options: Mains: Clevite 77: MS-2245AL Federal Mogul: 7411MA King: MB5442SI Jason
| Banned ![]() Join Date: Nov 2010 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
Groaned at 28 Times in 11 Posts
| Not Ranked : 0 score I was just in the process of starting the same project with King Bearings for Rod Bearings. |
| Not Ranked : 0 score I just posted the oversize bearing part numbers in my ms6 part number thread. I couldnt find them forever but I finally found them for the crank, rod, and thrust bearing.
Groans: 433
| Not Ranked : 0 score PLEASE post in here!!!!!!
| Not Ranked : 0 score Alright, thought that I would update everyone about the con rod bearings. ACL actually had them already. They are the same ones that are used on the Mitsubishi 4B11T 2.0L motor. Here are the part numbers for not only ACL, but Clevite 77 interchanges if you are interested: ACL: 4B1236H Clevite: CB1918H That is the "standard" part number for the ACL and Clevite. ACL has the .025, .25, and the "X" which have an additional .001". Jason
| Banned ![]() Join Date: Jun 2012
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score And by oversize we mean that the bore the bearings create is undersize? ________________________ Nike Free Run Hollister Dundrum New Balance Sneakers |
Groans: 793
You trolling me nigga?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
![]() Join Date: Jun 2009
| Not Ranked : 0 score When the crank is machined, it's journals have metal removed, thus making each journal's outside diameter smaller. Thus the replacement bearings must be oversize, with a larger assembled inside diameter to maintain specified clearance. To my knowledge, no bearing manufacturer makes smaller than stock rod or main bearings. Of necessity, they will be either standard or oversize. BTW: if bearings are now available (mains and rods) from Clevite, that company's uniform quality is superb. You really can't do better than Clevite 77.
Groans: 793
You cannot remove material from the crank, and the bearing bore and expect clearances to be maintained. The term oversized, refers to the thickness of the bearing halves.
Groans: 40
(Thread Starter) | Not Ranked : 0 score I think u guys are saying the same thing in different ways... Sent from my Galaxy Nexus using Tapatalk 2
| Not Ranked : 0 score ^ Exactly! The backing of bearing shells will the thicker and the O.D. of the bearing surfaces when combined will be larger to compensate for the loss of metal on the crank journals. In an earlier part of my life and growing up in an automotive/industrial/diesel production engine rebuilding company and machine shop, I spent a LOT of time at the controls of crankshaft grinders, rod reconditioning machines, cylinder boring bars, milling machines, etc., and in assembly of short blocks and cylinder heads. About the only machine I did not have time to learn to operate before my journey through business school and a post-graduate degree was the camshaft grinder and the development of the lobe blank masters for custom (read: performance) grinds. I am still very much involved in that business, but now on the management side.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | BZiggy10 (02-05-2014) |
![]() | | #19 | ![]() |
Groans: 793
| Not Ranked : 0 score He said larger inside diametre. That's not the same as smaller inside diametre.
![]() | | #20 | ![]() |
| Not Ranked : 0 score ^ You are right. The assembled I.D. of the bearings must be smaller to match the smaller journal size (plus the oil clearance). Misstatement brain fart in my first post, corrected above.
![]() | | #21 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Discuss Here: Oversized crank bearings
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| Mazda crank pulley tool vs Ford crank pulley tool | SPEED6 KILLAH | MazdaSpeed 6 - Engine, Transmission & Driveline | 52 | 03-11-2017 09:46 AM |
| Oversized crank bearings | tbot | MazdaSpeed 3 - Engine, Transmission & Driveline | 23 | 07-24-2015 05:20 PM |
| Mazda3 Crank vs Speed3 Crank | relenger | MazdaSpeed 3 - Engine, Transmission & Driveline | 36 | 12-19-2010 08:22 AM |
| LCA Spherical bearings | Todd98SE | 2010 MS3 - Suspension & Brakes | 7 | 02-03-2010 01:00 PM |
| LCA Spherical bearings | Todd98SE | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 01-31-2010 06:07 PM |
