(Thread Starter) | Mazdaspeed Forums Spark Plug Index Database Gap size - 0.26 - 0.32 | Preferred gap is between 0.26 to 0.28 Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug Heat Range Conversion Chart Code: HKS 25 30 35 40 45 50 52.5 55 DENSO 16 20 22 24 27 31 32 34 NGK 5 6 7 8 9 10 10.5 11
NGK Copper Plugs LZTR4A-11 (5306) LZTR5A-13 (4306) BKR7E
| The Following User Says Thank You to Haltech For This Useful Post: | cciepunk (12-27-2013) |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1819 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
Groaned at 39 Times in 23 Posts
| Not Ranked : 0 score HKS has plugs available for the MS3/MS6 as well I actaully have a set of the heat range 7 (1 step colder) from the HKS-USA site: 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. BTW, I've also been running the NGK 6510's gapped @ .32 for almost a year now and they are great
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 |
(Thread Starter) | Thanks very much Whoosh!
![]() Join Date: Sep 2008
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score so what would the best spark plugs be for just having TBE, CAI, and BOV? |
| Banned ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
| Not Ranked : 0 score what are the ngks supposed to be gapped at stock... anybody know? |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groaned at 196 Times in 127 Posts
| Not Ranked : 0 score stock they come at something stupid like 42 |
| Not Ranked : 0 score i dont think the ones on my car were ever gapped. ken just told me it isnt necessary unless the car doesnt run right...lol we'll see. |
![]() Join Date: Mar 2008 Location: Yakima, Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score What is the torque setting for spark plugs?
__________________ 2007 MAZDASPEED 3, MS CAI, MS CBE. |
(Thread Starter) | Twist in until it stops by hand using the extension of the ratchet.. than one 1/4 inch turn to secure. Be sure to use a dab of anti seize on the threads and a dab of di-electric grease on the top of the plug where the coil connects to.
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
| Not Ranked : 0 score Here is a good spark plug reading link. Someone rip the info from there and sticky it! Well for non-iridium types, but you kinda get the idea. Spark Plugs |
![]() Join Date: May 2008 Location: Saint John, NB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score I am guessing the .30 to .32 gapping is in mm? |
![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score i kno nothing about gap and what not, what plug would u guys reccommend just to make the motor run better? no mods yet |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score Start at .038 and work your way down from there. We have found that on stock gap (.042) the NGK's seem to work very well with stock boosted applications. If you turn up the boost your going to want to knock that gap down a little bit. We have ran them as high as .038 at 21 psi on the stock turbo. I have yet to have blow out problems with the one range colder plugs. |
![]() Join Date: Aug 2008 Location: Central Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Has anyone tried just running a plain ole copper plug? |
(Thread Starter) | No one has sourced a copper plug compatible with these COPs yet.
![]() Join Date: Sep 2008 Location: Creve Coeur
| Not Ranked : 0 score I just wanted to Throw this out there. I thew in a set of NGK 5610s last night and found that the stock plugs in my car (fomoco) were gapped at .030!!!!!!!!!!!!!!! Started the ngks at .038. I wondered what the deal was. I think stock was supposed to be around 40-42???? The car was only touched by mazda before I got it at 30k miles, its around 44k now. Input????? It smoothed it out alot, still getting flames out the back between shifts though sometimes.... |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
![]() | | #19 | ![]() |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score Should I switch to step colder plugs? What's the advantage? How often should I be swapping plugs? 10,500 on the odometer. |
![]() | | #20 | ![]() |
| Banned ![]() Join Date: Sep 2008 Location: Calgary, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score so...any advantages? |
![]() | | #21 | ![]() |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| Not Ranked : 0 score I personally think it would be useful to post the gap issues with some plugs. For example, both the stock heat range Denso and one step colder NGK are both factory gapped at ~.045. That isn't correct for our motor and requires a funky bend on the ground electrode. They work, but are not ideal. Denso 1 and 2 step colder are the proper gap.
__________________ |
![]() | | #22 | ![]() |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
Groaned at 48 Times in 42 Posts
| Not Ranked : 0 score What is the advantage to using +1 +2 step colder plugs? |
![]() | | #23 | ![]() |
![]() Join Date: Apr 2009 Location: Atlanta, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score I am looking at buying some plugs. Ditto on the "What are the pros for getting a +1 +2 plug set?"
__________________ My best to date is a 14.5 @ 100mph |CAI|BOV [SIGPIC][/SIGPIC] |
![]() | | #24 | ![]() |
Groans: 1,940
| Not Ranked : 0 score my understanding is as follows: good for more extensive mods. and they will also help keep knock at bay |
![]() | | #25 | ![]() |
![]() Join Date: Aug 2008 Location: Orange Country, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 489
| Not Ranked : 0 score does anyone know the part number for the denso itv 22's trying to get them at an advanced auto parts near my house and theyre retarded and cant find it by "itv 22" they need a part number
__________________ 08.5 BM MS3 GT; CPE Nano; Forge BPV; CPE Catless TBE; CPE 60 RMM: ITV22; Cobb AP Stage 2 +SF 93; PTP HPFP; CPE Front Mount Intercooler |
![]() | | #26 | ![]() |
![]() Join Date: May 2009 Location: Toledo, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
| Not Ranked : 0 score 5340
__________________ ToledoSpeed3 ![]() 09 MazdaSpeed3 GT, True Red |
![]() | | #27 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score I have repeated issues with colder plugs, I fry then in like 2k miles. the arm over electrode looks glazed white like ceramic and i get misfire trouble codes. this happened with Densso itv 22 and 24 and the NGKs, So i am gonna go back to stock plugs ! fuck this bs. I may consider trying itv 20 stock heat and see if they hold up. its happening more often ive got the maf tuned to about 12-12.5 A/F I wanted to ask can anyone explain why i am having plug issues .... they come out looking like the car runs lean even before I made air/fuel higher. and we all know the car runs rich. |
![]() | | #28 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 952
Groans: 70
| Not Ranked : 0 score ^ thats a strange issue, i am running the denso 2 step colder and the only issie i have after 8k miles is a rough idle sometimes. Are they gapped correctly? |
![]() | | #29 | ![]() |
![]() Join Date: May 2008 Location: LBC
Rep Power: 0 ![]() Thanks: 0
and yes i've checked the gap multiple times.on the good side, i can get my TMIC off in 5 mins flat now cause i've had to change my plugs so many dang times. | |
![]() | | #30 | ![]() |
| Always Blasted ![]() Join Date: Jul 2009 Location: North NJ
Rep Power: 679 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
Groans: 34
Groaned at 274 Times in 34 Posts
| Not Ranked : 0 score the ITV22s come gapped at .32 i thought, and i just spoke to cobb and they said to gap to .28 if you have the AP. is prefered gap what people who have the AP are running? or is that for stock ECU in which case the ITV22s come ready.
__________________ 07 Speed 6 GT Cobb AP Stage 2+TIHSF+TMIC 93 Octane, ETS 3.5'' TMIC, Cobb Short Ram Intake, Cobb Turbo Inlet Pipe, Turbosmart Dual Port Blow Off Valve, SU Test Pipe, Custom CPE/Magnaflow Exhaust, Corksport Strut Brace, TWM Stage 2 Short Shifter, TWM Weighted Desert Eagle Shift Knob, AWR Transmission Mount, SU Base Bushings, SU Rear Motor Mount, Optima Yellowtop Battery, PIAA Plasma Ion Fogs, EBC Red Brakes, Denso ITV22s .28 Gap, Prosport Boost Gauge, RPM Sport Springs, Bilstein Shocks, SPC Balljoints, Continental Extreme Contact DWS AAA XL, Pirelli Sottozero snow tires, 5zigen ProRacer GN+ 18x8.5. |
![]() | | #31 | ![]() |
And i had a coil go bad on my half mile from my house i limped(ran off 3 cyl, car shook really bad barely accelerated.) to mazda fully bolted with fmic and they replaced ignition coil. Dashhawk said misfire cyl 1 i changed 4 plugs still same thing, i swap coil from 1 to 2 and the error switched from 1 to 2. Coil is bad. And earlier same day i had cyl 4 misfiring, i replaced plug and it went away and it only misfired under boost 10 psi or more, this is getting annoying ! i think this colder plug bull shit is just an excuse for people who cant tune out knock or something, people with stock plugs have no issues at all. i ordered 4 stock plugs at a rediculous 15 ea. mazda dont even stock coil nor plugs because theyve never seen any go bad they said ! parts made me pre pay for plugs because they are special order, not stocked. my friend has stock plugs cpe tbe and cpe cai and he dynoed more power then me ...... with stock intercooler. And i have everything. so wtf ? he got 272 i got 265, then they sprayed our intercoolers with NOS and i got 281 he got 285. My intercooler made the difference here. | |
![]() | | #32 | ![]() |
![]() Join Date: Oct 2009 Location: An Army Base
Groaned at 15 Times in 2 Posts
| Not Ranked : 0 score Glad ive read this thread, Ive been asking this ? for some time now. |
![]() | | #33 | ![]() |
![]() Join Date: Mar 2009 Location: Sacramento
| Not Ranked : 0 score Someone confirm these are the correct plugs for the mazdaspeed3: 4 DENSO IRIDIUM Power Spark Plugs ITV22 5340 - Chevy:eBay Motors (item 270389179968 end time Nov-07-09 11 06 PST)
__________________ 2009 Crystal White Pearl Mazdaspeed3 Sport **SOLD** 2010 Monterey Blue Nissan 370z Base w/ Sport Package 6MT |
![]() | | #34 | ![]() |
| Not Ranked : 0 score YES, ITV22 are the correct ones. |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Thanks. I will be ordering a set.
![]() | | #36 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score what have you guys found to be the most reliable aftermarket plugs, it seems to me that these colder ones arnt lasting as long. |
![]() | | #37 | ![]() |
![]() Join Date: Dec 2009 Location: Middle Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Ditto. Having same issue. ITV22s gapped at .30 and already fouling w/ less than 2k on them.
__________________ 09 Speed 3 GT |
![]() | | #38 | ![]() |
| Not Ranked : 0 score For aluminum heads I always use 13 ft lbs. Btw... my stock, from the factory plugs (09 MS3) were at .28 gap. From the factory. I checked them all w/ feeler guages. All 4 were at .28 perfectly.
![]() | | #39 | ![]() |
| Not Ranked : 0 score Sorry for the multiple post. It's in just 1 thread now. Thanks phillyb, apologies.
![]() | | #40 | ![]() |
Groans: 1,940
| Not Ranked : 0 score mhmm...my understanding of ngks is that we use 6510 for 1 step colder. not that part number. |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3/6 - ECU Computer Tuning | 74 | 08-02-2019 08:18 AM |
| Spark Plug Database - Gen2 | Haltech | 2010 MS3 - Engine, Transmission & Driveline | 23 | 09-27-2017 05:09 PM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 6 - Engine, Transmission & Driveline | 41 | 05-05-2016 08:49 AM |
| Spark Plug Database - Gen2 | Haltech | 2010 MS3 - ECU Computer Tuning | 3 | 02-27-2016 04:53 PM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 205 | 09-22-2015 06:52 PM |
