> MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline
 Old 05-19-2008, 04:14 PM   #1
Default Spark Plug Database - Colder Than Stock ( Stage 1&2 )
This is a compiled database for spark plugs who's heat range is 1 and 2 stages colder than stock. Please add your plugs and we will update this thread.
Mazdaspeed Forums Spark Plug Index Database
Gap size - 0.26 - 0.32 | Preferred gap is between 0.26 to 0.28
Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug
Heat Range Conversion Chart
Code:
HKS 25 30 35 40 45 50 52.5 55
DENSO 16 20 22 24 27 31 32 34
NGK 5 6 7 8 9 10 10.5 11
Spark Plug Manf & Part Numbers
  • Denso Iridium
  • itv-20 - Stock heat range
  • itv-22 - 1 stage colder heat range
  • itv-24 - 2 stage colder heat range
  • itv-27 - 3.5 stage colder heat range
  • HKS
  • 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. - 1 Stage Colder Heat Range
  • 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - 2 Stage Colder Heat Range
  • NGK IX Iridium
  • NGK LTR7IX-11 (6510) - 1 Stage Colder Heat Range
  • NGK ILTR6A-8G (3787) - Stock Heat Range
  • Torque Master Spark Plugs
  • SVTP8BR Stock Heat Range
  • SVTP7YR 1 Stage Colder Heat Range
  • Autolite Iridium
  • Autolite Iridiums XP5364 - Stock Heatrange
  • Autolite Iridiums XP5263 - 1 Step Colder
NGK Copper Plugs
LZTR4A-11 (5306)
LZTR5A-13 (4306)
BKR7E
cciepunk likes this.
Haltech is offline
cciepunk (12-27-2013)
 Old 05-20-2008, 04:58 AM   #2
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
HKS has plugs available for the MS3/MS6 as well
I actaully have a set of the heat range 7 (1 step colder)
from the HKS-USA site:
BTW, I've also been running the NGK 6510's gapped @ .32 for almost a year now and they are great
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline
 Old 05-20-2008, 05:26 AM   #3
Thanks very much Whoosh!
Haltech is offline
 Old 10-04-2008, 01:48 PM   #4
speedster 3's Avatar
Posts: 20   (View Stats)
speedster 3 will become famous soon enough
so what would the best spark plugs be for just having TBE, CAI, and BOV?
speedster 3 is offline
 Old 10-04-2008, 01:53 PM   #5
phailerider's Avatar
Posts: 4,639   (View Stats)
what are the ngks supposed to be gapped at stock... anybody know?
phailerider is offline
 Old 10-04-2008, 02:03 PM   #6
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
stock they come at something stupid like 42
Djohns likes this.
Laloosh is offline
 Old 10-04-2008, 02:31 PM   #7
i dont think the ones on my car were ever gapped. ken just told me it isnt necessary unless the car doesnt run right...lol we'll see.
 Old 10-18-2008, 08:04 PM   #8
Speedy3's Avatar
Posts: 298   (View Stats)
Speedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the world
What is the torque setting for spark plugs?
2007 MAZDASPEED 3, MS CAI, MS CBE.
Speedy3 is offline
 Old 10-18-2008, 08:06 PM   #9
Twist in until it stops by hand using the extension of the ratchet.. than one 1/4 inch turn to secure. Be sure to use a dab of anti seize on the threads and a dab of di-electric grease on the top of the plug where the coil connects to.
Haltech is offline
 Old 10-26-2008, 04:19 PM   #10
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Here is a good spark plug reading link. Someone rip the info from there and sticky it! Well for non-iridium types, but you kinda get the idea.
Spark Plugs
bioevolve is offline
 Old 03-01-2010, 07:53 AM   #11
shpankey's Avatar
Posts: 496   (View Stats)
shpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the world
For aluminum heads I always use 13 ft lbs.
Btw... my stock, from the factory plugs (09 MS3) were at .28 gap. From the factory. I checked them all w/ feeler guages. All 4 were at .28 perfectly.
09 Speed 3 GT
shpankey is offline
 Old 11-18-2008, 06:29 PM   #12
Phantom's Avatar
Posts: 313   (View Stats)
Phantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud of
I am guessing the .30 to .32 gapping is in mm?
Phantom is offline
 Old 12-07-2008, 06:07 AM   #13
ptperformance's Avatar
Posts: 4,123   (View Stats)
No, it should be .032 in inches.
ptperformance is offline
 Old 02-02-2009, 11:00 PM   #14
zoom-zoomhatch's Avatar
Posts: 76   (View Stats)
zoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to beholdzoom-zoomhatch is a splendid one to behold
Has anyone tried just running a plain ole copper plug?
zoom-zoomhatch is offline
 Old 02-03-2009, 09:34 AM   #15
No one has sourced a copper plug compatible with these COPs yet.
Haltech is offline
 Old 11-22-2008, 09:10 AM   #16
ms6acton's Avatar
Posts: 24   (View Stats)
ms6acton will become famous soon enoughms6acton will become famous soon enough
i kno nothing about gap and what not, what plug would u guys reccommend just to make the motor run better? no mods yet
ms6acton is offline
 Old 12-07-2008, 06:06 AM   #17
Start at .038 and work your way down from there. We have found that on stock gap (.042) the NGK's seem to work very well with stock boosted applications. If you turn up the boost your going to want to knock that gap down a little bit. We have ran them as high as .038 at 21 psi on the stock turbo. I have yet to have blow out problems with the one range colder plugs.
 Old 02-13-2009, 12:59 PM   #18
Monstar's Avatar
Posts: 68   (View Stats)
Monstar has a spectacular aura aboutMonstar has a spectacular aura aboutMonstar has a spectacular aura about
I just wanted to Throw this out there. I thew in a set of NGK 5610s last night and found that the stock plugs in my car (fomoco) were gapped at .030!!!!!!!!!!!!!!! Started the ngks at .038. I wondered what the deal was. I think stock was supposed to be around 40-42???? The car was only touched by mazda before I got it at 30k miles, its around 44k now. Input?????
It smoothed it out alot, still getting flames out the back between shifts though sometimes....
Monstar is offline
 Old 02-21-2009, 02:32 PM   #19
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
did you read anything in the first post?
phillyb is offline
 Old 03-11-2010, 03:19 PM   #20
shpankey's Avatar
Thanks!
I know this was to him. But I'm kind of lost on this whole issue.
I checked my stockers (FoMoCo) and they were dead on at .028 gap from the factory. So I'm guessing I am in one measurement and others are using the other?
09 Speed 3 GT
shpankey is offline
 Old 05-01-2009, 08:38 AM   #21
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Should I switch to step colder plugs? What's the advantage?
How often should I be swapping plugs?
10,500 on the odometer.
this forum serves 2 purposes
Dash08 is offline
 Old 05-20-2009, 11:45 PM   #22
Monkey_3's Avatar
Posts: 131   (View Stats)
Monkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to beholdMonkey_3 is a splendid one to behold
so...any advantages?
Monkey_3 is offline
 Old 05-21-2009, 12:57 AM   #23
Axle Breaker
jmhinkle's Avatar
Groans: 162
I personally think it would be useful to post the gap issues with some plugs. For example, both the stock heat range Denso and one step colder NGK are both factory gapped at ~.045. That isn't correct for our motor and requires a funky bend on the ground electrode. They work, but are not ideal. Denso 1 and 2 step colder are the proper gap.
jmhinkle is offline
 Old 05-28-2009, 12:04 AM   #24
djrivera's Avatar
Posts: 193   (View Stats)
djrivera has much to be proud ofdjrivera has much to be proud ofdjrivera has much to be proud ofdjrivera has much to be proud ofdjrivera has much to be proud ofdjrivera has much to be proud ofdjrivera has much to be proud ofdjrivera has much to be proud ofdjrivera has much to be proud of
Groaned at 48 Times in 42 Posts
What is the advantage to using +1 +2 step colder plugs?
djrivera is offline
 Old 06-05-2009, 07:44 AM   #25
straydoginc's Avatar
Posts: 43   (View Stats)
straydoginc is just really nicestraydoginc is just really nicestraydoginc is just really nicestraydoginc is just really nicestraydoginc is just really nice
I am looking at buying some plugs. Ditto on the "What are the pros for getting a +1 +2 plug set?"
My best to date is a 14.5 @ 100mph |CAI|BOV
straydoginc is offline
 Old 06-05-2009, 10:42 AM   #26
phillyb's Avatar
Groans: 1,940
my understanding is as follows: good for more extensive mods.
and they will also help keep knock at bay
phillyb is offline
 Old 06-25-2009, 01:56 PM   #27
jlocurto's Avatar
Posts: 388   (View Stats)
jlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the world
does anyone know the part number for the denso itv 22's trying to get them at an advanced auto parts near my house and theyre retarded and cant find it by "itv 22" they need a part number
08.5 BM MS3 GT; CPE Nano; Forge BPV; CPE Catless TBE; CPE 60 RMM: ITV22; Cobb AP Stage 2 +SF 93; PTP HPFP; CPE Front Mount Intercooler
jlocurto is offline
 Old 06-25-2009, 09:35 PM   #28
ToledoSpeed3's Avatar
Posts: 244   (View Stats)
ToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the world
5340
ToledoSpeed3
09 MazdaSpeed3 GT, True Red
ToledoSpeed3 is offline
 Old 09-12-2009, 04:46 AM   #29
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
I have repeated issues with colder plugs, I fry then in like 2k miles. the arm over electrode looks glazed white like ceramic and i get misfire trouble codes. this happened with Densso itv 22 and 24 and the NGKs, So i am gonna go back to stock plugs ! fuck this bs.
I may consider trying itv 20 stock heat and see if they hold up. its happening more often ive got the maf tuned to about 12-12.5 A/F
I wanted to ask can anyone explain why i am having plug issues .... they come out looking like the car runs lean even before I made air/fuel higher. and we all know the car runs rich.
Nitr0EngiE is offline
 Old 09-12-2009, 09:35 AM   #30
atomic_rice's Avatar
Posts: 2   (View Stats)
atomic_rice is an unknown quantity at this point
im having the same issue. I've gone through 2 sets of ITV22s, getting misfire codes in different cylinders. I've changed the coil packs around, so i know its not the problem. Im thinking of goin back to stock as well. and yes i've checked the gap multiple times.
on the good side, i can get my TMIC off in 5 mins flat now cause i've had to change my plugs so many dang times.
atomic_rice is offline
 Old 02-19-2010, 11:45 AM   #31
shpankey's Avatar
Ditto. Having same issue. ITV22s gapped at .30 and already fouling w/ less than 2k on them.
09 Speed 3 GT
shpankey is offline
 Old 09-12-2009, 08:29 AM   #32
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
Groans: 70
^ thats a strange issue, i am running the denso 2 step colder and the only issie i have after 8k miles is a rough idle sometimes.
Are they gapped correctly?
2007speed3 is offline
 Old 09-12-2009, 09:52 AM   #33
Always Blasted
DCLXVI's Avatar
Posts: 653   (View Stats)
DCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the world
Groans: 34
Groaned at 274 Times in 34 Posts
the ITV22s come gapped at .32 i thought, and i just spoke to cobb and they said to gap to .28 if you have the AP. is prefered gap what people who have the AP are running? or is that for stock ECU in which case the ITV22s come ready.
07 Speed 6 GT Cobb AP Stage 2+TIHSF+TMIC 93 Octane, ETS 3.5'' TMIC, Cobb Short Ram Intake, Cobb Turbo Inlet Pipe, Turbosmart Dual Port Blow Off Valve, SU Test Pipe, Custom CPE/Magnaflow Exhaust, Corksport Strut Brace, TWM Stage 2 Short Shifter, TWM Weighted Desert Eagle Shift Knob, AWR Transmission Mount, SU Base Bushings, SU Rear Motor Mount, Optima Yellowtop Battery, PIAA Plasma Ion Fogs, EBC Red Brakes, Denso ITV22s .28 Gap, Prosport Boost Gauge, RPM Sport Springs, Bilstein Shocks, SPC Balljoints, Continental Extreme Contact DWS AAA XL, Pirelli Sottozero snow tires, 5zigen ProRacer GN+ 18x8.5.
DCLXVI is offline
 Old 09-13-2009, 02:40 PM   #34
Daily Driver
Nitr0EngiE's Avatar
the only reason cobb says that is for increased Boost im told .28 is better. but on my car i cant get past like 16 psi no matter what i set it to in SB, our turbos blow ass.
And i had a coil go bad on my half mile from my house i limped(ran off 3 cyl, car shook really bad barely accelerated.) to mazda fully bolted with fmic and they replaced ignition coil. Dashhawk said misfire cyl 1 i changed 4 plugs still same thing, i swap coil from 1 to 2 and the error switched from 1 to 2. Coil is bad. And earlier same day i had cyl 4 misfiring, i replaced plug and it went away and it only misfired under boost 10 psi or more, this is getting annoying !
i think this colder plug bull shit is just an excuse for people who cant tune out knock or something, people with stock plugs have no issues at all. i ordered 4 stock plugs at a rediculous 15 ea. mazda dont even stock coil nor plugs because theyve never seen any go bad they said ! parts made me pre pay for plugs because they are special order, not stocked.
my friend has stock plugs cpe tbe and cpe cai and he dynoed more power then me ...... with stock intercooler. And i have everything. so wtf ? he got 272 i got 265, then they sprayed our intercoolers with NOS and i got 281 he got 285. My intercooler made the difference here.
 Old 10-19-2009, 06:57 PM   #35
camdensms6's Avatar
Posts: 97   (View Stats)
camdensms6 is a glorious beacon of lightcamdensms6 is a glorious beacon of lightcamdensms6 is a glorious beacon of lightcamdensms6 is a glorious beacon of lightcamdensms6 is a glorious beacon of light
Groaned at 15 Times in 2 Posts
Glad ive read this thread, Ive been asking this ? for some time now.
camdensms6 is offline
 Old 10-22-2009, 08:55 AM   #36
TongMan's Avatar
Posts: 444   (View Stats)
TongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond repute
Someone confirm these are the correct plugs for the mazdaspeed3:
4 DENSO IRIDIUM Power Spark Plugs ITV22 5340 - Chevy:eBay Motors (item 270389179968 end time Nov-07-09 1106 PST)
2009 Crystal White Pearl Mazdaspeed3 Sport **SOLD**
2010 Monterey Blue Nissan 370z Base w/ Sport Package 6MT
TongMan is offline
 Old 10-22-2009, 09:07 AM   #37
Alittle Faster
bioevolve's Avatar
YES, ITV22 are the correct ones.
 Old 10-22-2009, 03:36 PM   #38
TongMan's Avatar
Thanks. I will be ordering a set.
TongMan is offline
 Old 02-08-2010, 07:12 PM   #39
curtspeed6's Avatar
Posts: 31   (View Stats)
curtspeed6 is infamous around these partscurtspeed6 is infamous around these partscurtspeed6 is infamous around these partscurtspeed6 is infamous around these parts
what have you guys found to be the most reliable aftermarket plugs, it seems to me that these colder ones arnt lasting as long.
curtspeed6 is offline
 Old 03-11-2010, 02:30 PM   #40
shpankey's Avatar
Sorry for the multiple post. It's in just 1 thread now. Thanks phillyb, apologies.
09 Speed 3 GT
shpankey is offline
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 74 08-02-2019 08:18 AM
Spark Plug Database - Gen2 Haltech 2010 MS3 - Engine, Transmission & Driveline 23 09-27-2017 05:09 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 6 - Engine, Transmission & Driveline 41 05-05-2016 08:49 AM
Spark Plug Database - Gen2 Haltech 2010 MS3 - ECU Computer Tuning 3 02-27-2016 04:53 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 06:52 PM
Page generated in 0.58326 seconds with 47 queries
