![]() Join Date: Feb 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score i am using 5/30 Penzoil Platinum. Not happy with the lower viscosity results compared with other oils posted on this board. below is the result of the second oil change on the car, showing the performance of PP. MI/HR on Oil = 3891 MI/HR on Unit = 7330 Sample Date = 8/09 Make Up Oil Added = 0 ALUMINUM = 3 CHROMIUM = 1 IRON = 14 COPPER = 111 LEAD = 3 TIN = 1 MOLYBDENUM = 48 NICKEL = 0 MANGANESE = 2 SILVER = 0 TITANIUM = 0 POTASSIUM = 1 BORON = 30 SILICON = 11 SODIUM = 2 CALCIUM = 2737 MAGNESIUM = 11 PHOSPHORUS = 638 ZINC = 736 BARIUM = 2 SUS Viscosity @ 210°F = 53.9 (56-63) cSt Viscosity @ 100°C = 8.44 (9.1-11.3) Flashpoint in °F = 390 Fuel % = <0.5 Antifreeze % = 0.0 Water % = 0 Insolubles % = 0.3 TBN = 4.5 |
![]() Join Date: Mar 2008 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,050
| Not Ranked : 0 score I drive around 70 miles a day during the week, with a nearly 50/50 mix of highway and city driving. I do slightly more highway driving, but it's a negligible amount.
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle |
![]() Join Date: Nov 2008 Location: Severn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 137
Groans: 35
| Not Ranked : 0 score Sending my break in oil w/1100 miles on it just to see how bad it is. Next sample will be in ~1500 miles (which will be 5k on the odometer). I have Motul 8800 in right now, curious to see how it handles everything. Will post results. |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score I've got a bottle of Rotella T Syn 5W-40 waiting to be mailed to Blackstone. I'll probably get it out tomorrow, so stay tuned for a UOA for Rotella.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
Groans: 35
| Not Ranked : 0 score Just got my sample back from Blackstone. Some of the values are pretty high, but it was the break in oil changed out early. Glad to see the fuel was not obnoxious, hopefully it stays that way. Stock 09 MS3 |
| Not Ranked : 0 score Ok, here's my first UOA on my Speed using Rotella T Syn 5W-40. This was my second fill using the Rotella. Looks like I'll continue to use it. Note the high phosphorus and zinc levels that are common with heavy duty oils like Rotella. They are anti-wear additives and detergents. Not sure why my magnesium level is so damn high, but they didn't say it was bad, so I'm not going to worry about it. MI/HR on Oil = 5,000 MI/HR on Unit = 16,500 Sample Date = 1/28/09 Make Up Oil Added = 0 Universal Averages shown in ( x ) ALUMINUM = 2 (3) CHROMIUM = 0 (1) IRON = 12 (18) COPPER = 28 (23) LEAD = 1 (1) TIN = 0 (0) MOLYBDENUM = 55 (68) NICKEL = 0 (0) MANGANESE = 0 (0) SILVER = 0 (0) TITANIUM = 0 (0) POTASSIUM = 0 (0) BORON = 30 (45) SILICON = 4 (5) SODIUM = 4 (26) CALCIUM = 852 (2,337) MAGNESIUM = 941 (83) PHOSPHORUS = 870 (645) ZINC = 1006 (779) BARIUM = 0 (0) SUS Viscosity @ 210°F = 65.9 (65-78) cSt Viscosity @ 100°C = 11.86 (11.6-15.3) Flashpoint in °F = 350 (>375) Fuel % = 1.3 (<2.0) Antifreeze % = 0.0 (0) Water % = 0 (<0.1) Insolubles % = 0.3 (<0.6) TBN = 4.9 COMMENTS: Nothing too unusual showed up in the initial sample from your Mazda. All wear read at or below averages, which is a very good indication of normal wearing parts, especially since this oil was run a little longer than average. Universal averages show normal wear after ~4,100 miles use on the oil. Fuel dilution was found at 1.3%. This is below our problem level and since it didn't hurt the viscosity, we don't think it's a concern, but we will watch it next time. The TBN was strong at 4.9, so the oil has lots active additive left. 1.0 is low. Try 6,500 miles on the next oil.
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score Just wanted to thank everyone for posting UOA's. Keep in mind that not only do you aid others in picking oils, but every submission of a speed3/speed6 UOA, adds to the lab's database for what's considered "normal" or "average" helping us detect when problems might be occurring. Remember if you want additional comments on your UOA's, post them to the bobistheoilguy.com forums! |
| Not Ranked : 0 score I'll probably go 5,000 mile again and get another analysis done before I start going higher. I don't want to bet everything on one analysis. Remember it's winter now. Much lower temps and oil cooling probably isn't a problem. Once summer roles around, I'm not about to go 6,500 miles on the oil.
| Well i dumped my oil today and filled up with 5/40 PP once again. Im going to dump it at 3K and send it off. I will probably get a higher change interval, but since i have no issues getting my PP locally now, i will stick with it for the time being.
![]() Join Date: Dec 2009 Location: Middle Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score out of curiousity.. are you getting the PP Euro Formula?
__________________ 09 Speed 3 GT |
| Not Ranked : 0 score Oil: 5 quarts of Pennzoil Platinum 5w-30 & .6 quart of Mobile 1 0w-30 (I had to do this). Total Miles: 11,000 Miles on Oil: 2,700 Car: 09 Mazdaspeed 3 w/ mods: Cobb Short Ram Intake & Turbo Inlet Pipe, High-Pressure Fuel Pump Internals, Street Unit's Test (mid/race) Pipe, Step colder Denso Iridium Plugs w/ upgraded coil pack springs, CP-e Rear Motor Mount (60 dur), Driven: Sometimes very hard. Maybe 10-15 full, hard pulls running through all the gears to redline. 60% highway 40% city. I have a daily commute of 20 miles all highway to work, and 20 miles back Monday through Friday. I did a few car warmups as temps have been near or below freezing this entire oil use. Info: The reason for the short change of only 2,700 miles is b/c I've recently felt the car was "off" and not running near its potential after doing some of the upgrades. Worse than it was running before them. I don't know if this was just the cold weather or what but I was a little worried and wanted to make sure all was well. Also, as I didn't have a UOA on it yet, and I wanted to quickly get a baseline down and start moving the miles up. I will be running my current fill (German Castrol) for 4,200 miles so I can directly compare to the universal averages. Filter was a Fram Cartridge.
| Not Ranked : 0 score Here's my latest analysis. This is my 3rd pan full of Rotella T Syn. All I can say is I will definitely continue to use this oil. Look at that viscosity, flashpoint and TBN. There's definitely enough additive and viscosity to go abit more miles. I may try 6,000 miles next time, which will probably be the sweet spot for me.
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score thanks frequentflyer for both of the UOA's! looks like the rotella works well - probably start using that instead of pp 5w30 |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score The high manganese is from the 'Octanium' octane booster I've been using since I get crazy knock with the OTS for my mods. Working through it with ATR now and should be weened off it soon. Not sure why they didn't not engine miles.. I'm at 10k
__________________ Some things. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
(Thread Starter) | Not Ranked : 0 score My latest UOA:
__________________ Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust |
(Thread Starter) | Not Ranked : 0 score Did you actually add 5.5 quarts of oil during the OCI?
| Not Ranked : 0 score Oil change interval? No I have not had to top off at all, probably just a mistake on the report. I use ~5.5 when I do the changes.
![]() Join Date: Mar 2009
Rep Power: 0 ![]() Thanks: 4
| Not Ranked : 0 score Has anyone tried to just change the oil filter every 3k and send in the oil from the filter for a UOA, to see how long you can go on the same synthetic oil??? After reading this article I will post I was wondering how long I could go with my MS3. Right now I go 3.5k and change oil filter. Then at 7k change both oil filter & oil with synthetic. Making Sense of Synthetic Lubricants - All of the manufacturers of synthetic oil tout the benefits of reduced wear, more horsepower, lower operating temperatures, and improved fuel mileage. All of these benefits are derivatives of better cold flow characteristics and higher levels of friction reducing additives that are found in synthetic oils. I can confirm better cold driving characteristics, increased fuel mileage of nearly 10%, noticeably lower operating temperatures, better heat dissipation capability, and long term high temperature stability based on my own experience with synthetic lubricants. Are these benefits enough, however, to persuade average drivers to give up their trusted petroleum oils and pay the extra price for synthetics? Enthusiasts, yes. Average drivers, perhaps not. However, synthetic lubricants can endure extended drain intervals, which is a major consideration toward justification of the higher costs. This benefit is not widely promoted by the major oil producers most likely because they want you to pay a premium for their synthetic oils every 3000 miles just like their regular oils. Most companies don’t bother to tell you that synthetic oils are capable of going 25,000 miles or more without significant breakdown. One customer told me he drove his Toyota more than 50000 miles (with filter changes every 10000 miles) before oil analysis results told him it was time for a change. It is not uncommon for over the road truckers to go several hundred thousand miles between synthetic oil changes but it should also be noted that most are equipped with finer oil filtration devices than most passenger cars. The short trips and stop and go city driving that most of do is much tougher on motor oil than over the road highway driving. In fact, frequent short trips (2 miles or less) and stop and go city driving is considered by some raters as extreme and our cars need increased protection. Fortunately, we can achieve the superior protection and the economic benefits of synthetic oils while staying within the recommendations of our car manufacturers. |
![]() | | #19 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score ^^this is nice to see, thanks for sharing. any mods on the car?
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Not yet, Im paying off my credit card after being out of work last spring. Once that gets to $0 I will be getting a few like... CP-e nano, engine mount & DP. Cobb inlet & AP. Synapse BOV and I will stop there before I get too addicted to moding my car lol |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Oh, also... I change my oil filter 1/2 way thru my oil life. So with this oil report I posted I changed the filter at 3.5k and then changed both at about 7k. So this time I will change filter at 4k and both at 8k. |
![]() | | #22 | ![]() |
| Not Ranked : 0 score Has any one used AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil in there MS3??? Also what are the benefits of using 5W-40 over recommended 5W-30??? - Plz don't respond to 2nd question unless you know your $hit. |
![]() | | #23 | ![]() |
Groans: 221
| Not Ranked : 0 score my analysis just got emailed to me. Looks decent. 15k on the car now. oil was PP 5w-40.
![]() | | #24 | ![]() |
The 40 weight Pennzoil Platinum perfectly sheared down to a high 30 weight. Which is awesome and I'm guessing exactly what you wanted. Any chance you have another new UOA with this oil? I'd love to see the numbers on a clean run with a good air filter, I'd bet they would be astonishing. I'm going to compare my German Castrol run to this UOA and decide which one to go with. But I'm MIGHTY impressed with the PP 5w-40 Euro formula!! Here's some online for those that are interested ($32 for 6 quarts)... Pennzoil Synthetic 5W40 European Formulation - Case 6/1 Qt Note these Euro formulations are made specifically for long drain intervals. This oil could go 7k miles easy, even on our engines.
__________________ 09 Speed 3 GT | |
![]() | | #25 | ![]() |
Groans: 221
sorry I thought I posted the last one up. Check out this one, I ran it longer, and still had good results.
__________________ '08 CWP MS3 w/ T3 3071r | |
![]() | | #26 | ![]() |
Dude, did you post this on BITOG? If not, do you mind if I link to it from there and of course credit you. What was your driving like? Hwy, cty, etc.?
![]() | | #27 | ![]() |
Groans: 221
My driving was a combination of a lot. My commute to work is about maybe a 10 minute drive, city. I always try to run it for the full 10 minutes though, and never hammer on it unless its been running for at least 10-15. I did a few road trips too on that oil, mostly from Burlington to PA, 800mi round trip, so theres a big chunk of highway miles too. Other than the commute, and the road trips its all city. And lots of beating on the car too. I'm not abusive, but I'm not shy about feeling the torque
![]() | | #28 | ![]() |
| Not Ranked : 0 score Awesome TBN for that kinda mileage on the oil. It's consistent too. If people are changing this oil every 3,000 miles, they're definitely wasting their money.
![]() | | #29 | ![]() |
Groans: 221
| Not Ranked : 0 score for some people the heavier oil has stopped the smoking from the turbo
![]() | | #30 | ![]() |
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score Heres my first oil change, done at 1000miles. Completely stock, no oil catch can. Next oil change will be at 3000miles. Heres my second oil change, done at 3000miles. Mods are OCC, Cobb SRI, Cobb Inlet, Turbosmart BPV |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Maybe Im missing something, but it doesnt look any better than the rest of the synthetic oils.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Still wanting to know... Has any one used AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil in there MS3??? Thanks |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Why does it say Miles on Oil is 8,312 miles? Shouldn't it be 2,700? Seems to me they think you put way more miles on the oil than you actually did.
![]() | | #34 | ![]() |
| Not Ranked : 0 score It's corrected now.
![]() | | #35 | ![]() |
| Not Ranked : 0 score Third oil change still with mobil one 5W30(doesnt have averages because they renamed it to an 07 instead an 09, but they are fixing it) Fourth I changed to mobil one 5W40
![]() | | #36 | ![]() |
| Not Ranked : 0 score Wow man, that doesn't look good to me. Compare with my UOA above, which had the same mileage (overall) on the car. Your copper wear is terrible. Mine by comparison was 12. Yours was 78. That's huge. This is why I don't like M1 5w-30. It always has high iron wear and sometimes copper too. I would seriously change oils if I were you.
![]() | | #37 | ![]() |
| Not Ranked : 0 score Well I changed to rotella t6 synthetic so well see what happens on this next one. Other than copper did you see any areas for concern? What is high copper lvl attributed too? I dont know if I can use PP yet just seen alot of damage penzoils done in the past.
![]() | | #38 | ![]() |
Groans: 221
| Not Ranked : 0 score yeah, but this time I'm not going to have as many miles on this oil change. Its been 4 months and I've barely put 3,000mi on it.
![]() | | #39 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score Here is my latest. 4100 on dealer oil. 22K on car
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
![]() | | #40 | ![]() |
| Not Ranked : 0 score This is not good. You have some pretty bad fuel dilution going on despite what they say. Look at your flashpoint. Your wear is awesome though so it looks like it didn't effect the oil's ability to protect. Still, I'd find a new oil. btw opt_ms3, BITOG was most impressed w/ your UOA!!
| Display Modes | |
| Mazdaspeed 3/6 UOA Results | div2 | MazdaSpeed 3 - Engine, Transmission & Driveline | 279 | 12-15-2016 06:38 AM |
| My E85 Results | MSP6 | MazdaSpeed 3/6 - E85 Fueling | 15 | 09-19-2012 04:59 AM |
| MY RESULTS WITH DIZZY TUNNING-BY BUCKER- B4 AND AFTER "REAL" DYNO RESULTS | stc terminus | 2010 MS3 - ECU Computer Tuning | 2 | 07-30-2012 10:43 PM |
| here is my vvt results | mike000g | Mazdaspeed3/6 General Discussion | 8 | 02-03-2012 10:43 PM |
| Flow Test Results – Mazdaspeed 3 FMIC for SRI vs Ram Air | CorkSport | CorkSport | 0 | 09-30-2011 12:10 PM |
