![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
(Thread Starter) | Not Ranked : 0 score As promised, here's my latest UOA: Engine 2.3L Turbo, direct injection Miles on engine 14630 Miles on oil 4632 Date sampled 04/08/08 Make Up Oil 0 OEM Mazda Filter Mobil 1 5W-30 Aluminum 4 Chromium 1 Iron 34 Copper 29 Lead 1 Tin 0 Moly 91 Nickel 0 Manganese 1 Silver 0 Ti 0 Potassium 2 Boron 53 Silicon 11 Sodium 9 Calcium 2400 Magnesium 12 Phosphorus 635 Zinc 787 Barium 1 Sus Visc @ 210F 55.2 should be 55-62 cST Visc @ 100 C 8.83 should be 8.8-11.1 Flashpoint in F 390 should be >365 Fuel % <0.5 should be <2.0 Antifreeze 0.0 Water % 0.0 should be <0.1 Insolubles % 0.3 should be <0.6 TBN 3.0 As I noted over at BITOG, Mobil1 5W-30 is working pretty well- in my engine, anyway... Here are my prior results: Engine 2.3L Turbo, direct injection Miles on engine 9838 Miles on oil 5046 Date sampled 12/31/07 Make Up Oil 0 OEM Mazda Filter Mobil 1 5W-30 Aluminum 4 Chromium 1 Iron 40 Copper 83 Lead 2 Tin 0 Moly 80 Nickel 1 Manganese 1 Silver 0 Ti 0 Potassium 2 Boron 38 Silicon 12 Sodium 6 Calcium 2634 Magnesium 11 Phosphorus 624 Zinc 808 Barium 2 Sus Visc @ 210F 56.2 should be 55-62 cST Visc @ 100 C 9.13 should be 8.8-11.1 Flashpoint in F 375 should be >365 Fuel % <0.5 should be <2.0 Antifreeze 0.0 Water % 0.0 should be <0.1 Insolubles % 0.4 should be <0.6 TBN 2.9
__________________ Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score Looks like wear is stabilizing. You could probably skip the next UOA, and do one at 10k miles, and the metals will probably be even less. It's interesting how UOA's show how long true engine break-in takes. It's usually 10-20k miles before the wear metals finally start being very consistent between intervals. |
As for long break-in periods, that was certainly the case with my '95 318ti. I switched to Mobil 1 15W-50 at 4K miles, and the 1.8 liter inline four didn't fully break-in until 21K, when highway mileage suddenly jumped from 28-30 mpg to 31-32 mpg. It's now racked up almost 112K, so I think I'll have a couple of UOAs done just to see what's going on.
__________________ Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust | |
| Not Ranked : 0 score Ha, UOA's are definitely addictive. Especially dyson ones...you always feel like you're getting some sort of special scientist analysis on your car...makes you feel like it will last forever with the right care! |
![]() Join Date: Apr 2008 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,888
| Not Ranked : 0 score So, without bothering to search or do the research myself... how do you guys do this? I'm picturing someone doing a CSI-esque cotton swabbing during an oil change, carefully placing the swab in a tiny plastic ziploc bag, and mailing it off to some lab somewhere in northern Montana. And how much do you pay for the report or whatever? |
| Anyone got the UOA on RP? I guess ill order the Sump pump from blackstone.
The pump is pretty trick; it's designed so that the oil is pumped directly into the sample bottle and the pump itself never touches the oil. The .25" plastic icemaker tubing the pump uses is so cheap-seven cents per foot-that it's not worth cleaning and re-using the tubing.
(Thread Starter) | Not Ranked : 0 score Nope, my dealer(Kings Mazda in Cincinnati) provides that with every new Mazda purchase. I have to provide the synthetic oil, but I still like to let them do it since the job is such a pain compared to my other cars.
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score Long Beach Mazda has the free oil changes thingy if you buy something else (overpriced) extra. I think it was thier security system or something of the sort. I imagine they are not the only dealership doing this. Say 30$ an oil change and you keep the car for 100K miles, it only saves you 1k. Thier cost is much lower, and that is only if you are religious about 3K mile oil changes. They were very pushy and tried to sell me on a "limited availability" markup on the car and wouldn't budge, so I drove 10 more miles and got what I wanted. It is certainly a buyers market for cars in the LA area. |
![]() Join Date: Mar 2008 Location: Minneapolis, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 804
| Not Ranked : 0 score It may not just be the break in period lasting a long time. It could also be the metal shavings not being drained completely within a few oil changes. Unless you drop the oil pan and clean it thoroughly, you could always have some shavings still in the oil pan waiting to be drained the next time around.
__________________ There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior ![]() 35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score might be a dumb question but why use 10w30 when car takes 5w30? advantages? |
![]() Join Date: Mar 2008 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
1. Normal shear down 2. Grade reduction from fuel dilution 3. Stability 4. I live in a mild climate with a heated garage 5. I always warm up an engine easy If I was seeing frequent dips below 20F, I would use 5W30. Mazda specs cars for use everywhere. -enganear | |
The advantage of the 5w-30 is better startup/cold weather flow. If you were in the snow belt, I'd try 10w-30 after winter, and back to 5w-30 during the colder months. You could probably run 10w-30 year round though. Just do a UOA and see how its doing! Everyone should do a UOA on their vehicle at least once, lets you check for leaks and such without a full teardown. | |
![]() Join Date: Mar 2008 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
| Not Ranked : 0 score I've seen better reports but my engine is pretty happy for now Iron has gone down but silicon up a little ( I might need to oil the filter). Fuel dilution hasn't changed and no antifreeze. Not too surprised on the viscosity.
__________________ Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount |
![]() Join Date: Jun 2008
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hey I have been reading this thread and It looks like the best two options are clearly either the PP or the M1 My question is I too have heard the wax stories about Pennzoil. A kid at autozone told me they still use it. He seemed to know alot about cars... alot more then me anyhow and he said the mobil 1 was the better option. Today while slacking at work I checked online to see if I could find anything about this. From pennzoil's sight I found a QA section Pennzoil Frequently Asked Questions. Question 4 addressed the wax issue and Pennzoil does say they use paraffins in their products, and seem to indicate that the PP does contain paraffins. I know from working in the painting industry that paraffin usually means paraffin wax, and well that makes me hesitant to put it in my car. Thoughts? Anyone use PP and actually check for sludge? -Pete |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
Groaned at 70 Times in 44 Posts
| Not Ranked : 0 score I used M1 for a long time and always got watery green solids in my catch can. With PP it's black and oily like it should be. I'm guessing the detergents in M1 don't go well with the fuel leaking down the cylinder walls that DI is known for. PP is cheaper as well and stands up to fuel dilution better than M1. PP FTW. |
![]() | | #19 | ![]() |
| Banned ![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 28
Groaned at 84 Times in 39 Posts
| Not Ranked : 0 score No one using Valvoline? I just changed my stock oil ~2K miles, to valvoline synpower 10w30 and everything went smoothly, along with a new filter and o-rings. Everything seems to run just fine and fuel economy has improved. Surprised no one is using Valvoline though, it's hella good oil, minus the fact that they don't advertise as much on T.V. |
![]() | | #20 | ![]() |
![]() Join Date: May 2008 Location: Albuquerque NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score anyone use Amsoil? I have the last two changes, next one I'll try and get an UOA. As far as I know they are 100% synthetic. Most other synthetics are blends and not pure. |
![]() | | #21 | ![]() |
![]() Join Date: Mar 2008 Location: Cupertino, CA
Rep Power: 6914 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 699
| Not Ranked : 0 score I just collected a sample to send to Blackstone labs. However the place that i got the oil change done at failed to rem to collect the sample from the oil pan stream, so they got 4oz from the canister that holds the oil filter. Does anyone see any drawbacks to this method? Will there be excessive sediment, aka metals? Im not sure of how the oil flows thru the cansiter and to the filter on this setup so any insights would be helpful. |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score From the Blackstone Labs FAQ: What about the oil left in the filter? Can I use that instead? Sure, just make a note on the slip that the oil came from the filter. If something really bizarre shows up, we'll take that into account. It shouldn't change much in the analysis, though. The FAQ also notes that a minimum of 2.5 oz is needed to perform all the tests, so you should be fine. As I mentioned earlier, I use the sample pump that Blackstone sells. With the pump I don't have to worry with getting the oil change guy to collect the oil, and I can also obtain a UOA without having to perform an oil change.
![]() | | #23 | ![]() |
Groans: 35
| Not Ranked : 0 score on the subject of oil.. i am assuming your manual states only to use 5w-30? our manual has a spread of grades over different temperature ranges.. ill re check the figures.. but its defiantly got 5-30 10-30 and even straight 30 grade as well as 5-40-10-40 and i think there may even be a 50 grade in there as well.. however i will check on that last one.. Hence the reason I am running a RP 10-40.. the thicker oil makes me feel a little bit better about giving it a good flogging.. and leaving it in their for longer than 5000km's.. ill prob leave it in for 10k (normal service down here) Cheers Doc |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here is my latest UOA on the MS3. I'm still running Mobil 1 5W-30. Looks pretty good, if I do say so myself. Here are Blackstone's comments: "Everything looks good in the latest sample from your Mazda. Silicon finally reads close enough to average levels that we can consider it normal, and no other harmful contaminants were found. Iron is still a bit above average but all wear has been steadily moving in the right direction. It took a little longer than usual for your engine to mature past break-in but better late than never. This oil still had some active additive left in it with a TBN of 3.4. 1.0 is low. It looks like you're going to keep your oil runs around 5,000 miles and we think that's working well for you." Miles on engine 25109 Miles on oil 4989 Date sampled 10/06/08 Make Up Oil 0.0 qt. OEM Mazda Filter Mobil 1 5W-30 Aluminum 4 Chromium 1 Iron 27 Copper 5 Lead 0 Tin 1 Moly 97 Nickel 0 Manganese 0 Silver 0 Ti 0 Potassium 2 Boron 53 Silicon 7 Sodium 7 Calcium 2365 Magnesium 13 Phosphorus 627 Zinc 832 Barium 0 Sus Visc @ 210F 55.5 should be 55-62 cST Visc @ 100 C 8.92 should be 8.8-11.1 Flashpoint in F 385 should be >365 Fuel % <0.5 should be <2.0 Antifreeze 0.0 Water % 0.0 should be <0.1 Insolubles % 0.4 should be <0.6 TBN 3.4
![]() | | #25 | ![]() |
![]() Join Date: Mar 2008 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,050
| Not Ranked : 0 score I've been using PP ever since my first oil change. I used the factory fill for the first 2.5k miles, then did another oil change at 5k miles and every 5k since. Initially I used 5w30, but at 20k miles I switched to 10w30 for it's better sheer resistance. Here's the UOA from my 30k mile oil change a couple months ago. "It looks like the ~5,000 mile oil change intervals have been working out for you. Our universal averages show typical wear from the Mazda 2.3L after ~4,000 miles on the oil. This oil was run a bit longer than that and you can see how nicely your engine wears compared to most. We're all for extended oil use and we don't think 6,000 miles would be too many to run the oil in your Mazda. With wear looking this good you may be able to go longer. Only a slightly low viscosity kept this from being a perfect report and that doesn't seem to be a problem. Nice!" Miles on engine - 29,930 Miles on oil - 4,862 Date sampled 07/02/08 Make Up Oil Added - 0.0 qt. OEM Mazda Filter Pennzoil Platinum 10W/30 Aluminum - 2 Iron - 10 Copper - 1 Molybdenum - 44 Boron - 22 Silicon - 3 Calcium - 2909 Magnesium - 11 Phosphorus - 632 Zinc - 702 Sus Visc @ 210F - 57.4 (should be 59-65) cST Visc @ 100 C - 9.48 (should be 9.9-11.9) Flashpoint in F - 395 (should be >365) Fuel % - <0.5 (should be <2.0) Antifreeze - 0.0 Water % - 0.0 (should be <0.1) Insolubles % - 0.3 (should be <0.6)
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle |
![]() | | #26 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score First oil change was just under 1,500 miles...used Mobil 1 then and for the next 2 oil changes at roughly 5k and 10k miles up until 14,987 miles when I switched to PP 5w-30. "Nothing too unusual showed up in this first sample from your Mazda (Matsuda in Japan). Universal averages show typical wear from this type of engine after 4200 miles on the oil. Iron was a bit higher than average, but all other wear looks okay, so we don't think this shows a problem developing. We'll watch iron next time. You ran the oil longer and this caused some of the high iron. The viscosity was a little low, but not low enough to affect wear. The TBN was 3.9; additive life remained. We think 1.0 is too low for extended use. Resample @ 4K miles to keep iron at bay." Miles on oil - 5,124 Miles on engine - 20,021 (at time sample was taken) Date sampled - 09/20/08 Make Up Oil Added - 0.0 qt. OEM Mazda Filter Pennzoil Platinum 5w-30 Aluminum - 4 Chromium - 1 Iron - 34 Copper - 13 Lead - 1 Tin - 0 Molybdenum - 51 Nickel - 0 Manganese - 1 Silver - 0 Titanium - 0 Potassium - 0 Boron - 25 Silicon - 5 Sodium - 2 Calcium - 2590 Magnesium - 14 Phosphorus - 593 Zinc - 735 Barium - 0 Sus Visc @ 210F - 54.4 (should be 56-63) cST Visc @ 100 C - 8.59 (should be 9.1-11.3) Flashpoint in F - 410 (should be >365) Fuel % - <0.5 (should be <2.0) Antifreeze - 0.0 Water % - 0.0 (should be <0.1) Insolubles % - 0.3 (should be <0.6) TBN - 3.9
__________________ 07 COSMIC BLUE MS3 GT 00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten 09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD 11 BLACK SUZUKI GSX-R750 - totaled 11 BLACK SUZUKI GSX-R750 - totaled...again *OFFICIALLY RETIRED FROM TWO WHEELS* |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here are the results of my last two UOAs- along with Blackstone's comments. I'm still running Mobil 1 5W-30. "Everything looks good in the latest sample from your Mazda. Silicon finally reads close enough to average levels that we can consider it normal, and no other harmful contaminants were found. Iron is still a bit above average but all wear has been steadily moving in the right direction. It took a little longer than usual for your engine to mature past break-in but better late than never. This oil still had some active additive left in it with a TBN of 3.4. 1.0 is low. It looks like you're going to keep your oil runs around 5,000 miles and we think that's working well for you." Miles on engine 25109 Miles on oil 4989 Date sampled 10/06/08 Make Up Oil 0.0 qt. OEM Mazda Filter Mobil 1 5W-30 Aluminum 4 Chromium 1 Iron 27 Copper 5 Lead 0 Tin 1 Moly 97 Nickel 0 Manganese 0 Silver 0 Ti 0 Potassium 2 Boron 53 Silicon 7 Sodium 7 Calcium 2365 Magnesium 13 Phosphorus 627 Zinc 832 Barium 0 Sus Visc @ 210F- 55.5 should be 55-62 cST Visc @ 100C- 8.92 should be 8.8-11.1 Flashpoint in F-385 should be >365 Fuel %- <0.5 should be <2.0 Antifreeze 0.0 Water % 0.0 should be <0.1 Insolubles % 0.4 should be <0.6 TBN 3.4 "Wear and silicon dropped in this sample, which was run about the same miles as you've been using for your Mazda. Compare this sample to universal averages and you can see that your engine is wearing normally, so we think you could easily run the oil longer, if you want. Averages are based on 4,130-miles on the oil. You were up to 5,182-without incident. No moisture, fuel, or coolant found. Insolubles (oil oxidation due to heat, use and blow-by) were okay at 0.4%, showing good oil filtration. The TBN was 3.8, good to go for more miles." Miles on engine 29870 Miles on oil 4546 Date sampled 1/13/09 Make Up Oil 0.0 qt. OEM Mazda Filter Mobil 1 5W-30 Aluminum 2 Chromium 1 Iron 25 Copper 2 Lead 1 Tin 1 Moly 82 Nickel 0 Manganese 0 Silver 0 Ti 0 Potassium 0 Boron 46 Silicon 5 Sodium 16 Calcium 2165 Magnesium 13 Phosphorus 583 Zinc 730 Barium 0 Sus Visc @ 210F- 57.2 should be 55-62 cST Visc @ 100C- 9.43 should be 8.8-11.1 Flashpoint in F- 385 should be >365 Fuel % <0.5 should be <2.0 Antifreeze- 0.0 Water %- 0.0 should be <0.1 Insolubles %- 0.4 should be <0.6 TBN- 3.8
![]() | | #28 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score thanks to everyone who posted UOA's. hal did you ever get some RP tested? |
![]() | | #29 | ![]() |
| Im sending off my sample tomorrow when i change to the PP 5/40
![]() | | #30 | ![]() |
![]() Join Date: May 2008 Location: castro valley
![]() | | #31 | ![]() |
| There is still traces of RP in my oil, so around March i can send a sample back. The cool thing is, they didnt charge me for the sample this time around because of that. This next sample will be completely flushed of RP to give me a good breakdown. I want to see how the Rotella is doing since they are advising him to go 6500. Rotella is easier for me to purchase locally, then PP.
![]() | | #32 | ![]() |
| Not Ranked : 0 score Just sent my PP 5w-30 sample off yesterday. I'll be sure to post my results.
![]() | | #33 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score SLS, what are your commuting habits? Lots of highway, city or a mix?
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
![]() | | #34 | ![]() |
![]() Join Date: Jul 2008 Location: Wallingford, CT
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Here's my oil sample analysis, from Blackstone labs. I had 7,355 miles with Amsoil Signature Series oil and a Wix oil filter, was still on break-in. |
![]() | | #35 | ![]() |
![]() Join Date: Mar 2009
Rep Power: 0 ![]() Thanks: 4
![]() | | #36 | ![]() |
![]() Join Date: Sep 2008
| Not Ranked : 0 score That's odd... no one using Royal Purple? I use 10w30 RP in my turboed Mustang and I'm going to start using it in my MS3 when I change the oil again. I got a killer deal on it at $4.00/qt and stocked up on it. |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Wow Boosted, 7355 miles between changes. You're brave. ![]() Seems like 5-6k is the sweet spot. I've got a sample kit on the way to me and will be sending them off some of my Rotella T syn 5w-40 soon.
![]() | | #38 | ![]() |
| Ive heard good things about the Rotella.. if your samples come back on par with the PP, ill probably switch. It costs me $60 to get 6 qts of PP 5/40 Euro blend.
![]() | | #39 | ![]() |
![]() Join Date: Feb 2009
| Not Ranked : 0 score Here's my latest UOA, and first post for that matter. PP FTW! |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Doesn't the manual say 7,500 miles? I figured with a good synthetic I'd be fine. I think i'm going to stick to about 5,000 miles or so from now on. |
| Mazdaspeed 3/6 UOA Results | div2 | MazdaSpeed 3 - Engine, Transmission & Driveline | 279 | 12-15-2016 06:38 AM |
| My E85 Results | MSP6 | MazdaSpeed 3/6 - E85 Fueling | 15 | 09-19-2012 04:59 AM |
| MY RESULTS WITH DIZZY TUNNING-BY BUCKER- B4 AND AFTER "REAL" DYNO RESULTS | stc terminus | 2010 MS3 - ECU Computer Tuning | 2 | 07-30-2012 10:43 PM |
| here is my vvt results | mike000g | Mazdaspeed3/6 General Discussion | 8 | 02-03-2012 10:43 PM |
| Flow Test Results – Mazdaspeed 3 FMIC for SRI vs Ram Air | CorkSport | CorkSport | 0 | 09-30-2011 12:10 PM |
