> MSF KB - Mazdaspeed 3/6 - Oil/Fluids
 Old 12-12-2011, 07:36 AM   #1
Default Oil discussion compilation thread
For whatever reason, it is difficult to search our forums for 3 letter words such as oil, and UOA (used oil analysis), so it was asked that someone create a thread compiling decent oil information for our cars.
Below is a collection of links found on msf (and now other reputable sites) that are oil related.
There is also a link to what is thought as the most informative oil website that I know of, "Bob is the Oil Guy .com".
Dealer Oil Changes dealership oil change discussion
2010 Oil Analysis oil discussion and uoa results
ZDDP lacking in modern oil oil ingredient / component discussion
What kind of oil? oil discussion
http://www.mazdaspeedforum.org/forum/foru...d-3-iyo-18303/ oil discussion
Response from Pennzoil on Ultra - Bob Is The Oil Guy - pennzoil's explanation of ultra vs. platinum (Bob is the oil guy link)
FerrariChat.com - FAQ: Motor Oil Articles by Dr. Ali E. Haas (AEHaas) - thanks to username nindoja, mathematical oil analysis
Motor Oil - All Chapters, Inclusive -Copy and Save This - FerrariChat.com - Dr. Haas's credentials (provided by username mzr165)
rfinkle2 is offline
 Old 12-12-2011, 10:10 AM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Thank fucking fuck Rob!
"Exclusivity" - CP-enis
Demodded.
The Seals
Tokay444 is offline
 Old 12-12-2011, 04:21 PM   #3
nindoja's Avatar
Posts: 2,395   (View Stats)
I know it's not on MSF, but this link has some really great analysis of motor oil.
The guy has basically tested everything out there, and even uses math to prove his points! *gasp*
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
nindoja is offline
 Old 12-12-2011, 04:23 PM   #4
Thanks very much nindoja.
I'm adding the link you provided to the OP.
Great stuff!
rfinkle2 is offline
 Old 12-12-2011, 06:04 PM   #5
MZR165's Avatar
Posts: 273   (View Stats)
MZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the worldMZR165 is the leader of the world
The site below has the same info as nindoja, but has some of Dr. Haas's credentials included in the beginning.
2007 Mazdaspeed 6 - Hypertech - J Barrone RMM - CS SRI & CS Turbo Inlet Pipe - Kumho Ecsta ASX
TOWER PERFORMANCE ENGINES
"You never get out of the throttle unless you see the timing tower."
“There is no limit to the good a person can do, if he does not care who gets the credit”
MZR165 is offline
 Old 12-12-2011, 06:11 PM   #6
Adding to OP. Thanks very much for the contribution!
The Dr's credentials definitely add credibility to the thread.
rfinkle2 is offline
 Old 12-12-2011, 06:17 PM   #7
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
I plan on switching to this my next oil change. Penn Grade 1 High Performance Oil
I'm still debating on 10w-40 or 10w-30.
Brad Penn "Green Oil" is supposed to be some of the best stuff around. I'll give a further review vs. Pennzoil Platinum in a separate thread you can link here after the switch.
NATOR PA
MS3-a(sore)ASS-rex is offline
 Old 12-12-2011, 06:22 PM   #8
I know you are familiar with the Evo world, and Forced Performance highly recommends Brad Penn.
Check out that Zddp in modern oil thread (started by Lex) above.
There is a link to a test of oils performed by Forced Performance (white paper Ziggo reminded me of).
rfinkle2 is offline
 Old 12-12-2011, 06:24 PM   #9
Groans: 224
Will do, thanks. The 2.1 stroker running an FP Black I'm building now will be running Brad Penn 20w-50 (off topic yes but cool none the less LOL)
NATOR PA
 Old 12-13-2011, 11:59 AM   #10
MZR165's Avatar
I don't know who is copying who, but Dr. Haas and Bob the Oil Guy have exactly the same write up's about oil! It's all very good information, but someone is guilty of plagiarism.
Bob the Oil Guy University
Motor Oil 101 - Bob is the Oil Guy
Dr. Haas, the PHd Surgeon
MZR165 is offline
 Old 12-13-2011, 12:02 PM   #11
Um, read the bob link. "by AE Haas"
Raider is offline
 Old 12-13-2011, 03:37 PM   #12
MZR165's Avatar
Ok....I didn't read the fine print! Gotta give me a little break, I'm looking through tri-focals! lol
MZR165 is offline
 Old 12-13-2011, 03:44 PM   #13
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
Groans: 65
Great thread Rob, ton of good info.
AZSPEED3 is offline
 Old 02-04-2012, 07:42 PM   #14
Ferg's Avatar
Posts: 1,498   (View Stats)
Ferg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the world
@codyb154
2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011
2008 Black Ms3 SOLD
Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs
AP Dizzy Tuned by BUCKER
CorkSport Interior LED Kit
2015 STi Limited in Lightning Red
Stock bottom end died at 18K hard canyon miles.
Current Mods after build
Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune
[11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap
Ferg is offline
 Old 09-19-2012, 01:34 PM   #15
Discuss
Raider is offline
Oil discussion compilation thread rfinkle2 Mazdaspeed3/6 General Discussion 23 05-17-2015 07:58 PM
Gen1/Gen2 Part throttle/cruise knock Discussion Thread. Roddiy Mazdaspeed3/6 General Discussion 18 08-23-2012 12:04 PM
Page generated in 0.37006 seconds with 27 queries
