> MSF KB - Mazdaspeed 3/6 - Wheels & Tires
 Old 02-27-2012, 08:24 PM   #121
anthony8488's Avatar
Posts: 140   (View Stats)
anthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond reputeanthony8488 has a reputation beyond repute
Anyone have pics of stock MS3 wheels with 235/35?
Also, if a 15mm is ideal for 205/40 the difference from 205 - 235 (using one of the OP's site links) is 15 mm (0.6'') closer to suspension/brakes components & will stick out 15 mm (0.6'') farther.. So is this 15mm gain the same as what a spacer would be, except the wheel face would not actually move? <-- all refering to a stock ms3 wheel, no drop yet.
COBB AP | COBB SF | COBB TIH |HKS SSQV RECIRC | Autotech HPFP Internals | TURBO XS DOWN PIPE | TURBO XS RACE PIPE | HKS HI-POWER CATBACK EXHAUST | DENSO ITV-22 PLUGS | CXRacing FMIC | SURE 90D RMM | MATT DAMOND OCC KIT | JBR ADJ SHIFT PLATE + HEAVY SHIFT KNOB
anthony8488 is offline
 Old 02-27-2012, 08:40 PM   #122
h4bs's Avatar
Posts: 65   (View Stats)
h4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant futureh4bs has a brilliant future
Hey guys,
I own a Gen 1 MS3 on stock suspension. Should 18x7.5 +42 Backspacing: 5.90" roll fine(no fender rolling) Reading your posts it seems fine, just want to make sure. Thanks!
h4bs is offline
 Old 02-28-2012, 07:14 AM   #123
travis9935's Avatar
Posts: 371   (View Stats)
travis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond repute
Groaned at 41 Times in 24 Posts
Originally Posted by h4bs View Post
Hey guys,
You running just the wheels no tires? Size please?
HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2
travis9935 is offline
 Old 02-28-2012, 04:25 PM   #124
h4bs's Avatar
Sorry, 225/40
h4bs is offline
 Old 02-28-2012, 05:27 PM   #125
travis9935's Avatar
I run 18X8 +48 225/40 & Cobb 1" lowering springs in the summer, no rolled fenders no issues.
 Old 02-28-2012, 05:30 PM   #126
h4bs's Avatar
Alright, I should be 100% good to go. Thanks.
h4bs is offline
 Old 02-29-2012, 07:17 AM   #127
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Edited OP to state 16s fit.
Keep the discussion up guys. The thread is doing everything I expected of it. Hopefully less "will these fit" threads have popped up recently.
If anyone notices any misinformation or wants something added to the OP be sure to "mention" me with said information. I don't have time to read thru every post all the time but I will do my best to keep the OP updated/current if mentioned.
2007 MS6 - broked & gone
2006 MS6 - less broked
RhoadBlock is offline
 Old 02-29-2012, 10:30 AM   #128
driver311's Avatar
Posts: 1,769   (View Stats)
I ended up bitching out and getting some 245s and the specs on tire rack were definately off. they listed the 245 actually being .1 wider tread width. So I called them and asked them why they had false info on there. He said I wasnt the first to complain about that exact tire specs. So guess what the very next day they were changed on the website. LOL. So the 255 is definately a touch wider and taller. .30 taller and .25 wider to be exact. The 245s will have to do for now. I also have a set of 245/40/17 starspecs at my house on some 17x9 grids and the contact patch on the spec is the same as the 255/40 hankook and shorter than both the kooks. Crazy that these manufactors do that with the sizes.
Moral of the story is people need to look at the specs and not base their selection of tire size alone. For instance my buddies 235/40/18 v12s are skinnier than my 225/40/18 federals. Shit just blows my mind LOL
Mazdaspeed
driver311 is offline
 Old 02-29-2012, 10:40 AM   #129
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Yup. There are huge width variances between not only the manufacturers, but also amongst different lines produced by even the same manufacturer with "identical specs"... It's a PITA...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Nliiitend1 is offline
 Old 02-29-2012, 12:12 PM   #130
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Just like tread patterns depend not only on tire model, but on section width. It's a bit of a black art picking the right tire.
Tapadatass
silvapain is offline
 Old 03-01-2012, 06:42 PM   #131
ChrisG's Avatar
Posts: 7   (View Stats)
ChrisG is an unknown quantity at this point
Can anyone comment from experience on 235/40 on RX8's, stock suspension? I'm interested in running this setup, but not really looking to roll my fenders. Gen One.
Thanks.
ChrisG is offline
 Old 03-01-2012, 06:52 PM   #132
Nliiitend1's Avatar
I ran that setup for a long time using 3 different sets of 235/40s, and never had any rubbing.
2008 MS3 GT
2016 MX-5 Club
 Old 03-02-2012, 08:53 AM   #133
Domino81's Avatar
Posts: 5,081   (View Stats)
I rubbed on my RX-8 with H&R's and Koni's in the corner by the door. Ran 235/40 BFG gForce Sports.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
Domino81 is offline
 Old 03-02-2012, 09:16 AM   #134
dastpe's Avatar
Posts: 1,644   (View Stats)
dastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the world
Never rubbed on h&r springs with 235/40 on rx8s...
dastpe is offline
 Old 03-02-2012, 09:38 AM   #135
Domino81's Avatar
I didn't until I ran the BFG's.
Domino81 is offline
 Old 03-02-2012, 10:48 AM   #136
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
well im about to go for the 245/40/18 on my rx8s...probably going to borrow a bat from someone once i start rubbing.
ScarMS3 is offline
 Old 03-02-2012, 11:27 AM   #137
Domino81's Avatar
Don't. Street unit rents the tool.
Professional Fender Roller Rental
Domino81 is offline
 Old 03-02-2012, 11:26 PM   #138
ahfunaki's Avatar
Posts: 764   (View Stats)
ahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the world
I did not realize they offered that...awesome!
tapa talked
[ 2010 Black Mica Speed3 w/tech package ]
go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers |
JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar |
Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge
show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate |
Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip
ahfunaki is offline
 Old 03-14-2012, 06:07 AM   #139
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
No rubbing.
Edit - had some time to respond better now lol
+45 pushes you closer to the fender by 7mm. 7.5" rim adds around 6.3mm per side. On the fender side you would be around 13.3mm closer to the fender than stock. On the strut side you would still be almost 1mm further out (towards fender) than stock.
225 tires adds 5mm per side (compared to stock 215) - so on fender side you'll be about 19.6mm closer than stock - a hair over 3/4 of an inch. On the strut side, you would be about 5.7mm closer to strut than stock... Less than 1/4 of an inch.
You will have no problems on the inside side and on the fender side, I'm 90% sure you'll be ok. With my 18x8 +48 I was out a total of around 21.7 mm and I did need to roll the rear slightly. I was also dropped around 1 inch. If you aren't dropped as much as I was, you'll be even better off.
The links in the OP to the calculators will give you a visual idea of what the new size will do
just wanted to confirm that they do fit. looks great. pics in the wheels and tire section under white ms3
exentix is offline
 Old 03-14-2012, 09:34 AM   #140
ScarMS3's Avatar
Groans: 97
well, im fine at stock height with the 245/40/18 general's, no rubbing whatsoever, and no road noise, tires feel awesome and have much better grip than my stock kumho all seasons...especially since they were bald.
ScarMS3 is offline
 Old 03-14-2012, 11:28 AM   #141
G-Man's Avatar
Posts: 46   (View Stats)
G-Man is a jewel in the roughG-Man is a jewel in the roughG-Man is a jewel in the rough
Groaned at 17 Times in 4 Posts
Read through all this thread desperate for a glimmer of hope - and here it is! But I'm prepared for some disappointment....
Found the wheels I want: 18x9 +38mm offset
and tires: 245/40/18 Conti Extreme Contact
Question is, is this offset too aggressive for the Gen1? Should I go for gold and get them?
I am on stock suspension with no intention of lowering. I am prepared to fender roll. The wife and my 14 month old is all I carry (combined weight of 300 pounds).
Cheers,
G
'08 Speed3, '06 Murano, '95 S14 SR20DET
G-Man is offline
 Old 03-14-2012, 11:30 AM   #142
travis9935's Avatar
Which gen? Wheel specs, Pics?
 Old 03-14-2012, 11:38 AM   #143
dastpe's Avatar
Cheers,
G
IMO that is going to look weird not being lowered with that low of an offset. maybe a touch of mexipoke. And you will rub pretty badly over big bumps with a loaded car. The tires will be out past the fenders. why not a different offset? or an 18x8 or 8.5?
dastpe is offline
 Old 03-14-2012, 11:56 AM   #144
G-Man's Avatar
Booo! I just like the wheel - right look and color. The 18x8 have an offset of +30mm which doesn't make that much of a difference (does it?)
G-Man is offline
 Old 03-14-2012, 12:39 PM   #145
dastpe's Avatar
not really...you can always see if someone local has a wheel with similar specs and test fit it on your car. if you go to the aggressive offset page, that last page there is some pics of a 9" wheel with 245s, but lowered on coils.
dastpe is offline
 Old 03-14-2012, 02:58 PM   #146
ScarMS3's Avatar
Groans: 97
Gen one rx8 wheels and I haven't taken any pictures yet.
ScarMS3 is offline
 Old 03-16-2012, 12:05 PM   #147
SN95NIK's Avatar
Posts: 6   (View Stats)
SN95NIK will become famous soon enoughSN95NIK will become famous soon enough
I'm looking at a 235/40/18 on 18 x 8.5" +45. GenWon on stock suspension. Anybody that can comment on this setup, would be greatly appreciated. Am I looking at rolling the rear fenders? Thanks,
SN95NIK is offline
 Old 03-16-2012, 12:23 PM   #148
Nliiitend1's Avatar
Yes. A rear roll is probably going to be needed to keep it from rubbing under conditions of extreme suspension compression.
2008 MS3 GT
2016 MX-5 Club
 Old 03-16-2012, 01:05 PM   #149
ScarMS3's Avatar
Groans: 97
had a little of that this morning....i need a smily face sipping a cup of tea with his pinky out. anyways i hit a dip in the road and rubbed on the right rear, so i suppose im going to have to do something about that....and was the combined weight of your child and wife 300lbs or is that you as well?
ScarMS3 is offline
 Old 03-16-2012, 08:58 PM   #150
G-Man's Avatar
That's combined weight of all 3 of us. Both of us are skinny martial-arts types, and the kid is the same lol. Looking forward to seeing pics of your wheels.
I've actually found the same wheel with an offset of 45mm so now I have another question - will these wheel be too close to the interior side?
18x9, 45mm offset
But with 235 tires (not 245s)
Thanks
G
G-Man is offline
 Old 03-21-2012, 08:35 AM   #151
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Does this muffin top at all on those wheels? also did you have to roll at all. I have read this whole thread. and im just trying to figure out what is the widest i can go front and back being the same size without having to do a pull. im ok with rolling if need be but would prefer not to. I am also at stock ride height but eventually might lower it an inch.
Pics?
Damond Built Speed 6
Deldran is offline
 Old 03-22-2012, 11:46 PM   #152
Biggs's Avatar
Posts: 212   (View Stats)
Biggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the world
Bit of a long winded question...
Im about to get 225/45 star specs put on the stock 18x7 wheels... will i have issue with the tire being too wide for the wheel? any potential de-beading of the tire while putting large lateral forces on the wheel/tire? (im headed to the track next month so its on my mind)
to fight this potential issue i was thinking of picking up som 18x8.5 +48 TrMotorsport MT1 wheels... will i have suspension clearing issues with that offset. I plan on still using 225/45s with this wheel so fender clearance probably wont be an issue with me.
Lastly, should i be concerned with HUB BORE... i know ours is 67.1 but im not sure what the bore is on wheels like the MT1 (its a '08-'12 STi wheel so it might be 73?). should i do something about that? hubcentric rings? what type or size?
all this is on stock suspension BTW.
09 TR MS3
Cp-e Nano SRI | Cp-e TIP | Cp-e RMM 75d | Cobb catted 3" DP | Cobb AP - Jorge Carrillo protune
NGK Iridium IX 6510 plus | PTP HPFP upgrade (internals)
TrMotorsprt MT1 18x8.5 +48 | Dunlop Direzza Sport Z1 Star Spec 235/40/18 | Mutegi Black Lug nuts
Hawk HPS Pads | Ate Super Blue | Techna-Fit SS lines
Hella Supertones | JBR Heavy Shift Knob
Biggs is offline
 Old 03-23-2012, 03:29 AM   #153
dastpe's Avatar
225/45 will be fine. you may have some minor rubbing problems with the taller sidewall than stock.
on an 8.5" wheel a 225 will stretch and not be the best for your track day. stick to the 18x7. you could go 235/40 on that 8.5...
i thought STI hub bore was 56.1 (someone double check me), so they would not fit your car unless a machine shop bored them out for you.
dastpe is offline
 Old 03-23-2012, 04:00 AM   #154
74te27's Avatar
Posts: 36   (View Stats)
74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all74te27 is a name known to all
I have RX8 wheels with 235/40/18 Michelin Pilot Sport on stock height and no rubbing.
Michelin 235 looks more like 245's compare to my Firestone Firehawk's 235's.
74te27 is offline
 Old 03-23-2012, 09:11 AM   #155
Biggs's Avatar
I just ordered TrMotorsport MT1 wheels.. 18x8.5 +48... its a acura TSX wheel so it has a 79 hub bore, they said they will fit it with a ring to make it fit....
I also bought 5mm spacers in case the 235/40 tire is too close to the suspension... do you guys think thats good enough?
please let me know
09 TR MS3
Biggs is offline
 Old 03-23-2012, 09:37 AM   #156
dastpe's Avatar
please let me know
yup. youll be good.
dastpe is offline
 Old 03-23-2012, 09:46 AM   #157
Biggs's Avatar
yup. youll be good.
wooo hooo!
09 TR MS3
Biggs is offline
 Old 03-23-2012, 10:05 AM   #158
Domino81's Avatar
I had to roll my fender pretty good with my ST100's (18x8.5 +48). Keep that in mind.
Domino81 is offline
 Old 03-23-2012, 10:33 AM   #159
Biggs's Avatar
rears only or all around... and rolled flat?
im running stock suspension too btw, so maybe i wont have to roll?
09 TR MS3
Biggs is offline
 Old 03-23-2012, 10:35 AM   #160
silvapain's Avatar
Groans: 136
To confirm an earlier comment: STi has a smaller hub bore than the MS3, and any wheel designed to fit that bore would have to be machined out to the MS3 67.1mm bore.
Tapadatass
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS Djohns MazdaSpeed 3/6 - Wheels & Tires 1978 01-17-2020 05:03 PM
Separate "Appearance" from "Wheels/Tires" KaiserSoze Website Help/Feedback 1 04-21-2008 08:33 PM
Page generated in 0.59464 seconds with 38 queries
