![]() | | #321 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score Tapa
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
![]() | | #322 | ![]() |
![]() Join Date: Nov 2010 Location: York/Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 777
| Not Ranked : 0 score can and has been done here in the states. run a 225 with 'natural camber' and a flat roll with a slight pull and grind the tab down and youll be golden. |
![]() | | #323 | ![]() |
![]() Join Date: Mar 2012 Location: north county san deigo
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
Groaned at 43 Times in 17 Posts
| Not Ranked : 0 score WhAts the offset?
__________________ 2008 cosmic blue, h&r lowering springs, koni struts,HKS intake, rx8 wheals,pump internals v3 ap coming soon car got broken into and v2 got stolen |
![]() | | #324 | ![]() |
![]() Join Date: Jul 2010 Location: Riverside,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 917
| Not Ranked : 0 score Planning this set up: 17x8 +40 MB Weapons with 235/45 tire CS springs and Koni yellows. Would it work out? Sent from my EVO LTE
__________________ [SIGPIC][/SIGPIC] 2008.5 CWP Speed3 GT - SOLD / ![]() 1991 Ford Mustang LX 5.0 SSP 331 Stroker 9:1 compression - AFR 185 Heads ported to 205 specs - 1.6 Roller Rockers - Comp Turbo Cam - Edelbrock RPM Performer II Upper and Lower intake mani - 24# injectors - 70mm throttle body and EGR spacer - C&L Intake - BBK Headers - MSD Billet Distributor - MSD Coil - Ford Racing Wires - MSD Ignition - A/C delete - Built 3 spd With reverse manual valve body - B&M Shifter - Aluminum driveshaft - 3.55 gears - Moser 31 spline Axles - Nitrous Express 125 shot - 5 lug conversion With SN95 Brakes |
![]() | | #325 | ![]() |
| Not Ranked : 0 score that wold be sick
![]() | | #326 | ![]() |
![]() Join Date: Jun 2010 Location: Lemoore, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38
| Not Ranked : 0 score Work CR KAI 18x9.5 +22 on 245/40? i figure a roll at least.... i have these on my rx8 and i am thinking about trading it in for a MS3 for the practicality of the wagon... thanks in advance |
![]() | | #327 | ![]() |
Groans: 423
Good luck fitting those. Would take a lot more than "a roll at least" to make it work.
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
![]() | | #328 | ![]() |
![]() | | #329 | ![]() |
![]() | | #330 | ![]() |
Groans: 423
![]() | | #331 | ![]() |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score Figured I would ask since you guys know wtf you are talking about, Ive currently got 235/40s wrapped on 18x9.5 +38 rims. Ive got coilovers, 5mm spacers up front and I did a slight roll on the back, they fit great but the tires are a bit stretched, what do you guys suggest would be the widest tire I could fit on there. Id rather not pull the fender but wouldnt be against rolling it more. I basicly want the rim and tire to be even and not stretched.
__________________ TEAM LUXURY |
![]() | | #332 | ![]() |
| Not Ranked : 0 score well if i end up doing the trade ill be selling those wheels lol thanks |
![]() | | #333 | ![]() |
Groans: 423
Tapa
![]() | | #334 | ![]() |
Groans: 97
| Not Ranked : 0 score With out the slight fender roll I was scraping the very edge of the tire whenever I would hit a bump. Now after it, I can fit 4 nator heads in the car and only slighty scrape the fender on a large dip/bump, otherwise zero issues. Ive got about 1"1/2 gap between the fender and wheel. And my kw's are super skinny so they still have over an inch of room between wheel and strut when turned all the way.
![]() | | #335 | ![]() |
Groans: 423
Also section widths can vary from brand to brand. When you are dealing with fitment like this that's something to keep in mind. Tapa
![]() | | #336 | ![]() |
Groans: 97
__________________ TEAM LUXURY | |
![]() | | #337 | ![]() |
Groans: 423
Tapa
![]() | | #338 | ![]() |
Groans: 97
| Not Ranked : 0 score Thanks for all the help man, I can build motors all day but when it comes to fitment, Im a total fucking newb lol
![]() | | #339 | ![]() |
| Not Ranked : 0 score do you have the bumper tab ground down? a lot of guys think they are rubbing fender when in fact its the bumper tab. you also may want to slightly pull your fenders before your tires do it for you. |
![]() | | #340 | ![]() |
Groans: 423
That's my opinion on it. See what @dastpe think about it. Tapa
![]() | | #341 | ![]() |
![]() Join Date: May 2009 Location: Melbourne, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score +38 from the aggressive thread, a spacer up front will be required with that offset.
__________________ 06 Black MPS3 Sport Pack - Australia edition Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen EXE-Crew |
![]() | | #342 | ![]() |
![]() Join Date: Sep 2011 Location: Atlanta, Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score 08 MS3 on Eibach PK - I want to get some new rims and i want them to be almost flush with fenders, just a touch inside ~2-3mm or so. I would greatly appreciate any input you guys can give me in order to make this happen. I am currently running 215/45s on my stockers and would like to run a 18x8/8.5 wheel with wider tires. Can anyone help me figure out exactly what size wheels/tires i would need to achieve my goal? I was looking at the XXR line and i like the 527s but +35 is out of the question for the simple fact that i dont want the wheels poking out past the fenders. Thanks in advance for any input on my dilemma
__________________ -------------------------------------------------------------------------------------- 2008 Sunlight Silver MS3 GT // Because racecar SOLD Cobb AP || Autotech Internals || CP-e Safe Seals || Bosch 3Bar|| Godspeed FMIC with Godspeed piping || ATP catless downpipe || GT3076R || 3" HTP Intake/Inlet || Turbo Smart Dual Port running in 50/50 || SI Boost Tubes || JBR RMM 80a || JBR SSP || JBR Shifter Bushings || EGR Delete || Corksport LED Lighting || Apexi auto timer || Eibach PK || 18x8 Motegi SP10s || 225/40/18 Nitto NT555 || NGK 1 Step Colder plugs Dynojet 7/6/2013 349.71whp 333lb tq Dynojet 8/2/2013 378.26whp 384lb tq Dynojet 8/31/2013 392.14whp 397lb tq PERM Tuned by Alan and DJ |
![]() | | #343 | ![]() |
| Not Ranked : 0 score 18x8 ~+42 with 235/40 |
![]() | | #344 | ![]() |
| Not Ranked : 0 score Thank you for the response! So around 40 - 42 would be ok? I see several rims that i like with +35 offset but i am afraid of them being bull-frogged.
![]() | | #345 | ![]() |
Groans: 97
| Not Ranked : 0 score Yeah the member who had these rims before me had told me about that and I took off the top portion of them using a dremel. And by pulling you mean now or if I go up in size.
![]() | | #346 | ![]() |
| Not Ranked : 0 score i would pull now personally, but just slightly. you can tell if you actually NEED a pull by looking to see if there is any paint on your tires and checking for burn marks on the inside of the fender. if either of those is there, get yourself a little pull. make sure to do it right and pull the whole quarter, dont just heat the fender and get that gay looking 3" flare of the fender. |
![]() | | #347 | ![]() |
| Not Ranked : 0 score Was OMW home from class today and one of my stock tires totally exploded at about 25k miles on them. The rest are pretty much bald so i was going to go a head and by new Wheels and tires, From what I've read 18x8.5 44 offset on stock suspension should be fine, but i could use some advice on which tires work well for DD and if i should go 225 or 235. Was looking at these guys 18x8.5 Rota Grid - Hyper Black (5x114.3/e44/73) Wheeldude.com - Professional wheel dealer.
__________________ Cobb SRI ll Jbarone SSP ll CP-e 60 RRM ll UR Test Pipe ll Cobb Knob ll Cobb AP Running Stage 2 + SF ll Auto tech InternalsComing Soon: ll UR Cat-back ll |
![]() | | #348 | ![]() |
| Not Ranked : 0 score 235/40. tirerack reviews for our cars are your best bet. tires depends way too much on personal preference and goals for the car and price range. |
![]() | | #349 | ![]() |
![]() Join Date: Apr 2012 Location: Silver Spring, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score Got a question boys. I drive a 2012 Genpu and I'm looking for a winter set up. I've done my research on the forums and I've decided to go with 205/60R16. I know the biggest issue with 16s is clearing the calipers. I have found 16"x6.5" rims and my question is... how much of an impact will the offset have in terms fit? I can get an offset of 40 mm or 45 mm. The guy in this thread R32 GTS-T Wheels, winter test fit! managed to fit his 16s that had an offset of 40. Would 45 be better in terms of clearing the calipers? Or does offset really only impact how flush the tire is with the body of the car. |
![]() | | #350 | ![]() |
![]() Join Date: Jan 2011 Location: IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 960
__________________ 07 True Red Mazdaspeed 3 GT - Totaled 2/7/2015 15 Soul Red Mazda3s GT HB | ||
![]() | | #351 | ![]() |
Groans: 423
Tapa
![]() | | #352 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Would 255/40/17 with the enkei rpf1 17x9 with 45mm offset fit on stock suspension for GenPu? |
![]() | | #353 | ![]() |
![]() Join Date: May 2011 Location: Lexington, KY / Troy, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score My friend has a set of nt03s for cheap. They are 17x8 +38. I'd planned on going 17x9 and sticking with stock suspension like I've seen on Goodwin racing. I'm on stock suspension and plan to stay that way. Will it look like a monster truck on my gen 1? Not sure about the tires he has with them yet. Thanks for the reply. Sent from my Galaxy Nexus using Tapatalk 2
__________________ 08.5 CWP MS3 GT AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays |
![]() | | #354 | ![]() |
Groans: 423
235/45 would give you closest to stock diameter. You'll want to roll fenders either way though. Tapa
![]() | | #355 | ![]() |
![]() Join Date: Jun 2011 Location: Cumberland, Rhode Island
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,309
Regarding offset, on the same width rim, lower offset will push the rim farther away from the caliper. You can plug some values into this calculator to see where the rim will sit. That being said, if I had to do it all again I would get 215/50-17 or 225/50-17. We dont usually have a ton of snow up here so the extra width and less sidewall will be a better all around winter setup than the 16" and 205s.
__________________ 2007 MS3 Black Mica. Stock. 235whp/244wtq DynojetFREEKtuned 277/316 Dynojet Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat Bilstein B8/Swift Spec-R/ST120s/Nitto 555 JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC | |
![]() | | #356 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score I'm looking for track wheels & tires and am considering 17x8.5 wheels, with 245/45x17 NT-01s.
This is for a 2007 Gen 1. Edit: realised this question is useless without a wheel offset! Doh! I'll come back with one soon.... Thx |
![]() | | #357 | ![]() |
![]() Join Date: Sep 2012 Location: Farmington, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score Just got my Speed3 genwon and wondering if this setup would work on stock suspension without a roll. Motegi Sp-10 18x8 +40 wrapped in KDW 2's 235/40-18. Thanks for the help. |
![]() | | #358 | ![]() |
BTW: Good choice on rims... i effing love the way they look!!!
Really glad you edited this one I was going to have to for no wheel offset
__________________ -------------------------------------------------------------------------------------- 2008 Sunlight Silver MS3 GT // Because racecar SOLD Cobb AP || Autotech Internals || CP-e Safe Seals || Bosch 3Bar|| Godspeed FMIC with Godspeed piping || ATP catless downpipe || GT3076R || 3" HTP Intake/Inlet || Turbo Smart Dual Port running in 50/50 || SI Boost Tubes || JBR RMM 80a || JBR SSP || JBR Shifter Bushings || EGR Delete || Corksport LED Lighting || Apexi auto timer || Eibach PK || 18x8 Motegi SP10s || 225/40/18 Nitto NT555 || NGK 1 Step Colder plugs Dynojet 7/6/2013 349.71whp 333lb tq Dynojet 8/2/2013 378.26whp 384lb tq Dynojet 8/31/2013 392.14whp 397lb tq PERM Tuned by Alan and DJ | ||
| The Following User Says Thank You to apawk For This Useful Post: | Drive By Fire (02-28-2014) |
![]() | | #359 | ![]() |
![]() So....will a 17x8 ET 45 (Konig Lace) with 245/40R-17 (Kumho Ecsta XS) work with stock suspension? Will I need a roll & if so how aggressive? Thx | |
![]() | | #360 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
that size will fit but you'll definitely need at least a roll. And don't do laces.
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." | |
| The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS | Djohns | MazdaSpeed 3/6 - Wheels & Tires | 1978 | 01-17-2020 05:03 PM |
| Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] | Haltech | Automotive News | 0 | 08-04-2009 09:40 AM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
| Separate "Appearance" from "Wheels/Tires" | KaiserSoze | Website Help/Feedback | 1 | 04-21-2008 08:33 PM |
