![]() | | #121 | ![]() |
![]() Join Date: Mar 2011 Location: Hampton VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
| Not Ranked : 0 score Also, if a 15mm is ideal for 205/40 the difference from 205 - 235 (using one of the OP's site links) is 15 mm (0.6'') closer to suspension/brakes components & will stick out 15 mm (0.6'') farther.. So is this 15mm gain the same as what a spacer would be, except the wheel face would not actually move? <-- all refering to a stock ms3 wheel, no drop yet.
__________________ COBB AP | COBB SF | COBB TIH |HKS SSQV RECIRC | Autotech HPFP Internals | TURBO XS DOWN PIPE | TURBO XS RACE PIPE | HKS HI-POWER CATBACK EXHAUST | DENSO ITV-22 PLUGS | CXRacing FMIC | SURE 90D RMM | MATT DAMOND OCC KIT | JBR ADJ SHIFT PLATE + HEAVY SHIFT KNOB [SIGPIC][/SIGPIC] |
![]() | | #122 | ![]() |
![]() Join Date: Jun 2011 Location: Montreal
| Not Ranked : 0 score Hey guys, I own a Gen 1 MS3 on stock suspension. Should 18x7.5 +42 Backspacing: 5.90" roll fine(no fender rolling) Reading your posts it seems fine, just want to make sure. Thanks! |
![]() | | #123 | ![]() |
![]() Join Date: Jun 2011 Location: sufu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Groaned at 41 Times in 24 Posts
| Not Ranked : 0 score You running just the wheels no tires? Size please?
__________________ HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2 |
![]() | | #124 | ![]() |
![]() | | #125 | ![]() |
| Not Ranked : 0 score I run 18X8 +48 225/40 & Cobb 1" lowering springs in the summer, no rolled fenders no issues.
![]() | | #126 | ![]() |
![]() | | #127 | ![]() |
![]() Join Date: May 2008 Location: Brandon, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 667
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score Edited OP to state 16s fit. Keep the discussion up guys. The thread is doing everything I expected of it. Hopefully less "will these fit" threads have popped up recently. If anyone notices any misinformation or wants something added to the OP be sure to "mention" me with said information. I don't have time to read thru every post all the time but I will do my best to keep the OP updated/current if mentioned. |
![]() | | #128 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score I ended up bitching out and getting some 245s and the specs on tire rack were definately off. they listed the 245 actually being .1 wider tread width. So I called them and asked them why they had false info on there. He said I wasnt the first to complain about that exact tire specs. So guess what the very next day they were changed on the website. LOL. So the 255 is definately a touch wider and taller. .30 taller and .25 wider to be exact. The 245s will have to do for now. I also have a set of 245/40/17 starspecs at my house on some 17x9 grids and the contact patch on the spec is the same as the 255/40 hankook and shorter than both the kooks. Crazy that these manufactors do that with the sizes. Moral of the story is people need to look at the specs and not base their selection of tire size alone. For instance my buddies 235/40/18 v12s are skinnier than my 225/40/18 federals. Shit just blows my mind LOL
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() | | #129 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Yup. There are huge width variances between not only the manufacturers, but also amongst different lines produced by even the same manufacturer with "identical specs"... It's a PITA...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
![]() | | #130 | ![]() |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
Tapadatass
__________________ | |
![]() | | #131 | ![]() |
![]() Join Date: Nov 2011
Rep Power: 0 ![]() Thanks: 16
| Not Ranked : 0 score Can anyone comment from experience on 235/40 on RX8's, stock suspension? I'm interested in running this setup, but not really looking to roll my fenders. Gen One. Thanks. |
![]() | | #132 | ![]() |
| Not Ranked : 0 score I ran that setup for a long time using 3 different sets of 235/40s, and never had any rubbing.
![]() | | #133 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score I rubbed on my RX-8 with H&R's and Koni's in the corner by the door. Ran 235/40 BFG gForce Sports.
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #134 | ![]() |
![]() Join Date: Nov 2010 Location: York/Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 777
| Not Ranked : 0 score Never rubbed on h&r springs with 235/40 on rx8s... |
![]() | | #135 | ![]() |
| Not Ranked : 0 score I didn't until I ran the BFG's.
![]() | | #136 | ![]() |
![]() Join Date: Apr 2010 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,756
Groans: 97
| Not Ranked : 0 score well im about to go for the 245/40/18 on my rx8s...probably going to borrow a bat from someone once i start rubbing. |
![]() | | #137 | ![]() |
![]() | | #138 | ![]() |
![]() Join Date: Dec 2011 Location: Warren, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score tapa talked
__________________ [ 2010 Black Mica Speed3 w/tech package ] go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers | JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar | Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate | Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip [SIGPIC][/SIGPIC] | |
![]() | | #139 | ![]() |
![]() Join Date: Dec 2011 Location: howard, pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,479
Groans: 46
![]() | | #140 | ![]() |
Groans: 97
| Not Ranked : 0 score well, im fine at stock height with the 245/40/18 general's, no rubbing whatsoever, and no road noise, tires feel awesome and have much better grip than my stock kumho all seasons...especially since they were bald. |
![]() | | #141 | ![]() |
![]() Join Date: May 2011 Location: Fort Collins, CO
Rep Power: 0 ![]() ![]() ![]() Thanks: 23
Groaned at 17 Times in 4 Posts
Found the wheels I want: 18x9 +38mm offset and tires: 245/40/18 Conti Extreme Contact Question is, is this offset too aggressive for the Gen1? Should I go for gold and get them? I am on stock suspension with no intention of lowering. I am prepared to fender roll. The wife and my 14 month old is all I carry (combined weight of 300 pounds). Cheers, G
__________________ '08 Speed3, '06 Murano, '95 S14 SR20DET | |
![]() | | #142 | ![]() |
| Not Ranked : 0 score Which gen? Wheel specs, Pics?
![]() | | #143 | ![]() |
![]() | | #144 | ![]() |
| Not Ranked : 0 score Booo! I just like the wheel - right look and color. The 18x8 have an offset of +30mm which doesn't make that much of a difference (does it?)
![]() | | #145 | ![]() |
| Not Ranked : 0 score not really...you can always see if someone local has a wheel with similar specs and test fit it on your car. if you go to the aggressive offset page, that last page there is some pics of a 9" wheel with 245s, but lowered on coils. |
![]() | | #146 | ![]() |
Groans: 97
![]() | | #147 | ![]() |
| Not Ranked : 0 score I'm looking at a 235/40/18 on 18 x 8.5" +45. GenWon on stock suspension. Anybody that can comment on this setup, would be greatly appreciated. Am I looking at rolling the rear fenders? Thanks, |
![]() | | #148 | ![]() |
| Not Ranked : 0 score Yes. A rear roll is probably going to be needed to keep it from rubbing under conditions of extreme suspension compression.
![]() | | #149 | ![]() |
Groans: 97
| Not Ranked : 0 score had a little of that this morning....i need a smily face sipping a cup of tea with his pinky out. anyways i hit a dip in the road and rubbed on the right rear, so i suppose im going to have to do something about that....and was the combined weight of your child and wife 300lbs or is that you as well? |
![]() | | #150 | ![]() |
I've actually found the same wheel with an offset of 45mm so now I have another question - will these wheel be too close to the interior side? 18x9, 45mm offset But with 235 tires (not 245s) Thanks G
![]() | | #151 | ![]() |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
Pics?
__________________ Damond Built Speed 6 | |
![]() | | #152 | ![]() |
![]() Join Date: Jul 2010 Location: Maryland
Rep Power: 188 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score Bit of a long winded question... Im about to get 225/45 star specs put on the stock 18x7 wheels... will i have issue with the tire being too wide for the wheel? any potential de-beading of the tire while putting large lateral forces on the wheel/tire? (im headed to the track next month so its on my mind) to fight this potential issue i was thinking of picking up som 18x8.5 +48 TrMotorsport MT1 wheels... will i have suspension clearing issues with that offset. I plan on still using 225/45s with this wheel so fender clearance probably wont be an issue with me. Lastly, should i be concerned with HUB BORE... i know ours is 67.1 but im not sure what the bore is on wheels like the MT1 (its a '08-'12 STi wheel so it might be 73?). should i do something about that? hubcentric rings? what type or size? all this is on stock suspension BTW.
__________________ 09 TR MS3 Cp-e Nano SRI | Cp-e TIP | Cp-e RMM 75d | Cobb catted 3" DP | Cobb AP - Jorge Carrillo protune NGK Iridium IX 6510 plus | PTP HPFP upgrade (internals) TrMotorsprt MT1 18x8.5 +48 | Dunlop Direzza Sport Z1 Star Spec 235/40/18 | Mutegi Black Lug nuts Hawk HPS Pads | Ate Super Blue | Techna-Fit SS lines Hella Supertones | JBR Heavy Shift Knob |
![]() | | #153 | ![]() |
on an 8.5" wheel a 225 will stretch and not be the best for your track day. stick to the 18x7. you could go 235/40 on that 8.5... i thought STI hub bore was 56.1 (someone double check me), so they would not fit your car unless a machine shop bored them out for you. | |
![]() | | #154 | ![]() |
![]() Join Date: Feb 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I have RX8 wheels with 235/40/18 Michelin Pilot Sport on stock height and no rubbing. Michelin 235 looks more like 245's compare to my Firestone Firehawk's 235's. |
![]() | | #155 | ![]() |
I also bought 5mm spacers in case the 235/40 tire is too close to the suspension... do you guys think thats good enough? please let me know
__________________ 09 TR MS3 Cp-e Nano SRI | Cp-e TIP | Cp-e RMM 75d | Cobb catted 3" DP | Cobb AP - Jorge Carrillo protune NGK Iridium IX 6510 plus | PTP HPFP upgrade (internals) TrMotorsprt MT1 18x8.5 +48 | Dunlop Direzza Sport Z1 Star Spec 235/40/18 | Mutegi Black Lug nuts Hawk HPS Pads | Ate Super Blue | Techna-Fit SS lines Hella Supertones | JBR Heavy Shift Knob | |
![]() | | #156 | ![]() |
![]() | | #157 | ![]() |
![]() | | #158 | ![]() |
| Not Ranked : 0 score I had to roll my fender pretty good with my ST100's (18x8.5 +48). Keep that in mind.
![]() | | #159 | ![]() |
im running stock suspension too btw, so maybe i wont have to roll?
![]() | | #160 | ![]() |
Groans: 136
| Not Ranked : 0 score To confirm an earlier comment: STi has a smaller hub bore than the MS3, and any wheel designed to fit that bore would have to be machined out to the MS3 67.1mm bore. Tapadatass
| The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS | Djohns | MazdaSpeed 3/6 - Wheels & Tires | 1978 | 01-17-2020 05:03 PM |
| The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS | RhoadBlock | MSF KB - Mazdaspeed 3/6 - Wheels & Tires | 364 | 09-17-2012 05:30 PM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
| Separate "Appearance" from "Wheels/Tires" | KaiserSoze | Website Help/Feedback | 1 | 04-21-2008 08:33 PM |
