> MSF KB - Mazdaspeed 3/6 - Wheels & Tires
 Old 07-19-2012, 05:16 PM   #281
dastpe's Avatar
Posts: 1,644   (View Stats)
dastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the world
Originally Posted by dantes5823 View Post
so im thinking about running some PF01's in either 17x9 +40 or 18x9 +45 18x8.5 +48 or even a 17x8.5 +40. I would prefer a wider tire and im not agains rulling and pulling. I want to run a 245 tire but not sure if it would work on either setup. Im lowered on the eibachs.
any of those setups would be cool. if you saw my car at the nator pa meet last week. i have 18x8.5 +33 in the rear and +35 in front. i think 245s would be fine on both the 8.5 setups. not too familiar with the 9" wheel.
dastpe is offline
 Old 07-19-2012, 05:18 PM   #282
dantes5823's Avatar
Posts: 6,576   (View Stats)
Its looking like the 17x9 +40. Mike has that on his car, actually he has pretty much exactly what i want so im gonna test fit one day. Looking to get PF01's for sure tho.
dantes5823 is offline
 Old 07-19-2012, 06:17 PM   #283
caesura's Avatar
Posts: 175   (View Stats)
caesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the worldcaesura is the leader of the world
Groans: 45
help!! I fitted my new private akzents that are 18x8 +46offset and they wouldn't clear the front brake calipers so my question is what size spacer I'd need? i know the stock offset is 50 something so would a 10mm spacer be enough or will I need something more like a 25mm?
Cobb AP: JBR WP Intake: CX Racing Fmic: CPE Catted Dp: SU Rmm: Autotech Intenals: Turbosmart BPV: JBR TB tig: JBR rear swaybar: JBR Shifter: TB Performance Mid Chasis Brace: TB Peformance Traction Bar V2: H/R Springs: Privat Akzents 18x8.5+48: 10mm Spacers: Hella Horns:
caesura is offline
 Old 07-19-2012, 07:05 PM   #284
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
So the spokes are actually rubbing the face of the caliper?
Sent from my SCH-I535 using Tapatalk 2
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-19-2012, 08:19 PM   #285
caesura's Avatar
Groans: 45
Yeah the spokes are right up against it so I'm assuming I'd need the 25mm spacer but just wanted a second opinion.
caesura is offline
 Old 07-19-2012, 08:48 PM   #286
smoogs12's Avatar
Groans: 423
How bad of a rub?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-19-2012, 09:57 PM   #287
caesura's Avatar
Groans: 45
How bad of a rub?
I haven't driven it because I can't get the lug nuts tightened enough lol so pretty bad
caesura is offline
 Old 07-19-2012, 10:26 PM   #288
speedy308's Avatar
Posts: 153   (View Stats)
speedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond reputespeedy308 has a reputation beyond repute
I say about a 10mm spacer would be enough. what you should do is hold the wheel up to the point where it clears and measure the gap between the rotor/wheel. You will need extended studs as well if you need more than 5mm
2012 Mazdaspeed 3 w/ Tech - Few mods
speedy308 is offline
 Old 07-21-2012, 05:48 AM   #289
Domino81's Avatar
Posts: 5,081   (View Stats)
Jesus, even some washers on the studs just to move it away from the hub.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
Domino81 is offline
 Old 07-21-2012, 06:24 AM   #290
dastpe's Avatar
or just run hubcentric spacers. i dont understand how that offset and width is rubbing against the brakes. thats almost the same as an rx8 wheel.
if that is the correct offset, that wheel should be fine. +46 sticks out more, so should be easier to fit.
dastpe is offline
 Old 07-21-2012, 07:15 AM   #291
caesura's Avatar
Groans: 45
[QUOTE=dastpe;1520154]or just run hubcentric spacers. i dont understand how that offset and width is rubbing against the brakes. thats almost the same as an rx8 wheel.
I thought they would fit easily because they are just like rx8 rims but I didn't take the lip of the rim into account which is about 2inches. Anyway ordered the 10mm hub centric spacers Friday.
caesura is offline
 Old 07-21-2012, 07:44 AM   #292
smoogs12's Avatar
Groans: 423
[quote=caesura;1520170]
Pretty sure that you will need longer studs with those spacers.
Someone correct me if I'm wrong but I believe 10mm is where the line is drawn.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-21-2012, 08:38 AM   #293
caesura's Avatar
Groans: 45
Yeah pretty much anything 10mm and up you will from what I read, but they come with extended studs so I'm good
caesura is offline
 Old 07-21-2012, 08:55 AM   #294
smoogs12's Avatar
Groans: 423
What ones did you get?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-21-2012, 09:41 AM   #295
caesura's Avatar
Groans: 45
I got these ones HUBCENTRIC WHEEL SPACERS 10MM 5X114.3 MAZDA MAZDA5 06+ W/ EXTENDED STUDS | eBay
caesura is offline
 Old 07-21-2012, 01:58 PM   #296
dastpe's Avatar
no, i meant hubcentric spacers with studs in them. H&R makes them...and others.
dastpe is offline
 Old 07-21-2012, 05:11 PM   #297
caesura's Avatar
Groans: 45
I couldn't find really any other ones that were the right size, and h and r doesn't make them in 10mm for the mazdaspeed3/3.
caesura is offline
 Old 07-22-2012, 06:40 AM   #298
dastpe's Avatar
i think thats because you would have to cut the current studs. they are something like 18mm long.
dastpe is offline
 Old 07-22-2012, 09:44 AM   #299
curlyface's Avatar
Posts: 232   (View Stats)
curlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond reputecurlyface has a reputation beyond repute
Thinking of going:
255/40/r17
on 17x8 +35
Will I need to roll fenders being dropped 1-1.3" on a 1st gen ms3?
2007 Mazdaspeed 3
-CP-e CATTED DP-PTP HPFP-COBB SRI-COBB TIP-COBB XLE-COBB AP FREEKTUNE-DENSO ITV24-JBR CHROME MOLLY-JBR PMM-JBR TMM-JBR OCC-JBR RSB-RALLY ARMOR-DASHHAWK-E4P STS-DEFI GAUGES-RL COILOVERS-
curlyface is offline
 Old 07-22-2012, 06:03 PM   #300
Speed3man's Avatar
Posts: 197   (View Stats)
Speed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond reputeSpeed3man has a reputation beyond repute
Okay I have a question I'm looking to run 235/40/18 nt05 with tsw +40 offset.. Will I need to run spacers for it not to rub? Also I have amr coilovers.. Thanks
Speed3man is offline
 Old 07-24-2012, 11:16 AM   #301
smoogs12's Avatar
Groans: 423
Whats the width of the wheel?
And also....Does anyone know what the hub bore is on oz ultraleggeras?
Been searching like crazy and just cant find a solid answer. The wheels are the 17x8et35 version.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-25-2012, 07:57 AM   #302
greenespeed's Avatar
Posts: 1,320   (View Stats)
greenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the world
Groaned at 6 Times in 3 Posts
Anyone have pics they could post of a ms6 with 18x8 +35 offset with 235-40-18 tires and lowered suspension. I currently have stock suspension running this size wheel but with a 225-45-18 tire and it rubs like hell. ( I know wrong size tire but got for next to nothing with the wheels ).
I am getting the fenders rolled as much as possible this weekend so that should help and soon will be going with 235-40-18 tires but need to know if it will still rub when I lower it. thanks.
2006 Mazdaspeed6 BCM GT
MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress
Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay.
greenespeed is offline
 Old 07-25-2012, 09:43 AM   #303
smoogs12's Avatar
Groans: 423
This was in the op. Its +33, but for all intent and purpose, its close enough.
Youll need a good roll for sure.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-27-2012, 02:48 PM   #304
dynamix's Avatar
Posts: 60   (View Stats)
dynamix is a glorious beacon of lightdynamix is a glorious beacon of lightdynamix is a glorious beacon of lightdynamix is a glorious beacon of lightdynamix is a glorious beacon of lightdynamix is a glorious beacon of light
what size tire would i need on an ms6 with stock height on evo x enkei's?
dynamix is offline
 Old 07-27-2012, 06:48 PM   #305
smoogs12's Avatar
Groans: 423
245/40/18 is oem for those wheels
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-27-2012, 09:33 PM   #306
dastpe's Avatar
i run 235/40
dastpe is offline
 Old 07-27-2012, 10:48 PM   #307
dynamix's Avatar
would a 225/40 be good to run on them or would that be a bit of a stretch with 225s.
dynamix is offline
 Old 07-28-2012, 09:23 AM   #308
smoogs12's Avatar
Groans: 423
There's no reason you cant do that, but I would use 235/40 or 245/40 just for the sake of keeping the overall diameter as close to stock as possible.
You might see a tiny bit of stretch with 225s depending on what manufacturer you go with (actual section width varies from brand to brand) but it wouldn't be much. Most likely just super flush with the lip of the wheel.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 07-29-2012, 07:58 PM   #309
snwslasher27's Avatar
snwslasher27 has much to be proud ofsnwslasher27 has much to be proud ofsnwslasher27 has much to be proud ofsnwslasher27 has much to be proud ofsnwslasher27 has much to be proud ofsnwslasher27 has much to be proud ofsnwslasher27 has much to be proud ofsnwslasher27 has much to be proud ofsnwslasher27 has much to be proud ofsnwslasher27 has much to be proud of
Groaned at 4 Times in 1 Post
Two part question:
I am looking at 18x8 with 45+offset on stock suspension. I am going to throw the stock Dunlop 225/40s on them .
I am pretty sure I wont have issues rubbing or using the stock tires on this setup bust wanted to be sure.
Also, recently picked up set of used Motegi 16's white wheels 16x7 with 42+ offset already checked them, they have adequate clearance around the front calipers.
Just wanted to make sure I will be good with no rubbing on this set up as well,
and what tire specs i should look for 215/55, 205/55, 215/60, 205/60?
Thanks , glad i made the move from mazda3forums.com to here, much better speed knowledgebase
snwslasher27 is offline
 Old 07-30-2012, 09:29 AM   #310
Big sugaaakane1's Avatar
Posts: 883   (View Stats)
Big sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the worldBig sugaaakane1 is the leader of the world
wow.... i was going to be a complete noob and start a thread asking if certain wheels i wanted would fit. i go to the nator meeting out here in new york and they told me research. well here i am and ll i have to say is thank you and for the rest of the noobsters.. RESEARCH!!!!!
Big sugaaakane1 is offline
 Old 08-05-2012, 09:10 AM   #311
ericdebruyn1's Avatar
Posts: 344   (View Stats)
ericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the world
Groaned at 43 Times in 17 Posts
Can fit 18x8 +20 with18/225/40, lowered with h&r lowering springs with Koni struts and shocks tightened all the way very little rubbing, I'm just going to roll the fenders in the back and should be good, or get 18/215/40 next time u get tires ImageUploadedByTapatalk1344179289.739503.jpg
This is looking from the back
Sorry taken with my phone so not the best quality
2008 cosmic blue, h&r lowering springs, koni struts,HKS intake, rx8 wheals,pump internals
v3 ap coming soon car got broken into and v2 got stolen
ericdebruyn1 is offline
 Old 08-12-2012, 10:50 PM   #312
naoandlater's Avatar
Posts: 655   (View Stats)
Just installed h&r springs with koni yellows on my car. Running 18x8.5 +45 wrapped in 235/40/10 Nitto NT555. Rubs when turning hard. *Fixed the clunking sound.
Pics of the car
(With 5mm spacers on the rear)
(Please don't mind the jdm angel pic. I didn't take it)
15 Soul Red Mazda3s GT HB
naoandlater is offline
 Old 08-13-2012, 09:30 PM   #313
Did you tighten the shocks down all the way? And is the thumping noise coming from the back or front?
If you can get 215x45 or 40 and you might be good, tire shops say that it's in safe but my girl friends brother has 205x45 on 8.5" wide rims and drifts the fuck out of his z3 and nothing has happened this is his car you can kinda see how stretched the tires are
I'm on vacation and sorry I'm not a big help
 Old 08-13-2012, 09:31 PM   #314
Pics of the car
Read my post above ^^^ sorry
h3lp clark kent likes this.
 Old 08-13-2012, 10:40 PM   #315
Attachment 70150
It's all good.
The sound was coming from the back. I did some more reading and found out that koni yellows on the rear needed to be tightened a bit more than the factory torque spec. The sound is gone now.
I thought about going switching tires but I honestly don't want stretch less than 225 on a 8.5 inch width rim.
 Old 08-16-2012, 02:09 PM   #316
manila's Avatar
Posts: 1,767   (View Stats)
Does anyone have pics of an MS3 with wheels similar to these specs? 18x7.5 +42
'12 MS3 Black Mica w/ Tech
manila is offline
 Old 08-16-2012, 03:57 PM   #317
smoogs12's Avatar
Groans: 423
@manilaMS12
Those wheels are exactly the same specs.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 08-16-2012, 04:11 PM   #318
KRNAGE's Avatar
Posts: 120   (View Stats)
KRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond repute
@manilaMS12
Tapa
No fitment issues at all - that's my MPS but just recently sold them CE28 replicas. Friend has them now getting powder coated. On stock shocks with road magnet springs at that time
Sent from my GT-I9100 using Tapatalk 2
06 Black MPS3 Sport Pack - Australia edition
Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen
EXE-Crew
KRNAGE is offline
 Old 08-16-2012, 05:00 PM   #319
smoogs12's Avatar
Groans: 423
Lol Kinda funny how you just happened to see my post
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
 Old 08-16-2012, 07:19 PM   #320
KRNAGE's Avatar
Tell me about it. I'm checking fitment threads as I want to get on the rota grid 18x9.5 wagon so really want to be sure as no one around me has this setup for me to test fit to be 100%
EXE-Crew
KRNAGE is offline
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS Djohns MazdaSpeed 3/6 - Wheels & Tires 1978 01-17-2020 05:03 PM
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS RhoadBlock MSF KB - Mazdaspeed 3/6 - Wheels & Tires 364 09-17-2012 05:30 PM
Separate "Appearance" from "Wheels/Tires" KaiserSoze Website Help/Feedback 1 04-21-2008 08:33 PM
Page generated in 0.60182 seconds with 36 queries
