![]() | | #241 | ![]() |
![]() Join Date: Jun 2011 Location: sufu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Groaned at 41 Times in 24 Posts
| Not Ranked : 0 score
Sent from AT&T Inspire 4G using Tapatalk.
__________________ HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2 | |
![]() | | #242 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score Holy quadruple fucking post brownie.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #243 | ![]() |
| Not Ranked : 0 score What I just woke up :-P Sent from AT&T Inspire 4G using Tapatalk.
![]() | | #244 | ![]() |
Groans: 793
| Not Ranked : 0 score You know the "multi" button at the bottom of each post is for quoting multiple posts, rite?
![]() | | #245 | ![]() |
![]() | | #246 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score lol did you really just blah blah blah @Tokay444? What a faggot. |
![]() | | #247 | ![]() |
BTW I give, not receive!Sent from AT&T Inspire 4G using Tapatalk.
![]() | | #248 | ![]() |
| Not Ranked : 0 score T-Dawg is more of a pitcher than a catcher, is what he is saying. Essentially a top, not a bottom. |
![]() | | #249 | ![]() |
Groans: 793
| Not Ranked : 0 score You're only ghey if you push back anyway.
![]() | | #250 | ![]() |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score lightly smoking at idle in under 1 minute despite all the fixes (bnoon bolt, occ, ptp pill, occ, 5w40 & raised idle). have 36k miles and the build date was 5/08. i'm near an oil change and hoping the thinned out oil is the smoking culprit. will change the oil this weekend but will take the car in if it's still smoking. my dealer is cool, but i plan to put the stock tune, tmic, tip, airbox back on and take off the ptp pill and bnoon bolt to help it smoke better. i hope they fix this. it will break my heart to stock out and sell this car even though i'll get a new 5.0 with lower payments.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() | | #251 | ![]() |
![]() Join Date: Jun 2011 Location: Norfolk, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score For those who have had the VVT fix done, did it quiet down the startup noise? I had mine done a week ago and it was good at first. Now I have the startup noise again. Not as loud as before, but it's still there. They replaced the actuator and chain on mine so I'm not sure why it would still be making that noise.
__________________ 2006 VRM Mazdaspeed6 #06475 1994 Ford Probe GT |
![]() | | #252 | ![]() |
| Not Ranked : 0 score If it is the quick rattle that is there, then goes away after a few seconds, take it back. |
![]() | | #253 | ![]() |
![]() Join Date: Sep 2011 Location: Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score Quick update for you guys: I had the VVT and Vent Kit sintalled. Within a day or two, the (what I believe is) camshaft position sensor right next to the fuel pump right next to cylinder 4's coil pack was leaking oil on the head pretty bad. The mechanic said the instructions didn't call for the O-ring to be replaced on that particular sensor, but immediately fixed it. Keep an eye on your heads after the fix!!
__________________ 2007 Black Mica MS3 SURE SRI, Resonator Deletes, TRZ TMM/RMM, Sure Sidewinder TIP. Bitchin'. |
![]() | | #254 | ![]() |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Groaned at 68 Times in 44 Posts
| Not Ranked : 0 score Good news for me - brought my car in today to get my wiper motor replacement checked (so I can get refunded the $250 I spent on a new one 2 months before the recall), and they reported a loud timing chain on their own. Free VVT fix for me! And not a moment too soon...just about to roll over 65,000 miles.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
![]() | | #255 | ![]() |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score ok so i bought my car used at over 70,000 miles and still received the letters.. i got a 48,000 mile extended warranty when i bought the car. its now at 86,000. Am i covered for this due to the extended warranty i bought? |
![]() | | #256 | ![]() |
Groans: 793
| Not Ranked : 0 score Talk to the warranty provider. Not us.
![]() | | #257 | ![]() |
| Not Ranked : 0 score good advice |
![]() | | #258 | ![]() |
![]() Join Date: May 2011 Location: Grand Junction,Co
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
| Not Ranked : 0 score Well this is bs... Took the speed 3 to groove mazda friday morning, even emailed the service guy a video of my turbo smoking No such luck, he said they had to duplicate the smoke in order to do anything. I'm fucking pissed. 500 mile round trip for nothing FUCK YOU MAZDA
__________________ 2008.5 MGM MS3 GT |
![]() | | #259 | ![]() |
| Not Ranked : 0 score Sounds like dealer sucks. Should take the o2 sensor off, pump in a quart of oil into downpipe. If you let it sit 30 minutes and it smokes, drive to dealer and idle it out front with the GM and service manager. Fwiw, video worked for me. |
![]() | | #260 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score Well this week my car started making the dreaded VVT Chain/acuator noise Also Im at 100k fml.. Im looking to go with the DRC, I am in NO way what so ever going to let this slide or procrastinate fixing this but at the same time, I'll need to pull some money together, and I drive this car daily, Any idea how long it is until I should stop driving it? Will driving lightly help, stay outta boost ect.. dam, track day at Big Willow canceled.
__________________ Long Block Built by GPwerks and Loose Screw Motor Sports https://www.gp-werks.com/ http://www.crossoverauto.com ^Any Parts, Great Prices^ |
![]() | | #261 | ![]() |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] | |
![]() | | #262 | ![]() |
![]() Join Date: Dec 2009 Location: NM/TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| Not Ranked : 0 score I had to make a stop to the dealership last week for something with the suspension, and when he went to test drive it, my car smoked (1st time ever) they saw it and said that i should be covered, so they looked it up and i am. they just said its gonna take a couple weeks between getting the parts in and there are 5 cars in front of me for the same reason. Guess it was good timing for me..haha
__________________ 1994 Mazda RX-7 = SOLD 2006 BCM MS6 = SOLD 2009 Dodge Ram 1500 ///Cobb AP///ETS TMIC///3''CorkSport Exhaust///2.5''Test Pipe///Cp-e TIP///AEM CAI w/ Filter Wrap///HKS BOV///Apexi Grounding Kit///CorkSport Sway bar///TWM SS stage 1 w/ bushings///SURE shortcut///SURE counterweight///SURE RMM///Eibach Sport Line Lowering Spring///Hawk Plus Prob Brake Pads/// Power Slot Slotted Rotors///ProSport Boost, A/F, Water Temp Gauges///Triple Dash Pod///Shark Fin Antenna///CarLink IPOD Connector/// HKS & SU Caps///Redline Tuning Quicklift Elite///ChargeSpeed Lip///ITV24 Plugs///Valentine1 Radar Think that's it... |
![]() | | #263 | ![]() |
| Not Ranked : 0 score Actually I did take 2 mods off - TMIC and intake. It only takes about 30 minutes to swap them out and reflash back to stock, so I figured it wasn't worth the possibility for future headaches if they decided to take pics.
![]() | | #264 | ![]() |
Groans: 74
| Not Ranked : 0 score called the dealer about bringing the car in for the smokey turbo. service manager told me to have my oil change records with me. i have them, but i'm hoping he was just being stern over the phone. can't imagine these guys going 15 rounds over a vent kit. service manager than put me on the phone with one of his reps. this guy said their sop is to install the vent kit and see how it does for 50 miles before moving onto the turbo. i will stock out under the hood and leave the dp so the stock cats can't mask the smoke. if they give me a hard time about the dp, i will stock out, sell her, and go get a new base 5.0 with lower payments and a warranty. it would be a shame since i love this car.
![]() | | #265 | ![]() |
Groans: 324
![]() | | #266 | ![]() |
Groans: 74
| Not Ranked : 0 score national park service popo for sure.
![]() | | #267 | ![]() |
| Not Ranked : 0 score Not sure how to straight up post a vid so just click the pic and u will see what my car did today. Then I sent this vid to the dealership that i drove 500 miles round trip to, and this is the email I got back Hello Mr. Epping, I’m sorry on your trip we could not duplicate the smoking concern. The technician tried several times, as well as myself. I rechecked with the technician and he is positive your turbo is ok. It’s not making any noise and if it were in need of a turbo, the smoke symptom would be constant. We appreciate your video. The problem with video, is we can’t monitor the vehicle. We can’t tell if the temperature is cold, if the vehicle is at operating temp, if the vehicle is dumping fuel, or is it an oil burn? These are all possibilities on the Speed3. If we can prove that the vent kit is needed, we also have another issue. We would need the factory intake parts to install the vent kit. We have been able to modify the vent kit to work with some cold air intake kits, but need the factory parts to be sure. I am sorry there is not a closer Mazda dealer to you. I will be happy to provide another free loaner if you have another trip to Denver coming up. Please let me know. Thank you, Kenny Berndt Service Manager Groove Mazda What do I do guys?
![]() | | #268 | ![]() |
Groans: 324
| Not Ranked : 0 score show them the video lol |
![]() | | #269 | ![]() |
| Not Ranked : 0 score Remove top O2 sensor, use a pump and squirt in a quart of used oil, aimed up to the top. Then drive the smoking shitbox to the dealer, idle it in front of showroom until someone comes out or then drive up to the door to service department and smoke them out. |
![]() | | #270 | ![]() |
Groans: 74
| Not Ranked : 0 score mine doesn't smoke after being on the interstate so I'll wait till it gets worse. I don't want to trouble with stocking out if the cocksucking villains can't replicate the smoke.
![]() | | #271 | ![]() |
| Not Ranked : 0 score That is the vid i sent to the service manager. Via email And the smoking issue is random. I can go days without it smoking, then in certain situations it will just smoke like it did in the video
![]() | | #272 | ![]() |
![]() Join Date: Mar 2010 Location: san antonio,tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 107
| Not Ranked : 0 score i had same issue where it would smoke then other times it wouldnt , but one day i was driving it and it was smoking bad so i drove it straight to dealer and left it running in service bay and at first didnt smoke but after 5 min was bellowing out crap ton of smoke and told the service guy who few days prior said they couldnt do anything unless it smoked ,came out and said to turn the car off and i said i want to make sure you see this , then service manager comes all pissy telling me to shut off my car and pull it to side of building ( turbo got replaced )hope you get it coverd tho , sucks sometimes when its hit or miss
__________________ 2012 Mazda 2 sport : Fun car 2012 Mazdaspeed 3 :Blk w/tech pkg. Forge BPV v.1 2010 Mazda 3 2.5 : RB springs,auto exe front bumper(Girlfriend car) 1987 Mazda Rx-7 GXL 2+2 :turbo swap ... ![]() 1987 Mazda Rx-7 SE : turbo swap (Girlfriends car as well) |
![]() | | #273 | ![]() |
![]() Join Date: Dec 2011 Location: Union OH
| Not Ranked : 0 score My local service manager told me that 'only turbos making noise are being replaced.' Funny, that's not what the notifications from Mazda said. Also, I got the vent kit installed (after riding their asses for three days) with no mention of the CAI that was on the car. It's a MS CAI - Maybe 'some cold air intakes' specifically references the MS intake. Because, you know, Mazda planned for this issue and designed their CAI to work with the not-yet-designed modified vent kit.
![]() | | #274 | ![]() |
| Not Ranked : 0 score Never go back to that dealer-ever. Post that info in the nationwide Dealer Shit List, post their name too so everyone can know they are fucking retarded. |
![]() | | #275 | ![]() |
Groans: 793
| Not Ranked : 0 score Short ram, cai, makes no difference. It's the TIP that gets replaced with the vent kit. All you need is a plug for the intake arm.
![]() | | #276 | ![]() |
| Not Ranked : 0 score I just called the dealer and asked when they were expecting the parts in. They told me that the parts for the VVT fix are on national back-order because Mazda is working on a new revision for the parts to prevent it from happening again. Maybe they're filling me full of crap, but according to them the new parts are going to be ready next month.
![]() | | #277 | ![]() |
Groans: 793
| Not Ranked : 0 score They're on back order because every single person who got the letters is having their's replaced because they come pre broken.
![]() | | #278 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
| Not Ranked : 0 score The only parts we haven't been able to get are the crank sprocket diamond washers. |
![]() | | #279 | ![]() |
Groans: 793
| Not Ranked : 0 score That's what I'm waiting on. Bought the ptp vvt the other day.
![]() | | #280 | ![]() |
![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| OFFICIAL Warranty Extension Program on turbo and VVT Actuator Thread. | SPEED6 KILLAH | Mazdaspeed3/6 General Discussion | 528 | 09-24-2017 06:36 PM |
| VVT/Timing Chain Noise Warranty Extension; 07-10 CX-7, 07-10 MS3, 06-07 MS6 | Brennan | Gen2 MS3 General Discussion | 4 | 01-21-2012 06:16 AM |
| Mazda extending warranty on smoky turbo + noisy VVT. extension Program SSP86 + SSP87 | bertrand_CX_7 | CX-7 > Engine, Transmission & Driveline | 8 | 01-20-2012 08:06 PM |
