> MSF KB - Mazdaspeed 3/6 - Fuel
 Old 01-18-2011, 12:21 PM   #1
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
Default 2010+ Mazdaspeed 3, I recommend to monitor your fuel pumps closely
Since Cobb recently discovered that the gen 2 ECU tends to max out the stock CDFP (camshaft driven fuel pump), I personally would recommend to any of you new to this car and planning to mod it that being prepared for a CDFP upgrade be your priority. The gen 2 ECU has been shown to max out the CDFP with as little as an intake and extremely mild tune, maybe less in some cases. The first money that you should spend when you plan to mod your car is on a datalogger.
Unfortunately, I have not led by example in this instance, but if I can help to keep anyone new from having problems, then I'm doing one of my biggest jobs here. It's a good idea to have the money ready to get one when you start changing things. Do NOT use PTP pumps, the only options that I would currently recommend are:
-CP-E direct replacement pump
-KMD internals with a VERY GOOD installer/installation
-Autotech internals with a VERY GOOD installer/installation
If there are more options that become proven over time, I will update this sticky. Thanks for reading and happy modding.
--Nate
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
The Following User Says Thank You to Nataphen For This Useful Post:
dvswimer (01-06-2018)
2010+ Mazdaspeed 3, I recommend to monitor your fuel pumps closely Nataphen 2010 MS3 - Fuel, Nitrous & Water Injection 508 07-06-2013 11:44 AM
Fuel Pumps - Gen 1 & Gen 2 MS3&MS6 whitewater 2010 MS3 - Fuel, Nitrous & Water Injection 6 05-24-2012 02:43 AM
recommend me a fuel pump (08ms3) blue_train MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 01-05-2012 03:09 PM
If Fuel Pumps are necessary, why no TSB? Silver Ecstasy 2010 MS3 - Fuel, Nitrous & Water Injection 52 09-07-2011 07:19 PM
Cp-e or PTP fuel pumps? manelscout4life MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 99 06-09-2010 05:32 PM
Page generated in 0.79851 seconds with 42 queries
