![]() Join Date: Apr 2010 Location: Kansas City, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 585
Groans: 39
| Not Ranked : 0 score Yes I've read that also. What confuses me is that it added a bunch fuel before the fp drop.
__________________ 2010 Silver Mazdaspeed3 |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
(Thread Starter) | Not Ranked : 0 score Try changing your load table AFRs and see if that helps. I haven't had this problem, so I wonder if the boost tune is still leaning on the load tables somewhat. I have raised my load AFRs, and I haven't encountered a problem. Since the ECU is designed around load tuning, it may be contradicting your OL fueling table targets. I changed mine from ~1.40 calculated load to 12.00 to match my OL fueling targets. Be safe, but give it a shot and see what happens. EDIT: Sorry about seeming redundant there. I'd had a few beers last night and I was trying to make sure that I got my point across. Now that I look at it today, it looks like I'm trying to explain something to a down's syndrome kid.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
| Not Ranked : 0 score I think that Nate may be right on target here. I have seen a big spike in afr (turns ultra rich totally ignoring the max enrichment table) when my calculated load differs from my load in the throttle required - x gear normal bat tables. I know I am like a broken record, but they are supposed to be within .05 what is seen in atr in your logs. FWIW, I've been adjusting my wgdc tables, and nearing the load targets (more boost) seen in atr in my logs. Mine is / was way worse than yours probably is @indianryan , btw. The boost on the stage 2 tune comes in way sooner than a stage 1 tune, and imo, my wgdc's are way off. It could be that I am still running the stock airbox that compounds the problem, although it is a stage 2 tune for the stock airbox. |
Groans: 39
![]() Join Date: Jan 2011 Location: FAYETTNAM
Rep Power: 0 ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score i just installed autotech internal, i have a cobb tih sri my noob question is can i run a stage 2 map with out a dp thanks for the help |
![]() Join Date: May 2009 Location: Calgary
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 892
| Not Ranked : 0 score Think you need atleast a test pipe before running stage 2. |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
| Banned ![]() Join Date: Mar 2012 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
Groaned at 34 Times in 12 Posts
| Not Ranked : 0 score well the way i see it $350 for an upgraded fuel pump is a pretty good deal it also gives you peace of mind that you know you can mod it safely to your hearts content. |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
__________________ 2 years after hitting 700hp and still running strong. Happy to see others joining the club. |
![]() Join Date: Jul 2010 Location: Rochester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,462
Groans: 64
__________________ Cp-e HPFP : JBR 80duro RMM : JBR Special Edition Heavy Shift Knob : JBR EGR Delete : Matt Damond OCC kit : Cobb AP : Cobb DP : Cobb BPV XLE : ETS TMIC : CP-e SRI : Cp-e TIP : Magnaflow CBE : Aeroforce Interceptor Dual Gauge : Blockhead vent pod :PERM Tuned : H&R Springs : TSW Nurburgring 18x8.5 w/ 235/45 Hankook Ventus V12 Evo : DDM 6000k Lows : DDM 3000k Fogs : Corksport LED light kit : 3M 35% color stable tint | |
What really sucks is I sent my pump in with 2,000 miles on it, shining and new, and have a "medium pressure" , lets say greater than 2,000 mile fuel pump. You go on the record as coining the phrase "medium pressure fuel pump". LOL! | |
Groans: 39
I assume there are others that have had no issues with the CP-E HPFP, so maybe there is a valid explanation for it not holding the fp above 1600 psi in Dizzy's situation. But I don't think it's fair for CP-E to only guarantee that it will keep the fp above 1600 psi ONLY for a stock tune. I guess it is possible that there is a problem with Cobb's map. I'll stay tuned and hope that either CP-E or Cobb comes up with an answer. | |
I don't know what flashing to the stock map does in CP-E's favor, given CP-E knows why we purchased these pumps, and that certainly was not to run the stock map. CP-E, Cobb and Ecutek are the only companies yet to crack this ECU (or bother), and surely they know the ECU's behavior @ stock and more agressive tuning levels. | |
Groans: 39
The stage1 is hardly an aggressive tune, which makes me wonder how far the CP-E pump was actually designed to go... It's hard not to jump to conclusions at this point, but maybe there's more to this than what we know now. | |
What bugs me is the willingness of Christian to alter the tune (@ least offer suggestive help), and the perception I get of Cp-e's answer to Dizzy. The first thing Christian / Cobb wants to do is help correct the problem, where as the first thing Cp-e does is blame Cobb (albeit indirectly). | |
Groans: 64
| Not Ranked : 0 score I agree, I have not been able to find any other instances of fuel pressure dropping with the cp-e pump which really puts me in a bind. It's actually ironic at this point because the reliability and quality of this product makes it very tough to proof any faults (if in fact there are any).
I am interested in how the ecu acts, what the effects on afr targets are etc. if the pump falls below the ap's targets Christian posted in the last page of this thread. (very close to the ~1700 range @ all points wot. ) | |
| Display Modes | |
| 2010+ Mazdaspeed 3, I recommend to monitor your fuel pumps closely | Nataphen | 2010 MS3 - Fuel, Nitrous & Water Injection | 508 | 07-06-2013 11:44 AM |
| Fuel Pumps - Gen 1 & Gen 2 MS3&MS6 | whitewater | 2010 MS3 - Fuel, Nitrous & Water Injection | 6 | 05-24-2012 02:43 AM |
| recommend me a fuel pump (08ms3) | blue_train | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 2 | 01-05-2012 03:09 PM |
| If Fuel Pumps are necessary, why no TSB? | Silver Ecstasy | 2010 MS3 - Fuel, Nitrous & Water Injection | 52 | 09-07-2011 07:19 PM |
| Cp-e or PTP fuel pumps? | manelscout4life | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 99 | 06-09-2010 05:32 PM |
