![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
(Thread Starter) | Not Ranked : 0 score Since Cobb recently discovered that the gen 2 ECU tends to max out the stock CDFP (camshaft driven fuel pump), I personally would recommend to any of you new to this car and planning to mod it that being prepared for a CDFP upgrade be your priority. The gen 2 ECU has been shown to max out the CDFP with as little as an intake and extremely mild tune, maybe less in some cases. The first money that you should spend when you plan to mod your car is on a datalogger. Unfortunately, I have not led by example in this instance, but if I can help to keep anyone new from having problems, then I'm doing one of my biggest jobs here. It's a good idea to have the money ready to get one when you start changing things. Do NOT use PTP pumps, the only options that I would currently recommend are: -CP-E direct replacement pump -KMD internals with a VERY GOOD installer/installation -Autotech internals with a VERY GOOD installer/installation If there are more options that become proven over time, I will update this sticky. Thanks for reading and happy modding. --Nate
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
| The Following User Says Thank You to Nataphen For This Useful Post: | dvswimer (01-06-2018) |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score maxing out how so? what pressure does the factory tune command?
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() Join Date: Nov 2010 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score Just as a heads up, I believe CP-E uses auto tech internals to build their pumps. I have found a source for auto tech internals and they are currently in stock. They are, however about $400 for a kit. If anyone is interested, I will post the information, but I cannot attest to success in shade tree installations of the auto tech internals components. I myself would rather wait for the KMD kits or CP-E pumps to be available because of there proven success here on this forum...
__________________ Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies... |
Groans: 31
(Thread Starter) | Not Ranked : 0 score The pump itself is actually a little better than the gen 1, but the new ECU stresses it more when the boost is increased. If you want to read up about it in depth, the Cobb alpha tester thread in the gen 2 tuning section has all the info. Basically, if the FRP drops below 1600psi, the ECU increases IPW (injector pulse width) to too high of a degree for the stock CDFP to keep pressure. Exactly.
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" | |
| Big Titty Sucker ![]() Join Date: Nov 2010 Location: NY
Rep Power: 744 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 579
Groans: 139
| Not Ranked : 0 score I was just reading about this. Sucks. as I wanted to just do the SRI and a basic tune. Now, it looks like I have to just do the SRI. Crazy that the stock pump is so limited. The stock pump in my Camaro was good until I hit about 425 whp, then I had to swap it. But that was a 100 whp gain over stock before I had to swap it.... |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Not Ranked : 0 score Well all i've gotten from the alpha testing thread is the stock CDFP will be fine till you raise boost PSI. Cobb will have OTS maps that don't do this for owners without a HPFP. I'm running a Corksport intake/tip UR highflow catted DP, TP, and CBE.. and I've got no issues with the my fuel pressure dropping below 1600PSI. Fuel pump keeps up fine.. now once I raise boost pressure with the AP I'm sure I will need internals.. such is why I've already got mine ordered threw KMD. No need to try to scare every gen2 owner into buying a HPFP first. I've has no issues what so ever.. We should scare every gen2 owner into NOT going catless.. which will cause boost spikes and creeps.. and then we will blow... |
| The Following User Says Thank You to Spoofmastafly For This Useful Post: | dvswimer (01-06-2018) |
![]() Join Date: Jan 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 118
However, if it's dangerous to remove the main cat with the stock ECU I'll go with the intake only... | |
![]() Join Date: Nov 2010 Location: West Lafayette, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
Groans: 70
Groaned at 23 Times in 15 Posts
| Not Ranked : 0 score You should be fine with the stock pump on those mods. Nataphen is simply suggesting that if you plan to get a downpipe or anything that adds more power down the road that you save yourself some potential heartache and buy a new HPFP or internals. I am an alpha tester for Cobb and they had to tone back the tune on mine because we were already going beyond what the fuel pump can handle. And that was stage1 with a SRI only
__________________ I drive an old RX-7 because I like breaking down a lot. |
I think the most important item here is that you should have some data monitoring system if you are going to mod. When I installed the ETS top mount, I had all kinds of surging under boost. I removed it and it went away, but my fuel rail pressures are still not stable with the intake and RP.
__________________ Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies... | |
I get what your saying, I was just simply throwing my input out there.. I just got back doing three logs myself.. Having only spiked to 16psi once, and fuel pressure to never drop below 1600psi when in 14-15psi boost range.. Even hit 1700psi once or twice.. Every car is different.. a ETS top mount is similar to running a catless DP.. it opens up the airway alot on these cars.. I wouldn't suggest running one of them without an upgraded hpfp. But I completely agree everyone should but a monitoring system before anything else.. DashDAQ will have complete PID's sooner or later.. I love mine. | |
Groans: 31
Everyone should get a datalogger before they start modding. When they notice a problem, the pump should be replaced.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST | |
Groans: 139
| Not Ranked : 0 score So a more basic plug in tuner like the Hypertech should be ok from what I gather? |
Groans: 31
(Thread Starter) | Not Ranked : 0 score As I said, I would get a datalogger first. Bolt-ons should be fine in most cases, as long as you do not raise your boost levels. Datalogger first IMO, and I stick to that. Hypertech doesn't have a 2010+ unit yet. I don't know what it will be like if and when it comes out.
![]() Join Date: Jun 2009
It seems from the datalogging experience of gen 1 users who did have fuel pump pressure drops that the gen 1 ECU does pull timing and sacrifice boost and other engine operating parameters to focus on maintaining safe AFR's when the pump shits. I don't know if this is the case with gen 2. Datalogging would be necessary to find out if the newer ECU works the same way to maintain safe AFR's.
![]() Join Date: Aug 2010 Location: Honolulu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 424
Groans: 54
Groaned at 42 Times in 32 Posts
In my case, temps below approx. 58 degrees F at WOT is when the the fuel pressure drops. Boost is set to around 19PSI, and the instant the pressure drops boost is dropped to around 17 PSI where it then stays steady until the RPM's get higher and the pump has less issues. So cobb's findings of approx 18 PSI being the 'max' before the pump has issues fits in line with the data i've seen from my own car. | |
![]() | | #19 | ![]() |
Rep Power: 123 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
![]() | | #20 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score OP and title reworded to tone down a bit, LOL.
![]() | | #21 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Thanks very much, ebnash. Your situation shows what I'm trying to get across. Datalogging is very important, even with mild mods. No two cars are going to react the same to changes.
![]() | | #22 | ![]() |
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score I spooke with CP-e today regarding upgraded HPFP. My little concern is, both my cars (CX-7 with 25.000 miles and my speed3 with 1100 miles on it) . The fuel pumps ran farely less miles. Swapping those to a new CP-e pump is kind of ... Because I don't know how old and how many miles the cores used to "re-build" the CP-e upgraded HPFP ran. Is that something to be concerned about? So far I don't abuse my cars so the pump cores should still be OK (35.000/3 years). Now the best option for me the money will be to use the KMD kit to upgrade my stocker FP. I'm kind of undecided between CP-2 pump and KMD internals. Do we have any update from other users, i.e, how long their KMD kit did last? Also since you mentioned the Gen2 pump is a little bit better than the Gen1, it make my choice even harder. Since I really plan to beat the shit out of my speed3 , Should I go with the CP-e pump, in the event of any issue, I should be cover under their live time warranty. Any advice?
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Picking a CPe Pump whenever there available. Can't wait to get this mod out of the way so i have more room to growwww!
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #24 | ![]() |
![]() Join Date: May 2010 Location: Colorado Springs, CO 80915
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 921
| Not Ranked : 0 score Hmm this is concerning me a little. I am running Cobb SRI and Ebay DP with the stock testpipe and no way to monitor. This is what i get for breaking the head of one of the DP bolts so i cant put the stock DP back on..As far as i can tell nothing but a CEL on but like i said, no way to monitor. Hopefully i can get my neighbor to get the bolt out and rethread it so i can put the stock DP back on. Lesson for all the Genpu nOObs, listen to what your fellow members say before u go and start modding your car!
__________________ 2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD 2012 Jeep Wrangler Unlimited Sport: Current DD |
![]() | | #25 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Talk to CPE about the pump core, that is not a decision that I can make for them. I like the idea of the CPE pump better because it is warrantied, the pump is tested, and it is drop in ready. KMD internals seem to be good, though there have been some that have failed. It's very easy to mess up the internals install, so a large majority of the failures may very well be because of the installer.
![]() | | #26 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score ^^CPE pump has a lifetime warranty and theres a reason for that. It is absolutely NOT something you need to worry about. I haz CPE fuel pump as of this week And im telling you...my shit runs smoother. i only have sri, testpipe, ets tmic but in the cold...while getting on it a little bit...it just didnt feel right. now theres no hiccups. i dont have a way to monitor though so it could be me just imagining shit but either way...get it done
__________________ |
![]() | | #27 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score Nice to see some info flowing about our cars. I have a ets top mount I'm waiting for I guess I should get the pump for good measure. I'm in Irving, TX anyone wanna datalog my car after the top mount? |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Thanks both for your answer. Yeah, the lifetime warranty is very appealing on the CP-e pump. I think I'll spread the expense-saving. I'll go upgraded CP-e HPFP for the speed3 and upgrade the internal on the CX-7 since I don't plan to mess up to much with the 7. Think I just find the trade of. Thanks bot for the inputs.
![]() | | #29 | ![]() |
Groans: 70
| Not Ranked : 0 score I think I am going to get the KMD internals. My dad is a professional mechanic for Marathon Oil I think he can handle it! lol
![]() | | #30 | ![]() |
![]() Join Date: May 2010 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 369
Groans: 58
| Not Ranked : 0 score Well the Cp-e HPFP is awesome. I installed one on my gen 2 about 15 days ago and everything runs smooth. I dont have anything to datalog right now but am looking into a few different things. Nataphen I think since we know we should use a data logger there needs to be information on what is out there that we can use. I myself and thinking of ordering a PLX kiwi wifi obdII reader and hook it up to my ipod touch. But have also though about going with the DASHDAQ as well but it still doesnt have all the PIDs. So it is a bit expensive for my taste on that. That is just my .02.
__________________ [SIGPIC][/SIGPIC] 2013 CWP (DD)COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP TUNE IN PROGRESS (RFINKLE2) 1999 Mazda Miata (PROJECT) (blown motor) BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8 |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
| Not Ranked : 0 score the problem is there are no good dataloggers for the gen 2. You can get a dashdaq for the same price price as the AP. Does anyone know if a dashhawk will show fuel pressure, fuel trims? Does the dashhawk competely not work with the gen 2 or does it work choppy or not show all the data like knock and afrs?
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
![]() | | #32 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jan 2009
Rep Power: 175 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
We have been selling and pushing the Innovate motorsports datlogers for YEARS. These are robust as hell, log at a very high sample rate, and are easy as hell to use for the average modder. Most profesional tuning shops have two or three LM-2s they use to log cars while on the dyno. These are the best logers short of a full blown Motec setup! The OT-2 is a downsized unit that does everything the LM-2 does, less the stand alone wideband, and display, and works wirelessly with your laptop, Iphone, Ipad,or Ipod touch. The software that Innovate uses is self graphing, and very addaptive. We have a ton of the OT2's on the shelf right now. Retail price is dirt cheap at 179.95 If you guys without a way to monitor your car want them, drop me a line, I'll give you a great GB on the little suckers | |
![]() | | #33 | ![]() |
| Not Ranked : 0 score I hooked up the DH to my Gen2 speed 3 couple days ago and it's still there. I don't know which parameter reads the Knock retard and fuel trims. Anyone interesting of knowing what the DH can/can't read. Pls PM me with a list of params to look at so I can double check and confirm Thanks
![]() | | #34 | ![]() |
Groans: 58
| Not Ranked : 0 score The DH still is able to read some things on our car but it is really laggy. I used my friends DH to monitor FP when we installed the cp-e HPFP to make sure everthing was good. It was really choppy. It doesnt read AFR or KR. But it will give you a few things.
![]() | | #35 | ![]() |
Please explain.. Sofar DH is reading only Boost, ltft, stft. Thanks
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. | |
![]() | | #36 | ![]() |
| Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
Are you monitoring the correct fuel pressure parameter? There's like two of three of them. It should be the one that says Fuel Pressure Direct Injection.
__________________ | |
![]() | | #37 | ![]() |
May be we should create a sticky thread for the parameters, their meaning and what should be they OK values to point out to newbes like me what are import and on what to focus when starting messing arround with their car.This is the last question about login. Knock retard with DH: Which PID parameters read it and what should be the OK value? Thanks to every one.
![]() | | #38 | ![]() |
![]() Join Date: Feb 2010 Location: Toronto
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
Groaned at 80 Times in 41 Posts
| Not Ranked : 0 score I monitor DI pressure, boost,a/f ratio Long term and short term fuel trims Dash hawk has allot, but I have notice sometimes when you plug in you have N/A in couple of boxes. This happens rarely but all you have to do is shut engine off and then unplug, then restart car and plug back in after couple of minutes.
__________________ Street Unit RMM 62 durameter 2-piece, solid shifter bushings, TWM short throw shift kit,Amsoil synthetic gear lube, Corksport Metal Skid Plate,6,000K philip Ultinon bulbs, 3,000K Le Mans yellow Fog light H.I.D's |
![]() | | #39 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score So I've been WOT a few times in this colder weather - probably really bad for the engine, can't go back and un-WOT now though. I really want the new firmware to come out so I can datalog. I thought the neutered stg 1 maps still briefly reached 18psi? Only for around 500-750 rpms though IIRC. At any rate, looks like I'm gonna be sticking to 16 psi and only fiddle with the timing and WGDC for a while. |
![]() | | #40 | ![]() |
Groans: 70
__________________ I drive an old RX-7 because I like breaking down a lot. | |
| 2010+ Mazdaspeed 3, I recommend to monitor your fuel pumps closely | Nataphen | 2010 MS3 - Fuel, Nitrous & Water Injection | 508 | 07-06-2013 11:44 AM |
| Fuel Pumps - Gen 1 & Gen 2 MS3&MS6 | whitewater | 2010 MS3 - Fuel, Nitrous & Water Injection | 6 | 05-24-2012 02:43 AM |
| recommend me a fuel pump (08ms3) | blue_train | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 2 | 01-05-2012 03:09 PM |
| If Fuel Pumps are necessary, why no TSB? | Silver Ecstasy | 2010 MS3 - Fuel, Nitrous & Water Injection | 52 | 09-07-2011 07:19 PM |
| Cp-e or PTP fuel pumps? | manelscout4life | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 99 | 06-09-2010 05:32 PM |
