> MSF KB - Mazdaspeed 3/6 - Fuel
 Old 09-21-2011, 04:10 PM   #161
Intruder's Avatar
Posts: 144   (View Stats)
Intruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud of
Originally Posted by rangers4094 View Post
why do you have to remove the battery boX?
For ease of access.
Getting the nut off the high pressure fuel line can be a pain the ass with all the parts in place. I took the battery and intake out completely and it was a peace of cake to do the fuel pump.
2010 Mazdaspeed3
Intruder is offline
 Old 09-21-2011, 04:21 PM   #162
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
You don't. All I removed was the TMIC.
Now that I have done it, I wouldn't remove anything from the car.
wolly6973 is offline
 Old 09-21-2011, 11:30 PM   #163
2010Speed3's Avatar
Posts: 607   (View Stats)
2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world
I'd say remove it if you no idea what the hell you're supposed to be looking for. If you have somebody with you who knows what they're doing, then don't remove the battery tray and intake.
SOLD on 08/2013
2010 Black Mica MazdaSpeed3
Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC
2010Speed3 is offline
 Old 09-22-2011, 06:27 AM   #164
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
You don't. All you really need to take out is the TMIC. The battery box would just make wrenching the pump out easier.
adlpb is offline
 Old 09-25-2011, 08:39 AM   #165
iracer7's Avatar
Posts: 329   (View Stats)
iracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond repute
Read this how-to and the Autotech how-to and don't see steps 5, 6, or 7 included in your write up. Why the difference? I'm no expert.
Cobb AP, CPE SRI, Cobb Turbo Inlet, Turbosmart Dual-Port BOV, ETS 3.5" TMIC, TRZ Rear Motor Mount, TurboXS Race Pipe, TWM Shifter Bushings, Dabears2k 35W 6000k HID's, Luminiacs 2500k halogen fogs, Putco brake light led bulbs, CPE tow plate, Cobb Springs, OZ Racing Ultraleggara Gold Wheels, weapon r torque damper
iracer7 is offline
 Old 09-25-2011, 01:24 PM   #166
yetihairball's Avatar
Posts: 4   (View Stats)
yetihairball is an unknown quantity at this point
Default KMD Install Failed
I got the fuel pump off the car and took out the internals, but I could not get the OE piston, the part that slides into the 18mm nut, out. That sucker was seized in there and no amount of vice grips or pliers was getting it to come out. I bought this car used so I am thinking that this is not the factory fuel pump. There were lots of other aftermarket stuff on the car that I've been finding over time. The pump holds pressure just fine, but did anyone else have issues taking out the OE piston to replace it with the new one?
I have an '06 MS 6.
yetihairball is offline
 Old 09-25-2011, 01:47 PM   #167
irishking03's Avatar
Posts: 2,136   (View Stats)
Nice write up
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline
 Old 09-25-2011, 01:56 PM   #168
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Groans: 62
You don't!!!!!!!!
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline
 Old 09-25-2011, 02:26 PM   #169
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
I have an '06 MS 6.
Did you damage the piston trying to take it out? The oem one slides out, but the upgraded ones require removing the 18mm nut first because it's bigger. As long as you didn't damage it, put it back in and just monitor for fuel pressure as you add power. If you did damage it at all, then remove the nut and see what's up.
Sent from my DROIDX using Tapatalk
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
Pedal-Force is offline
 Old 09-25-2011, 02:29 PM   #170
m4tic's Avatar
Posts: 4,928   (View Stats)
it doesnt matter what you do to that 18mm cap, as long as the small rubber oring is in there
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
m4tic is offline
 Old 09-25-2011, 02:38 PM   #171
Paul's Avatar
Posts: 822   (View Stats)
Paul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the world
Groaned at 20 Times in 5 Posts
This will be me next saturday... AT Internal.
Also CS SRI/TIP/Airbox/ MM Insert / JBR SSP.... at least I only have to take all the stuff off once.... Buy everything at once instead of one by one.
Prob bring my Laptop with this post and some other .PDFs pulled up when I got to the auto shop bays on post. 3$ an hour with all tools included FTW.
2011 MS3 || Tech Pkg || Shark fin ||
|| HTP 3.5 Intake || || BNR4 || CS TMIC || CS CBE ||
|| CS Boost & BpV Tubes || DENSO IVT22 || FORGE BPV v2 ||
|| AT Internals || COBB APV3 || CNT DP || Koni Yellows || H&R Springs ||
|| JBR Shift Knob || JBR Stage 2 SSP || JBR SSBushings ||
|| JBR 88 RMM || JBR 80 TMM || JBR 80 PMM || JBR RSB || JBR RCAs || JBR EGR Block/Delete - OCC - Small Battery box ||
\\|// AJ 91 & E85/91 Mix Tunes by A.J \\|//
|| Window Tints, Lamine-x Headlights/Fogs, Tinted Tails, JDM Rain Guards ||
Paul is offline
 Old 09-25-2011, 03:48 PM   #172
rangers4094's Avatar
Posts: 37   (View Stats)
rangers4094 will become famous soon enough
Groaned at 10 Times in 2 Posts
is it true that cp-e hdfp uses autotech internals, and just tests the shit out of it.
is it really worth the extra $ to get the cp-e pump?
rangers4094 is offline
 Old 09-25-2011, 04:05 PM   #173
adlpb's Avatar
Groans: 669
I don't think they use autotech internals. If you think you're capable of performing the installation above then you should just get internals. Only advantage of cp-e is lifetime warranty.
adlpb is offline
 Old 09-25-2011, 09:35 PM   #174
It may have already been upgraded then because the piston was not coming out from the nut. As much as I was pulling on it I am surprised I didn't do any damage (I thought it was just supposed to slide out).
I've never had any issues with fuel/boost cut, I was only upgrading the internals as a precautionary measure since I am planning on getting the car dyno tuned at Cobb in the next week or so.
 Old 09-26-2011, 01:27 PM   #175
wolly6973's Avatar
Groans: 386
It is speculated that CP-E gets their internals from APR, since APR won't sell to anyone if you mention the word Mazda.
 Old 09-26-2011, 06:44 PM   #176
fulloncrazy's Avatar
Posts: 2   (View Stats)
fulloncrazy is an unknown quantity at this point
wont we still get boost/fuel cut even with hpfp upgrade? i was under the impression it was the map and or maf readings that set off the cuts.
fulloncrazy is offline
 Old 09-26-2011, 10:18 PM   #177
wolly6973's Avatar
Groans: 386
Get an AP and that won't happen.
 Old 10-03-2011, 11:22 AM   #178
toobs123's Avatar
Posts: 32   (View Stats)
toobs123 has a spectacular aura abouttoobs123 has a spectacular aura abouttoobs123 has a spectacular aura about
Thanks for the guide!
Just want to add my .02 about the install. Regarding the e8 tool, you can get away w/using a 1/4 inch socket. I think it was a 1/4 inch, but it didnt strip any of the bolts, just be careful. Was really easy, thanks again.
toobs123 is offline
 Old 10-04-2011, 02:33 AM   #179
so prior to installation of the internals clean with brake parts cleaner, and then soak in oil or gasoline?
 Old 10-04-2011, 07:02 AM   #180
Oil. No gas. Gas bad, it drys it out.
 Old 10-04-2011, 09:01 AM   #181
Jake5713's Avatar
Posts: 1,775   (View Stats)
You can use gas to clean it just oil well afterwards!!
Jake5713 is offline
 Old 10-04-2011, 11:26 AM   #182
davinspeed3's Avatar
Posts: 252   (View Stats)
davinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the world
I just used non chlorinated parts cleaner and then oiled. No gas.
2011 BLACK MICA MAZDASPEED 3
25% E-85 Dizzy Tuned
CP-E SRI // CP-E TIP // CP-E DP // CP-E FMIC // CP-E TURBO MANIFOLD // COBB AP // COBB XLE BPV // SURE SHORTCUT & COUNTERWEIGHT // SURE ANCHORS // JBR DOGBONE RMM // TWM DESERT EAGLE KNOB // DENSO ITV 22's // AUTOTECH INTERNALS // RESONATOR DELETE // MD OCC // SWIFT SPRINGS
davinspeed3 is offline
 Old 10-07-2011, 03:28 AM   #183
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groaned at 6 Times in 4 Posts
I'll be installing my fuel pump internals tomorrow, but before doing so. by oil, do you mean like motor oil that we put in our car?
I have some Royal Purple 5w-20.... would that work?
and do i just put like couple drops or so "oil" onto the shaft and bottom cylinder area?
Thanks! sorry for noob question, dont want to mess up the install
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline
 Old 10-07-2011, 05:00 AM   #184
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
its all good.
oil the internals themselves with motor oil. so yeah, royal purple would be fine. use some gloves and lubricate them well.
2010 Black Mica
rghispanic88 is offline
 Old 10-07-2011, 11:57 AM   #185
Always good to ask and make sure. I was kinda scared to due this install at first. I'm not new to the mechanics of installing parts but never takin apart a pump and tried to put it back together. It really wasn't to bad. As for the question yes. Just use motor oil and oil the entire shaft, as it is the moving part. I used a liberal amount. Enough to cover the entire shaft, but not so much that's it's just dripping off. And FYI. Do not use one of those cheap clamp on table vices. I snapped it in half. Couldn't believe it. I ended up putting the socket on while attached to my breaker bar, held the socket on while beating the breaker bar handle on the concrete. Then after doing that I put the breaker bar between my legs and turned the pump with all I got, and off came the nut.
 Old 10-07-2011, 01:12 PM   #186
AndyT's Avatar
Posts: 36   (View Stats)
AndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant futureAndyT has a brilliant future
I've just ordered some Autotech internals so will be doing an install shortly, some very good info so feeling a little more confident. Just need to get myself a deep 18mm socket.
AndyT is offline
 Old 10-07-2011, 04:46 PM   #187
xtasy's Avatar
autotech internals came right now. =\ it's 6 already.. Hopefully ill finish the install before 8
xtasy is offline
 Old 10-07-2011, 05:05 PM   #188
Groans: 263
dont rush, take your time.
2010 Black Mica
 Old 10-07-2011, 05:16 PM   #189
^^^^ This. Don't rush something that could cost you big if you screwed it up.
 Old 10-08-2011, 02:54 AM   #190
xtasy's Avatar
haha yeah, i didnt install it today, going to install it monday instead.. working the weekends.
I guess I get the concept of the installation, one more question, shall i lube the spring too?
I spend today loosening my downpipe bolts, for next weeks or 2 weeks later dp installation.
xtasy is offline
 Old 10-08-2011, 05:17 AM   #191
foodtime's Avatar
Posts: 225   (View Stats)
dude..uhh..anger problems?
foodtime is offline
 Old 10-08-2011, 05:48 AM   #192
adlpb's Avatar
Groans: 669
Yes, I'd lube all parts
adlpb is offline
 Old 10-08-2011, 07:14 AM   #193
I didn't lube the spring as it's not getting any friction rubbing against another part. Don't see how that will help any, but can't hurt if it makes you feel better.
I was a little pissed after the vice broke, but had to improvise.
 Old 10-08-2011, 04:40 PM   #194
m4tic's Avatar
you will strip it.. someone used a socket on my pump the first time it came out.. the next time using the proper E8, it rounded one of the heads
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 10-17-2011, 08:56 AM   #195
LakeSTLMS3's Avatar
Posts: 281   (View Stats)
LakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the world
yeah I agree on not using the 1/4' socket. I used it for two of the bolts but on the third one it started to strip. I went and got an E8 socket and it came right out.
OP, great write up! KMD's instructions were okay but not great. Their pictures weren't very clear so yours definitely helped...........
If anyone is nervous about this install, Dont be!!! Just take your time, come with the right tools and dont forget the lube!
2011 Black Mica Genpu
COBB AP / Corksport SRI & TIP - LED fog kit - exhaust hangers / StreetUnit testpipe / OBX CBE / Ultimate Racing catted DP / CP-e TMIC - tow plate / Eibach Pro kit / KMD internals / Turbosmart dualport bov / ITV22 denso plugs / TRZ dogbone RMM / JBR 80duro TMM - 80duro PMM - heavy shift knob - SSP - shifter bushings - mud flaps - RSB - 5mm spacers - EGR block off - TB TIG and coolant bypass / RX-8 wheels 18x8 / 245/40/18 Pirelli's / Aeroforce gauges
Stratified!........
E85 tuned - VD 348whp/396tq
Future Mods:
Koni yellows - OCC - BNR S3 - FMIC - JBR big intake - Cobb 3port - Bosch 3 bar - GA - retune from Lex
LakeSTLMS3 is offline
 Old 10-19-2011, 11:26 PM   #196
iracer7's Avatar
For anyone who has done this before, do you think it would be possible to use 2 adjustable wrenches instead of buying a 17 and 19mm open ended wrench?
iracer7 is offline
 Old 10-20-2011, 04:43 AM   #197
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
Waiting on my KMD internals to come!!!!! Cant wait to get this installed!!!! Thanks for the write up!
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline
 Old 10-20-2011, 06:12 AM   #198
adlpb's Avatar
Groans: 669
You can try, but keep in mind that space is extremely limited if you only remove the TMIC. I've done the fuel pump on several occasions and have never removed the battery or TIH. An open wrench will give you more room that an adjustable one. But I'm sure it can be done.
adlpb is offline
 Old 10-21-2011, 07:22 PM   #199
Tucson's First GenPu
AZRushki's Avatar
Posts: 234   (View Stats)
AZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the world
its all good.
read the thread awesome st00fs
anyways question. Have had my Cp-e pump in and out of car. Has been in a box for 6 months when i stocked out. I don't wanna take it apart, do I need to re-lube or will the car's lubage be enough?
Ya, I got some stuffs in thurr
AZRushki is offline
 Old 10-21-2011, 08:36 PM   #200
Groans: 263
yeah you should lube it. it might have dried up in 6 months
2010 Black Mica
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f633/fuel-pump-internals-install-125915/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-29-2014 05:22 PM
Fuel Pump internals Install! rghispanic88 2010 MS3 - How-To's 445 07-17-2017 11:53 AM
oil in engine bay after pump internals install Realgib3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-24-2009 05:04 PM
Page generated in 0.60097 seconds with 43 queries
