![]() | | #41 | ![]() |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
__________________ 417whp 428tq 12.037@117.2mph |
| The Following 2 Users Say Thank You to Snyeed For This Useful Post: | impossible (05-21-2016), snailD (05-14-2016) |
![]() | | #42 | ![]() |
(Thread Starter) | Not Ranked : 0 score She's all back together! Fired right up. new tires mounted today, 235/40/18's nitto NT555. Plenty of little things needing to be done but I'm happy to be driving her again.
| The Following 4 Users Say Thank You to Snyeed For This Useful Post: |
![]() | | #43 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score congrats james
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
| The Following User Says Thank You to snailD For This Useful Post: | Snyeed (05-21-2016) |
![]() | | #44 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Car is looking great with the DG aero mods. Is the PI wired up yet?
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
| The Following User Says Thank You to impossible For This Useful Post: | Snyeed (05-21-2016) |
![]() | | #45 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score Car is looking clean...I want to drive out there and carve up Big Cottonwood with you
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | | #46 | ![]() |
| Not Ranked : 0 score lets do east canyon, thats my favorite
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score 1000+ miles on the motor, switched to Rotella per Sp63 recommendations. Compression check is happening today with a snap on guage, hopefully all is well and I can start tuning for powa!
| The Following User Says Thank You to Snyeed For This Useful Post: | 802MS3 (06-08-2016) |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Compression results are in..
![]() | | #49 | ![]() |
Groans: 30
| Not Ranked : 0 score Are those 2 step colder Denso's?
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score Itv22's
![]() | | #51 | ![]() |
Groans: 30
| Not Ranked : 0 score Ahh staying Denso or going NGK's now that motor is broken in?
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Never had a problem running denso's, I'm not against trying NGK's though. what are you running?
![]() | | #53 | ![]() |
Groans: 30
| Not Ranked : 0 score NGK's, I started with Denso's but after seeing a local here have one come apart inside the cylinder and ruin his engine I made the switch
| The Following User Says Thank You to impossible For This Useful Post: | Snyeed (06-09-2016) |
![]() | | #54 | ![]() |
| Not Ranked : 0 score i'm going to continue to run denso's. never had an issue, i've only seen them come apart from extreme detonation and i like the fact that they are much closer to the gap we run than NGK's. which come at .040 vs denso .032 especially when he will be gapping them down to at least .026
| The Following User Says Thank You to snailD For This Useful Post: | pharaoh313 (06-16-2016) |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nothing new to report, A few maps in with the freek. I hope once we verify the PI is working correctly I could finish up all the tuning on a dyno.
| The Following User Says Thank You to Snyeed For This Useful Post: | impossible (07-03-2016) |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Took some time to install my fan controller, just a small step into controlling temps.
![]() | | #57 | ![]() |
![]() Join Date: Sep 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
| Not Ranked : 0 score The color you went with in the motor is really nice looking. It has an industrial machinery quality to it. I really can't stop staring! So it's well into summer now, any updates with the build or tune? How are you liking that turbo?
__________________ 2009 MS3 GT - JBR SRI/TIP - CS Racepipe - TurboXS CBE - Cobb AP - Stratified E85 Flash Tune Stg. II (294/342) - Stratified Guardian Angel - Autotechs - CP-e S2 RMM - KW V2 - SPC RUCAs |
| The Following User Says Thank You to jtday For This Useful Post: | Snyeed (07-26-2016) |
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score Working out small issues that have come up but I received my first PI map, waiting on the freek.
| The Following User Says Thank You to Snyeed For This Useful Post: | jtday (10-18-2016) |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score Tuning for e85 has officially started! going to get my nitto DR's mounted today on some evo 9 wheels.
![]() | | #60 | ![]() |
__________________ 417whp 428tq 12.037@117.2mph Last edited by Snyeed; 10-16-2016 at 09:31 PM. |
| The Following 5 Users Say Thank You to Snyeed For This Useful Post: | impossible (02-25-2017), Mazdazilla6 (10-18-2016), Micha (11-01-2016), snailD (10-24-2016), TRBLSM (10-20-2016) |
![]() | | #61 | ![]() |
| Not Ranked : 0 score What was your DA?
![]() | | #62 | ![]() |
| The Following User Says Thank You to Snyeed For This Useful Post: | Mazdazilla6 (10-21-2016) |
![]() | | #63 | ![]() |
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Snyeed (10-30-2016) |
![]() | | #64 | ![]() |
![]() Join Date: Apr 2011 Location: HOFFMAN ESTATES IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Nice build! ..lots of work, though hope u ll reach 700hp ![]() !! It ll b all worth the sweat and moneySent from my SM-G900P using Tapatalk |
| The Following User Says Thank You to manu For This Useful Post: | Snyeed (10-30-2016) |
![]() | | #65 | ![]() |
Groans: 30
| Not Ranked : 0 score I didn't even know the dude I was talking to was you on FB, you sent me that video of your 1/4 pass. Glad to know your car is out there killing now man! Any updates and power figures?
| Bangers and Mash: Website offers auto classifieds limited to $1,000 [w/video] | Haltech | Automotive News | 0 | 02-12-2010 08:00 AM |
| VIDEO: Griffin Up! Saab supporter creates mash-up in support of brand | Haltech | Automotive News | 0 | 12-28-2009 10:10 AM |
| REPORT: Electric Infiniti will stay true to brand's performance roots? | Haltech | Automotive News | 0 | 11-24-2009 08:50 AM |
