 Old 06-20-2019, 03:59 PM   #1
The_big_dill's Avatar
Posts: 38   (View Stats)
The_big_dill has a spectacular aura aboutThe_big_dill has a spectacular aura about
Default Balance Shaft install
Hello guys,
As I am rebuilding for primarily daily use, I want to retain my balance shaft.
As almost everyone deletes their balance shaft from their engine, every search ends with "Just delete it".
I am looking in the service manual and it seems like there is a typo on the torque spec and it is indicated in a very strange way.
FSM is telling me to torque the BS:
25Nm + 44-46Nm. Why? I understand torque + angle, I don't understand torque + torque.
Any help is appreciated!
The_big_dill is offline   Reply With Quote
 Old 06-21-2019, 08:40 AM   #2
shamie's Avatar
Posts: 952   (View Stats)
Tighten all bolts to the first # then to the second #. Do not add the #s .
Be sure you have it aligned and shimmed properly also.
Or "Just delete it."
 Old 06-21-2019, 09:57 AM   #3
Thanks for the reply.
That is what I did. I have never seen that instruction before was why I got confused.
The shims were stuck on the balance shaft when I removed it, I didn't take them off, I imagine there isn't a reason to re-shim.
There are dowels on the BS, is there additional alignment I need to do in relation to the block?
Appreciate it!
Phil.
 Old 06-21-2019, 11:04 AM   #4
shamie's Avatar
There's the gears that need aligned. There should be marks on them.
 Old 06-21-2019, 03:33 PM   #5
Oh ok, I thought you meant the BS to block. I aligned the gears by eye and it looks the same as the pictures before i took it apart, if thats close enough lol.
Thanks!
 Old 06-21-2019, 05:35 PM   #6
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
It's called a 2-step or 2-stage torque sequence. 3-step takes it another level, like with the head bolts.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Balance shaft help sfeldner Gen2 MS3 General Discussion 11 03-25-2016 11:18 AM
Balance shaft reinstallation brandontrek MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-14-2015 12:30 PM
Balance shaft Re-install Johnasaurus 2010 MS3 - Engine, Transmission & Driveline 18 09-18-2014 08:16 AM
Balance Shaft Delete Smoker6 Mazdaspeed3/6 General Discussion 83 05-03-2009 09:42 PM
Page generated in 0.25869 seconds with 23 queries
