Like Tree6Likes
  • 1 Post By Mazdazilla6
  • 1 Post By mxlplx71
  • 2 Post By shaneski
Closed Thread
 Old 04-23-2016, 08:58 PM   #1
Sleepin6's Avatar
Posts: 99   (View Stats)
Sleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to behold
Default Burnt exhaust valve rebuild
Was just wondering what fail safe items I should replace so I don't burn a valve again. Doing a rebuild now and want to make sure everything that can prevent this is changed or fixed. Thanks.
MS6 GT...REBUILD IN PROGRESS
BOLTED AND BOOST PROVIDED BY...
SPEED1/CORKSPORT...
Sleepin6 is offline
 Old 04-24-2016, 09:17 PM   #2
Sleepin6's Avatar
Anyone go through this on there rebuild?
SPEED1/CORKSPORT...
Sleepin6 is offline
 Old 04-24-2016, 10:18 PM   #3
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
what tune, boost, and mods
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
mxlplx71 is offline
 Old 04-24-2016, 10:26 PM   #4
Have the head checked by a shop. The largest contributing factor to burnt valves is out of round seats on either the head or the valve or too large of a clearance between the valve stem and guide.
Sleepin6 likes this.
Mazdazilla6 is offline
Sleepin6 (04-25-2016)
 Old 04-25-2016, 03:47 PM   #5
Sleepin6's Avatar
Ots stage 3,20-21lbs,fully bolted minus intake/exhaust mani's.
Ok it's going to get checked at the shop and will go through the full inspection and see what happened. It has rough edges on the head and a chunk of a valve is missing on the exhaust side cyl 2. That's why 0psi...I appreciate the response.
It was a Cobb ots tune and I'm sure that didn't help either. If there's anything else you guys can think of please don't hesitate to pm me or reply. Thanks.
SPEED1/CORKSPORT...
Last edited by Sleepin6; 04-25-2016 at 03:47 PM. Reason: MSF Database - Automerged Doublepost
Sleepin6 is offline
 Old 05-17-2016, 04:13 PM   #6
Sleepin6's Avatar
You were right about the seats. He said I need to replace 2 of them in cyl 2 which was the cyl with the one burnt valve and another on the way out. Thanks.
SPEED1/CORKSPORT...
Sleepin6 is offline
The Following User Says Thank You to Sleepin6 For This Useful Post:
Mazdazilla6 (05-17-2016)
 Old 05-17-2016, 04:14 PM   #7
No worries. Happy you got it figured out!
Sleepin6 (05-19-2016)
 Old 05-17-2016, 05:01 PM   #8
Sleepin6's Avatar
Yeah...now I have to figure out how to not let it happen again. Keep it cool they tell me...I did purchase an aftermarket aluminum radiator overseas...
SPEED1/CORKSPORT...
Sleepin6 is offline
 Old 06-02-2016, 04:24 PM   #9
Sleepin6's Avatar
Default Valve size?
Can I get away with std size valves when going aftermarket? I only want to upgrade the metal material if I can for heat reasons and strength. What are the advantages of oversized valves if i have the stock cams anyway? Thanks.
SPEED1/CORKSPORT...
Sleepin6 is offline
 Old 06-02-2016, 04:57 PM   #10
mxlplx71's Avatar
Groans: 128
Aftermarket valves require valve seals and guides. Different diameter.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
mxlplx71 is offline
Sleepin6 (06-02-2016)
 Old 06-02-2016, 05:56 PM   #11
mxlplx71's Avatar
Groans: 128
Here's mine
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
mxlplx71 is offline
 Old 06-02-2016, 07:18 PM   #12
sheston's Avatar
Posts: 1,847   (View Stats)
That doesn't look like it works like much of a valve anymore. Did a piston hit it?
sheston is offline
 Old 06-02-2016, 07:51 PM   #13
Sleepin6's Avatar
Well the head shop said the guides needed to be replaced anyway so hopefully it works out. So supertech doesn't make oem size performance valves?
SPEED1/CORKSPORT...
Sleepin6 is offline
 Old 06-03-2016, 07:54 AM   #14
mxlplx71's Avatar
Groans: 128
i think it just melted there was no damage any place else.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
mxlplx71 is offline
 Old 06-03-2016, 08:49 AM   #15
Sleepin6's Avatar
My 2 exhaust valves in cyl 2 looked the same way.
SPEED1/CORKSPORT...
Sleepin6 is offline
 Old 09-10-2016, 10:34 PM   #16
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
So what did you use for replacement? I may be in the same boat.
I also want to go with stiffer valve springs, does anyone know the stiffness of the OEM valve springs?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
mituc is offline
 Old 09-10-2016, 11:14 PM   #17
shaneski's Avatar
Posts: 505   (View Stats)
The last post on the first page shows the stock valves are stiffer than the single spring rate of super techs, usually only need stiffer ones with a turbo that makes enough power to go over 7500rpm
Valve Spring Choices
I've been on stock valve train with my built set up for near 2 years and had zero issues
blackms3_71 and Sleepin6 like this.
shaneski is offline
The Following 2 Users Say Thank You to shaneski For This Useful Post:
mituc (09-11-2016), WetzMS3 (09-12-2016)
 Old 09-11-2016, 02:19 PM   #18
Sleepin6's Avatar
I went with supertech valves and kept everything else oem.
SPEED1/CORKSPORT...
Sleepin6 is offline
 Old 09-24-2016, 10:20 PM   #19
Sleepin6's Avatar
O yeah I forgot port an polished also.
SPEED1/CORKSPORT...
Sleepin6 is offline
Closed Thread
exhaust dump valve question tymoto21 MazdaSpeed 3 - Engine, Transmission & Driveline 9 11-14-2014 11:43 AM
another burnt valve thebestdj07 Mazdaspeed3/6 General Discussion 11 10-19-2014 05:56 PM
Intake and Exhaust Valve options JDMCRX MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-04-2014 08:04 AM
Head Rebuild and Valve clearance issues tkephart MazdaSpeed 6 - Engine, Transmission & Driveline 14 10-05-2012 12:46 PM
Page generated in 0.39473 seconds with 26 queries
