Like Tree92Likes
 Old 05-07-2014, 08:41 PM   #1
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
Default Captain kr's track build
So i have been amiss with all of my drama and bullshit going on. A couple months after 2013 Nator meet i got the great idea to spray 2 D012 nozzles of meth to supplement my fueling addiction. Needless to say i washed the cylinder walls and had low compression in 3 cylinders. I also had a couple of fan issues which leaded to a Blown headgasket and a bent ringland...... so i tore that bitch down and planned the following.......
Goals
150+ trap
Crazy E.T.
insane hp
10.6:1 pistons
h11 11mm studs
Arp Mains
Keyed Crank & Pinned Cams
stock HG
Manley I beams
Supertech +1mm intake and exhaust valves
Ported intake and exhaust ports with bowling
55lb spring with ti retainers
Web camshafts
I-Moto shift forks
06speed6 bearing caps
HTZ 6466
AEM 5 bar map sensor
Tial V-Band manifold if i can't sell this t4 tmt twinscroll mani
JMFab v2 intake manifold
4.5 maf housing with a 4 inch tip
SBFI 2200 CC injectors
Split Second Controller
3.5 dp tapering down before the ds tunnel
DSS Rear axles
ARP Wheel studs
RX-7 wheels with 26 inch Hoosier QTP
Carbon fiber pieces to lighten this pig up
RCI 5 gallon fuel cell
2x walbro inline pumps with a 1psi boost switch
Perm plate with dual ports
matt damon occ with vent kit
vented oil cap
TR1245
3 inch cold side piping with a 2.5 inch hot side and Tial Q
Ralco RZ short shifter with a 2 inch extension
Clutch Master Twin disk
battery relocated to the rear
JBR Trilogy set with a custom solid bushing for track events
Mazda5 alternator for ac delete
File Type: jpg 10349950_556962474424303_7121268685183446237_n.jpg (126.1 KB, 44 views)
File Type: jpg 10369193_556962487757635_7375059738132972141_n.jpg (109.4 KB, 43 views)
File Type: jpg 1536727_560448484075702_1535797172890751132_n.jpg (64.6 KB, 43 views)
File Type: jpg 10354758_560367170750500_8196284850271241629_n.jpg (67.1 KB, 41 views)
File Type: jpg 10363321_560374147416469_9074509331774613918_n.jpg (57.5 KB, 33 views)
File Type: jpg 10364216_558467517607132_5245433981514687860_n.jpg (74.8 KB, 38 views)
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
The Following 46 Users Say Thank You to Captain KR For This Useful Post:
2.0t03speed (05-08-2014), 6oost3d (05-08-2014), 802MS3 (05-09-2014), BobtailedSnail (05-08-2014), chaser27 (10-20-2014), Code Monkey (05-07-2014), daafisch (05-08-2014), dan7225 (05-08-2014), Darksun280 (05-10-2014), DaUberSchwebel (07-30-2014), derek13p (07-28-2014), doubleflusher (05-08-2014), Easter Bunny (05-07-2014), Etipp98 (05-07-2014), Haltech (05-08-2014), Hammology (05-10-2014), Hush (05-08-2014), impossible (05-19-2014), ItsNox (05-08-2014), jeopardy98 (11-21-2014), jkowalski (05-08-2014), jracer (05-11-2014), Jsn_Rob (07-26-2014), Koke382 (07-30-2014), Mazdazilla6 (05-08-2014), Micha (05-13-2014), ms3blackmica (05-08-2014), mtosofsky (05-07-2014), MZR801 (05-24-2014), Neverlift (05-10-2014), OsOlOcO (11-19-2014), predapio (05-08-2014), psychophyr (05-20-2014), Pu Manchu (05-11-2014), Realgib3 (05-09-2014), Rokusek (05-08-2014), Sid3wayS (05-07-2014), Snyeed (05-10-2014), SpeedRebirth (05-08-2014), Status Update (05-08-2014), taf0422 (05-08-2014), Tomas (07-30-2014), trancehead (05-08-2014), trini247 (05-08-2014), Vader (05-08-2014), WetzMS3 (05-07-2014)
The Following User Says NO Thank You to Captain KR For This Un-useful Post:
dooderek (05-08-2014)
 Old 05-07-2014, 08:48 PM   #2
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Sounds like a nice setup, nothing else trans related other than shift forks? Staying stock gearing?
Captain KR (05-07-2014)
 Old 05-07-2014, 08:53 PM   #3
Justin@Freektune's Avatar
Posts: 954   (View Stats)
I approve this message
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 7 Users Say Thank You to Justin@Freektune For This Useful Post:
BobtailedSnail (05-08-2014), Captain KR (05-07-2014), Easter Bunny (05-08-2014), impossible (05-19-2014), ItsNox (05-08-2014), LumberJack (05-08-2014), taf0422 (05-08-2014)
 Old 05-07-2014, 09:01 PM   #4
Captain KR's Avatar
Groans: 391
stock gearing is all i want/ need I strongly believe these gears are gold and will drive me where i need to be
Killah Built
The Following 6 Users Say Thank You to Captain KR For This Useful Post:
Easter Bunny (05-08-2014), Etipp98 (05-07-2014), impossible (05-19-2014), Justin@Freektune (05-08-2014), mtosofsky (05-07-2014), sho (05-09-2014)
 Old 05-08-2014, 08:12 AM   #5
Seems how you ran 11.2 with 500hp and all seasons. You should be good to kill it at the track with a real setup
PTE 6062
633HP/523TQ
Captain KR (05-08-2014), Easter Bunny (05-08-2014), Koke382 (07-30-2014), sho (05-09-2014)
 Old 05-08-2014, 08:14 AM   #6
5LOWMS6's Avatar
Posts: 1,088   (View Stats)
5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world
Groans: 46
Groaned at 37 Times in 19 Posts
Another monster ms6 :bigthumbsup:
06 Liquid Platinum GT
COBB AP // 3" ID MAF // 3" HTP TIP // Ebay catless DP // Autotech FPI // DO DVC-30 w/D07 // Grimmspeed EBCS // FORGE V1 BPV // DM OCC // JBR SSP|TIGs|EGR- // SURE RMM|Juggernaught // CP-E TMIC|Rear Diff Mount // Whiteline RSB // ISC N1 Coilovers // 18x8 +45 TSW Nurburgring
MisterSix Tuned..
vdyno: 287hp/335tq Uncorrected (2400ft ASL) 303hp/355tq Corrected
5LOWMS6 is offline   Reply With Quote
The Following User Says Thank You to 5LOWMS6 For This Useful Post:
 Old 05-08-2014, 08:23 AM   #7
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Im glad to see this moving in the right direction Will! Made me sad seeing you pull up in a minivan at ENM. Good luck with the rest of the build!
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 05-08-2014, 12:22 PM   #8
Captain KR's Avatar
Groans: 391
Bro i wanted to throw my purple slicks on the minivan. Would have been EPIC!
taf0422 likes this.
Killah Built
The Following 2 Users Say Thank You to Captain KR For This Useful Post:
Koke382 (07-30-2014), taf0422 (05-08-2014)
 Old 05-08-2014, 12:28 PM   #9
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
hopefully this one stays together =D
 Old 05-08-2014, 12:30 PM   #10
LumberJack's Avatar
Congrats Will, I also approve this message. Can't wait to see you wreck shop
10.36@148 Fastest Gen 2
 Old 05-08-2014, 12:31 PM   #11
Police - Grammarhead
Vansquish's Avatar
In for 13's.
Just kidding, good luck! I'm curious how much power you'll be able to manage on that high-compression motor before you start to have serious knock issues.
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
Captain KR (05-08-2014), chaser27 (10-20-2014), Easter Bunny (05-08-2014)
 Old 05-08-2014, 12:41 PM   #12
baileysms6's Avatar
Posts: 26   (View Stats)
baileysms6 is just really nicebaileysms6 is just really nicebaileysms6 is just really nicebaileysms6 is just really nicebaileysms6 is just really nice
Groaned at 4 Times in 1 Post
Would be happy to help when you need it ... just say the word.
2006 MazdaSpeed 6 Silver - Freek Built -- Tuned by Purple Drank
2014 Mazda CX-5 GT tech Daily
baileysms6 is offline   Reply With Quote
The Following User Says Thank You to baileysms6 For This Useful Post:
 Old 05-08-2014, 01:54 PM   #13
Rokusek's Avatar
Posts: 5,551   (View Stats)
OMG... Thats where you have been hiding you sick son of a bitch!!
-PJ
The Following 2 Users Say Thank You to Rokusek For This Useful Post:
Captain KR (05-08-2014), memin (05-08-2014)
 Old 05-08-2014, 03:34 PM   #14
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Hey Will glad to see you're still alive and on this side of steel bars.
Hope it all works out for you.
Knock'em dead kid.
What a lovable bunch we are!!
The Following 6 Users Say Thank You to predapio For This Useful Post:
BobtailedSnail (05-08-2014), Captain KR (05-08-2014), Darksun280 (05-10-2014), Easter Bunny (05-08-2014), Justin@Freektune (05-08-2014), Rokusek (05-09-2014)
 Old 05-08-2014, 03:44 PM   #15
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Out of all those parts he listed, it took him the longest to choose a turbo.
So I chose it for him.
www.tunedbynishan.com
The Following 18 Users Say Thank You to ms3blackmica For This Useful Post:
BobtailedSnail (05-08-2014), Captain KR (05-08-2014), daafisch (05-09-2014), derek13p (07-28-2014), doubleflusher (05-08-2014), Easter Bunny (05-08-2014), Hammology (05-10-2014), impossible (05-19-2014), ItsNox (05-09-2014), Justin@Freektune (05-08-2014), LumberJack (05-08-2014), Micha (05-13-2014), predapio (05-09-2014), psychophyr (05-20-2014), Realgib3 (05-09-2014), Rokusek (05-09-2014), SarcasticOne (05-08-2014), taf0422 (05-08-2014)
 Old 05-08-2014, 07:57 PM   #16
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
One word for this build...... NiggggaaaAUUUUUHHHHH!!!!
Also this chocolateer is the most indecisive person to talk to. 3.5" DP, 2200cc injectors, PI system layout, AEM 5 Bar Map, T-case bearing caps.....hmmmmmmmmm thieving @Captain KR;
Skreets be calling...
The Following User Says Thank You to BobtailedSnail For This Useful Post:
 Old 05-08-2014, 08:00 PM   #17
Captain KR's Avatar
Groans: 391
I will be addressing the power in increments and i do not want to overwhelm myself with power i will have 3 maps and the final map will be run on the slicks to make the E.T. stick..... I also have the perfect road to do test hits in my area to gain plenty of seat time prior to hitting whichever track event is rented out first. My greatest fear is complete drivetrain failure on the slicks but i am prepping for that with extra axles and replacement components. It is also another reason i went with the twin disk instead of a single disk puck clutch.
Nishan has made my mind in many ways as to how i am going to handle certain things. At the end of the day we decided 4 digits is not as important and putting up track numbers.
As many of you know i do not fear breaking and am used to failure but if i can fire off a single good pass and back it up that is all i need to do in order to finish out a track visit.
nindoja and ItsNox like this.
Killah Built
The Following 13 Users Say Thank You to Captain KR For This Useful Post:
baileysms6 (05-08-2014), BobtailedSnail (05-08-2014), daafisch (05-09-2014), Darksun280 (05-10-2014), Easter Bunny (05-08-2014), ItsNox (05-09-2014), Mauro_Penguin (05-09-2014), ms3blackmica (05-08-2014), OsOlOcO (11-19-2014), psychophyr (05-20-2014), Realgib3 (05-09-2014), SLOWHATCH (05-10-2014), taf0422 (05-09-2014)
 Old 05-08-2014, 08:06 PM   #18
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
What does your pile of parts trap?
Beanfab / Tuned by Nishan
The Following 12 Users Say Thank You to doubleflusher For This Useful Post:
BlackFlag (02-07-2015), ButtholeRedMS3 (08-11-2015), Captain KR (05-08-2014), Downmented (07-28-2014), Easter Bunny (05-08-2014), Hammology (05-10-2014), Justin@Freektune (05-09-2014), mzr0818 (08-01-2014), Neverlift (05-10-2014), predapio (05-09-2014), taf0422 (05-09-2014), UnknownSuperhero (07-30-2014)
 Old 05-08-2014, 08:07 PM   #19
Captain KR's Avatar
Groans: 391
150.06
doubleflusher and Fail_6 like this.
Killah Built
The Following 11 Users Say Thank You to Captain KR For This Useful Post:
ButtholeRedMS3 (08-11-2015), daafisch (05-09-2014), derek13p (07-28-2014), doubleflusher (05-08-2014), Easter Bunny (05-08-2014), Hammology (05-10-2014), impossible (02-02-2016), Justin@Freektune (05-09-2014), mzr0818 (08-01-2014), predapio (05-09-2014), taf0422 (05-09-2014)
 Old 05-08-2014, 08:09 PM   #20
Groans: 1,443
Rokusek likes this.
The Following 10 Users Say Thank You to doubleflusher For This Useful Post:
Captain KR (05-08-2014), derek13p (07-28-2014), Easter Bunny (05-09-2014), Hammology (05-10-2014), Justin@Freektune (05-09-2014), Koke382 (07-30-2014), Micha (05-13-2014), Rokusek (05-09-2014), taf0422 (05-09-2014), veezyweezy (07-28-2014)
 Old 05-08-2014, 08:10 PM   #21
What e.t. Does your trap run?
Captain KR (05-09-2014)
 Old 05-08-2014, 10:47 PM   #22
Finally you post up some details! I keep seeing you teasing shit on facebook and it's been driving me crazy. IMO stick with the t4 mani, twinscroll ftw!
I can't wait to see the numbers (power, 1320, and trap) you make! Best of luck and it's time that people see what speed6's can really do.
Also I've heard rumors that DSS made front axles for our car too so you may want to ring them up and ask about it.
Captain KR likes this.
Captain KR (05-09-2014), ItsNox (05-09-2014)
 Old 05-09-2014, 01:22 AM   #23
Captain KR's Avatar
Groans: 391
I appreciate the tip i will give them a ring about some axles.... the front ones i just bought are new so i shouldn't have any issue for a little bit. I preload the rear pretty heavy so i don't think i will have much issues with the front. Then again i said i wouldn't be building again so you never know what will happen at a higher hp and slicks. The wot box will help me build enough boost to spin off the line and i am foreseeing using 22-26 psi of air pressure in the tires. Avoiding the dead hook will be in my ability to control the clutch pedal and staying focused. I also plan hunting the track in the morning or on a cold day as a super sticky track will not be my friend.
With what I know now vs what I knew when the 11.2 pass went down I am confident that this will be pretty fucking epic. I just need to not think about money and keep moving my plans forward so i can do my part.
Killah Built
2.0t03speed (05-09-2014), blackmicamps6 (05-09-2014), Easter Bunny (05-09-2014), ItsNox (05-09-2014), Justin@Freektune (05-09-2014), Mauro_Penguin (05-09-2014), Mazdazilla6 (05-09-2014), Micha (05-13-2014), Realgib3 (05-09-2014), Rokusek (05-09-2014), SarcasticOne (05-09-2014)
 Old 05-09-2014, 08:11 AM   #24
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
Good luck with your build and thank you for pushing this platform.
417whp 428tq 12.037@117.2mph
 Old 05-10-2014, 04:25 PM   #25
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Best of luck with your future fail Will.
Past Mazdas & Speeds
ButtholeRedMS3 (08-11-2015), Easter Bunny (05-11-2014)
 Old 05-10-2014, 05:32 PM   #26
Nishan
That has nothing to do with being indecisive.
He straight up needs those.
Easter Bunny (05-11-2014), ItsNox (05-11-2014), Micha (05-13-2014)
 Old 05-10-2014, 09:16 PM   #27
That last part was of mods was reference towards Will thieving off our discussions, not him being indecisive. Lol
 Old 05-10-2014, 10:46 PM   #28
Captain KR's Avatar
Groans: 391
Killah Built
BobtailedSnail (05-11-2014), Easter Bunny (05-11-2014), Hammology (05-10-2014), ItsNox (05-11-2014), Micha (05-13-2014), predapio (05-11-2014)
 Old 05-11-2014, 05:22 AM   #29
predapio's Avatar
Groans: 309
Will's Ebonics translation
Woman, you know you want my testicles in your mouth. Are you inferring that my methods of masturbation are not superior to yours? I'll have you know that my methods are better than any masturbatory dream that you've ever had. You weak lightweight.
Still doesn't make sense to me though...
The Following 16 Users Say Thank You to predapio For This Useful Post:
baileysms6 (05-11-2014), ButtholeRedMS3 (08-11-2015), Captain KR (05-11-2014), Easter Bunny (05-11-2014), Etipp98 (05-11-2014), ItsNox (05-11-2014), LumberJack (05-14-2014), magicka (05-11-2014), maisonvi (05-11-2014), memin (05-11-2014), Micha (05-13-2014), ms3blackmica (05-11-2014), OsOlOcO (11-19-2014), sho (05-11-2014), sidekick (06-04-2014), taf0422 (05-11-2014)
 Old 05-11-2014, 09:35 AM   #30
Nah homie don't be steal my terms, you didn't know stroke game til I whipped you like Massa would have. Do I need to post vids!??
The Following 3 Users Say Thank You to BobtailedSnail For This Useful Post:
Captain KR (05-11-2014), Easter Bunny (05-11-2014), sidekick (06-04-2014)
 Old 05-13-2014, 11:01 PM   #31
Captain KR's Avatar
Groans: 391
Spent time with my bae today..... god damn i fucking miss her so much....LE SIGH .... i ordered the twin gates, my mounts, TR 1245, and my joe's racing Battery cut off switch.
Killah Built
The Following 8 Users Say Thank You to Captain KR For This Useful Post:
BobtailedSnail (05-14-2014), Easter Bunny (05-14-2014), impossible (05-19-2014), Little John (05-14-2014), Mazdazilla6 (05-13-2014), Micha (05-13-2014), ms3blackmica (05-13-2014), Realgib3 (05-14-2014)
 Old 05-13-2014, 11:58 PM   #32
Nishan
Damn girl can I get yo numba
The Following 5 Users Say Thank You to ms3blackmica For This Useful Post:
Captain KR (05-14-2014), Easter Bunny (05-14-2014), LumberJack (05-14-2014), Micha (05-14-2014), Realgib3 (05-14-2014)
 Old 05-20-2014, 04:18 PM   #33
Captain KR's Avatar
Groans: 391
Parts porn!!!! Soon bae soon
baileysms6, Rokusek and jkowalski like this.
Killah Built
The Following 9 Users Say Thank You to Captain KR For This Useful Post:
5LOWMS6 (05-20-2014), BobtailedSnail (05-21-2014), doubleflusher (05-21-2014), Easter Bunny (05-20-2014), Mazdazilla6 (06-04-2014), Micha (05-27-2014), ms3blackmica (05-20-2014), Rokusek (05-20-2014), SpeedRebirth (05-20-2014)
 Old 05-20-2014, 05:56 PM   #34
Not sure if small child or large inter cooler.
The Following 5 Users Say Thank You to Easter Bunny For This Useful Post:
BlackFlag (02-07-2015), BrianB6 (05-28-2014), Captain KR (05-20-2014), Code Monkey (05-20-2014), ItsNox (05-21-2014)
 Old 05-20-2014, 08:41 PM   #35
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
Making moves! Looks awesome Will. Get this shit together man! See you at the track
2006 Mazdaspeed6 GT BCM
SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors
Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP
HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM
Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate
Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN
psychophyr is offline   Reply With Quote
The Following 2 Users Say Thank You to psychophyr For This Useful Post:
Captain KR (05-20-2014), ms3blackmica (05-20-2014)
 Old 05-21-2014, 05:48 PM   #36
jkowalski's Avatar
Posts: 289   (View Stats)
jkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the world
William my welder has been sitting in the shed collecting dust hurry up and let's get started
2010 Speed3 35r 12.404@120 sold
2014 camaro 1SS 1LE 12.22@115 also sold
2015 Mazda 6 stock ass daily
jkowalski is offline   Reply With Quote
The Following 5 Users Say Thank You to jkowalski For This Useful Post:
BobtailedSnail (05-21-2014), Captain KR (05-21-2014), Easter Bunny (06-04-2014), Micha (05-27-2014), ms3blackmica (05-26-2014)
 Old 06-04-2014, 07:38 AM   #37
Captain KR's Avatar
Groans: 391
I bought a turbo from @EdgeAutosport.com; talked to some dude named jp. I dont know if i like him as a person i kept getting this rapey vibe the longer i talked to him. He is my man though and i honestly dont think i would purchase anything from anyone else.
2.0t03speed, LumberJack and ItsNox like this.
Killah Built
2.0t03speed (06-04-2014), BobtailedSnail (06-04-2014), ButtholeRedMS3 (08-11-2015), Easter Bunny (06-04-2014), ItsNox (06-04-2014), Realgib3 (06-04-2014)
 Old 06-04-2014, 02:40 PM   #38
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
Let me know how you like that Fp 6466! Hope you get the speed6 record aswell! Looks like i need to do some changes because i feel slow now with all of these legit high hp (over 600+whp) builds going on. I need to talk to @Darksun280; and find out where yall gonna stay up here on Mount Olympus.
2006 Evolution IX RS
ER Built 2.3l
On jackstands
awaiting parts
surebOOst is offline   Reply With Quote
The Following 3 Users Say Thank You to surebOOst For This Useful Post:
Captain KR (06-04-2014), h.h.sk1nny (06-04-2014), Realgib3 (06-04-2014)
 Old 06-04-2014, 05:55 PM   #39
Captain KR's Avatar
Groans: 391
I actually ended up getting a pte gen2 6466. I cant wait to rip this bish around.
Killah Built
The Following 3 Users Say Thank You to Captain KR For This Useful Post:
2.0t03speed (07-10-2014), psychophyr (06-04-2014), Realgib3 (06-04-2014)
 Old 06-04-2014, 11:56 PM   #40
That's a clean ass wrap job! Only doing the trunk?
Captain KR (06-05-2014)
Captain KR's build thread Captain KR Mazda MZR DISI Engine Builds (2006-2013) 28 04-17-2013 08:41 AM
Video: A woman shows you how to build a proper circle track racer Haltech Automotive News 0 06-01-2011 05:50 PM
Porsche to relocate U.S. headquarters to ex-Ford facility, plans to build track Haltech Automotive News 0 05-11-2011 09:50 AM
Corvette Museum wants to build race track across the highway Haltech Automotive News 0 04-27-2010 03:00 PM
Volkswagen to build test track at Chattanooga plant Haltech Automotive News 0 10-22-2008 04:10 PM
Page generated in 0.60969 seconds with 41 queries
