  • 2 Post By Ziggo
 Old 01-23-2013, 07:26 PM   #1
Ziggo's Avatar
Posts: 3,843   (View Stats)
Default Compression Ratio Calculator
Change pistons? Get an overbore? Have the block & head machined flat? Get a thicker headgasket?
Use the handy dandy ziggy compression ratio calculation spreadsheet to see the overall effect on the static compression ratio of your motor!
Livingframe and rfinkle2 like this.
Ask Me About My:
The Following 13 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (01-23-2013), ButtholeRedMS3 (01-09-2016), Code Monkey (10-13-2014), Enki (01-15-2016), Livingframe (06-20-2015), magicka (01-24-2013), ms3blackmica (04-24-2013), phate (01-23-2013), rfinkle2 (01-23-2013), SarcasticOne (01-24-2013), skeurton (01-24-2013), Speed3eak (01-23-2013), SPEED6 KILLAH (01-28-2013)
 Old 01-23-2013, 07:30 PM   #2
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Is it too early to say sticky?
 Old 01-23-2013, 07:38 PM   #3
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
I'm a sucker for a good spreadsheet
 Old 01-23-2013, 07:40 PM   #4
Ziggo's Avatar
Too late technically. Though sticking my own thread does make me feel a little dirty, a bit masturbatory IMO.
Ask Me About My:
Arnie1229 (01-16-2015), ASHMS3 (02-06-2013)
 Old 10-13-2014, 11:14 AM   #5
Mazdaspeedin's Avatar
Posts: 31   (View Stats)
Mazdaspeedin is a glorious beacon of lightMazdaspeedin is a glorious beacon of lightMazdaspeedin is a glorious beacon of lightMazdaspeedin is a glorious beacon of lightMazdaspeedin is a glorious beacon of light
Groaned at 5 Times in 1 Post
Has anyone ever stroked a 2.3 disi mzr before? Using a 2.5 crankshaft.
More power by the hour!
Mazdaspeedin is offline   Reply With Quote
 Old 10-13-2014, 05:30 PM   #6
Ozynigma's Avatar
Posts: 743   (View Stats)
From my casual reading on this forum I seem to recall the bearing shells are different widths on the DISI and NA motors. So no.
Turbo calculator ? x09MS3GT MazdaSpeed 3/6 - Turbo Induction 1 01-11-2013 07:45 PM
Wideband Air/Fuel Ratio Gauge vs. Narrowband Air/Fuel Ratio Gauge aggierandy 2010 MS3 - ECU Computer Tuning 3 01-05-2013 12:50 AM
best compression ratio? LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 11 12-28-2010 11:27 PM
TURBO CALCULATOR!!! superskaterxes Mazdaspeed3/6 General Discussion 10 04-19-2009 09:10 AM
Page generated in 0.27492 seconds with 25 queries
