(Thread Starter) | Not Ranked : 0 score So I knew I would approach a "build" like this for some time. I am not going for major HP or fame just want to keep my motor together for DD duties at 400-450WHP. Keeping it fun and on the edge of a true DD which mine currently is. I would like to thank Tom @MS3-a(sore)ASS-rex, for even giving me the idea to do something like this. I haven't put a motor together since my 302 back ...well in the early 80's for god sake...lol Also want to thank a couple of the MSF pioneers in this area @chimmike and @Tomas for their contribution to this type of build. I suspect it will become extremely common for those wanting a lil insurance by adding some forged internals to their DD and I know a few other drop-ins are under way or in the planning stages like this one. Only time will tell how successful this will be but of course other platforms have been doing it for ages so how hard can it be cough subie cough 99.5 drop ins for example..some of those guys don't even measure the bores for god sake...I call it poke and hope.I wasn't in any particular hurry and thought my tune would keep things together but recently my motor had other plans and is likely an outlier as to how it decided to..well perform less than optimally. Long story short, I believe I have lost a ringland in the #3 cylinder with the details being discussed here: How bad is this-Oil everywhere So I already knew some of what I would need and so had a small list compiled of the following: Wiseco pistons and their brother's K1 rods I am also running OE VVT from 07 so I will replace all the timing stuff..including washers and bolts for cams and crank. ARP head studs the rest is all Mazda OEM stuff and I will compile and entire list as I go. a shout out to @silvapain for his spreadsheet of OE parts and @phate for linking me to it. I have access to quite a bit of cool measuring equip from my rat scoobie buddy who is about to build his motor such as a bore gauge, digital calipers, mic, fixed hones, etc. so I should be prepared. I do plan to measure the bores and crank pins and if things are too far out...well depending on how far, I will pull the motor, send my Wiseco's back and maybe get some angry HCR pistons just b/c my motor hates me...gotta get even right? anyway...that's all for now I'll update as things progress. oh I did get these today complements of @eric@edgeautosport cheap scale but they all weigh the same...pistons, pins and clips they are not near as cool as Dan and Clints huh? Build Tolerance Specs: Updated as the build progresses Wiseco OE spec piston: PWC .0025 [I will target .0025 but if it gets out to .0030 I will live with it] K1 Rod w ARP 2000: Torque to 25ft/lbs + 55* Specialty Tools: Updated as the build progresses Cam timing tools - Silvapain Torque wrench [inch & ft lbs] - owned Angle Gauge - Amazon Search 87.5mm ARP ring compressor ARP 901-8750 ARP Ring Compressors Flex-Hone 89mm 320 grit - Amazon Search Plateau Brush 3" - 3-1/2" Plateau Brush Explanation: Plateau Cylinder Bore Finishes Lubes and Fluids: Lucas assembly lube 4oz Lucas Oil 10152 Lucas Oil Assembly Lube Lucas 30wt Break-in Oil 5qt Lucas Oil 10631 Lucas Oil High Zinc Engine Break-In Oils + 1qt of any 30wt dino oil ATF for cylinder honing and wall cleaning/lubing for fast breakin 10/20/12 Update: so before I was forced down the road of a build I wanted to find out just how much oil pressure there is at our turbo feed outlet in the block. I wanted to be able to measure pressure in 3 different configurations. 1) restricted to turbo and guage 2) unrestricted to turbo and gauge 3) unrestricted to gauge and restricted to turbo. This allows me to monitor oil pressure for the experiment and keep a gauge connected afterward. I realize this may not be the best source of a pressure reading but as long as I have a baseline of now and after the motor is built I don't think it matters much. Anyway, I put together a list of what I would need to accomplish this with some help from @Celestspeed3 Edit: 10/31/12 Updated graphic to include hose length modifications and additional fittings. Parts links 4 An to M12x1 5 Straight Adapter Saab Volvo TD04L 1 5mm Oil Restrictor | eBay Earl's 921104 Earl's Specialty Fittings P.T.F.E.-Lined Stainless Steel Hose JEGS Performance Products 100531 JEGS Fuel Pressure Gauge In-Line Adapter Fittings Earl's 924104 Earl's Specialty Fittings I may drill this 1.5mm fitting out so there is zero restriction. This way is cheaper than getting a $19 ATP open bolt. Turbo Oil Feed Banjo Bolt Kit Garrett T25 T28 TB25 TB28 Journal Bearing | eBay 1mm restrictor banjo which is ~.040 - not quite as small as an ATP .035 but this is not rocket science. Turbo Oil Feed Banjo Bolt Kit Garrett GT2871R GT2876R GT3071R Ball Bearing | eBay I am going to get under the car today and get measurements to confirm my gestimates on SS line length and will update if necessary. Pulled my belt tensioner off and inspected the area and everything should work as designed. 10/26/12 Update More parts and tools acquired today: 11/21/12 Update Job costing spreadsheet uploaded.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 03-13-2013 at 10:35 AM. Reason: Gross mission creep in here |
| The Following 55 Users Say Thank You to Dano For This Useful Post: | 802MS3 (10-17-2012), 86AmishMs3 (10-21-2012), ASHMS3 (10-17-2012), atvfreek (10-17-2012), BlueStreak (10-17-2012), breakfasteatre (01-09-2013), btstarcher (10-18-2012), charlesfist (10-18-2012), Chimmike (10-17-2012), Ckmazdaspeed3 (03-30-2013), darkstar5440 (08-02-2014), djuosnteisn (10-17-2012), Downmented (10-17-2012), Easter Bunny (10-18-2012), EdgeAutosport.com (10-18-2012), eljefe62 (01-09-2013), El_Diablo (12-13-2013), fredricktsang (10-18-2012), helmetface (10-17-2012), IshiKage (10-21-2012), Jay@posifab.com (10-25-2012), jman46 (10-17-2012), jracer (10-18-2012), JTMS3 (11-07-2012), kylec_2003 (11-08-2012), leon78 (10-18-2012), Lex (10-26-2012), magicka (12-07-2012), Micha (02-07-2013), Monotonous ONE (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), Neverlift (10-18-2012), NJSPEED3 (10-18-2012), phate (10-17-2012), Pointless (10-17-2012), rfinkle2 (10-18-2012), rghispanic88 (10-17-2012), RichieRichness (10-19-2012), robry (11-06-2012), Roddiy (10-26-2012), silvapain (10-18-2012), SilverDemon (10-17-2012), snailD (11-10-2012), Snyeed (10-17-2012), speed14 (10-17-2012), speedms6 (10-17-2012), speed_freak91 (10-18-2012), statesm (10-23-2012), TiGraySpeed6 (10-17-2012), Tokay444 (10-17-2012), Tomas (10-17-2012), torquemaniac (11-09-2015), uncorked11 (10-19-2012), WetzMS3 (01-12-2015), Ziggo (01-23-2013) |
| Not Ranked : 0 score Glad to see that you have access to the proper measuring equipment. That' my biggest fear with drop in builds, I think you'll be fine. I used those same Wiseco's on the gray 6 and it runs like a champ. I'll be following along
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score <- raging boner
__________________ |
| The Following User Says Thank You to helmetface For This Useful Post: | Dano (10-17-2012) |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score my time is coming...
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | Dano (10-17-2012), MS3-a(sore)ASS-rex (10-18-2012) |
(Thread Starter) | Not Ranked : 0 score hahah you're a young guy right...dick gets hard when the wind blows...ah...those days...lol j/k man...I can't wait until my rods get here...<------see what I did there? ...says Mr. Consumption...Mr Oil Consumption...
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 10-17-2012 at 06:33 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 3780 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,647
Groans: 493
| Not Ranked : 0 score Dope, im glad to see more of these popping up. Subbd for results. Good luck Sent from my GT-P3113 using Tapatalk 2
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! |
| The Following User Says Thank You to Downmented For This Useful Post: | Dano (10-17-2012) |
Groans: 793
| Not Ranked : 0 score yup. don't want to face it, but there is no choice. i may as well go bnr while i'm at it.
| The Following 5 Users Say Thank You to Tokay444 For This Useful Post: | Celestspeed3 (10-19-2012), Dano (10-17-2012), helmetface (10-17-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012) |
Groans: 433
| Not Ranked : 0 score Do it to it! Mine's still running great! Sent from my iPhone your mom's face
| The Following 4 Users Say Thank You to Chimmike For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score BTW. talked to Andy at Wiseco today and he says the PWC is already built into their drop-in pistons and indicated I only needed a .0025 PWC measured at the skirt for turbo induction...that sounds tight to me. I do know Manley and Wiseco's for the scoobies at 99.5 call for .0035 what say the experts? @phate @silvapain @Tomas @djuosnteisn @SPEED6 KILLAH
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following 2 Users Say Thank You to phate For This Useful Post: | Dano (10-17-2012), djuosnteisn (10-18-2012) |
(Thread Starter) | Not Ranked : 0 score I thought as much. no sheet came with the pistons.
| The Following User Says Thank You to Dano For This Useful Post: | djuosnteisn (10-18-2012) |
| Not Ranked : 0 score So I was thinking about my new pistons when I said .0035....I think I still have the sheet for those same pistons you have, let me go check.
(Thread Starter) | Not Ranked : 0 score the sheet that came with Pablo's pistons, in silvapain's thread, say .0035 Stated at the top of the piston pic I think ring gaps will be different with the HCR pistons but I can't believe the PWC would be.
| Not Ranked : 0 score This sheet is the spec for standard bore pistons exactly like yours Dano. They're what I used in the gray 6's engine. .0030" PWC
| The Following 5 Users Say Thank You to phate For This Useful Post: | atvfreek (10-17-2012), charlesfist (10-18-2012), Dano (10-17-2012), djuosnteisn (10-18-2012), rfinkle2 (10-18-2012) |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Good luck Mr. Dano, I see something like this in my future. Defiantly keep this thread updated.
__________________ 417whp 428tq 12.037@117.2mph |
| The Following 2 Users Say Thank You to Snyeed For This Useful Post: | Dano (10-17-2012), sleepyspeed6 (10-18-2012) |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
If I had to choose between honing the liners a further 0.001" afer a light hone to bring the PWC from 0.0025 to 0.0035 and leaving it a 0.0025 I would leave it. Honing that 0.02mm by hand with a drill or whatever won't be very accurate. Better just leave it alone before you fuck up something. That's just my opinion. Picking up that 0.02mm difference in the bore is already hard enough with gauges going only 2 metric decimals.
__________________ | |
| The Following 6 Users Say Thank You to Tomas For This Useful Post: | charlesfist (10-18-2012), Dano (10-17-2012), djuosnteisn (10-18-2012), Easter Bunny (10-18-2012), silvapain (10-18-2012), Tokay444 (10-17-2012) |
| Not Ranked : 0 score Love it! I will be tuned in as well.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 2 Users Say Thank You to atvfreek For This Useful Post: | Dano (10-17-2012), MS3-a(sore)ASS-rex (10-18-2012) |
he does have a super fly adjustable fixed hone but I wouldn't even consider doing that with a drop in. to much lubricant pouring over the crank for a clean install.
BTW did any of the drop in guys even measure what the PWC is on a motor with wear? I am thinking it would be on the big side but really have no idea. Edit: oh and @Tomas...me an my buddy ruined his case halves...lol went too far with the honing trying to remove taper and out of roundness...like you say...it is a bitch with hand held tools. here's the hone.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 10-17-2012 at 07:25 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following 4 Users Say Thank You to Dano For This Useful Post: |
![]() | | #19 | ![]() |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
| Not Ranked : 0 score Which piston are you running custom?
__________________ [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to SPEED6 KILLAH For This Useful Post: | Dano (10-17-2012) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score nah...just OE 9.5.1 std bore K640M875
![]() | | #21 | ![]() |
| Not Ranked : 0 score Okay I'll go with .0025 nice and tight there a reason behind it..
| The Following 4 Users Say Thank You to SPEED6 KILLAH For This Useful Post: |
![]() | | #22 | ![]() |
skirt coating will wear off ?
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
![]() | | #23 | ![]() |
| Not Ranked : 0 score good luck with the build! I'm looking forward to watching this one
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Dano (10-17-2012) |
![]() | | #24 | ![]() |
I know all about that.
And that hone you posted earlier, it's heavy enough to bend the shit out of the oil squirters. Make sure you put some masking tape on the shaft to mark how deep you can go before colliding with the tubes. Edit: hmmm. I think you are gonna have to bend the oil squirters anyway but that does not mean you should do it by slamming the honing stones on them. lol
__________________ | ||
| The Following 6 Users Say Thank You to Tomas For This Useful Post: | charlesfist (10-18-2012), Dano (10-17-2012), djuosnteisn (10-18-2012), phate (10-17-2012), rfinkle2 (10-18-2012), Tokay444 (10-18-2012) |
![]() | | #25 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score Good luck with the build @Dano. Would you mind linking the referenced spreadsheet here for the rest of us? Thanks!!!
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #26 | ![]() |
not that it is a bad hone...it will def take some material off quickly but you have to pay attention and step down to the clearance you want. I now think of it more like a hand held boring tool ![]() kinda like Wiseco says... • Install and torque main bearing caps • Use torque plates. This simulates the distortion that occurs when the cylinder head is mounted to the block. (hint: After boring and honing, leave the torque plates in place and fit/gap the piston rings to their respective cylinders.) • Allow for a minimum of .003" excess material for use as honing stock. • Intermediate hone to within .0005" of finished size with #220-#280 grit stones. (With diamond stones use #280-#400 grit.) • Finish hone with #400 grit stone or higher. (Use #600 grit diamond stone. If using hand operated equipment, set drill speed between 200-450 rpm.) • Finish with an appropriate stone or tool to achieve desired plateau finish (see below). I will use a brush hone and put an exact 20-25* cross hatch in that bitch. ...or at least that is my plan for now and I am all ears to any better ideas. ![]() Fallopian tubes..ok never thought about that....
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 10-17-2012 at 11:32 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #27 | ![]() |
Groans: 224
| Not Ranked : 0 score Good luck Dano. I can't wait for another one of these swaps to be successful! I've been trying to start my own build but my car has been very uncooperative.
| The Following 4 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post: |
![]() | | #28 | ![]() |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score Same here. 0.0035" PWC on my sheet. My machinist said my new block was dead-on with the PWC clearance, and he didn't have to hone/bore it at all. Wiseco knew my block was brand new when they made the pistons.
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), djuosnteisn (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012) |
![]() | | #29 | ![]() |
Groans: 136
| Not Ranked : 0 score @Dano, when you time the engine, be sure to double-check #1 TDC; don't trust the crank locking pin stuck in the side of the block. I don't know if you saw the MCY degree wheel in my build thread, and how far the pin was off TDC (~7°).
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | charlesfist (10-18-2012), Dano (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), NJSPEED3 (11-11-2012), rfinkle2 (10-18-2012) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Over my head, but rootin' for you nonetheless. You are going to run the 3071 with this fresh engine? |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Dano (10-18-2012) |
![]() | | #31 | ![]() |
![]() I mean it will make a great turbo for someone else just not me....that chapter is closed.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 10-18-2012 at 09:10 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #32 | ![]() |
Wiseco and Pablo both state .0025 for the OE spec pistons Phate's sheet from Wiseco states .0030 for the OE spec pistons SilvaPain is running HCR pistons which could generate more heat and so they are speced at .0035 my plan will be to target .0025 and if it is as big as .0030 I will live with it. Some piston slap, if it would even occur, never killed anyone. OP updated with this information.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |||
| The Following 7 Users Say Thank You to Dano For This Useful Post: | atvfreek (10-18-2012), djuosnteisn (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), NJSPEED3 (11-11-2012), phate (10-18-2012), silvapain (10-18-2012), SPEED6 KILLAH (10-18-2012) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score It's really easy, lol. I now have a real degree wheel and TDC stop if you would like to borrow it.
| The Following 5 Users Say Thank You to phate For This Useful Post: | charlesfist (10-18-2012), Dano (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012), silvapain (10-18-2012) |
![]() | | #34 | ![]() |
Groans: 136
Once you have the head on and bolted down, get an long M14 x 1.25 bolt and thread it down into the #1 plug well. No need to torque it down; just thread it in by hand. Put the degree wheel on a use a coat hanger or welding wire to be a pointer for the wheel; we used a coat hanger wrapped around the bolts for the alternator. Then rotate the crank very slowly until the piston just touches the bolt, and mark the wheel. Then rotate the crank in the opposite direction until the piston just touches the bolt again, and mark that point. You will end up with to markings at different places on the wheel. Then split the angle between the two in half, and that's TDC. Take the bolt out and rotate the crank until the pointer hits the TDC line, and you're at TDC for piston #1 . P.S. You let me know when you want to sell me that GT28
| The Following 8 Users Say Thank You to silvapain For This Useful Post: | atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), kritz (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), phate (10-18-2012), rfinkle2 (10-18-2012), TiGraySpeed6 (10-18-2012) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score I want to come down to Ill. and learn how to build an engine for chrissake. All of this TDC pin talk and degree wheels has me feeling a dunce. I'm half tempted to blow my own shit up so I have to learn to build a motor. |
| The Following 14 Users Say Thank You to rfinkle2 For This Useful Post: | atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), jracer (10-18-2012), kritz (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), ms3blackmica (11-04-2012), NJSPEED3 (11-11-2012), phate (10-18-2012), skeurton (10-18-2012), taf0422 (10-19-2012), TiGraySpeed6 (10-18-2012), Tokay444 (10-18-2012), uncorked11 (10-19-2012) |
![]() | | #36 | ![]() |
Groans: 136
| Not Ranked : 0 score You come down here and help me vinyl wrap my car and we have a deal.
| The Following 10 Users Say Thank You to silvapain For This Useful Post: | atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), Easter Bunny (10-18-2012), jracer (10-18-2012), kritz (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), NJSPEED3 (11-11-2012), rfinkle2 (10-18-2012), SofaKingAwesome (11-08-2012) |
![]() | | #37 | ![]() |
DJ has one too so I should be able to get one somewhere on here. Maybe I'll just buy one IDK. Tappin
![]() | | #38 | ![]() |
Groans: 136
| Not Ranked : 0 score I have a full timing tool kit I can mail down to you. I just need it back in time for Clint's engine build.
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | charlesfist (10-18-2012), Dano (10-18-2012), djuosnteisn (10-18-2012), MS3-a(sore)ASS-rex (10-18-2012), rfinkle2 (10-18-2012), SPEED6 KILLAH (10-18-2012) |
![]() | | #39 | ![]() |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
| Not Ranked : 0 score Gold?
__________________ Damond Built Speed 6 |
| The Following User Says Thank You to Deldran For This Useful Post: | silvapain (10-18-2012) |
![]() | | #40 | ![]() |
Groans: 224
| Not Ranked : 0 score I will gladly trade engines with you if you're really feeling that intrigued....lol
| The Following 10 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post: | amoosenamedhank (10-18-2012), atvfreek (10-18-2012), charlesfist (10-18-2012), Dano (10-18-2012), djuosnteisn (10-18-2012), Easter Bunny (10-18-2012), rfinkle2 (10-18-2012), silvapain (10-18-2012), SofaKingAwesome (11-08-2012), SPEED6 KILLAH (10-18-2012) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f658/fail-formerly-known-dano-s-drop-build-127709/ | ||||
| The Antique Outboard Motor Club Forums - 1960 evinrude 10hp parts swap? | This thread | Refback | 11-01-2013 05:11 AM | |
| Tuoreimmat viestit | This thread | Refback | 12-09-2012 11:00 AM | |
| Mazda 3 MPS | This thread | Refback | 12-09-2012 10:46 AM | |
| Dano's Koni FSD install | Dano | MazdaSpeed 3 - How-To's | 64 | 03-03-2015 12:49 PM |
| My Pop 'n drop build | Chimmike | Mazda MZR DISI Engine Builds (2006-2013) | 381 | 11-10-2013 06:51 PM |
| Dano's Boost Tuning 101 + Cool Stuff | Dano | MSF KB - Mazdaspeed 3/6 - ECU Computer Tuning | 1512 | 09-20-2012 06:47 AM |
| 2010 MS3 Build, please drop your 2 cents in! | randino69 | 2010 MS3 - Build Diaries | 17 | 03-26-2012 10:19 PM |
| Dano's SS Exmani install | Dano | MazdaSpeed 3 - How-To's | 18 | 11-12-2010 10:38 PM |
