  • 1 Post By Tokay444
 Old 06-22-2016, 01:51 AM   #1
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Default Final decision on headstud arguement
So I'm in the process of rebuilding a side motor to swap in, and I've been doing tons of research on like everything, pistons, rods.. all that shit. And I thought I had it figured out with the headstuds. Replace them but avoid arp2000's because people lifted heads. L19/H11 was the way to go until the CA 625's showed up. So that's what I've did, I bought the CA625's.
Just a while ago I was having a discussion with another guy that's building a motor and had bought the ARP2000's. I was like whoa man, from what I've gathered those things give out and lift the head, go with the CA625's.
And as I went through some old MSF threads to show him about it, I really began to see people talking about it's not necessarily the studs/bolts but the Tq being used on them. Then I saw people putting over 500+ whp on stock bolts! I saw the difference in tinsel strength's, so my question is this...
Are there whp values that hit a point that say, up to xxx whp you can use stock head bolts
up to xxx whp use arp 2000's
up to xxx whp use L19/H11/CA625's?
I'm trying to find this sort of info, because if I can, id just like to sell these CA625's and go stock because it's like 60 bucks vs 300... And my goals are around 500+/- whp
MY view on head studs for the MZR
I looked at this thread, but are those numbers for whp accurate? Up to 620whp for stock headbolts?
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 06-24-2016, 07:02 AM   #2
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
if you want to do 500+ stick with the better studs.... its not worth risking it at that power level. stay away from arp 2000.
Easter Bunny (06-30-2016)
 Old 06-25-2016, 04:11 PM   #3
HaXiR's Avatar
Yeah I read about the arp 2000's, just thinking it may save a lot of money using stock head bolts if they can handle 500 whp, and by the looks of it they can?
Current:
 Old 06-30-2016, 12:05 PM   #4
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Some say the ARP2000s are not better than the OEMs. They are a little bit more rigid but less elastic and when they elongate you're done.
So go with L19 or whatever is better.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 06-30-2016, 12:09 PM   #5
HaXiR's Avatar
I have the custom age 625's. The debate is stock head bolts vs. these CA625 studs. DO I really need them if my power will be max around 500 +/-
Current:
 Old 06-27-2016, 09:16 AM   #6
Daily Driver
Nitr0EngiE's Avatar
bro this is what your saying, let me translate....
"I am willing to spend 6k building the engine and stuff, but when it comes to head studs I want to save 200$ and risk having problems"
just saying
 Old 06-27-2016, 11:14 AM   #7
HaXiR's Avatar
just saying
Ya I get what you're saying, but I mean, If it doesn't NEED it, and these head bolts have proven to hold big power, WHY spend the money?
Current:
 Old 06-27-2016, 11:23 AM   #8
Daily Driver
Nitr0EngiE's Avatar
because there is doubt its called piece of mind
The Following 4 Users Say Thank You to Nitr0EngiE For This Useful Post:
Code Monkey (06-27-2016), Easter Bunny (06-30-2016), Mauro_Penguin (07-05-2016), pharaoh313 (06-27-2016)
 Old 06-30-2016, 01:27 PM   #9
mituc's Avatar
Groans: 111
Man, what can I say... the debate on the head studs had a pretty clear outcome. I'm not saying you should do as people suggested here, I'm sure there are other options as well (more or less tested), but in the end it's your decision.
 Old 06-30-2016, 01:30 PM   #10
For $240 bucks i would not want to be so close to the limit.
I would only use stock head bolts if you expected to stay medium turbo and around 400-430 hp.
 Old 06-30-2016, 08:12 PM   #11
HaXiR's Avatar
I suppose that's a valid point... guess I'll just stick with the CA's..
Current:
 Old 07-01-2016, 05:13 AM   #12
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
It's less about the material and more about that torquing technique.
WetzMS3 likes this.
"Exclusivity" - CP-enis
Demodded.
The Seals
Mauro_Penguin (07-05-2016), WetzMS3 (07-01-2016)
 Old 07-03-2016, 06:48 PM   #13
HaXiR's Avatar
Is there a special way of torqueing these CA625's down, or is it like others and do 20/40/60 in the proper order
Current:
 Old 07-03-2016, 07:12 PM   #14
Tokay444's Avatar
Groans: 793
No one knows. The one tried tested and true method is stock screws with oem torquing procedure.
Demodded.
The Seals
Final decision on Toyota/BMW sports car due by year end Haltech Automotive News 0 09-18-2015 07:00 AM
Final Toledo Jeep decision may have nothing to do with city's efforts Haltech Automotive News 0 04-13-2015 02:00 PM
Final dealer arbitration case today; final rulings due within 10 days Haltech Automotive News 0 07-14-2010 01:30 PM
Henderson says GM bankruptcy decision still in doubt; Hummer decision expected before month's end Haltech Automotive News 0 04-17-2009 11:30 AM
*****Please help me with my decision please help ****** silversurfer3 Mazdaspeed3/6 General Discussion 8 11-07-2008 07:26 AM
Page generated in 0.34247 seconds with 24 queries
