  • 1 Post By Fstrnyou
  • 1 Post By MSMS3
 Old 06-13-2019, 02:26 PM   #1
The_big_dill's Avatar
Posts: 38   (View Stats)
The_big_dill has a spectacular aura aboutThe_big_dill has a spectacular aura about
Default Locating main bearings
Hi all,
The main bearings on these engines do not have locating tangs.
How do you ensure that the installed bearing is centered in the bore?
In addition, the cradle does not have any dowels or aligning features, so it can be fastened in different positions... how do you ensure it is centered as well?
I can get close by eye, but I can't imagine that is acceptable when we have clearances to the thousands of an inch.
Thanks,
Phil.
The_big_dill is offline   Reply With Quote
 Old 06-13-2019, 03:23 PM   #2
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
For the bearing, you install them to clear the oil opening and i never heard of any that moved away. IT kind of seat into place and remain there....and unless you install them really off, it won't really matter if it is few mills more on the left or right, the crank is floating with some clearances.
You get the craddle aligned (intake to exaust side) by the bloc machining. It won't fall in place unless you push hard or tighten the bolts.....This is the main thing to make sure the top and bottom is aligned in that direction with the crank. (Line bore)
For the craddle left/right (Damper to clutch) the bolts alone will be enough to center it
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 06-13-2019, 04:01 PM   #3
Thank you for the quick reply.
On the block side I Can use the oil passages as a guide, but on the cradle side its eyeballed.
Aligning the short side of the cradle (intake to exhaust) is not a problem. The cradle has room to move around in the other direction though. Maybe because I am using studs??
I discovered the bearing halve misalignment when I was checking clearances on the mains. I loosened the cradles, nudged it the other direction, fastened it and it was aligned to the eye.
 Old 06-14-2019, 06:55 AM   #4
Jeff23spl's Avatar
You can compare diameter of bolts against studs but at the end, i dont think it should change your clearances.
even if the bottom is few mills far left and the top is few mills far right, it won't change the center line and as long as the bearing aren't exposed to touche the counterweights (except the middle one of course), i wouldn't worry much. At worst you lose few mills on the oil film diameter.
@MSMS3 may confirm ?
Wife drive 2010 CX7
 Old 06-14-2019, 01:00 PM   #5
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
@MSMS3;
Jeff23spl likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 06-16-2019, 12:06 AM   #6
MSMS3's Avatar
Posts: 2,826   (View Stats)
More and more manufacturers are moving away from the traditional main and rod bearings that had indexing tabs that fit in depressions or slots in the block or con rods. It’s a crush fit, anyway, with the mating edges of each half being pressed together when the main or rod bolts are torqued, tightly pressing the bearing backing into the supporting main saddle, cap or the connecting rod bore. It’s locked in that way.
So, simply make sure each oil hole in the bearing is centered in the oil hole in the main bearing saddle in the block before laying the crank in place. The center bearing has shoulders, so you can’t get it wrong.
With the crank in place, insert the other bearing half and position the main cap. Make sure the mating edge is aligned with the mating edge of the other bearing half in the block, so that the width matches as you close the gap and begin the crush.
Of course, follow Mazda’s sequence on tightening and final torque.
In essence, be sure to center the bearing oil hole in the block oil hole and get the other half to fully contact the mating surface (edge to edge full contact) to optimize crush as the two come together.
 Old 06-20-2019, 03:49 PM   #7
Thank you very much for the replies guys.
I believe my confusion came from the fact that I was clamping the cradle to the block without the crank to measure clearances.
I think the difficulty was positioning the bearings into the cradle, I imagine it is easier when you position them on the crank. Either way, the alignment looked good.
Appreciate the support!
The Following User Says Thank You to The_big_dill For This Useful Post:
MSMS3 (06-20-2019)
Main Bearings? Solarsurge 2010 MS3 - Engine, Transmission & Driveline 0 07-05-2018 06:06 PM
Undersized rod & main bearings senor blanco ms3 MazdaSpeed 3 - Engine, Transmission & Driveline 10 10-19-2015 03:12 PM
Rod and Main Bearings 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 10 02-26-2009 02:22 AM
Page generated in 0.28325 seconds with 23 queries
