![]() Join Date: Mar 2012
Rep Power: 0 ![]() Thanks: 10
(Thread Starter) | Not Ranked : 0 score Its a fully built gen 2 block. Sp63 pistons Manley H beam rods .020over JBR BSD PNP Head 65lb corwer spring retainers corksport seals freakstuds, and arp mains The guys is asking 4k for the engine. It has no miles on it. He put it in the car and was going to do a 6266 turbo on it, but before he finished with all the piping and all he ran into a family emergency and is needing to sell the engine. This is his 3rd MZR engine assembly. It has a resurfaced and decked head and block and the crank is balanced. The compression ratio is 10.5:1 aswell. |
(Thread Starter) | Not Ranked : 0 score anyone have any opinion on whether i should pick this engine up this weekend or not? good deal, bad deal, check this, or check that? Any type of advice would be greatly appreciated before i make the 5 hour drive to pick this block up tomorrow. |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score Who built it? Where is this at? The picture of the full block on the stand looks familiar. Its possible the guy is a member here. Without knowing who built it, it's hard to say if its a good block to buy or not. Pictures look good, parts list is fine, as long as it was assembled correctly and with new oem components, it should be fine.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following 2 Users Say Thank You to WetzMS3 For This Useful Post: | dgk910 (07-15-2016), monkey.bones.007 (07-15-2016) |
(Thread Starter) | Not Ranked : 0 score A guy named Gino that owns it did the assembly and pnp work. Longs machine shop in San Antonio, TX did the machine work. they have great reviews on google. He had it posted on the mazdaspeed buy/sell group on facebook. |
| Not Ranked : 0 score @SofaKingAwesome;, @MS3Shadow;, either of you guys know who Gino might be, and if he is on here?
| The Following User Says Thank You to WetzMS3 For This Useful Post: | dgk910 (07-15-2016) |
| i don't know. i'll just mention @KotzurRacing; since he's also a engine builder, maybe he knows.
(Thread Starter) | Not Ranked : 0 score his name is Gino Alfrido. he said he doesn't ever post on here so I'm sure he isn't very active. |
| The Following User Says Thank You to dgk910 For This Useful Post: | SofaKingAwesome (07-15-2016) |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
Haven't heard much out of him lately, think he runs in the same circles as RoRo and Ovaries. You could have him meet you at @KotzurRacing;s shop and have him look it over for you.
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER | |
(Thread Starter) | Not Ranked : 0 score He apparently had his block at Kotzur and didn't see eye to eye with them i guess. He took it from Kotzur to Longs in SA. i don't know what went on between him and Kotzur and don't want to cause any problems anywhere. Probably would best if i kept Kotzur out of the equation. |
![]() Join Date: Apr 2013 Location: San Antonio TX
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 362
| Not Ranked : 0 score He said that my guys were talking shit but it was his guys, so he came and picked up the block. I know that sp63 is the only place i have my cranks keyed you might ask him who did it. Im not spending 4k just for the same tooling as sp63 to key cranks. not worth it in the long run. cant beat $275
__________________ COBB BROKE JMS FIXED MazdaSpeed. Errrone can afford |
| The Following User Says Thank You to KotzurRacing For This Useful Post: | dgk910 (07-15-2016) |
(Thread Starter) | Not Ranked : 0 score Thanks for the info Kotzur. I will ask who keyed the crank. |
| Not Ranked : 0 score What's the verdict
(Thread Starter) | Not Ranked : 0 score i picked it up this past weekend. seems to be well built. Gino was a great guy and i felt really good about buying the engine from him. will be a few weeks before it's in my Speed6 though. |
| Advice on buying an MS3 | Mustangkr500 | Mazdaspeed3/6 General Discussion | 18 | 06-16-2016 10:12 PM |
| Buying advice | jferguso | Mazdaspeed3/6 General Discussion | 1 | 04-03-2015 04:25 PM |
| Built Engine Advice - Need to Sleeve? | DocBrown | 2010 MS3 - Engine, Transmission & Driveline | 15 | 10-11-2013 09:20 AM |
| Advice: Buying MS6 | vman159 | Mazdaspeed3/6 General Discussion | 14 | 03-01-2012 06:24 AM |
