 Old 05-07-2016, 09:24 AM   #1
Mzr
Mzr's Avatar
Posts: 1   (View Stats)
Mzr is an unknown quantity at this point
Default Ms6 shortblock rebuild
Hi guys, Chad here. I just signed up. Been browsing the forums for the past little while. I picked up a ms6 last week and so far have determined that the piston rod on the 4th cylinder has snapped. I don't have the history of the car but it is stock with 84k miles on it. I'm going to get the engine taken out to examine if there is any damage internally. The timing chain looks like it is OK but I need to see if any valves are bent or not. I was wondering what I should look for in the process. I am thinking of just rebuilding the short block if the valves are ok. I appreciate your feedback!
Mzr is offline   Reply With Quote
 Old 05-07-2016, 10:04 AM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Welcome , good luck.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-08-2016, 10:10 AM   #3
jmen73's Avatar
Posts: 63   (View Stats)
jmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of light
With that many miles and history mystery, get the head done too. It'll already be out and then your history mystery will be solved. It would behoove you to replace the timing chain. Never use a used timing chain unless you know how old it is and the stresses it has seen.
2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not).
jmen73 is offline   Reply With Quote
Page generated in 0.23934 seconds with 22 queries
