Like Tree7Likes
  • 2 Post By pwdunmore
  • 1 Post By pwdunmore
 Old 09-04-2016, 07:10 PM   #1
pwdunmore's Avatar
Posts: 368   (View Stats)
Default Pwdunmore's MS6 Build
I started this build last year by building an engine. I thought it was going to be a spare forged block to be used for my MS3... but FWD sucks...
Engine:
- Bored to 88mm
- Manley Rods
- Speed performance custom piston with custom low friction coating (to prevent piston slap)
- L11 Head studs
- BNR S4
- Ebay Exhaust Manifold
- ATP 3" Downpipe
- Custom 3" exhaust
- HDI FMIC (to be installed)
- 3.5" Aluminium JBR intake
- Snow performance Stage 2 MAF Meth (to be installed)
- BC coil overs + RPF1 45+ 17/9" Pilot SS Michelin (to be installed)
- CP-e Stage 1 Clutch
- Speed performance transfer case caps
- CP-e rear diff mount + SURE front diff mount
- Damond stage 3 OCC's with PCV plate
- Techna-fit SS clutch line
- Stoptech brakes + pads
- Stock crank bolts
- Stock head
So I bought this...
Then I noticed the rust issue and got a $2000 estimate to repair it... but I found this a month later with no rust:
I am in the process of breaking in the engine right now. Ran the engine for the first time last week, let it warm up and then drained the oil. Doing the first 50 miles now of 50-75% throttle and its pulling strong. Running Napa premium conventional with the Lucas break in additive. Once I am get good compression I will switch to synthetic.
I wanted to thank everyone here on MSF for the help they have unknowingly provided.
;@rfinkle @MD1032 @Ziggo @dale_gribble ;@Lex
Without all the information I have gathered over the years I would have never been able to do this. Thank you all and I hope to make a 400+WHP beast after tuning is finally done.
I am tuning with Hypnotic and will post logs as I go.
Love you guys sooooo flame on!
Code Monkey and ItsNox like this.
My car thread:
The Following 7 Users Say Thank You to pwdunmore For This Useful Post:
Code Monkey (09-04-2016), Erick13Speed3 (09-05-2016), ItsNox (09-04-2016), MD1032 (09-04-2016), robbspeed (09-05-2016), Snyeed (01-29-2017), WetzMS3 (09-09-2016)
 Old 09-05-2016, 01:02 AM   #2
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
Which ebay exhaust manifold?
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
 Old 09-05-2016, 01:18 AM   #3
I_AINT_RICE's Avatar
Posts: 196   (View Stats)
I_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond repute
2.4L? Is that 90mm? Please elaborate
Sent from my SAMSUNG-SM-G870A using Tapatalk
I_AINT_RICE is offline   Reply With Quote
 Old 09-05-2016, 08:14 AM   #4
BLKspd5's Avatar
Posts: 65   (View Stats)
BLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really nice
Very nice, what'd you do with the first car?
Engine/Exhaust/Intake
Corksport:Injector Seals, OCC, EBCS, HPFP Internals, Long Catted DP||Magnaflow:CBE||HTP:3.5" Intake & 51r Tray||JBR:Boost Tubes, Recirc. Hose||CP-E:TMIC||Cobb:Accessport V3(Freektune)||Forge:V2 BPV(Blue Spring)||Damond Motorsports:Full EGR Delete||NGK 6510
Suspension/Chassis
Corksport:Camber Plates, FSB/RSB, Endlinks, Short Shifter||JBR:Rear Camber Arms||CP-E:RMM||H&R:Street Performance Coilovers||Damond Motorsports:PMM, TMM
BLKspd5 is offline   Reply With Quote
 Old 09-09-2016, 01:09 PM   #5
pwdunmore's Avatar
XS Power - V3 I believe
It's the 88mm piston from Speed performance. So it's a few decimal points short but that's what rounding is for... lol
The first rusty black MS6 is sitting at my mechanic still. It will be there another week if anyone in the GTA wants parts from it, first come first serve. I don't need anything from it anymore and it has a full panda interior.
I am installing the FMIC right now from HDI and it looks like I can make it fit with my damond power steering cooler. Just need to make another bracket for it to sit flat instead of vertical.
Had to cut a huge chunk from the crash bar so much for making a crash bar mod free kit... be warned if you have the north american MS6 and buy this Australian kit, the crash bars are different. So you will need to hack it up...
Nitro likes this.
My car thread:
 Old 09-19-2016, 12:10 PM   #6
pwdunmore's Avatar
Logs of my break in tune (spring pressure only):
datalog6.csv
datalog5.csv
Looks like she flows more than my k04 without being pushed as all lol...
My car thread:
The Following User Says Thank You to pwdunmore For This Useful Post:
robbspeed (09-19-2016)
 Old 09-20-2016, 09:50 PM   #7
88mm does not make a 2.4L, you're actually still not even past 2.3L. It puts you at 2287cc. You won't get to 2.4L without a 90mm bore or a stroker crank.
 Old 09-22-2016, 08:26 AM   #8
pwdunmore's Avatar
Fixed... I will now refer to my engine as a 2.2L lol
My car thread:
 Old 10-10-2016, 09:35 AM   #9
pwdunmore's Avatar
Finally got the wheels and tires on.
3rd gear pulls at 19psi, sent these logs for the next revision. (2 people in the car)
datalog7.csv
datalog8.csv
datalog9.csv
Nitro likes this.
My car thread:
Mazdazilla6 (10-10-2016)
 Old 10-10-2016, 02:44 PM   #10
pwdunmore's Avatar
levon.mark likes this.
My car thread:
Snyeed (11-19-2016)
 Old 12-02-2016, 12:11 AM   #11
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
what tire size did you go with? how wide our your rims? Glad to see you figured out your fmic pipe routing
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 12-02-2016, 09:03 AM   #12
pwdunmore's Avatar
I have 245/45/17 and the FMIC piping was fun with the stupid power steering cooler... lol
My car thread:
 Old 12-02-2016, 09:17 AM   #13
Vitamin M's Avatar
Posts: 87   (View Stats)
Vitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these parts
hey man where do you recommend going for machine work in GTA, where did you get this work done for the motor ?
Vitamin M is offline   Reply With Quote
 Old 12-03-2016, 06:05 AM   #14
pwdunmore's Avatar
Rainbow Engines in Markham, they have done good work so far but they are busy due to it being a smaller shop.
Vitamin M likes this.
My car thread:
 Old 01-04-2017, 09:35 AM   #15
pwdunmore's Avatar
Devil's own meth tank and SS lines with check valve to go with a D014 with 100% meth. Hopefully that will be enough extra fuel for the BNR S4.
I have the car stored for the winter right now so I will install this next time I see the car... lol. I have this and step colder spark plugs to be installed then I can complete tuning with Hypnotic Tuning in the spring.
My car thread:
Snyeed (01-29-2017)
pwdunmore's 2012 pwdunmore 2010 MS3 - Build Diaries 7 02-06-2017 11:27 AM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Page generated in 0.39368 seconds with 27 queries
