Like Tree8Likes
 Old 10-12-2015, 02:05 PM   #1
Realgib3's Avatar
Posts: 2,443   (View Stats)
Default Realgib3 End of the Road Build
Well ladies, it's been a long, well documented strugle with this car, but the time has come.
After blowing a head gasket almost exactly a year ago, I've spent the past year trying to
decide the best course of action and have finally decided. I'm returning the car back to
a mild build, with a stock turbo, and will be putting it up for sale after the break-in miles are complete. It will be tough to let it go, but I just have to at this point. With that said, I will not be out of the Mazda game, though I may not have a "Big Build" until late 2016 because of some other projects I'm starting on. Until then, I'll still be tuning and living vicariously through those cars lol.
So for the specs on this final build...
Engine:
Freshly bore/honed 88mm block
Wiseco 88mm Pistons
Manley H-Beams
Mazda OE Bearings
Keyed crank
Stock head
10mm L19's
Power: (or lack thereof)
Rebuilt K04
Catless DP (resonated)
CNT Catback
Garrett FMIC/custom piping
Custom 3" intake
HPFP Internals
Drivetrain/suspension/etc:
Freshly Rebuilt, Gen1 Trans
ACT Streetlight FW w/ Kentucky Clutch full face disk
ISC N1 Coilovers
DM mounts
JBR RSB
I'll keep pictures coming as I continue assembly this week. Car will have AC and all other amenities back and I'll obviously tune it. I'm not parting it out, so don't bother telling me that.
The Following 10 Users Say Thank You to Realgib3 For This Useful Post:
ArmanRus (10-12-2015), ItsNox (10-27-2015), JgamB (12-09-2015), Micha (10-12-2015), rodrigo (10-12-2015), SamiChicago (01-22-2016), sho (10-12-2015), Snyeed (10-13-2015), TRBLSM (10-12-2015), WetzMS3 (10-12-2015)
 Old 10-12-2015, 02:09 PM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
"it ends tonight " famous last words man .....
The Following 3 Users Say Thank You to rodrigo For This Useful Post:
aaronc7 (10-26-2015), Easter Bunny (10-12-2015), Realgib3 (10-12-2015)
 Old 10-12-2015, 03:18 PM   #3
TRBLSM's Avatar
Posts: 73   (View Stats)
TRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond reputeTRBLSM has a reputation beyond repute
Sad to see this happen man...but all of your build threads have been more than valuable to the community. Best of luck with the other projects and hopefully the next speed comes back bigger n badder!!
2006 True Red 3 MPS - Top Mounted 5858 in progress
TRBLSM is offline   Reply With Quote
The Following User Says Thank You to TRBLSM For This Useful Post:
 Old 10-22-2015, 07:04 AM   #4
Realgib3's Avatar
Well I lost a whole week last week, not being able to get to the shop, but I finally went back last night.
pulled the cams back out and checked the head stud tq, then put the cams back in and tq them down, put all the timing components in, timed the motor, and started putting on some of the accessories. Should be able to get it off the stand and at least get the clutch/trans bolted up Saturday morning.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
Mauro_Penguin (10-26-2015), WetzMS3 (10-26-2015)
 Old 10-22-2015, 07:34 AM   #5
This thread has herpes.
Realgib3 (10-22-2015)
 Old 10-26-2015, 08:29 AM   #6
Realgib3's Avatar
More herpes from Saturday @Easter Bunny;
Hoping to find time to put the engine in this week. I have some stupid stuff to finish up in the engine bay like reconnecting my PS lines to the rack and @HOCKEYNUBE; reconnecting the wires he cut, then the engine can go in.
sho likes this.
The Following 5 Users Say Thank You to Realgib3 For This Useful Post:
802MS3 (10-26-2015), Easter Bunny (10-26-2015), impossible (05-01-2016), Mauro_Penguin (10-26-2015), sho (10-26-2015)
 Old 10-26-2015, 10:45 AM   #7
The flareup is bad...........................
sho (10-26-2015)
 Old 10-26-2015, 02:39 PM   #8
HOCKEYNUBE's Avatar
Posts: 144   (View Stats)
HOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the world
Let me know they next time you're going to be out and let me know when the power isn't out this time.... maybe ill bring my stock pump too
and as far as living through other cars... when I run a 10 second pass next year you better actually be there!!! and I may need you to drive it to get it to a 10
2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller
HOCKEYNUBE is offline   Reply With Quote
The Following User Says Thank You to HOCKEYNUBE For This Useful Post:
sho (10-26-2015)
 Old 10-28-2015, 07:12 AM   #9
Realgib3's Avatar
Got some time last night after work, swapped over all my exhaust mani studs from another head, put the mani,turbo,oil lines,etc etc on, hooked the ps back up at the rack, some other little stuff, then put the motor in. Should be back this weekend to start with wiring, accessories, etc.
First time in 5 years there's a stock turbo mounted in this engine bay. So sad.
The Following 3 Users Say Thank You to Realgib3 For This Useful Post:
JgamB (12-09-2015), sho (10-28-2015), WetzMS3 (10-28-2015)
 Old 10-28-2015, 10:31 AM   #10
So sad.
quoted for truth
Realgib3 (10-28-2015)
 Old 10-28-2015, 03:40 PM   #11
HOCKEYNUBE's Avatar
just one step closer to getting to the final goal of the beast that's all....... worth it!
 Old 12-06-2015, 09:26 AM   #12
Realgib3's Avatar
Ran into some stupid bullshit issues, then had zero time or motivation to touch this thing, but finally had a while yesterday to make some progress. I can't wait till this is done and out of my life.
 Old 12-14-2015, 09:58 AM   #13
Realgib3's Avatar
Starting to become a car again. Wiring is all redone from when I had the PI/WOT Box/Alternator relocation, Put the interior back in, new charge pipes done, welded up the egr port on the intake mani, etc. couple little things I'm missing (like a fucking Tab gasket) and then it'll be ready to fire up... And get the fuck outa my shop. Finally.
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
Easter Bunny (12-14-2015), Mauro_Penguin (12-14-2015), RE-ACTIONENGSPEED3 (12-26-2015), WetzMS3 (12-14-2015)
 Old 01-17-2016, 11:38 AM   #14
Realgib3's Avatar
Alright guys, so this car has been "Complete" for about 2 weeks now, but I have yet to be able to start it. Here's a rundown of the issue, but basically... can't get fuel.
Turn key on and ITFP primes (audible)
AP Reads 6 PSI
The end
So on to the things I've tried. There are actually quite a few threads on a similar issue that I've found, but nothing I've found in those has worked.
I've basically made jumper wires to bypass (both individually and all at once in different tests) each of the FP Relays, and the FP resistor balast. All produce the same results, KOEO I here the pump turn on and prime for ~2 sec, only 6 psi pressure builds. Cranking the car like this basically sounds/acts exactly like when you depress both the clutch and throttle all the way to crank the car for a comp check or to prime the oil system on a new build.
I've probably spent 16+ hrs on this issue at this point, gone over all the wiring that was touched from the old PI setup, WOT box, etc, and still exact same issues. I need to get this car going so I can break it in and sell it. Someone please save me.
Oh I also swapped pumps with my 6 and still no dice, 6 runs fine with the 3 pump now, but 3 still no run with the 6 pump.
Mauro_Penguin (01-19-2016)
 Old 01-17-2016, 11:59 AM   #15
It sounds a bit obvious but all wires that were touched should probably be gone over again. It sounds like one is shorting and not getting proper voltage to the pump. Have you done any testing with a multimeter?
 Old 01-17-2016, 12:10 PM   #16
Realgib3's Avatar
Yep I've gotta assume something got fucked when the PI wiring was removed, but each of those (only 4 wires) has been looked over multiple times and are all soldered and wrapped up nicely.
I'm also reading ~11.5v+ at the corect pin on the ITFP plug, then voltage jumps for ~2 sec when you go to KOEO, then back to 0, again, on the proper pin. This is basically showing that the "Priming" procedure is happening correctly from a voltage standpoint.
It's just crazy that even with the feed line disconnected from the HPFP up in the engine bay, just trying to get gas to flow into a cup... still not enough pressure to even make it there.
 Old 01-17-2016, 03:18 PM   #17
Kink in a line somewhere?
 Old 01-17-2016, 04:46 PM   #18
Realgib3's Avatar
Yep that seems to be the consensus from everyone today is an issue with the line, which is completely believable since I had then ripped outa the car before. Unfortunately won't know till Tuesday night.
 Old 01-17-2016, 04:49 PM   #19
I hope I'm wrong but I have to ask
Are.you sure there is gas in the tank?
 Old 01-17-2016, 05:43 PM   #20
Realgib3's Avatar
lol. I've done some dumb shit, but yes there's over half a tank.
 Old 01-17-2016, 05:49 PM   #21
sheston's Avatar
Posts: 1,847   (View Stats)
Could it have gummed up enough to cause this by sitting so long?
 Old 01-18-2016, 01:27 PM   #22
Realgib3's Avatar
Alright looked at it more today.
Started at the ITFP and slowly connected more and more lines until we stopped seeing fuel. Narrowed it down to something at the HPFP.
Basically, fuel is getting to the HPFP, but none is getting through it to the rail. Took the pump out and at first glance everything looks fine. The issue is fuel will go from the feed line, into the pump, then straight back out the "yellow clip" side nipple of the pump, but no fuel will come out of the pump toward the hard line to the rail.
gay.
 Old 01-18-2016, 01:46 PM   #23
Yatta's Avatar
Posts: 1,862   (View Stats)
gay.
relief valve stuck?
SuckSqueezBangBlow likes this.
 Old 01-18-2016, 02:41 PM   #24
Realgib3's Avatar
relief valve stuck?
Spill Valve?
And there's for sure a possibility of issues with the CDFP, which I'll be taking apart tonight since I now know where the fuel is stopping.
I'm just trying to wrap my head around how we typically get fuel to the rail by just turning KOEO a few times, without the CDFP even pumping? Like I just need to see on paper what path that ~50psi of fuel takes to get through the CDFP to the rail, before I even turn the car over.
 Old 01-18-2016, 03:10 PM   #25
Yatta's Avatar
Spill Valve?
yes, sorry, I get the two confused, but would check the valve on the CDFP, its designed to pass fuel...
 Old 01-19-2016, 07:53 AM   #26
Realgib3's Avatar
So does anyone have any idea what the crack pressure of the CV inside this fitting is? I've narrowed everything down to fuel stopping at this fitting, not being able to flow through the pump to the hardline, then to the rail. There's a small check ball at the tip of the fitting that can be pressed in with no effort, so that's not the issue. I'm assuming there's a check valve further within the fitting though, that is keeping fuel from flowing through for some reason. All I know is I can't blow through the fitting right now and I can't get fuel to flow through it either. The rest of the pump is very clean and seems to be functioning properly.
Easter Bunny (01-19-2016), Mauro_Penguin (01-19-2016)
 Old 01-19-2016, 09:18 AM   #27
I know this is WAYYY off topic (but it's your build thread), but I saw somewhere that you're running RD's clutch kit. Can't really find to much on it but it seems like a hell of deal.
Also did you measure the pressure from the itfp right before the hpfp?
 Old 01-19-2016, 09:42 AM   #28
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
since you swapped pumps and both run fine in one car and both don't solve the issue with your 3 I'm guessing it's past that. hardline clogged?
Blue Pu.
 Old 01-19-2016, 05:59 PM   #29
sheston's Avatar
So with the pump off, you can do KOEO and get fuel out the hard line? Just adding to ^^ @anavrinIV;
 Old 01-20-2016, 07:01 AM   #30
Realgib3's Avatar
Nope, the hardline comes after the HPFP, so I get fuel to the HPFP from the tank, but nothing makes it past the check valve in the outlet of the pump.
I'll be checking the pressure coming from the tank next. If that's low though, I have no clue where I'll look next as far as issues go.
 Old 01-20-2016, 08:47 AM   #31
Could the filter sock be full of shit and gummed up from sitting
 Old 01-20-2016, 08:53 AM   #32
Realgib3's Avatar
I kept the sock with the pumps when I switched them, cuz I was thinking the same thing. Only thing that stayed between them was the actual basket and top hat assembly. Maybe a hole in the actual pickup tube in the basket? If it turns out to be low fuel pressure issue, then something like that, creating an internal leak basically, could be the problem.
I just know it's an hour drive each way to the shop and I'm tired of driving out there, especially in the winter, to get fucking no where.
 Old 01-20-2016, 10:09 AM   #33
damn thats inconvenient
 Old 01-22-2016, 07:58 AM   #34
Realgib3's Avatar
Well it runs. What a stupid fucking issue. I'm still debating on whether I want to divulge ALL the issues that have gone on with this build in the last year, but for now I'll wait and just be happy it runs.
MAF is unplugged since I didn't have my laptop with me to flash a basemap on the car for 3" MAF and 50/50. Other than that, it runs well, no leaks yet. Still have a lot of little stuff to button up, including putting a wiper motor back in, putting the bumper back on, etc, but I should have it ready and driving in a week or so.
The Following 9 Users Say Thank You to Realgib3 For This Useful Post:
Code Monkey (01-22-2016), Easter Bunny (01-22-2016), Etipp98 (01-22-2016), JgamB (01-26-2016), Mauro_Penguin (01-22-2016), Micha (01-24-2016), pmartz16 (01-26-2016), sho (01-25-2016), WetzMS3 (01-22-2016)
 Old 01-22-2016, 08:47 AM   #35
I need to know.
Code Monkey (01-22-2016), Mauro_Penguin (01-22-2016), WetzMS3 (01-22-2016)
 Old 01-22-2016, 11:46 AM   #36
Realgib3's Avatar
I need to know.
Well I will tell you the fueling issue was an o-ring that was removed by a friend, when he swapped his stock pump for my aftermarket one. One little fucking o-ring that wouldn't allow pressure to build.
The Following 7 Users Say Thank You to Realgib3 For This Useful Post:
Code Monkey (01-22-2016), Easter Bunny (01-22-2016), impossible (05-01-2016), Mauro_Penguin (01-22-2016), Micha (01-24-2016), sho (01-25-2016), WetzMS3 (01-22-2016)
 Old 01-22-2016, 01:28 PM   #37
Where was the fuel going?
Micha (01-24-2016)
 Old 01-22-2016, 02:27 PM   #38
Realgib3's Avatar
Back into the basket. It's one of the o-rings on the regulator.
Easter Bunny (01-26-2016), Micha (01-24-2016)
 Old 01-25-2016, 10:00 PM   #39
TRBLSM's Avatar
@Realgib3; sent you a PM
Tapatorque steering
 Old 01-30-2016, 04:58 AM   #40
Cmfk's Avatar
Posts: 20   (View Stats)
Cmfk will become famous soon enough
Seems legit haha atleast it idles now
Sent from my SM-G920T using Tapatalk
Cmfk is offline   Reply With Quote
The Following User Says Thank You to Cmfk For This Useful Post:
Amaroms3 (10-19-2016)
The Road to an EFR 9180 Build NCspecV81 2010 MS3 - Big Turbo Builds 1465 06-02-2018 12:06 PM
Realgib3 2014 Build Realgib3 Mazda MZR DISI Engine Builds (2006-2013) 471 01-15-2016 02:47 PM
Realgib3 2013 DIY Build Realgib3 Mazda MZR DISI Engine Builds (2006-2013) 272 04-18-2014 01:55 AM
Automakers on uphill road to build brand in China Haltech Automotive News 0 09-08-2009 07:40 AM
Automakers on uphill road to build brand in China Haltech Automotive News 0 09-06-2009 07:10 PM
Page generated in 0.59428 seconds with 30 queries
