Like Tree21Likes
 Old 08-09-2016, 01:01 PM   #1
I_AINT_RICE's Avatar
Posts: 196   (View Stats)
I_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond repute
Default Rebuilding an already forged engine..
Hey guys, decided to make a new thread following my rebuild.
Experienced a loud ticking on a 30k forged motor. Pulled it apart, wrist pin retaining clip popped out and scored the cylinder wall. Car already had 88mm pistons so no saving the sleeves. Decided to go through darton for their resleeving service.
Heres the plan:
-new piston from weisco (just purchased)
-send out crank to micropolished and get keyed.
-new bearings and rings
-hot tank head and new valve seals
-new friction disk for 6 puck
Question: Who pins cams?
Pics
Sent from my SAMSUNG-SM-G870A using Tapatalk
I_AINT_RICE is offline   Reply With Quote
The Following User Says Thank You to I_AINT_RICE For This Useful Post:
dead-zone (09-09-2016)
 Old 08-09-2016, 02:04 PM   #2
SP63 is probably your best option for keyed crank.
To have the cams pinned, you'll need the motor timed, so it will need to be done locally. Most competent machine shops should be able to do it, whether or not any of them are willing to and able to competently time the motor is the bigger question.
All that being said, there are motors putting out plenty of power without being keyed or pinned.
macdiesel and I_AINT_RICE like this.
Easter Bunny (09-10-2016), I_AINT_RICE (08-09-2016), Mauro_Penguin (08-11-2016), monkey.bones.007 (08-09-2016)
 Old 08-09-2016, 02:25 PM   #3
Thanks man. Planned on sp63 for the keying. Might now touch the cams then
 Old 08-09-2016, 04:02 PM   #4
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Why do people key the crank and cams? Is it to prevent the engine from going out of time if the friction washers slip?
 Old 08-09-2016, 04:05 PM   #5
That is exactly why it's done.
macdiesel likes this.
 Old 08-10-2016, 05:47 AM   #6
Nice, What are the chances of the engine going out of time with friction washers?
 Old 08-10-2016, 06:27 AM   #7
Personally, I haven't seen it. But then again, I dont know many people making over 500whp without the crank keyed
BuddySpeed3 (08-10-2016)
 Old 08-10-2016, 07:25 AM   #8
If assembled correctly, the chances of slipping timing are minimal. Even on higher HP builds.
That white gen1 with the record that Justin just bought, friction washers.
Justin@Freektune likes this.
The Following 9 Users Say Thank You to WetzMS3 For This Useful Post:
blackms3_71 (08-10-2016), BuddySpeed3 (08-10-2016), Dano (08-16-2016), Easter Bunny (09-10-2016), Justin@Freektune (08-14-2016), Mauro_Penguin (08-11-2016), mxlplx71 (08-10-2016), nindoja (10-06-2016), qtrmile beast (08-17-2016)
 Old 08-10-2016, 06:41 PM   #9
Awesome, How much power is it putting down?
 Old 08-10-2016, 10:26 PM   #10
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
i think it was 800+
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 3 Users Say Thank You to mxlplx71 For This Useful Post:
BuddySpeed3 (08-11-2016), Easter Bunny (09-10-2016), WetzMS3 (08-11-2016)
 Old 08-10-2016, 10:38 PM   #11
droflow's Avatar
Posts: 114   (View Stats)
droflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond repute
What would cause a wrist pin retainer to pop out? Just had an engine rebuilt with wiseco pistons and wondering how to prevent this from happening just after 30k haha
2007 Cosmic Blue Mica Mazdaspeed3 GT
Mazdaspeed CAI, Autotech HPFP, Corksport TMIC, E-cutout, corksport test pipe, stratified tune
In the works:
Built engine- Bored .020 over, Eagle Rods, Wiseco 88mm pistons, Damond PCV plate, corksport injector seals, ported IM
droflow is offline   Reply With Quote
 Old 08-10-2016, 11:10 PM   #12
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Installer error. Either it wasnt in right and now at the bottom of the oil pan or never installed at all.
 Old 08-12-2016, 07:35 PM   #13
sheston's Avatar
Posts: 1,847   (View Stats)
Maybe you need keyed wrist pins? :-)
Would be interested in if you find pieces of the clip in the oil pan or not.
I_AINT_RICE likes this.
The Following 3 Users Say Thank You to sheston For This Useful Post:
Easter Bunny (09-10-2016), I_AINT_RICE (08-12-2016), WetzMS3 (08-16-2016)
 Old 08-12-2016, 08:06 PM   #14
No sir, relooked at the piston. The retainer clips is still there, just got eroded. I'll post pics shortly
 Old 08-16-2016, 01:01 PM   #15
Gonna pull the engine today.. Pics to come
 Old 08-16-2016, 06:18 PM   #16
droflow's Avatar
Didn't you already pull the engine???
In the works:
 Old 08-16-2016, 07:25 PM   #17
Nah just knocked the pistons out
 Old 08-16-2016, 08:27 PM   #18
droflow's Avatar
Well damn, it looked like the block was pulled already from the photos! Did you just drop the crank with the rods attached?
In the works:
The Following User Says Thank You to droflow For This Useful Post:
 Old 08-16-2016, 08:43 PM   #19
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I think it can become more of an issue with higher rev builds not necessarily higher HP builds. Higher rev necessarily requires heavier valve springs (to prevent valve float). When you start down that road its more possible the washers might give way.
What happened to OP def sucks. Possibly a material defect in the original Wiseco clips?
WetzMS3 likes this.
Easter Bunny (09-10-2016), WetzMS3 (08-16-2016)
 Old 08-17-2016, 03:25 PM   #20
Pulled the engine apart:
Missing 3 oil squirters
Bearing look great
The clutch was hardly hanging on
Overall, doesnt look too bad
WetzMS3 (08-17-2016)
 Old 08-17-2016, 04:11 PM   #21
Trail of Fail
Dano's Avatar
you have to bend the oil jets to work with any aftermarket pistons, and do it correctly
I did it by putting the female end of a long 1/4 drive extension over the jet from the bottom after each pistons/rod combo was installed and torqued down. This so I could visibly see where it needed to go. doing it before assembly is like flying blind IMO. I got it close before putting the rod caps on and torquing of course but you get the idea.
I suppose it's possible you may have over heated the pistons/pins which lead to the clip failure.
good luck with the rebuild.
Easter Bunny (09-10-2016), I_AINT_RICE (08-17-2016), WetzMS3 (08-18-2016)
 Old 08-17-2016, 04:26 PM   #22
The wrist pin actually rode on the clip itself. Over time eroding the retainer clip and allowing the wrist pin to walk back and forth. Unfortunately I have a potatoe for a camera phone. If the pic was actually visible, you can see the clip still in its place, its just completely flush.
And that's the plan on the oil squirters. Had to do that with a evo 10 engine I built recently
 Old 08-17-2016, 05:20 PM   #23
Trail of Fail
Dano's Avatar
no matter what camera you used in the pic you posted, there would be no way to determine if the clip was there or not. You disassembled it so have a better view for sure.
I just like to solve problems and I can't see how the pin can get past a clip if properly installed. There is no meaningful lateral force on the pin to force it past a clip.
I can't even see it happening in the absence of extra lubrication due to the jet being gone. oil still gets splashed all over the bottom of the piston. AFAIK, the jets are primarily for cooling not pin lubrication.
the clip didn't magically shrink.
If I were you, I'd want to know the cause before building again. Basic failure analysis 101.
Easter Bunny (09-10-2016), WetzMS3 (08-18-2016)
 Old 08-17-2016, 05:41 PM   #24
Yeah, the engine was built when I purchased the car. I plan on throwing in spiro clips. That's what ive done on all the engines I've built. Honesty, I hate these stupid wiesco retaining c clips.
Heres some pics brother. Thanks for the help
Honestly, the only time I have seen a clip fail similar to this was having someone throw in the clips in prior to setting the wrist pin. Instead of removing the clips, they banged the pin past one of the clips.
Not sure if this is what happened here, but regardless it's pretty odd
Last edited by I_AINT_RICE; 08-17-2016 at 05:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-18-2016, 12:46 AM   #25
How loose is the pin in it's bore? They're not press fit (obviously) but they should be decently snug without any circlips. If too loose it could smack against the clip enough over time.
 Old 08-18-2016, 08:27 AM   #26
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
SERIOUSLY!@@!!@ How fucking lazy do you have to be to try and press a wrist pin past its retaining clip ...... I cant believe i just read that. Suppose you get it past, then the pin is scored and the clip is compromised after being pressed. What fail.
OP FWIW I have Wiseco pistons and 50k later still no problems
 Old 08-18-2016, 08:32 AM   #27
Lol, agreed.
I have 20k on my Wiseco pistons, no problems either.
Were the oil squirters ever found? Curious as to where they ended up and in what condition. I'd imagine they broke off many many miles ago.
 Old 08-18-2016, 08:36 AM   #28
Daily Driver
Nitr0EngiE's Avatar
this makes no sense because the ring is constantly coated in oil so it should not be corroding or rusting even though its against aluminum. there is something else wrong.
 Old 08-18-2016, 08:54 AM   #29
droflow's Avatar
So how are you supposed to bend the oil squirters? Put the piston at the bottom of the stroke and bend it around it?
In the works:
 Old 08-18-2016, 08:57 AM   #30
I do it similarly to the way @Dano; described. You can eye ball it before torquing the rod caps, but always verify after its torqued.
 Old 08-18-2016, 09:08 AM   #31
droflow's Avatar
Do you just bend it enough so it doesn't hit the piston skirt?
In the works:
 Old 08-18-2016, 07:18 PM   #32
Trail of Fail
Dano's Avatar
IIRC you have to both bend it out (related to the cylinder wall) and inward (toward the rod.) wait, maybe away from the rod..lol been awhile but def away from the cylinder wall since there is no relief milled into the piston skirt.
if you go too far out from the wall you get contact.
in OPs setup, the jets were likely gone at or within a few miles of startup
the original builder made a few mistakes.
on my 1st build I lost one jet then learned to look at the clearance with everything installed and rotated around.
much better pics...still no idea how the pin got past the clip...unless the dumbass hammered the pin past the already installed clip.
my Wiseco's have about 25K on them...no issues detected.
WetzMS3 and I_AINT_RICE like this.
Last edited by Dano; 08-18-2016 at 07:18 PM. Reason: MSF Database - Automerged Doublepost
Easter Bunny (09-10-2016), I_AINT_RICE (08-18-2016), WetzMS3 (08-18-2016)
 Old 08-18-2016, 08:21 PM   #33
I'll run spirolox in my build. Love them. No reason to run those stupid c clip style retaining clips.
What do you guys think if darton dry sleeves? AZ NATOR states it will be a limiting factor relative to wet sleeves?
 Old 08-18-2016, 08:46 PM   #34
Who in Nator AZ?
If it ain't @Enki;, I've heard the rest are drama queens and fuckbois.
 Old 08-18-2016, 10:00 PM   #35
Trail of Fail
Dano's Avatar
they look legit.
I have no experience with sleeves.
What did you go with Ben? @btstarcher;
 Old 08-18-2016, 10:23 PM   #36
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Word is you should run wet sleeves for daily duty but you can get away with dry for a dedicated drag car that gets shut down for cooldown after every run.
Dano (08-18-2016), WetzMS3 (08-19-2016)
 Old 08-18-2016, 10:56 PM   #37
But why? Stock block is dry sleeve based (casted and molded).
Called the darton guy that Kevin mentioned. Not sure what rep stated the 30psi. In no way is it a limit (boost based)?
 Old 08-18-2016, 11:49 PM   #38
Dry sleeves will do you just fine. Plenty of people run them. Wet sleeves don't do much for our engine since we don't have any cooling issues (unless you're doing mega heavy track duty stuff). The other guys might be thinking of sealing up the jackets and going sans coolant, which in that case yea, it'd only be good for those short straight line races.
I_AINT_RICE (08-19-2016)
 Old 08-20-2016, 03:52 PM   #39
M900's Avatar
Posts: 8   (View Stats)
M900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to behold
Do not use spiro lox in a piston that is meant to have round wire locks, the grooves are machined differently. I would compare the wire diameter of the lock that failed to a good one, may have been the wrong lock or the groove may have been cut wrong.
Paul
And make sure that rod is not bent or twisted, both of which can put a side load on the pin.
Paul
Last edited by M900; 08-20-2016 at 03:52 PM. Reason: MSF Database - Automerged Doublepost
M900 is offline   Reply With Quote
 Old 08-21-2016, 11:22 AM   #40
M900's Avatar
And the wrist pins are different depending on the type of lock used. Round wire equals chamfer, spiro lox just have an edge break.
Paul
Engine blown, thinking of rebuilding EEGeek Mazda MZR DISI Engine Builds (2006-2013) 4 11-26-2013 05:15 AM
Rebuilding engine after ZZB - can I reuse CP-E SafeSeals? Matrix311 Mazdaspeed3/6 General Discussion 17 09-26-2013 04:46 PM
Does this engine need rebuilding? wruss64 MazdaSpeed 3 - Engine, Transmission & Driveline 42 11-11-2010 12:06 AM
Tell Me how you built your forged engine Spoolme MazdaSpeed 6 - How-To's 9 04-04-2010 06:13 AM
My Forged Engine Build JumpingJackson MazdaSpeed 6 - Engine, Transmission & Driveline 156 03-06-2010 04:26 PM
Page generated in 0.63239 seconds with 32 queries
