Like Tree21Likes
 Old 08-30-2016, 04:58 PM   #41
I_AINT_RICE's Avatar
Posts: 196   (View Stats)
I_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond repute
Hey everyone. Everything has been moving along beautifully. Purchased a block from a friend, will be ready tomorrow from the machine shop.
Sent the rod out to get the small bushing replaced on the rod along with an inspection to make sure its not bent.
Rings, lube, etc is all in the mail should arrive Thursday. Just have a few questions/concerns:
1. Ring gap.. What do all the big power guys gap their rings to?
2. How to tell if you have oversized main bearings? My crank diameter is 2.052" and the rod journal size is 2.165". Not sure what the stock crank is?
Think thats about it for the time being. Pics will be posted shortly.
I_AINT_RICE is offline   Reply With Quote
 Old 08-30-2016, 06:44 PM   #42
sheston's Avatar
Posts: 1,847   (View Stats)
Not sure I count as a big horse power guy, but I gapped mine per Wiseco's recommendation. Seems to be working well, been running for ~15k, running 30 psi, ....
 Old 08-30-2016, 07:20 PM   #43
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
You run 30 psi on a k04? That torque must be stupid lol.
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 08-30-2016, 07:37 PM   #44
sheston's Avatar
I think I'm the one who's stupid. But built motor and I have fun with it. Only get to use it in 4th gear :-)
WetzMS3 and robbspeed like this.
WetzMS3 (08-30-2016)
 Old 08-30-2016, 07:45 PM   #45
Wiseco sends a sheet with the rings breaking down the way to determine gap. Google also has it readily available. If I was on a computer I'd post an image. From there it's a bit of a balance between boost level and driving habits.
I'd have to consult the assembly manual to find main bearing numbers. I'll look tomorrow if someone hasn't chimed in.
monkey.bones.007 (08-31-2016)
 Old 09-01-2016, 12:56 PM   #46
Rods and mains are both 52mm. You need to remeasure, the only way that's possible is if your measuring instrumentation is out of calibration or the crank has been previously welded and you're running bearings from another engine (highly unlikely). Exact spec from the manual:
Edit: Or are you saying that the large end on your rod is 2.165"?
I_AINT_RICE likes this.
The Following 4 Users Say Thank You to Mazdazilla6 For This Useful Post:
Easter Bunny (09-10-2016), HawkeyeGeoff (09-09-2016), I_AINT_RICE (09-03-2016), WetzMS3 (09-01-2016)
 Old 09-03-2016, 10:32 PM   #47
Attachment 228061
Thanks man!
Anyone know what size rod bearings these are? Oem not sure I'd they're oversized
Sent from my SAMSUNG-SM-G870A using Tapatalk
 Old 09-04-2016, 10:20 AM   #48
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Do you not have a 0 to 1 inch mic. you could just mic them to find out what size they are. You'd want to use the ball attachment to get the correct reading in the middle of the bearing.
Tappin
 Old 09-04-2016, 10:28 AM   #49
Why reuse bearings in the first place? New ones are cheap, just figure out the crank journal size.
 Old 09-07-2016, 09:53 PM   #50
Got mahle bearings. I'll post pics within the next couple days. Should be putting the engine back together this weekend
 Old 09-09-2016, 12:00 PM   #51
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Pulled the engine apart:
Missing 3 oil squirters
Bearing look great
The clutch was hardly hanging on
Overall, doesnt look too bad
This is pretty much how much 6 puck looked after ~36k. I switched to SB Stg. 3 endurance and never looked back.
For ring gap I believe .0035 is what is recommended for us. Because I had my built motor rebuilt for the 2nd time, I ended up having to go with .0045. It probably wont last more than 60-70k, but I'm okay with that. So far ~1k in it seems fantastic, great compression results.
Did you replace all the wrist pins? The ones from my pauter rods were toasted when I took it out at 36k. It sounded like piston slap....in fact it was wrist pins big time.
Edit: These are Piston to Wall clearances.
Silver 2007 Speed3 GT
Last edited by HawkeyeGeoff; 09-09-2016 at 12:23 PM. Reason: MSF Database - Automerged Doublepost
I_AINT_RICE (09-09-2016)
 Old 09-09-2016, 12:03 PM   #52
Those are PWC numbers you are mentioning, not ring gap. Ring gap based on Wiseco recommendations ends up around .018 and .020 depending on goals and preference.
HawkeyeGeoff (09-09-2016), I_AINT_RICE (09-09-2016)
 Old 09-09-2016, 12:23 PM   #53
I stand corrected.
You ganna be boozing with us down at ENMMW tonight?
Edit: My ring gaps were set at:
First ring: .018
2nd ring: .020
Oil: .022
I also use the 88mm Wisecos. But it was also re-touch honed.
The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post:
I_AINT_RICE (09-09-2016), WetzMS3 (09-09-2016)
 Old 09-09-2016, 12:30 PM   #54
Hell. Here's my spec sheet.
88mm Wisecos + Pauter rods. Crank was a good used core. Cyls were honed again (2nd rebuild).
 Old 09-09-2016, 01:01 PM   #55
The guys running .018 & .020; you guys aren't getting any smoke/blow by? Car will probably be around 550whp with the comp turbo 5862. Trying to go as big as I can without it smoking. I've seen ring butting before on a 5.3, it ain't pretty
 Old 09-09-2016, 01:38 PM   #56
Trail of Fail
Dano's Avatar
88mm Wisecos
1st ring .019
2nd ring .022
28-30PSI tune
zero smoke or oil loss at around 10K miles. 190 compression, 5-7% leakdown across the board.
The Following 4 Users Say Thank You to Dano For This Useful Post:
Easter Bunny (09-10-2016), Enki (09-09-2016), I_AINT_RICE (09-09-2016), WetzMS3 (09-09-2016)
 Old 09-09-2016, 01:53 PM   #57
.020
No issues to report, 17k-ish miles.
 Old 09-09-2016, 07:01 PM   #58
Got the crank in. Gotta torque it down and check end play. Reusing the main bearings because they looked perfect. Without being torqued down, there seemed to be a decent amount of crank end play. I'll get everything locked down then check. Gonna grab a pilot bushing and water pump o-ring and call it a night
The Following User Says Thank You to I_AINT_RICE For This Useful Post:
WetzMS3 (09-13-2016)
 Old 09-10-2016, 04:41 AM   #59
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Ok, so I'm joining this club of people rebuilding already forged engines.
Long story short:
1. on Thu when I arrived at the hotel I noticed the engine was rattling when I opened the door. I was kind of surprised because the car was driving as usual and because of how roads and traffic is around here I have to go WOT quite a lot.
2. on Fri I drove from the hotel to the dealer (I was scheduled for some air con work).
3. checked the oil, it was half way between min and max;
4. they checked the timing chain, then pulled the valve cover and checked the timing, all was fine, even though the mechanic wanted to make a little adjustment because it was a fraction of a tooth off - which was explaining I think why my car was making a lot of torque (about 490) and not as much power (about 420-430 crank);
5. put everything together, did a compression test (kind of cold and dry): 170/0/175/175. Yes, 0 on cyl2.
6. checked the oil again and it was missing about one quart only from sitting on the hoist and being worked on and tested for compression.
7. attempted to start the car again and it was obviously running in 3 cyls.
At this point we're not sure what is going on, we'll find out on monday when they will pull the engine. It can be the piston, it can be the valves or the rings on that #2 .
The engine didn't have much left considering what they did and how everything turned, so I'm happy this happened on the hoist at my preferred dealer and not in the middle of a highway with the car full of luggage with my family in.
I'm leaning towards getting the SP63 4032 pistons but the manufacturing time is quite significant, so I may very well go for the Manley 2618 (630005C-4). We'll see.
I also want to add stiffer valve springs to be able to rev a bit higher. Otherwise this setup was absolutely perfect.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 09-10-2016, 11:33 AM   #60
Long story short:
With that little of compression, it sounds like a valve. Even with no rings, you'll have some compression.
 Old 09-10-2016, 11:53 AM   #61
for ring end gap i would error on the side of too big over too small.
if in doubt go bigger
I_AINT_RICE (09-10-2016)
 Old 09-10-2016, 05:39 PM   #62
Had to purchase new mains. The crank end play was .014". Which is past the service limit. Went with king bearings MB5442SI. Always had good luck with kings, should be here Tuesday
 Old 09-10-2016, 07:31 PM   #63
Gapped the rings.
.019 .024
Didn't touch the oil rails
 Old 09-15-2016, 06:13 PM   #64
Bored hotside and comp turbo turbine just came in. Upped it from a 5858 to a 5862. Bearings will be in tomorrow
Got some unicorn blood too
robbspeed likes this.
 Old 09-17-2016, 12:14 AM   #65
Got the crank in and mains torqued. Forgot to take pics. Also bent the oil squirters to clear the pistons. Gonna throw the pistons/rods in tomorrow and hopefully the head. Should be getting the thing back together this week.
Random pics while putting the turbo back together
robbspeed (09-18-2016)
 Old 09-17-2016, 12:55 AM   #66
mituc's Avatar
Groans: 111
Don't you need to balance the turbo once you disassembled it?
 Old 09-17-2016, 12:56 AM   #67
Only when you swap hard parts. And the turbine, various thrust washers, and compressor wheel was balanced with one another when I get the hot side bored out.
 Old 09-18-2016, 10:50 AM   #68
Gotta borrow a friends timing tool and should have it put together by today
 Old 09-18-2016, 05:58 PM   #69
Engine is timed. Just need some misc stuff, bolt up trans/transfercase then drop in.
For all the guys that have dropped ms6 engines in, were you able to drop it in with the manifolds?
 Old 09-20-2016, 10:20 PM   #70
The Following 2 Users Say Thank You to I_AINT_RICE For This Useful Post:
sheston (09-23-2016), WetzMS3 (09-21-2016)
 Old 09-24-2016, 11:30 PM   #71
Started it up today. Had a shit ton of backfiring, totally forgot to rescale the maf and didn't bring my computer. Also, forgot to gap the plugs. I'll fix the tune, gap the plugs and break it in tomorrow. Video to come
 Old 09-26-2016, 05:25 PM   #72
So got it running, drove it down the block. Immediately after the pull, started to backfire and barely idle. As soon as there is any load it tries to die. I'll post up a log in a couple. Has a little bit of white smoke from exhaust . Honestly looks like I have quite a bit of water in the tank. Which wouldn't be totally out of the question givin the fact the car was parked outside during monsoon season with the fuel lines opened.
 Old 09-26-2016, 05:52 PM   #73
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Something came loose, air leak or something probably.
 Old 09-26-2016, 05:54 PM   #74
sheston's Avatar
Don't supposed you forgot to plug the MAF back in :-)
 Old 09-26-2016, 09:52 PM   #75
Blew a head gasket first pull. Not sure how but looks to be. Oil in the coolant.
 Old 10-03-2016, 08:17 PM   #76
What headstuds/bolts are you using and are you running an aftermarket headgasket? Also check to make sure it's not an oil cooler leak that's causing them to mix.
 Old 10-03-2016, 08:46 PM   #77
Never thought about the oil cooler... I'll have to check it tomorrow! Arp 2000 studs. Dnj gasket.
Reused the arp from my last block. Had 30k on them
Pulled the valve cover today, coolant was all over the head
 Old 10-03-2016, 08:57 PM   #78
Never heard of DNJ. You should consider throwing a stock gasket in there. Might also want think about using stock headbolts since those ARPs don't really have a proper torque spec to hold more than the stock bolts can.
I_AINT_RICE (10-04-2016)
 Old 10-03-2016, 10:07 PM   #79
mituc's Avatar
Groans: 111
Use the L19 or CA625 head studs and OEM head gasket. Do not use the ARP2000 unless you're not planning to make more than like 420-430whp.
 Old 10-04-2016, 08:43 AM   #80
Already purchased a felpro replacement and oem head bolts. They should be adequate though
Engine blown, thinking of rebuilding EEGeek Mazda MZR DISI Engine Builds (2006-2013) 4 11-26-2013 05:15 AM
Rebuilding engine after ZZB - can I reuse CP-E SafeSeals? Matrix311 Mazdaspeed3/6 General Discussion 17 09-26-2013 04:46 PM
Does this engine need rebuilding? wruss64 MazdaSpeed 3 - Engine, Transmission & Driveline 42 11-11-2010 12:06 AM
Tell Me how you built your forged engine Spoolme MazdaSpeed 6 - How-To's 9 04-04-2010 06:13 AM
My Forged Engine Build JumpingJackson MazdaSpeed 6 - Engine, Transmission & Driveline 156 03-06-2010 04:26 PM
Page generated in 0.60630 seconds with 30 queries
