![]() | | #81 | ![]() |
![]() Join Date: Oct 2013 Location: Saint Simons Island, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 313
| Not Ranked : 0 score We've been waiting for almost half a year! Oh yeah, NICE BUILD!
__________________ Slow for now... Cobb ApV3///Cobb SRI+TIP///JBR Solid Shift Bushings///JBR 88 RMM///JBR SSP/// JBR Shift Knob///Cobb EBCM///MSR 045 18x8 +35///Nitto Nt05 235/40/18///CS Batt Box///CS Catted DP///ITV22's///Autotech Internals///TR8 FMIC///Koni FSD's/// CS springs Freek Tuning Meow |
| The Following User Says Thank You to BlackFlag For This Useful Post: | memin (04-13-2015) |
![]() | | #82 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score Mmmm can't. Wait to see when u turn it up... What's ur break in procedure? U running break in oil?
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #83 | ![]() |
![]() Join Date: Nov 2011 Location: Caldwell, ID
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,042
(Thread Starter) | Not Ranked : 0 score Running it fairly hard. No wot yet, but I've hit about 12psi now. Oil change due at 50 miles, 500 and 1500. I added a motor break in additive with zinc
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() |
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | ItsNox (04-13-2015) |
![]() | | #84 | ![]() |
(Thread Starter) | Not Ranked : 0 score Welp, today I had time to try and fix a coolant leak. I had some coolant coming from my transfer case. Pulled the wastegate, dp, and driveline to get at it. We will see if I fixed it tomorrow. Other than that, things are going well. I will do my first oil change tomorrow. Oil looks really good. I need to pull my rear fenders more for those r888s. They are more like a 275 not a 255 lol. I will get some wot pulls going soon and post of some vd results.
![]() | | #85 | ![]() |
| Not Ranked : 0 score So u just drive it real hard for break in? Sorry for dumb questions no one can ever answer this when I ask. I thought u weren't supposed to rail on it a lot? Just vary the rpms
![]() | | #86 | ![]() |
(Thread Starter) | Not Ranked : 0 score Opinions vary. But yes, I have been fairly aggressive with breaking it in. "Driving it like you stole it" apparently helps the rings seat better.
![]() | | #87 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score Really glad to see you do a hard break-in. I've read the same thing about the rings. Ill do the same method when I build. Looking forward to updates!
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
![]() | | #88 | ![]() |
| Not Ranked : 0 score Updates??
![]() | | #89 | ![]() |
(Thread Starter) | Not Ranked : 0 score Car running great!!! Turbo not so much. I was hearing a whining noise on startup on my car, then it started making it while in boost. Pulled turbo and the compressor wheels was rubbing on the housing. Sent it off for warranty. Just waiting to hear the consensus and a good turbo. I was super bummed, but it could be worse. Can't wait to get it back and finally got WOT!!!!
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | ItsNox (04-27-2015) |
![]() | | #90 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score What kind of QA did that pile of shit turbo go through? Thank them for pissing shards of metal straight into your brand new motor! |
![]() | | #91 | ![]() |
(Thread Starter) | Not Ranked : 0 score No shards of metal have gone into my motor. They have to take quite a trip to make it that far. Precison turbos aren't pos' btw. Every good name out there has a lemon. I would buy a PTE with confidence and they have customer service to back it up
![]() | | #92 | ![]() |
| Not Ranked : 0 score Believe dat^
![]() | | #93 | ![]() |
| Not Ranked : 0 score And thts shitty ur turbo had to take a dump. I would still stick a borescope down in ur cylinders just for a look see.
| The Following User Says Thank You to MSP611 For This Useful Post: | duappleganger (04-29-2015) |
![]() | | #94 | ![]() |
| Not Ranked : 0 score Yea we understand that, it's just so frustrating how hard it is to get a build to go together without having to deal with this kind of bullshit. I had problems with the clutch kit that I bought after my build and it ended up costing me money and a lot of time just because of poor parts that were supplied. You get there in the end but these kind of things are just SO frustrating! I feel for you, and at least a turbo is easier to drop in/out than a gearbox....... Just. |
| The Following User Says Thank You to Reedy For This Useful Post: | h.h.sk1nny (04-29-2015) |
![]() | | #95 | ![]() |
Keep the updates a'comin! Cant wait to see what that 5858 does for ya!
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
| The Following User Says Thank You to ItsNox For This Useful Post: | h.h.sk1nny (04-29-2015) |
![]() | | #96 | ![]() |
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() | |
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | ItsNox (04-29-2015) |
![]() | | #97 | ![]() |
(Thread Starter) | Not Ranked : 0 score UPDATE!!!! So my turbo got shipped out from Precision yesterday. It was all covered under warranty. Just waiting to get the turbo back, slap it in and starting some logs with dual do10s. Tryin to get it ready for midnight drags on the 23rd of this month.
| The Following 7 Users Say Thank You to h.h.sk1nny For This Useful Post: | Erick13Speed3 (05-16-2015), ItsNox (05-22-2015), Jackis (05-20-2015), Jester2552 (05-16-2015), Putin 2.3T (05-16-2015), RE-ACTIONENGSPEED3 (05-19-2015), tastysi2004 (05-20-2015) |
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score Turbo got installed last night and drove the car home!!! Woot woot!!!! I started tuning today and ran into spark plug blowout and it was pretty bad lol. I gapped, ngk 6510s, them down to .024 and went for a drive. Seemed to fix it a little bit but still bad. Going to drop them down to .022 tomorrow and see if I can actually do a pull lol. My afrs are in the 9s at the moment too because of meth being sprayed. I will get that cleaned up shortly though. dual d010s are too much right now, so I just have a single nozzle 10 spraying at the moment.
| The Following 3 Users Say Thank You to h.h.sk1nny For This Useful Post: |
![]() | | #99 | ![]() |
![]() Join Date: Feb 2013 Location: Anchorage AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score power!
__________________ YEEMARKS SP63 Built Engine. 5858. Meth. Old Time in S3: 12.4 @ 111 Parts needed to install: JMF, HTP 4.0", HKS BOV |
![]() | | #100 | ![]() |
| The Following User Says Thank You to ItsNox For This Useful Post: | h.h.sk1nny (05-23-2015) |
![]() | | #101 | ![]() |
| Not Ranked : 0 score What is the reason for the spark blow-out? It seems you're not running that much boost yet, is that common? |
![]() | | #102 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score i bet its a hessitation from being too rich, possibly a boost leak along with the meth. i haven't seen spark blowout on a .26 gap up to 35psi-ish
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() | | #103 | ![]() |
(Thread Starter) | Not Ranked : 0 score Gapped it down to .021 and it is almost all gone now. Will retry at .020 and .019 tomorrow. Got my afr's figured out too. I have heard as low as .017 for gap, so I'm not worried; every car is different. Just got done putting 125 miles on the motor. I think I'm up to about 300 now lol. WGDC is up to 20 now but have not had a chance to go WOT yet...
![]() | | #104 | ![]() |
| Not Ranked : 0 score Hmmm interesting never seen such low gapping... But if it's workin Fuck it... Can't wait to see some results
![]() | | #105 | ![]() |
![]() Join Date: Jun 2011 Location: Tacoma Wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,346
| Not Ranked : 0 score I had to gap mine down to .019 due to spark blowout on my build but I'm running HCR
__________________ Blacked Out 2010 Black Mica MazdaSpeed 3 Performance: Speed Performance 10.6:1 Built motor, CP-e Exhaust Mani, GTX3071, Tial MVR EWG, JBR 3.5" SRI, Cobb AP V3, Autotech HPFP, Guardian Angel, eBay Downpipe, CP-E Triton CBE, Treadstone TR8L Intercooler, CX Racing FMIC Piping Kit, JBR Crashbar, NGK Plugs, PNP Intake Manifold, CoolingMist WMI system w/failsafe, DM Throttle Body Spacer with Dual D07 Nozzles, |
| The Following User Says Thank You to England15j For This Useful Post: | h.h.sk1nny (05-23-2015) |
![]() | | #106 | ![]() |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
| Not Ranked : 0 score I have also gap mine at 0.020 with no problem at all ...
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] |
| The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | England15j (05-26-2015), h.h.sk1nny (05-25-2015) |
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score Update. Fixed my blowout issue. Apparently is was also maxxing out my idc's and did not know it. So slight blowout and maxed out injectors lol. Figured they would not be maxed just running spring pressure. Long story short, my 3.5 bar map sensor was not dialed in (car dialed in for 3 bar), and was reading 15psi or so. Dialed it in and found out I was hitting 27+ psi and saw my IDC's super high lol. Now I am trying to figure out why I am overboosting. My wgdc's are zero'd out, and I have tried running all 3 setups for routing my lines (ATP, Grimmspeed and @jmhinkle;'s way), with no success. Guess the next step is to check out if my ebcs is messed up
| The Following User Says Thank You to h.h.sk1nny For This Useful Post: | levon.mark (05-28-2015) |
![]() | | #108 | ![]() |
![]() Join Date: Jun 2011 Location: Beach Park Illinois
Rep Power: 2610 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46,278
| Not Ranked : 0 score I ended up having to do the copper rod mod too with my coil packs. Stopped my hesitation and I am gapped at .023.
__________________ I am slow again. 2017 Lightning Blue SuperCab Raptor ordered 1/3/17. Built 2/3/17. Delivered 2/8/17. I modded it a little. |
| The Following 2 Users Say Thank You to Micha For This Useful Post: | England15j (05-29-2015), Vansquish (06-08-2015) |
![]() | | #109 | ![]() |
| Not Ranked : 0 score What's this copper rod mod u speak of lol? Should it be done no matter Wat in Ur opinion?
| The Following 3 Users Say Thank You to MSP611 For This Useful Post: |
![]() | | #110 | ![]() |
![]() Join Date: Nov 2010 Location: Saint-Petersburg, RU
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 804
| Not Ranked : 0 score I suppose its just stretching the springs inside coil packs so they sit there as tight as possible, but I may be wrong
__________________ Does your MS3 start when it's -30C (-22F)? Forged, bolted, tuned, gtx30/tial/ewg. Thanks. |
![]() | | #111 | ![]() |
| Not Ranked : 0 score Just installed this on mine and was able to regap my plugs from .020 to .028 and didn't experience the spark blowout I had previously experienced at .024. The results went so well I'm going to attempt .032 and see how it likes it 2.5" of 4awg copper rod ImageUploadedByTapatalk1433774395.111990.jpg
![]() | | #112 | ![]() |
| Not Ranked : 0 score So u just put Tht copper rod inside Ur coilpack spring? @Jackis; Tht is just the spring stretch mod... Been around for a minute
![]() | | #113 | ![]() |
| Not Ranked : 0 score Replace the spring with the copper rod
| The Following User Says Thank You to England15j For This Useful Post: | ItsNox (06-08-2015) |
![]() | | #114 | ![]() |
![]() Join Date: Apr 2014 Location: Cold lake / Edmonton AB
Groaned at 18 Times in 5 Posts
| Not Ranked : 0 score Where does one get this copper rod, Sent from my iPhone using Tapatalk |
![]() | | #115 | ![]() |
| Not Ranked : 0 score Inter webs or hardware store
| The Following User Says Thank You to England15j For This Useful Post: | Jdraps13 (06-08-2015) |
![]() | | #116 | ![]() |
| Not Ranked : 0 score Hmmm search I will for this copper rod and hopefully I can find it at like home depot when I'm home lol
![]() | | #117 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just an update for you guys. Car is rippin!!! We have it at 30psi right now with more room for boost and timing. Just waiting on my JMF manifold and my new AIS meth pump/lines to show up. Then we will be cranking it up more and I'm hoping for 600hp. Can't say enough about this turbo. Took my first win on the new setup. Not sure what hp he was at but built/sleeved Evo X got his ass handed to him with sparkplug blowout and boost cut. Got some decent footage on a GoPro. I will get a VD posted here too. Certainly can't forget about my tuner!!! Thanks Ryan for all the patience and help dude, you rock!!! @2.0t03speed;
__________________ Old stuff: Stock k04 12.301 @ 113.20 New Stuff: PTE 5858 and Built, not bought, by ME ![]() Last edited by h.h.sk1nny; 07-17-2015 at 11:38 PM. |
| The Following 9 Users Say Thank You to h.h.sk1nny For This Useful Post: | 2.0t03speed (07-19-2015), Bleupit80 (01-21-2016), Easter Bunny (07-19-2015), England15j (07-17-2015), Hammology (07-17-2015), ItsNox (07-18-2015), Jester2552 (07-20-2015), Micha (07-18-2015), sho (07-18-2015) |
![]() | | #118 | ![]() |
![]() Join Date: Sep 2013 Location: Tacoma, WA
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 382
| Not Ranked : 0 score I'm not your tuner.. >.>'
__________________ 2011 Mazdaspeed 3 [Sold] 2013 Ford F-150 XLT 3.5 Ecoboost |
| The Following User Says Thank You to Putin 2.3T For This Useful Post: | h.h.sk1nny (07-17-2015) |
![]() | | #119 | ![]() |
(Thread Starter) | Not Ranked : 0 score OMG, lolz sorry to both of you. The number in the names is what confuzed me. Fixed
![]() | | #120 | ![]() |
| Not Ranked : 0 score vidz of said race?
| The Following User Says Thank You to MSP611 For This Useful Post: | BLKSTIG (07-19-2015) |
| Built motor and BNR V2 | MattyP617 | 2010 MS3 - Big Turbo Builds | 9 | 03-05-2015 08:57 PM |
| built motor | blackms3_71 | Mazdaspeed3/6 General Discussion | 11 | 01-31-2013 08:19 AM |
| Built Motor is Done..... | yoichi | MazdaSpeed 6 - Engine, Transmission & Driveline | 107 | 12-14-2009 10:52 AM |
