 Old 03-12-2018, 02:28 PM   #1
lilDevilMS3's Avatar
Posts: 1   (View Stats)
lilDevilMS3 is an unknown quantity at this point
Default Timing Chain Guide rail/arm bolt size! Please help!
Hi guys, I am replacing my timing chain along with guide arms and VVT.
Unfortunately one of the guide rail bolts broke leaving behind a piece inside the
hole. I need to replace the bolt but dont know the correct spec/size.
Anyone know?
Thanks!
lilDevilMS3 is offline   Reply With Quote
 Old 03-12-2018, 06:55 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Mazda knows.
Jimellismazdaparts.com
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 03-13-2018, 05:52 AM   #3
GroceryGtr's Avatar
Posts: 472   (View Stats)
could always use the other one for reference. Both sides are the same.
 Old 03-13-2018, 07:29 AM   #4
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
I don't have the answer but I hope you read the How to VVT thread carefully and will correctly torque your new bolts and friction washers. (Not re-use the old one)
I don't know but i feel the need to mention it because doing the timing on a Mazda L engine isn't the easiest thing to do compared to measure a bolt. I want to prevent a ZZB in progress...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Timing chain tensioner and guide cbspeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 12-06-2010 05:27 AM
Page generated in 0.24068 seconds with 23 queries
